[GRASS-SVN] r73061 - in grass/trunk/raster/r.watershed: front ram seg
Tue Aug 7 14:29:35 PDT 2018
Author: mmetz
Date: 2018-08-07 14:29:35 -0700 (Tue, 07 Aug 2018)
New Revision: 73061
   grass/trunk/raster/r.watershed/front/main.c
   grass/trunk/raster/r.watershed/ram/close_maps.c
   grass/trunk/raster/r.watershed/ram/close_maps2.c
   grass/trunk/raster/r.watershed/ram/def_basin.c
   grass/trunk/raster/r.watershed/ram/do_astar.c
   grass/trunk/raster/r.watershed/ram/do_cum.c
   grass/trunk/raster/r.watershed/ram/do_flatarea.c
   grass/trunk/raster/r.watershed/ram/find_pour.c
   grass/trunk/raster/r.watershed/ram/init_vars.c
   grass/trunk/raster/r.watershed/ram/main.c
   grass/trunk/raster/r.watershed/ram/no_stream.c
   grass/trunk/raster/r.watershed/ram/over_cells.c
   grass/trunk/raster/r.watershed/ram/split_str.c
   grass/trunk/raster/r.watershed/seg/bseg_get.c
   grass/trunk/raster/r.watershed/seg/bseg_read.c
   grass/trunk/raster/r.watershed/seg/bseg_write.c
   grass/trunk/raster/r.watershed/seg/close_maps.c
   grass/trunk/raster/r.watershed/seg/close_maps2.c
   grass/trunk/raster/r.watershed/seg/cseg_open.c
   grass/trunk/raster/r.watershed/seg/cseg_read.c
   grass/trunk/raster/r.watershed/seg/cseg_write.c
   grass/trunk/raster/r.watershed/seg/def_basin.c
   grass/trunk/raster/r.watershed/seg/do_astar.c
   grass/trunk/raster/r.watershed/seg/do_cum.c
   grass/trunk/raster/r.watershed/seg/dseg_open.c
   grass/trunk/raster/r.watershed/seg/dseg_read.c
   grass/trunk/raster/r.watershed/seg/dseg_write.c
   grass/trunk/raster/r.watershed/seg/find_pour.c
   grass/trunk/raster/r.watershed/seg/init_vars.c
   grass/trunk/raster/r.watershed/seg/main.c
   grass/trunk/raster/r.watershed/seg/no_stream.c
   grass/trunk/raster/r.watershed/seg/over_cells.c
   grass/trunk/raster/r.watershed/seg/sg_factor.c
   grass/trunk/raster/r.watershed/seg/slope_len.c
   grass/trunk/raster/r.watershed/seg/split_str.c
   grass/trunk/raster/r.watershed/seg/sseg_open.c
r.watershed: indent again
Modified: grass/trunk/raster/r.watershed/front/main.c
--- grass/trunk/raster/r.watershed/front/main.c	2018-08-07 21:10:33 UTC (rev 73060)
+++ grass/trunk/raster/r.watershed/front/main.c	2018-08-07 21:29:35 UTC (rev 73061)
@@ -30,6 +30,7 @@
 static void do_opt(const struct Option *opt)
     char *buf;
     if (!opt->answer)
 	return;
     buf = G_malloc(strlen(opt->key) + 1 + strlen(opt->answer) + 1);
@@ -78,7 +79,8 @@
     G_add_keyword(_("stream network"));
     G_add_keyword(_("stream power index"));
     G_add_keyword(_("topographic index"));
-    module->description = _("Calculates hydrological parameters and RUSLE factors.");
+    module->description =
+	_("Calculates hydrological parameters and RUSLE factors.");
     opt1 = G_define_standard_option(G_OPT_R_ELEV);
     opt1->guisection = _("Inputs");
@@ -86,13 +88,15 @@
     opt2 = G_define_standard_option(G_OPT_R_INPUT);
     opt2->key = "depression";
     opt2->label = _("Name of input depressions raster map");
-    opt2->description = _("All non-NULL and non-zero cells are considered as real depressions");
+    opt2->description =
+	_("All non-NULL and non-zero cells are considered as real depressions");
     opt2->required = NO;
     opt2->guisection = _("Inputs");
     opt3 = G_define_standard_option(G_OPT_R_INPUT);
     opt3->key = "flow";
-    opt3->description = _("Name of input raster representing amount of overland flow per cell");
+    opt3->description =
+	_("Name of input raster representing amount of overland flow per cell");
     opt3->required = NO;
     opt3->guisection = _("Inputs");
@@ -114,8 +118,7 @@
     opt6 = G_define_option();
     opt6->key = "threshold";
-    opt6->description =
-	_("Minimum size of exterior watershed basin");
+    opt6->description = _("Minimum size of exterior watershed basin");
     opt6->required = NO;
     opt6->type = TYPE_INTEGER;
     opt6->guisection = _("Inputs");
@@ -122,8 +125,7 @@
     opt7 = G_define_option();
     opt7->key = "max_slope_length";
-    opt7->label =
-	_("Maximum length of surface flow in map units");
+    opt7->label = _("Maximum length of surface flow in map units");
     opt7->description = _("For USLE");
     opt7->required = NO;
     opt7->type = TYPE_DOUBLE;
@@ -131,10 +133,8 @@
     opt8 = G_define_standard_option(G_OPT_R_OUTPUT);
     opt8->key = "accumulation";
-    opt8->label =
-	_("Name for output accumulation raster map");
-    opt8->description =
-    _("Number of cells that drain through each cell");
+    opt8->label = _("Name for output accumulation raster map");
+    opt8->description = _("Number of cells that drain through each cell");
     opt8->required = NO;
     opt8->guisection = _("Outputs");
@@ -147,8 +147,7 @@
     opt18 = G_define_standard_option(G_OPT_R_OUTPUT);
     opt18->key = "spi";
-    opt18->label =
-	_("Stream power index a * tan(b)");
+    opt18->label = _("Stream power index a * tan(b)");
     opt18->required = NO;
     opt18->guisection = _("Outputs");
@@ -174,8 +173,7 @@
     opt12 = G_define_standard_option(G_OPT_R_OUTPUT);
     opt12->key = "half_basin";
     opt12->label = _("Name for output half basins raster map");
-    opt12->description =
-	_("Each half-basin is given a unique value");
+    opt12->description = _("Each half-basin is given a unique value");
     opt12->required = NO;
     opt12->guisection = _("Outputs");
@@ -182,8 +180,7 @@
     opt13 = G_define_standard_option(G_OPT_R_OUTPUT);
     opt13->key = "length_slope";
     opt13->label = _("Name for output slope length raster map");
-    opt13->description =
-	_("Slope length and steepness (LS) factor for USLE");
+    opt13->description = _("Slope length and steepness (LS) factor for USLE");
     opt13->required = NO;
     opt13->guisection = _("Outputs");
@@ -223,8 +220,7 @@
     flag_seg = G_define_flag();
     flag_seg->key = 'm';
-    flag_seg->label =
-	_("Enable disk swap memory option: Operation is slow");
+    flag_seg->label = _("Enable disk swap memory option: Operation is slow");
     flag_seg->description =
 	_("Only needed if memory requirements exceed available RAM; see manual on how to calculate memory requirements");
@@ -237,8 +233,7 @@
     flag_flat = G_define_flag();
     flag_flat->key = 'b';
-    flag_flat->label =
-	_("Beautify flat areas");
+    flag_flat->label = _("Beautify flat areas");
     flag_flat->description =
 	_("Flow direction in flat areas is modified to look prettier");
@@ -288,8 +283,7 @@
     /* Build command line */
     sprintf(command, "%s/etc/r.watershed/%s",
-	    G_gisbase(),
-	    flag_seg->answer ? "seg" : "ram");
+	    G_gisbase(), flag_seg->answer ? "seg" : "ram");
