[GRASS-SVN] r73045 - grass/branches/releasebranch_7_4/db/db.execute
svn_grass at osgeo.org
Fri Aug 3 14:50:23 PDT 2018
Author: mmetz
Date: 2018-08-03 14:50:23 -0700 (Fri, 03 Aug 2018)
New Revision: 73045
grass/branches/releasebranch_7_4/db/db.execute/main.c
db.execute: check return code of db_execute_immediate() also for sql option (backport trunk r72993)
Modified: grass/branches/releasebranch_7_4/db/db.execute/main.c
--- grass/branches/releasebranch_7_4/db/db.execute/main.c 2018-08-03 21:48:20 UTC (rev 73044)
+++ grass/branches/releasebranch_7_4/db/db.execute/main.c 2018-08-03 21:50:23 UTC (rev 73045)
@@ -80,6 +80,18 @@
/* parms.sql */
db_set_string(&stmt, parms.sql);
ret = db_execute_immediate(driver, &stmt);
+ if (ret != DB_OK) {
+ if (parms.i) { /* ignore SQL errors */
+ G_warning(_("Error while executing: '%s'"),
+ db_get_string(&stmt));
+ error++;
+ else {
+ G_fatal_error(_("Error while executing: '%s'"),
else { /* parms.input */
while (get_stmt(fd, &stmt)) {
