[GRASS-SVN] r73039 - grass/branches/releasebranch_7_4/db/db.connect
Fri Aug 3 14:18:25 PDT 2018
Author: mmetz
Date: 2018-08-03 14:18:24 -0700 (Fri, 03 Aug 2018)
New Revision: 73039
   grass/branches/releasebranch_7_4/db/db.connect/main.c
db.connect: use GRASS default, not current parameters as default answer, fix setting from default and from user options (see #3601; backport trunk r72942)
Modified: grass/branches/releasebranch_7_4/db/db.connect/main.c
--- grass/branches/releasebranch_7_4/db/db.connect/main.c	2018-08-03 21:15:04 UTC (rev 73038)
+++ grass/branches/releasebranch_7_4/db/db.connect/main.c	2018-08-03 21:18:24 UTC (rev 73039)
@@ -69,17 +69,28 @@
     def->description = _("Overwrite current settings if already initialized");
     def->guisection = _("Set");
+    /* the default answers below are GRASS default settings,
+     * not current settings */
     driver = G_define_standard_option(G_OPT_DB_DRIVER);
     driver->options = db_list_drivers();
-    driver->answer = (char *) db_get_default_driver_name();
+    if (strcmp(DB_DEFAULT_DRIVER, "sqlite") == 0) {
+	driver->answer = "sqlite";
+    else {
+	driver->answer = "dbf";
     driver->guisection = _("Set");
     database = G_define_standard_option(G_OPT_DB_DATABASE);
-    database->answer = (char *) db_get_default_database_name();
+	database->answer = "$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db";
+    else {
+	database->answer = "$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/";
     database->guisection = _("Set");
     schema = G_define_standard_option(G_OPT_DB_SCHEMA);
-    schema->answer = (char *) db_get_default_schema_name();
     schema->guisection = _("Set");
     group = G_define_option();
@@ -87,7 +98,6 @@
     group->type = TYPE_STRING;
     group->required = NO;
     group->multiple = NO;
-    group->answer = (char*) db_get_default_group_name();
     group->description = _("Default group of database users to which "
 			   "select privilege is granted");
     group->guisection = _("Set");
@@ -179,7 +189,6 @@
 	exit(EXIT_SUCCESS);
     if (def->answer) {
 	db_set_default_connection();
 	db_get_connection(&conn);
@@ -191,8 +200,8 @@
 	exit(EXIT_SUCCESS);
-    /* set connection */
-    db_get_connection(&conn);	/* read current */
+    /* do not read current, set new connection from options */
+    G_zero(&conn, sizeof(dbConnection));
     if (driver->answer)
 	conn.driverName = driver->answer;
@@ -207,7 +216,12 @@
 	conn.group = group->answer;
     db_set_connection(&conn);
+    /* check */
+    if (db_get_connection(&conn) != DB_OK) {
+	G_fatal_error(_("Unable to set default database connection"));
+	exit(EXIT_FAILURE);
     exit(EXIT_SUCCESS);