     new_argv[new_argc++] = command;
     if (flag_sfd->answer)
@@ -329,9 +323,10 @@
     new_argv[new_argc++] = NULL;
     G_debug(1, "Mode: %s", flag_seg->answer ? "Segmented" : "All in RAM");
-/*    if (flag_seg->answer)
-       G_message(_("Using memory cache size: %.1f MB"), atof(opt16->answer));
+    if (flag_seg->answer)
+        G_message(_("Using memory cache size: %.1f MB"), atof(opt16->answer));
     ret = G_vspawn_ex(new_argv[0], new_argv);
     if (ret != EXIT_SUCCESS)
@@ -356,7 +351,7 @@
 		   opt1->answer, flag_seg->answer, flag_sfd->answer);
     if (opt10->answer)
 	write_hist(opt10->answer,
-		   "Watershed basins", opt1->answer, flag_seg->answer,
+		   "Watershed basins", opt1->answer, flag_seg->answer,
 		   flag_sfd->answer);
     if (opt11->answer)
 	write_hist(opt11->answer,
@@ -364,7 +359,7 @@
     if (opt12->answer)
 	write_hist(opt12->answer,
-		   "Watershed half-basins", opt1->answer, flag_seg->answer,
+		   "Watershed half-basins", opt1->answer, flag_seg->answer,
 		   flag_sfd->answer);
     if (opt13->answer)
 	write_hist(opt13->answer,
@@ -379,7 +374,8 @@
 /* record map history info */
-static void write_hist(char *map_name, char *title, char *source_name, int mode, int sfd)
+static void write_hist(char *map_name, char *title, char *source_name,
+		       int mode, int sfd)
     struct History history;
@@ -387,10 +383,10 @@
     Rast_short_history(map_name, "raster", &history);
     Rast_set_history(&history, HIST_DATSRC_1, source_name);
-    Rast_append_format_history(
-	&history, "Processing mode: %s", sfd ? "SFD (D8)" : "MFD");
-	&history, "Memory mode: %s", mode ? "Segmented" : "All in RAM");
+    Rast_append_format_history(&history, "Processing mode: %s",
+			       sfd ? "SFD (D8)" : "MFD");
+    Rast_append_format_history(&history, "Memory mode: %s",
+			       mode ? "Segmented" : "All in RAM");
     Rast_command_history(&history);
     Rast_write_history(map_name, &history);
Modified: grass/trunk/raster/r.watershed/ram/close_maps.c
--- grass/trunk/raster/r.watershed/ram/close_maps.c	2018-08-07 21:10:33 UTC (rev 73060)
+++ grass/trunk/raster/r.watershed/ram/close_maps.c	2018-08-07 21:29:35 UTC (rev 73061)
@@ -29,7 +29,8 @@
 	fd = Rast_open_new(wat_name, DCELL_TYPE);
 	if (abs_acc) {
 	    G_message("Writing out only positive flow accumulation values.");
-	    G_message("Cells with a likely underestimate for flow accumulation can no longer be identified.");
+	    G_message
+		("Cells with a likely underestimate for flow accumulation can no longer be identified.");
 	    for (r = 0; r < nrows; r++) {
 		Rast_set_d_null_value(dbuf, ncols);	/* reset row to all NULL */
 		for (c = 0; c < ncols; c++) {
@@ -61,8 +62,7 @@
 	Rast_close(fd);
-	stddev =
-	    sqrt((sum_sqr - (sum + sum / do_points)) / (do_points - 1));
+	stddev = sqrt((sum_sqr - (sum + sum / do_points)) / (do_points - 1));
 	G_debug(1, "stddev: %f", stddev);
 	/* set nice color rules: yellow, green, cyan, blue, black */
@@ -80,51 +80,51 @@
 		clr_min = min - 1;
 		clr_max = -stddev - 1;
 		Rast_add_d_color_rule(&clr_min, 0, 0, 0, &clr_max, 0,
-					  0, 0, &colors);
+				      0, 0, &colors);
 	    clr_min = -stddev - 1.;
 	    clr_max = -1. * exp(lstddev * 0.75);
-				      0, 255, &colors);
+				  0, 255, &colors);
 	    clr_min = clr_max;
 	    clr_max = -1. * exp(lstddev * 0.5);
 	    Rast_add_d_color_rule(&clr_min, 0, 0, 255, &clr_max, 0,
-				      255, 255, &colors);
+				  255, 255, &colors);
 	    clr_min = clr_max;
 	    clr_max = -1. * exp(lstddev * 0.35);
 	    Rast_add_d_color_rule(&clr_min, 0, 255, 255, &clr_max, 0,
-				      255, 0, &colors);
+				  255, 0, &colors);
 	    clr_min = clr_max;
 	    clr_max = -1.;
 	    Rast_add_d_color_rule(&clr_min, 0, 255, 0, &clr_max, 255,
-				      255, 0, &colors);
+				  255, 0, &colors);
 	clr_min = -1.;
 	clr_max = 1.;
 	Rast_add_d_color_rule(&clr_min, 255, 255, 0, &clr_max, 255,
-				  255, 0, &colors);
+			      255, 0, &colors);
 	clr_min = 1;
 	clr_max = exp(lstddev * 0.35);
 	Rast_add_d_color_rule(&clr_min, 255, 255, 0, &clr_max, 0,
-				  255, 0, &colors);
+			      255, 0, &colors);
 	clr_min = clr_max;
 	clr_max = exp(lstddev * 0.5);
 	Rast_add_d_color_rule(&clr_min, 0, 255, 0, &clr_max, 0,
 	clr_min = clr_max;
 	clr_max = exp(lstddev * 0.75);
-				  0, 255, &colors);
+			      0, 255, &colors);
 	clr_min = clr_max;
 	clr_max = stddev + 1.;
 	Rast_add_d_color_rule(&clr_min, 0, 0, 255, &clr_max, 0, 0,
-				  0, &colors);
+			      0, &colors);
 	if (max > 0 && max > stddev + 1) {
 	    clr_min = stddev + 1;
 	    clr_max = max + 1;
 	    Rast_add_d_color_rule(&clr_min, 0, 0, 0, &clr_max, 0, 0,
-				      0, &colors);
+				  0, &colors);
 	Rast_write_colors(wat_name, this_mapset, &colors);
@@ -139,8 +139,8 @@
 		if (!Rast_is_d_null_value(&tanb[SEG_INDEX(wat_seg, r, c)])) {
-		    dvalue = log(sca[SEG_INDEX(wat_seg, r, c)] /
-		                 tanb[SEG_INDEX(wat_seg, r, c)]);
+		    dvalue = log(sca[SEG_INDEX(wat_seg, r, c)] /
+				 tanb[SEG_INDEX(wat_seg, r, c)]);
 		    dbuf[c] = dvalue;
 		    sum += dvalue;
 		    sum_sqr += dvalue * dvalue;
@@ -151,8 +151,7 @@
 	Rast_close(fd);
 	mean = sum / do_points;
-	stddev =
@@ -169,31 +168,31 @@
 	    clr_min = min - 1;
 	    clr_max = mean - 0.5 * stddev;
-					  255, 0, &colors);
+				  255, 0, &colors);
 	clr_min = mean - 0.5 * stddev;
 	clr_max = mean - 0.2 * stddev;
-				  255, 0, &colors);
+			      255, 0, &colors);
 	clr_min = clr_max;
 	clr_max = mean + 0.2 * stddev;
 	clr_min = clr_max;
 	clr_max = mean + 0.6 * stddev;
-				  0, 255, &colors);
+			      0, 255, &colors);
 	clr_min = clr_max;
 	clr_max = mean + 1. * stddev;
-				  0, &colors);
+			      0, &colors);
 	if (max > 0 && max > clr_max) {
 	    clr_min = clr_max;
 	    clr_max = max + 1;
-				      0, &colors);
+				  0, &colors);
 	Rast_write_colors(tci_name, this_mapset, &colors);
@@ -208,7 +207,9 @@
-		    dvalue = sca[SEG_INDEX(wat_seg, r, c)] * tanb[SEG_INDEX(wat_seg, r, c)];
+		    dvalue =
+			sca[SEG_INDEX(wat_seg, r, c)] *
+			tanb[SEG_INDEX(wat_seg, r, c)];
 		    dbuf[c] = dvalue;
 		    sum += dvalue;
@@ -219,8 +220,7 @@
 	Rast_close(fd);
-	stddev =
@@ -237,31 +237,31 @@
 	    clr_min = min - 1;
-					  255, 0, &colors);
+				  255, 0, &colors);
-				  255, 0, &colors);
+			      255, 0, &colors);
 	clr_min = clr_max;
 	clr_min = clr_max;
-				  0, 255, &colors);
+			      0, 255, &colors);
 	clr_min = clr_max;
-				  0, &colors);
+			      0, &colors);
 	    clr_min = clr_max;
 	    clr_max = max + 1;
-				      0, &colors);
+				  0, &colors);
 	Rast_write_colors(spi_name, this_mapset, &colors);
Modified: grass/trunk/raster/r.watershed/ram/close_maps2.c
