[GRASS-SVN] r73028 - grass/trunk/scripts/r.grow
Thu Aug 2 22:50:14 PDT 2018
Author: zarch
Date: 2018-08-02 22:50:14 -0700 (Thu, 02 Aug 2018)
New Revision: 73028
   grass/trunk/scripts/r.grow/r.grow.py
r.grow: Remove the use of split function in the string module (not supported in python3) and remove unused import
Modified: grass/trunk/scripts/r.grow/r.grow.py
--- grass/trunk/scripts/r.grow/r.grow.py	2018-08-02 19:54:23 UTC (rev 73027)
+++ grass/trunk/scripts/r.grow/r.grow.py	2018-08-03 05:50:14 UTC (rev 73028)
@@ -60,11 +60,10 @@
 #% description: Value to write for "grown" cells
 #%end
-import sys
 import os
 import atexit
 import math
-from string import split
 import grass.script as grass
 from grass.exceptions import CalledModuleError
@@ -94,7 +93,7 @@
     tmp = str(os.getpid())
     temp_dist = "r.grow.tmp.%s.dist" % tmp
     shrink = False
     if radius < 0.0:
         shrink = True
@@ -124,7 +123,7 @@
     # Workaround for r.mapcalc bug #3475
     # Mapcalc will fail if output is a fully qualified map name
-    out_name = split(options['output'], '@')
+    out_name = options['output'].split('@')
     if len(out_name) == 2:
         if out_name[1] != grass.gisenv()['MAPSET']:
             grass.fatal(_("Output can be written only to the current mapset"))
@@ -131,8 +130,8 @@
         output = out_name[0]
     else:
-    if shrink == False:
+    if shrink is False:
         try:
             grass.run_command('r.grow.distance', input=input, metric=metric,
                               distance=temp_dist, value=temp_val)
@@ -160,6 +159,7 @@
     # write cmd history:
     grass.raster_history(output)
 if __name__ == "__main__":
     options, flags = grass.parser()
     atexit.register(cleanup)