--- grass/trunk/raster/r.watershed/ram/close_maps2.c	2018-08-07 21:10:33 UTC (rev 73060)
+++ grass/trunk/raster/r.watershed/ram/close_maps2.c	2018-08-07 21:29:35 UTC (rev 73061)
@@ -46,7 +46,8 @@
 			for (bl = 90 + incr; bl <= 255; bl += 40) {
 			    flag = 1;
 			    while (flag) {
-				Rast_get_c_color(&r, &red, &green, &blue, &colors);
+				Rast_get_c_color(&r, &red, &green, &blue,
+						 &colors);
 				/* if existing rule is too dark then append a new
 				   rule to override it */
 				if ((blue * .11 + red * .30 + green * .59) <
Modified: grass/trunk/raster/r.watershed/ram/def_basin.c
--- grass/trunk/raster/r.watershed/ram/def_basin.c	2018-08-07 21:10:33 UTC (rev 73060)
+++ grass/trunk/raster/r.watershed/ram/def_basin.c	2018-08-07 21:29:35 UTC (rev 73061)
@@ -51,8 +51,7 @@
 		    direction = asp[SEG_INDEX(asp_seg, r, c)];
 		    if (direction == drain[rr][cc]) {
 			thisdir = updrain[rr][cc];
-			switch (haf_basin_side
-				(oldupdir, downdir, thisdir)) {
+			switch (haf_basin_side(oldupdir, downdir, thisdir)) {
 			case LEFT:
 			    overland_cells(r, c, basin_num, basin_num - 1,
 					   &new_elev);
Modified: grass/trunk/raster/r.watershed/ram/do_astar.c
--- grass/trunk/raster/r.watershed/ram/do_astar.c	2018-08-07 21:10:33 UTC (rev 73060)
+++ grass/trunk/raster/r.watershed/ram/do_astar.c	2018-08-07 21:29:35 UTC (rev 73061)
@@ -12,6 +12,7 @@
     CELL alt_val, alt_nbr[8];
     CELL is_in_list, is_worked, flat_is_done, nbr_flat_is_done;
     int index_doer, index_up;
     /* sides
      * |7|1|4|
      * |2| |3|
@@ -47,7 +48,8 @@
     if (flat_flag) {
 	alt_bak =
-	    (CELL *) G_malloc(sizeof(CELL) * size_array(&alt_seg, nrows, ncols));
+	    (CELL *) G_malloc(sizeof(CELL) *
+			      size_array(&alt_seg, nrows, ncols));
 	flat_done = flag_create(nrows, ncols);
 	flat_is_done = 0;
@@ -103,7 +105,7 @@
 		is_in_list = FLAG_GET(in_list, upr, upc);
 		is_worked = FLAG_GET(worked, upr, upc);
 		skip_diag = 0;
 		alt_nbr[ct_dir] = alt[index_up];
 		if (flat_flag && !is_in_list && !is_worked) {
 		    alt_val = alt_bak[index_doer];
@@ -126,7 +128,7 @@
 		/* avoid diagonal flow direction bias */
 		if (!is_worked) {
 		    slope[ct_dir] =
@@ -174,8 +176,8 @@
-	    }    /* end if in region */
-	}    /* end sides */
+	    }			/* end if in region */
+	}			/* end sides */
 	FLAG_SET(worked, r, c);
     G_percent(count, do_points, 1);	/* finish it */
@@ -317,8 +319,7 @@
     return 0;
-double
-get_slope(int r, int c, int downr, int downc, CELL ele, CELL downe)
+double get_slope(int r, int c, int downr, int downc, CELL ele, CELL downe)
     double slope;
Modified: grass/trunk/raster/r.watershed/ram/do_cum.c
--- grass/trunk/raster/r.watershed/ram/do_cum.c	2018-08-07 21:10:33 UTC (rev 73060)
+++ grass/trunk/raster/r.watershed/ram/do_cum.c	2018-08-07 21:29:35 UTC (rev 73061)
@@ -16,22 +16,23 @@
 	/* EW Dist at North edge */
 	ew_dist1 = G_distance(window.east, window.north,
-	                      window.west, window.north);
+			      window.west, window.north);
 	/* EW Dist at Center */
 	ew_dist2 = G_distance(window.east, (window.north + window.south) / 2.,
-	                      window.west, (window.north + window.south) / 2.);
+			      window.west,
+			      (window.north + window.south) / 2.);
 	/* EW Dist at South Edge */
 	ew_dist3 = G_distance(window.east, window.south,
-	                      window.west, window.south);
+			      window.west, window.south);
 	/* NS Dist at East edge */
 	ns_dist1 = G_distance(window.east, window.north,
-	                      window.east, window.south);
+			      window.east, window.south);
 	/* NS Dist at Center */
 	ns_dist2 = G_distance((window.west + window.east) / 2., window.north,
-	                      (window.west + window.east) / 2., window.south);
+			      (window.west + window.east) / 2., window.south);
 	/* NS Dist at West edge */
 	ns_dist3 = G_distance(window.west, window.north,
 	ew_res = (ew_dist1 + ew_dist2 + ew_dist3) / (3 * window.cols);
 	ns_res = (ns_dist1 + ns_dist2 + ns_dist3) / (3 * window.rows);
@@ -40,7 +41,7 @@
 	ns_res = window.ns_res;
 	ew_res = window.ew_res;
     for (ct_dir = 0; ct_dir < sides; ct_dir++) {
 	/* get r, c (r_nbr, c_nbr) for neighbours */
 	r_nbr = nextdr[ct_dir];
@@ -78,7 +79,8 @@
 	G_debug(1, "ew contour: %.4f", contour[2]);
 	contour[4] = (ew_res - contour[0]);
 	contour[5] = (ns_res - contour[2]);
-	contour[7] = sqrt(contour[4] * contour[4] + contour[5] * contour[5]) / 2.;
+	contour[7] =
+	    sqrt(contour[4] * contour[4] + contour[5] * contour[5]) / 2.;
 	G_debug(1, "diag contour: %.4f", contour[7]);
 	contour[4] = contour[5] = contour[6] = contour[7];
@@ -135,7 +137,7 @@
 	/* skip user-defined depressions */
 	else
 	    dr = dc = -1;
-	if (dr >= 0 && dr < nrows && dc >= 0 && dc < ncols) { /* if ((dr = astar_pts[killer].downr) > -1) { */
+	if (dr >= 0 && dr < nrows && dc >= 0 && dc < ncols) {	/* if ((dr = astar_pts[killer].downr) > -1) { */
 	    down_index = SEG_INDEX(wat_seg, dr, dc);
 	    value = wat[this_index];
 	    if (fabs(value) >= threshold)
@@ -196,9 +198,9 @@
 	     * stream power index a * tan(beta) */
 	    if (atanb_flag) {
 		sca[this_index] = fabs(wat[this_index]) *
-		                  (cell_size / contour[np_side]);
+		    (cell_size / contour[np_side]);
 		tanb[this_index] = get_slope_tci(alt[this_index],
-		                                 alt[down_index],
+						 alt[down_index],
 						 dist_to_nbr[np_side]);
@@ -286,7 +288,7 @@
     int nextmfd[8] = { 3, 7, 5, 1, 0, 4, 2, 6 };
     int mfdir;
     G_message(_("SECTION 3a: Accumulating Surface Flow with MFD."));
     G_debug(1, "MFD convergence factor set to %d.", c_fac);
@@ -294,7 +296,7 @@
     dist_to_nbr = (double *)G_malloc(sides * sizeof(double));
     weight = (double *)G_malloc(sides * sizeof(double));
     contour = (double *)G_malloc(sides * sizeof(double));
     cell_size = get_dist(dist_to_nbr, contour);
     flag_clear_all(worked);
@@ -317,7 +319,7 @@
 	else
 	    dr = dc = -1;
@@ -431,8 +433,8 @@
 			    if (atanb_flag) {
 				sum_contour += contour[ct_dir];
 				tci_div += get_slope_tci(ele, alt[nbr_index],
-				                         dist_to_nbr[ct_dir]) *
-					   weight[ct_dir];
+							 dist_to_nbr[ct_dir])
+				    * weight[ct_dir];
 			    valued = wat[nbr_index];
@@ -481,7 +483,7 @@
 		if (atanb_flag) {
 		    sum_contour = contour[np_side];
 		    tci_div = get_slope_tci(ele, alt[down_index],
-				            dist_to_nbr[np_side]);
+					    dist_to_nbr[np_side]);
 	    /* topographic wetness index ln(a / tan(beta)) and
@@ -488,16 +490,16 @@
 	    if (atanb_flag) {
-		                  (cell_size / sum_contour);
+		    (cell_size / sum_contour);
 		tanb[this_index] = tci_div;
     if (workedon)
-	G_warning(n_("MFD: A * path already processed when distributing flow: %d of %d cell",
-        "MFD: A * path already processed when distributing flow: %d of %d cells",
-        do_points),
-		  workedon, do_points);
+	G_warning(n_
+		  ("MFD: A * path already processed when distributing flow: %d of %d cell",
+		   "MFD: A * path already processed when distributing flow: %d of %d cells",
+		   do_points), workedon, do_points);
     G_message(_("SECTION 3b: Adjusting drainage directions."));
@@ -514,7 +516,7 @@
 	else
 	    dr = dc = -1;
@@ -548,8 +550,7 @@
 		    ele_nbr = alt[nbr_index];
 		    edge = Rast_is_c_null_value(&ele_nbr);
-		    if ((ABS(valued) + 0.5) >= threshold  &&
-		        ele_nbr > ele)
+		    if ((ABS(valued) + 0.5) >= threshold && ele_nbr > ele)
 			stream_cells++;
 		    is_worked = !(FLAG_GET(worked, r_nbr, c_nbr));
@@ -579,7 +580,7 @@
 		continue;
 	    /* update asp */
 	    if (dr != r_max || dc != c_max) {
 		aspect = drain[r - r_max + 1][c - c_max + 1];
Modified: grass/trunk/raster/r.watershed/ram/do_flatarea.c
--- grass/trunk/raster/r.watershed/ram/do_flatarea.c	2018-08-07 21:10:33 UTC (rev 73060)
+++ grass/trunk/raster/r.watershed/ram/do_flatarea.c	2018-08-07 21:29:35 UTC (rev 73061)
@@ -1,3 +1,4 @@
  * flat area beautification after Garbrecht and Martz (1997)
@@ -56,7 +57,8 @@
 	G_fatal_error(_("Beautify flat areas: priority queue error"));
-    struct pq_node *n = (struct pq_node *) G_malloc(sizeof(struct pq_node));
+    struct pq_node *n = (struct pq_node *)G_malloc(sizeof(struct pq_node));
     n->next = NULL;
     n->idx = -1;
     q->last->next = n;
@@ -100,7 +102,8 @@
     return 0;
-struct orders {
+struct orders
     int index, uphill, downhill;
     char flag;
@@ -109,14 +112,15 @@
     struct orders *oa = (struct orders *)a;
     struct orders *ob = (struct orders *)b;
     return (oa->index < ob->index ? -1 : (oa->index > ob->index));
  * return 0 if nothing was modidied
  * return 1 if elevation was modified
-int do_flatarea(int index, CELL ele, CELL *alt_org, CELL *alt_new)
+int do_flatarea(int index, CELL ele, CELL * alt_org, CELL * alt_new)
     int upr, upc, r, c, ct_dir;
     CELL is_in_list, is_worked, this_in_list;
@@ -130,7 +134,8 @@
     struct pq *down_pq = pq_create();
     struct orders inc_order, *order_found, *nbr_order_found;
-    struct RB_TREE *order_tree = rbtree_create(cmp_orders, sizeof(struct orders));
+    struct RB_TREE *order_tree =
+	rbtree_create(cmp_orders, sizeof(struct orders));
     pq_add(index, down_pq);
     pq_add(index, up_pq);
@@ -175,7 +180,8 @@
 		    inc_order.index = index_up;
 		    inc_order.flag = 0;
 		    /* not yet added to queue */
-		    if ((order_found = rbtree_find(order_tree, &inc_order)) == NULL) {
+		    if ((order_found =
+			 rbtree_find(order_tree, &inc_order)) == NULL) {
 			n_flat_cells++;
 			/* add to down queue if not yet in there */
@@ -203,9 +209,9 @@
 	return 0;
     G_debug(2, "%d flat cells, %d cells in tree, %d start cells",
-               n_flat_cells, (int)order_tree->count, counter);
+	    n_flat_cells, (int)order_tree->count, counter);
     pq_destroy(down_pq);
@@ -233,7 +239,7 @@
 	if (last_order > uphill_order)
 	    G_warning(_("queue error: last uphill order %d > current uphill order %d"),
-	              last_order, uphill_order);
+		      last_order, uphill_order);
 	/* debug */
 	if (uphill_order == -1)
@@ -262,7 +268,8 @@
 		if (ele_nbr == ele && !is_worked) {
-		    if ((nbr_order_found = rbtree_find(order_tree, &inc_order)) == NULL) {
+		    if ((nbr_order_found =
 			G_fatal_error(_("flat cell escaped in uphill correction"));
@@ -314,7 +321,7 @@
 	if (last_order > downhill_order)
 	    G_warning(_("queue error: last downhill order %d > current downhill order %d"),
-	              last_order, downhill_order);
+		      last_order, downhill_order);
 	/* debug */
 	if (downhill_order == -1)
@@ -340,12 +347,13 @@
 			G_fatal_error(_("flat cell escaped in downhill correction"));
 		    if (nbr_order_found->downhill == -1) {
 			/* add to down queue */
 			pq_add(index_up, down_pq);
 			/* set nbr downhill order = current downhill order + 1 */
@@ -396,7 +404,9 @@
 	    uphill_order = 0;
 	alt_new[index_doer] +=
-	    (uphill_order + (double)(max_downhill_order - downhill_order) / 2.0 + 0.5) / 2.0 + 0.5;
+	    (uphill_order +
+	     0.5) / 2.0 + 0.5;
 	/* check all neighbours, breadth first search */
@@ -413,13 +423,15 @@
 			G_fatal_error(_("flat cell escaped in adjustment"));
 		    if (nbr_order_found->flag == 0) {
 			if (is_in_list)
-			    G_warning("adjustment: in_list cell should be in queue");
+			    G_warning
+				("adjustment: in_list cell should be in queue");
 			/* add to up queue */
 			pq_add(index_up, up_pq);
 			nbr_order_found->flag = 1;
@@ -433,6 +445,6 @@
     pq_destroy(up_pq);
     rbtree_destroy(order_tree);
     return 1;
Modified: grass/trunk/raster/r.watershed/ram/find_pour.c
--- grass/trunk/raster/r.watershed/ram/find_pour.c	2018-08-07 21:10:33 UTC (rev 73060)
+++ grass/trunk/raster/r.watershed/ram/find_pour.c	2018-08-07 21:29:35 UTC (rev 73061)
@@ -7,7 +7,7 @@
     CELL old_elev, basin_num;
     ocs_alloced = 2 * bas_thres;
-    ocs = (OC_STACK *)G_malloc(ocs_alloced * sizeof(OC_STACK));
+    ocs = (OC_STACK *) G_malloc(ocs_alloced * sizeof(OC_STACK));
     basin_num = 0;
     stream_length = old_elev = 0;
Modified: grass/trunk/raster/r.watershed/ram/init_vars.c
--- grass/trunk/raster/r.watershed/ram/init_vars.c	2018-08-07 21:10:33 UTC (rev 73060)
+++ grass/trunk/raster/r.watershed/ram/init_vars.c	2018-08-07 21:29:35 UTC (rev 73061)
@@ -70,8 +70,8 @@
 	else if (sscanf(argv[r], "ar=%s", arm_name) == 1)
 	    arm_flag++;
 	/* slope length
-	else if (sscanf(argv[r], "sl=%[^\n]", sl_name) == 1)
-	    sl_flag++; */
+	   else if (sscanf(argv[r], "sl=%[^\n]", sl_name) == 1)
+	   sl_flag++; */
 	else if (sscanf(argv[r], "length_slope=%s", ls_name) == 1)
 	    ls_flag++;
 	else if (sscanf(argv[r], "slope_steepness=%s", sg_name) == 1)
@@ -85,7 +85,7 @@
 	/* slope deposition
-	else if (sscanf (argv[r], "sd=%[^\n]", dep_name) == 1) dep_flag++; */
+	   else if (sscanf (argv[r], "sd=%[^\n]", dep_name) == 1) dep_flag++; */
 	else if (sscanf(argv[r], "-%d", &sides) == 1) {
 	    if (sides != 4)
 		usage(argv[0]);
@@ -150,14 +150,14 @@
     wat =
 	(DCELL *) G_malloc(sizeof(DCELL) *
 			   size_array(&wat_seg, nrows, ncols));
     sca = tanb = NULL;
     atanb_flag = 0;
     if (tci_flag || spi_flag) {
 	sca = (DCELL *) G_malloc(sizeof(DCELL) *
-			         size_array(&wat_seg, nrows, ncols));
+				 size_array(&wat_seg, nrows, ncols));
 	tanb = (DCELL *) G_malloc(sizeof(DCELL) *
 	atanb_flag = 1;
@@ -166,7 +166,8 @@
     if (er_flag) {
 	r_h =
-	    (CELL *) G_malloc(sizeof(CELL) * size_array(&r_h_seg, nrows, ncols));
+			      size_array(&r_h_seg, nrows, ncols));
     swale = flag_create(nrows, ncols);
@@ -181,7 +182,7 @@
     elebuf = Rast_allocate_buf(ele_map_type);
     if (ele_map_type == FCELL_TYPE || ele_map_type == DCELL_TYPE)
-	ele_scale = 1000; 	/* should be enough to do the trick */
+	ele_scale = 1000;	/* should be enough to do the trick */
     if (flat_flag)
 	ele_scale = 10000;
@@ -210,16 +211,16 @@
 	    else {
 		if (ele_map_type == CELL_TYPE) {
-		    alt_value = *((CELL *)ptr);
+		    alt_value = *((CELL *) ptr);
 		    alt_value *= ele_scale;
 		else if (ele_map_type == FCELL_TYPE) {
-		    dvalue = *((FCELL *)ptr);
+		    dvalue = *((FCELL *) ptr);
 		    dvalue *= ele_scale;
 		    alt_value = ele_round(dvalue);
 		else if (ele_map_type == DCELL_TYPE) {
-		    dvalue = *((DCELL *)ptr);
+		    dvalue = *((DCELL *) ptr);
@@ -302,7 +303,7 @@
 			       sizeof(double));
-    astar_pts = (int *) G_malloc((do_points + 1) * sizeof(int));
+    astar_pts = (int *)G_malloc((do_points + 1) * sizeof(int));
     /* heap_index will track astar_pts in ternary min-heap */
     /* heap_index is one-based */
@@ -330,8 +331,7 @@
 		asp_value = asp[seg_idx];
 		if (er_flag)
 		    s_l[seg_idx] = half_res;
-		if (r == 0 || c == 0 || r == nrows - 1 ||
-		    c == ncols - 1) {
+		if (r == 0 || c == 0 || r == nrows - 1 || c == ncols - 1) {
 		    wat_value = wat[seg_idx];
 		    if (wat_value > 0)
 			wat[seg_idx] = -wat_value;
Modified: grass/trunk/raster/r.watershed/ram/main.c
--- grass/trunk/raster/r.watershed/ram/main.c	2018-08-07 21:10:33 UTC (rev 73060)
+++ grass/trunk/raster/r.watershed/ram/main.c	2018-08-07 21:29:35 UTC (rev 73061)
@@ -49,6 +49,7 @@
 int updrain[3][3] = { {3, 2, 1}, {4, 0, 8}, {5, 6, 7} };
 int nextdr[8] = { 1, -1, 0, 0, -1, 1, 1, -1 };
 int nextdc[8] = { 0, 0, -1, 1, 1, -1, 1, -1 };
 char ele_name[GNAME_MAX], pit_name[GNAME_MAX];
 char run_name[GNAME_MAX], ob_name[GNAME_MAX];
 char ril_name[GNAME_MAX], dep_name[GNAME_MAX];
@@ -57,7 +58,8 @@
     thr_name[8];
 char ls_name[GNAME_MAX], st_name[GNAME_MAX], sl_name[GNAME_MAX],
     sg_name[GNAME_MAX];
-char wat_name[GNAME_MAX], asp_name[GNAME_MAX], tci_name[GNAME_MAX], spi_name[GNAME_MAX];
+char wat_name[GNAME_MAX], asp_name[GNAME_MAX], tci_name[GNAME_MAX],
+    spi_name[GNAME_MAX];
 char arm_name[GNAME_MAX], dis_name[GNAME_MAX];
 char ele_flag, pit_flag, run_flag, dis_flag, ob_flag, flat_flag;
 char wat_flag, asp_flag, arm_flag, ril_flag, dep_flag;
Modified: grass/trunk/raster/r.watershed/ram/no_stream.c
--- grass/trunk/raster/r.watershed/ram/no_stream.c	2018-08-07 21:10:33 UTC (rev 73060)
+++ grass/trunk/raster/r.watershed/ram/no_stream.c	2018-08-07 21:29:35 UTC (rev 73061)
@@ -53,7 +53,7 @@
 			else
 			    stream_length += diag;
-		    else {		/* downdir == 4,8 */
+		    else {	/* downdir == 4,8 */
 			if (asp_value == 4 || asp_value == 8)
 			    stream_length += window.ew_res;
 			else
@@ -69,7 +69,7 @@
 			if (aspect == drain[rr][cc]) {
-			            (updir, (int) downdir, thisdir)) {
+				    (updir, (int)downdir, thisdir)) {
 			    case LEFT:
 					       &new_ele);
Modified: grass/trunk/raster/r.watershed/ram/over_cells.c
--- grass/trunk/raster/r.watershed/ram/over_cells.c	2018-08-07 21:10:33 UTC (rev 73060)
+++ grass/trunk/raster/r.watershed/ram/over_cells.c	2018-08-07 21:29:35 UTC (rev 73061)
@@ -2,7 +2,8 @@
 #define BIGNEG	-9999999
 int
-overland_cells_recursive(int row, int col, CELL basin_num, CELL haf_num, CELL * hih_ele)
+overland_cells_recursive(int row, int col, CELL basin_num, CELL haf_num,
+			 CELL * hih_ele)
     int r, rr, c, cc;
     CELL new_ele, new_max_ele, value;
@@ -23,15 +24,15 @@
-    if (arm_flag) {
-	if (new_max_ele == BIGNEG) {
-	    *hih_ele = alt[SEG_INDEX(alt_seg, row, col)];
-	else {
-	    *hih_ele = new_max_ele;
+       if (arm_flag) {
+       if (new_max_ele == BIGNEG) {
+       *hih_ele = alt[SEG_INDEX(alt_seg, row, col)];
+       else {
+       *hih_ele = new_max_ele;
     return 0;
@@ -66,13 +67,16 @@
 		    if (asp[idx] == drain[rr][cc]) {
 			if (top >= ocs_alloced) {
 			    ocs_alloced += bas_thres;
-			    ocs = (OC_STACK *)G_realloc(ocs, ocs_alloced * sizeof(OC_STACK));
+			    ocs =
+				(OC_STACK *) G_realloc(ocs,
+						       ocs_alloced *
+						       sizeof(OC_STACK));
 			ocs[top].row = r;
 			ocs[top].col = c;
 			bas[idx] = basin_num;
 			haf[idx] = haf_num;
 			top++;
@@ -81,15 +85,15 @@
-    if (arm_flag) {
-	    cseg_get(&alt, hih_ele, row, col);
-	else {
+       if (arm_flag) {
+       cseg_get(&alt, hih_ele, row, col);
+       else {
     return 0;
Modified: grass/trunk/raster/r.watershed/ram/split_str.c
--- grass/trunk/raster/r.watershed/ram/split_str.c	2018-08-07 21:10:33 UTC (rev 73060)
+++ grass/trunk/raster/r.watershed/ram/split_str.c	2018-08-07 21:29:35 UTC (rev 73061)
@@ -36,8 +36,7 @@
 		    if (doit) {
+			switch (haf_basin_side(updir, (int)downdir, thisdir)) {
 			case LEFT:
 					   &new_elev);
Modified: grass/trunk/raster/r.watershed/seg/bseg_get.c
--- grass/trunk/raster/r.watershed/seg/bseg_get.c	2018-08-07 21:10:33 UTC (rev 73060)
+++ grass/trunk/raster/r.watershed/seg/bseg_get.c	2018-08-07 21:29:35 UTC (rev 73061)
@@ -11,7 +11,7 @@
     return 0;
-int bseg_get_old(BSEG * bseg, CELL *value, int row, int col)
+int bseg_get_old(BSEG * bseg, CELL * value, int row, int col)
     CELL x;
Modified: grass/trunk/raster/r.watershed/seg/bseg_read.c
--- grass/trunk/raster/r.watershed/seg/bseg_read.c	2018-08-07 21:10:33 UTC (rev 73060)
+++ grass/trunk/raster/r.watershed/seg/bseg_read.c	2018-08-07 21:29:35 UTC (rev 73061)
@@ -21,7 +21,7 @@
     for (row = 0; row < nrows; row++) {
 	Rast_get_c_row(map_fd, buffer, row);
 	for (col = ncols; col >= 0; col--) {
-	    cbuf = (char) buffer[col];
+	    cbuf = (char)buffer[col];
 	    bseg_put(bseg, &cbuf, row, col);
Modified: grass/trunk/raster/r.watershed/seg/bseg_write.c
--- grass/trunk/raster/r.watershed/seg/bseg_write.c	2018-08-07 21:10:33 UTC (rev 73060)
+++ grass/trunk/raster/r.watershed/seg/bseg_write.c	2018-08-07 21:29:35 UTC (rev 73061)
@@ -22,7 +22,7 @@
 	Rast_put_row(map_fd, buffer, CELL_TYPE);
-    G_percent(row, nrows, 1);    /* finish it */
+    G_percent(row, nrows, 1);	/* finish it */
     G_free(buffer);
     Rast_close(map_fd);
     return 0;
Modified: grass/trunk/raster/r.watershed/seg/close_maps.c
--- grass/trunk/raster/r.watershed/seg/close_maps.c	2018-08-07 21:10:33 UTC (rev 73060)
+++ grass/trunk/raster/r.watershed/seg/close_maps.c	2018-08-07 21:29:35 UTC (rev 73061)
@@ -24,7 +24,8 @@
 	seg_flush(&watalt);
 	if (abs_acc) {
+	    G_message
@@ -50,7 +51,7 @@
 	    Rast_put_row(fd, dbuf, DCELL_TYPE);
-	G_percent(r, nrows, 1);    /* finish it */
+	G_percent(r, nrows, 1);	/* finish it */
 	Rast_close(fd);
 	G_free(wabuf);
@@ -75,51 +76,51 @@
 		clr_min = min - 1;
-					  0, 0, &colors);
+				      0, 0, &colors);
-				      0, 255, &colors);
+				  0, 255, &colors);
 	    clr_min = clr_max;
 	    clr_min = clr_max;
-				      255, 0, &colors);
+				  255, 0, &colors);
 	    clr_min = clr_max;
 	    clr_max = -1.;
-				      255, 0, &colors);
+				  255, 0, &colors);
 	clr_min = -1.;
 	clr_max = 1.;
-				  255, 0, &colors);
+			      255, 0, &colors);
 	clr_min = 1;
-				  255, 0, &colors);
+			      255, 0, &colors);
 	clr_min = clr_max;
 	clr_min = clr_max;
-				  0, 255, &colors);
+			      0, 255, &colors);
 	clr_min = clr_max;
-				  0, &colors);
+			      0, &colors);
 	    clr_max = max + 1;
 	    Rast_add_d_color_rule(&clr_min, 0, 0, 0, &clr_max, 0, 0, 0,
-				      &colors);
+				  &colors);
@@ -166,7 +167,7 @@
 		seg_get(&atanb, (char *)&sca_tanb, r, c);
 		if (!Rast_is_d_null_value(&sca_tanb.tanb)) {
 		    if (tci_flag) {
 			dvalue = log(sca_tanb.sca / sca_tanb.tanb);
 			dbuf[c] = dvalue;
@@ -186,7 +187,7 @@
 	    if (spi_flag)
 		Rast_put_row(fd2, dbuf2, DCELL_TYPE);
 	G_free(wabuf);
 	seg_close(&atanb);
@@ -196,7 +197,8 @@
 	    G_free(dbuf);
-	    stddev = sqrt((sum_sqr - (sum + sum / do_points)) / (do_points - 1));
+	    stddev =
+		sqrt((sum_sqr - (sum + sum / do_points)) / (do_points - 1));
@@ -214,31 +216,31 @@
 		clr_min = min - 1;
-					      255, 0, &colors);
+				      255, 0, &colors);
-				      255, 0, &colors);
+				  255, 0, &colors);
 	    clr_min = clr_max;
 	    clr_min = clr_max;
-				      0, 255, &colors);
+				  0, 255, &colors);
 	    clr_min = clr_max;
-				      0, &colors);
+				  0, &colors);
 		clr_min = clr_max;
 		clr_max = max + 1;
-					  0, &colors);
+				      0, &colors);
@@ -247,7 +249,9 @@
 	    G_free(dbuf2);
 	    mean = sum2 / do_points;
-	    stddev = sqrt((sum_sqr2 - (sum2 + sum2 / do_points)) / (do_points - 1));
+	    stddev =
+		sqrt((sum_sqr2 - (sum2 + sum2 / do_points)) / (do_points -
+							       1));
@@ -265,31 +269,31 @@
 		clr_min = min - 1;
-					      255, 0, &colors);
+				      255, 0, &colors);
-				      255, 0, &colors);
+				  255, 0, &colors);
 	    clr_min = clr_max;
 	    clr_min = clr_max;
-				      0, 255, &colors);
+				  0, 255, &colors);
 	    clr_min = clr_max;
-				      0, &colors);
+				  0, &colors);
 		clr_min = clr_max;
 		clr_max = max + 1;
-					  0, &colors);
+				      0, &colors);
@@ -338,7 +342,7 @@
 		    dseg_put(&s_l, &max_length, r, c);
 	dseg_write_cellfile(&s_l, sl_name);
     if (sl_flag || ls_flag || sg_flag)
Modified: grass/trunk/raster/r.watershed/seg/close_maps2.c
--- grass/trunk/raster/r.watershed/seg/close_maps2.c	2018-08-07 21:10:33 UTC (rev 73060)
+++ grass/trunk/raster/r.watershed/seg/close_maps2.c	2018-08-07 21:29:35 UTC (rev 73061)
@@ -21,14 +21,14 @@
 	    theseg = &haf;
 	max = -9;
-	for (r = 0; r < nrows; r++) {
-	    for (c = 0; c < ncols; c++) {
-		cseg_get(theseg, &value, r, c);
-		if (value > max)
-		    max = value;
+	   for (r = 0; r < nrows; r++) {
+	   for (c = 0; c < ncols; c++) {
+	   cseg_get(theseg, &value, r, c);
+	   if (value > max)
+	   max = value;
 	max = n_basins;
 	G_debug(1, "%d basins created", max);
 	Rast_init_colors(&colors);
@@ -50,7 +50,8 @@
 			    flag = 1;
 			    while (flag) {
+						 &colors);
@@ -98,7 +99,7 @@
 	    Rast_put_row(map_fd, cellrow, CELL_TYPE);
-	G_percent(nrows, nrows, 1);    /* finish it */
+	G_percent(nrows, nrows, 1);	/* finish it */
 	G_free(cellrow);
 	Rast_close(map_fd);
 	Rast_write_colors(seg_name, this_mapset, &colors);
Modified: grass/trunk/raster/r.watershed/seg/cseg_open.c
--- grass/trunk/raster/r.watershed/seg/cseg_open.c	2018-08-07 21:10:33 UTC (rev 73060)
+++ grass/trunk/raster/r.watershed/seg/cseg_open.c	2018-08-07 21:29:35 UTC (rev 73061)
@@ -22,8 +22,8 @@
     if (0 >
 	(errflag =
-	 Segment_format(fd, Rast_window_rows(), Rast_window_cols(), srows, scols,
-			sizeof(CELL)))) {
+	 Segment_format(fd, Rast_window_rows(), Rast_window_cols(), srows,
+			scols, sizeof(CELL)))) {
 	close(fd);
 	unlink(filename);
 	if (errflag == -1) {
Modified: grass/trunk/raster/r.watershed/seg/cseg_read.c
--- grass/trunk/raster/r.watershed/seg/cseg_read.c	2018-08-07 21:10:33 UTC (rev 73060)
+++ grass/trunk/raster/r.watershed/seg/cseg_read.c	2018-08-07 21:29:35 UTC (rev 73061)
@@ -23,7 +23,7 @@
 	    G_free(buffer);
 	    Rast_close(map_fd);
 	    G_warning("%s(): unable to segment put row for [%s] in [%s]",
-		    me, map_name, mapset);
+		      me, map_name, mapset);
 	    return (-1);
Modified: grass/trunk/raster/r.watershed/seg/cseg_write.c
--- grass/trunk/raster/r.watershed/seg/cseg_write.c	2018-08-07 21:10:33 UTC (rev 73060)
+++ grass/trunk/raster/r.watershed/seg/cseg_write.c	2018-08-07 21:29:35 UTC (rev 73061)
@@ -18,7 +18,7 @@
 	Segment_get_row(&(cseg->seg), buffer, row);
     G_free(buffer);
     Rast_close(map_fd);
     return 0;
Modified: grass/trunk/raster/r.watershed/seg/def_basin.c
--- grass/trunk/raster/r.watershed/seg/def_basin.c	2018-08-07 21:10:33 UTC (rev 73060)
+++ grass/trunk/raster/r.watershed/seg/def_basin.c	2018-08-07 21:29:35 UTC (rev 73061)
@@ -56,7 +56,7 @@
-				(oldupdir, (int) downdir, thisdir)) {
+				(oldupdir, (int)downdir, thisdir)) {
 			case LEFT:
 					   &new_elev);
@@ -88,7 +88,7 @@
 		else
-	    else {			/* sides == 4 */
+	    else {		/* sides == 4 */
 		seg_get(&aspflag, (char *)&af, row, col);
 		asp_value = af.asp;
Modified: grass/trunk/raster/r.watershed/seg/do_astar.c
--- grass/trunk/raster/r.watershed/seg/do_astar.c	2018-08-07 21:10:33 UTC (rev 73060)
+++ grass/trunk/raster/r.watershed/seg/do_astar.c	2018-08-07 21:29:35 UTC (rev 73061)
@@ -47,7 +47,8 @@
     if (heap_size == 0)
 	G_fatal_error(_("No seeds for A* Search"));
-    G_debug(1, "heap size %"PRI_OFF_T", points %"PRI_OFF_T, heap_size, do_points);
+    G_debug(1, "heap size %" PRI_OFF_T ", points %" PRI_OFF_T, heap_size,
+	    do_points);
     count = 0;
@@ -61,7 +62,7 @@
 	r = heap_p.pnt.r;
 	c = heap_p.pnt.c;
-	G_debug(3, "heap size %"PRI_OFF_T", r %d, c %d", heap_size, r, c);
+	G_debug(3, "heap size %" PRI_OFF_T ", r %d, c %d", heap_size, r, c);
 	alt_val = heap_p.ele;
@@ -143,8 +144,9 @@
 	seg_put(&aspflag, (char *)&af, r, c);
     if (doer != -1)
-	G_fatal_error(_("bug in A* Search: doer %"PRI_OFF_T" heap size %"PRI_OFF_T" count %"PRI_OFF_T),
-		      doer, heap_size, count);
+	G_fatal_error(_("bug in A* Search: doer %" PRI_OFF_T " heap size %"
+		       PRI_OFF_T " count %" PRI_OFF_T), doer, heap_size,
+		      count);
     seg_close(&search_heap);
@@ -263,8 +265,7 @@
     return root_p;
-double get_slope(int r, int c, int downr, int downc, CELL ele,
-                        CELL downe)
     double slope;
Modified: grass/trunk/raster/r.watershed/seg/do_cum.c
--- grass/trunk/raster/r.watershed/seg/do_cum.c	2018-08-07 21:10:33 UTC (rev 73060)
+++ grass/trunk/raster/r.watershed/seg/do_cum.c	2018-08-07 21:29:35 UTC (rev 73061)
@@ -17,22 +17,23 @@
+			      window.west,
@@ -41,7 +42,7 @@
@@ -79,7 +80,8 @@
+	contour[7] =
@@ -199,11 +201,10 @@
 	    if (atanb_flag) {
-		sca_tanb.sca = fabs(wa.wat) *
+		sca_tanb.sca = fabs(wa.wat) * (cell_size / contour[np_side]);
 		sca_tanb.tanb = get_slope_tci(wa.ele, wadown.ele,
 		seg_put(&atanb, (char *)&sca_tanb, r, c);
@@ -216,7 +217,8 @@
 	    else {
 		seg_get(&aspflag, (char *)&afdown, dr, dc);
-		if (er_flag && !is_swale && !FLAG_GET(afdown.flag, RUSLEBLOCKFLAG))
+		if (er_flag && !is_swale &&
+		    !FLAG_GET(afdown.flag, RUSLEBLOCKFLAG))
 		    slope_length(r, c, dr, dc);
@@ -311,12 +313,12 @@
     flag_nbr = (char *)G_malloc(sides * sizeof(char));
-    wat_nbr = (DCELL *)G_malloc(sides * sizeof(DCELL));
-    ele_nbr = (CELL *)G_malloc(sides * sizeof(CELL));
+    wat_nbr = (DCELL *) G_malloc(sides * sizeof(DCELL));
+    ele_nbr = (CELL *) G_malloc(sides * sizeof(CELL));
     workedon = 0;
@@ -342,7 +344,7 @@
 	/* WORKEDFLAG has been set during A* Search
 	 * reversed meaning here: 0 = done, 1 = not yet done */
 	FLAG_UNSET(af.flag, WORKEDFLAG);
 	    r_max = dr;
 	    c_max = dc;
@@ -390,8 +392,8 @@
 			    if (ele_nbr[ct_dir] < ele) {
 				weight[ct_dir] =
 				    mfd_pow(((ele -
-					      ele_nbr[ct_dir]) / dist_to_nbr[ct_dir]),
-					    c_fac);
+					      ele_nbr[ct_dir]) /
+					     dist_to_nbr[ct_dir]), c_fac);
 			    if (ele_nbr[ct_dir] == ele) {
 				weight[ct_dir] =
@@ -463,9 +465,10 @@
 			    if (atanb_flag) {
-				sca_tanb.tanb += get_slope_tci(ele, ele_nbr[ct_dir],
-					         weight[ct_dir];
+				sca_tanb.tanb +=
+				    get_slope_tci(ele, ele_nbr[ct_dir],
+						  dist_to_nbr[ct_dir]) *
+				    weight[ct_dir];
 			    if (value > 0) {
@@ -478,7 +481,9 @@
 				if (wat_nbr[ct_dir] < 0)
 				    wat_nbr[ct_dir] += value * weight[ct_dir];
 				else
-				    wat_nbr[ct_dir] = value * weight[ct_dir] - wat_nbr[ct_dir];
+				    wat_nbr[ct_dir] =
+					value * weight[ct_dir] -
+					wat_nbr[ct_dir];
 			    valued = wat_nbr[ct_dir];
 			    wa.wat = valued;
@@ -494,10 +499,10 @@
 		/* adjust main drainage direction to A* path if possible */
 		/*if (fabs(wat_nbr[np_side]) >= max_acc) {
-		    max_acc = fabs(wat_nbr[np_side]);
-		    r_max = dr;
-		    c_max = dc;
+		   max_acc = fabs(wat_nbr[np_side]);
+		   r_max = dr;
+		   c_max = dc;
 		if (fabs(prop - 1.0) > 5E-6f) {
 		    G_warning(_("MFD: cumulative proportion of flow distribution not 1.0 but %f"),
@@ -526,7 +531,7 @@
 		if (atanb_flag) {
 		    sca_tanb.tanb = get_slope_tci(ele, ele_nbr[np_side],
@@ -540,10 +545,10 @@
     G_percent(do_points, do_points, 1);	/* finish it */
     if (workedon)
-	G_warning(_("MFD: A * path already processed when distributing flow: %d of %"PRI_OFF_T" cells"),
+	G_warning(_("MFD: A * path already processed when distributing flow: %d of %"
+		   PRI_OFF_T " cells"), workedon, do_points);
@@ -563,7 +568,7 @@
 	    dr = dc = -1;
 	FLAG_SET(af.flag, WORKEDFLAG);
 	    r_max = dr;
 	    c_max = dc;
@@ -606,7 +611,7 @@
 		    if (is_swale)
 			swale_cells++;
 		    if ((ABS(wat_nbr[ct_dir]) + 0.5) >= threshold &&
-		        ele_nbr[ct_dir] > ele)
+			ele_nbr[ct_dir] > ele)
 			stream_cells++;
 		    if (!(FLAG_GET(flag_nbr[ct_dir], WORKEDFLAG))) {
@@ -658,7 +663,8 @@
 		seg_put(&aspflag, (char *)&afdown, r_max, c_max);
 	    else {
-		if (er_flag && !is_swale && !FLAG_GET(af.flag, RUSLEBLOCKFLAG))
+		    !FLAG_GET(af.flag, RUSLEBLOCKFLAG))
 		    slope_length(r, c, r_max, c_max);
@@ -666,7 +672,7 @@
     seg_close(&astar_pts);
     G_free(dist_to_nbr);
     G_free(weight);
     G_free(wat_nbr);
Modified: grass/trunk/raster/r.watershed/seg/dseg_open.c
--- grass/trunk/raster/r.watershed/seg/dseg_open.c	2018-08-07 21:10:33 UTC (rev 73060)
+++ grass/trunk/raster/r.watershed/seg/dseg_open.c	2018-08-07 21:29:35 UTC (rev 73061)
@@ -23,8 +23,8 @@
     if (0 >
 	(errflag =
-			sizeof(double)))) {
+			scols, sizeof(double)))) {
 	close(fd);
 	unlink(filename);
Modified: grass/trunk/raster/r.watershed/seg/dseg_read.c
--- grass/trunk/raster/r.watershed/seg/dseg_read.c	2018-08-07 21:10:33 UTC (rev 73060)
+++ grass/trunk/raster/r.watershed/seg/dseg_read.c	2018-08-07 21:29:35 UTC (rev 73061)
@@ -24,7 +24,7 @@
 	    G_free(dbuffer);
 	    Rast_close(map_fd);
 	    return (-1);
Modified: grass/trunk/raster/r.watershed/seg/dseg_write.c
--- grass/trunk/raster/r.watershed/seg/dseg_write.c	2018-08-07 21:10:33 UTC (rev 73060)
+++ grass/trunk/raster/r.watershed/seg/dseg_write.c	2018-08-07 21:29:35 UTC (rev 73061)
@@ -19,7 +19,7 @@
 	Segment_get_row(&(dseg->seg), (DCELL *) dbuffer, row);
 	Rast_put_row(map_fd, dbuffer, DCELL_TYPE);
     G_free(dbuffer);
     Rast_close(map_fd);
     return 0;
Modified: grass/trunk/raster/r.watershed/seg/find_pour.c
--- grass/trunk/raster/r.watershed/seg/find_pour.c	2018-08-07 21:10:33 UTC (rev 73060)
+++ grass/trunk/raster/r.watershed/seg/find_pour.c	2018-08-07 21:29:35 UTC (rev 73061)
@@ -10,7 +10,7 @@
     char is_swale;
     basin_num = 0;
     Rast_set_c_null_value(&no_basin, 1);
@@ -42,7 +42,7 @@
 		    else {
 			stream_length = 0.0;
-		    seg_get(&watalt, (char *) &wa, row, col);
+		    seg_get(&watalt, (char *)&wa, row, col);
 		    old_elev = wa.ele;
 		basin_num =
Modified: grass/trunk/raster/r.watershed/seg/init_vars.c
--- grass/trunk/raster/r.watershed/seg/init_vars.c	2018-08-07 21:10:33 UTC (rev 73060)
+++ grass/trunk/raster/r.watershed/seg/init_vars.c	2018-08-07 21:29:35 UTC (rev 73061)
@@ -11,7 +11,8 @@
     int r, c;
     int ele_fd, wat_fd, fd = -1;
-    int seg_rows, seg_cols, num_cseg_total, num_open_segs, num_open_array_segs;
+    int seg_rows, seg_cols, num_cseg_total, num_open_segs,
+	num_open_array_segs;
     double memory_divisor, heap_mem, seg_factor, disk_space;
     /* int page_block, num_cseg; */
@@ -80,8 +81,8 @@
 	    arm_flag++;
 	/* slope length
-	else if (sscanf(argv[r], "slope_length=%s", sl_name) == 1)
-	    sl_flag++; */
+	   else if (sscanf(argv[r], "slope_length=%s", sl_name) == 1)
+	   sl_flag++; */
 	    sg_flag++;
@@ -96,7 +97,7 @@
 	/* slope deposition
 	    if (sides != 4)
 		usage(argv[0]);
@@ -136,10 +137,10 @@
 	atanb_flag = 1;
-    G_message(n_("SECTION 1 beginning: Initiating Variables. %d section total.",
-        "SECTION 1 beginning: Initiating Variables. %d sections total.",
-        tot_parts),
-	      tot_parts);
+    G_message(n_
+	      ("SECTION 1 beginning: Initiating Variables. %d section total.",
+	       "SECTION 1 beginning: Initiating Variables. %d sections total.",
+	       tot_parts), tot_parts);
     this_mapset = G_mapset();
     /* for sd factor
@@ -173,7 +174,7 @@
     if (segs_mb < 3.0) {
 	segs_mb = 3;
 	G_warning(_("Maximum memory to be used was smaller than 3 MB,"
-	            " set to 3 MB."));
+		    " set to 3 MB."));
     /* balance segment files */
@@ -219,7 +220,7 @@
 	    disk_space += 8;
     /* KB -> MB */
     memory_divisor = memory_divisor * seg_factor / 1024.;
     disk_space = disk_space * seg_factor / 1024.;
@@ -249,24 +250,28 @@
     disk_space *= num_cseg_total;
     if (disk_space < 1024.0)
-	G_verbose_message(_("Will need up to %.2f MB of disk space"), disk_space);
+	G_verbose_message(_("Will need up to %.2f MB of disk space"),
+			  disk_space);
     else
 	G_verbose_message(_("Will need up to %.2f GB (%.0f MB) of disk space"),
-	           disk_space / 1024.0, disk_space);
+			  disk_space / 1024.0, disk_space);
     if (er_flag) {
 	cseg_open(&r_h, seg_rows, seg_cols, num_open_segs);
 	cseg_read_cell(&r_h, ele_name, "");
     /* read elevation input and mark NULL/masked cells */
     /* scattered access: alt, watalt, bitflags, asp */
-    seg_open(&watalt, nrows, ncols, seg_rows, seg_cols, num_open_segs * 2, sizeof(WAT_ALT));
-    seg_open(&aspflag, nrows, ncols, seg_rows, seg_cols, num_open_segs * 4, sizeof(ASP_FLAG));
+    seg_open(&watalt, nrows, ncols, seg_rows, seg_cols, num_open_segs * 2,
+	     sizeof(WAT_ALT));
+    seg_open(&aspflag, nrows, ncols, seg_rows, seg_cols, num_open_segs * 4,
+	     sizeof(ASP_FLAG));
     if (atanb_flag) {
-	seg_open(&atanb, nrows, ncols, seg_rows, seg_cols, num_open_segs, sizeof(A_TANB));
+	seg_open(&atanb, nrows, ncols, seg_rows, seg_cols, num_open_segs,
+		 sizeof(A_TANB));
 	Rast_set_d_null_value(&sca_tanb.sca, 1);
 	Rast_set_d_null_value(&sca_tanb.tanb, 1);
@@ -280,7 +285,7 @@
     afbuf = G_malloc(ncols * sizeof(ASP_FLAG));
     /* initial flow accumulation */
     if (run_flag) {
@@ -300,7 +305,8 @@
     G_message("SECTION 1a: Mark masked and NULL cells");
     MASK_flag = 0;
-    do_points = (GW_LARGE_INT) nrows * ncols;
+    do_points = (GW_LARGE_INT) nrows *ncols;
 	Rast_get_row(ele_fd, elebuf, r, ele_map_type);
@@ -310,7 +316,7 @@
 	    Rast_get_row(wat_fd, watbuf, r, wat_map_type);
 	    watptr = watbuf;
 	    afbuf[c].flag = 0;
@@ -328,15 +334,15 @@
 	    else {
@@ -344,17 +350,17 @@
 		/* flow accumulation */
 		if (run_flag) {
 		    if (Rast_is_null_value(watptr, wat_map_type)) {
-			wat_value = 0;    /* ok ? */
+			wat_value = 0;	/* ok ? */
 		    else {
 			if (wat_map_type == CELL_TYPE) {
-			    wat_value = *((CELL *)watptr);
+			    wat_value = *((CELL *) watptr);
 			else if (wat_map_type == FCELL_TYPE) {
-			    wat_value = *((FCELL *)watptr);
+			    wat_value = *((FCELL *) watptr);
 			else if (wat_map_type == DCELL_TYPE) {
-			    wat_value = *((DCELL *)watptr);
+			    wat_value = *((DCELL *) watptr);
@@ -373,18 +379,18 @@
 		watptr = G_incr_void_ptr(watptr, wat_size);
-	seg_put_row(&watalt, (char *) wabuf, r);
+	seg_put_row(&watalt, (char *)wabuf, r);
 	seg_put_row(&aspflag, (char *)afbuf, r);
 	if (er_flag) {
 	    cseg_put_row(&r_h, alt_value_buf, r);
     Rast_close(ele_fd);
     G_free(wabuf);
     G_free(afbuf);
     if (run_flag) {
 	Rast_close(wat_fd);
 	G_free(watbuf);
@@ -391,7 +397,7 @@
     MASK_flag = (do_points < nrows * ncols);
     /* do RUSLE */
     if (er_flag) {
 	if (ob_flag) {
@@ -409,7 +415,7 @@
 	    Rast_close(fd);
 	    G_free(buf);
@@ -418,7 +424,7 @@
 	    dseg_open(&ril, seg_rows, seg_cols, num_open_segs);
 	    dseg_read_cell(&ril, ril_name, "");
 	/* dseg_open(&slp, SROW, SCOL, num_open_segs); */
 	dseg_open(&s_l, seg_rows, seg_cols, num_open_segs);
@@ -440,7 +446,7 @@
 	num_open_array_segs = num_cseg_total;
     if (num_open_array_segs < 1)
 	num_open_array_segs = 1;
     seg_open(&astar_pts, 1, do_points, 1, seg_cols, num_open_array_segs,
 	     sizeof(POINT));
@@ -454,7 +460,8 @@
     if (do_points % seg_cols > 0)
 	num_cseg_total++;
     /* no need to have more segments open than exist */
-    num_open_array_segs = (1 << 20) * heap_mem / (seg_cols * sizeof(HEAP_PNT));
+    num_open_array_segs =
+	(1 << 20) * heap_mem / (seg_cols * sizeof(HEAP_PNT));
     if (num_open_array_segs > num_cseg_total)
     if (num_open_array_segs < 2)
@@ -461,7 +468,7 @@
 	num_open_array_segs = 2;
     G_debug(1, "A* search heap open segments %d, total %d",
-            num_open_array_segs, num_cseg_total);
+	    num_open_array_segs, num_cseg_total);
     /* the search heap will not hold more than 5% of all points at any given time ? */
     /* chances are good that the heap will fit into one large segment */
     seg_open(&search_heap, 1, do_points + 1, 1, seg_cols,
@@ -490,8 +497,7 @@
 		if (er_flag)
 		    dseg_put(&s_l, &half_res, r, c);
 		asp_value = af.asp;
-		    c == ncols - 1) {
 		    /* dseg_get(&wat, &wat_value, r, c); */
 		    seg_get(&watalt, (char *)&wa, r, c);
 		    wat_value = wa.wat;
@@ -558,8 +564,8 @@
-	    }  /* end non-NULL cell */
-	}  /* end column */
+	    }			/* end non-NULL cell */
+	}			/* end column */
Modified: grass/trunk/raster/r.watershed/seg/main.c
--- grass/trunk/raster/r.watershed/seg/main.c	2018-08-07 21:10:33 UTC (rev 73060)
+++ grass/trunk/raster/r.watershed/seg/main.c	2018-08-07 21:29:35 UTC (rev 73061)
@@ -49,6 +49,7 @@
 char updrain[3][3] = { {3, 2, 1}, {4, 0, 8}, {5, 6, 7} };
@@ -71,7 +72,7 @@
 int main(int argc, char *argv[])
     int num_open_segs;
     zero = 0;
     one = 1;
     d_zero = 0.0;
Modified: grass/trunk/raster/r.watershed/seg/no_stream.c
--- grass/trunk/raster/r.watershed/seg/no_stream.c	2018-08-07 21:10:33 UTC (rev 73060)
+++ grass/trunk/raster/r.watershed/seg/no_stream.c	2018-08-07 21:29:35 UTC (rev 73061)
@@ -62,7 +62,7 @@
 			else
@@ -80,8 +80,7 @@
-					       (int) downdir,
-					       thisdir)) {
+						   (int)downdir, thisdir)) {
 			    case RITE:
 				overland_cells(r, c, basin_num, basin_num,
 					       &new_ele);
@@ -108,7 +107,7 @@
 	else {
 	    if (arm_flag) {
 		hih_ele = wa.ele;
 		slope = (hih_ele - old_elev) / stream_length;
 		if (slope < MIN_SLOPE)
Modified: grass/trunk/raster/r.watershed/seg/over_cells.c
--- grass/trunk/raster/r.watershed/seg/over_cells.c	2018-08-07 21:10:33 UTC (rev 73060)
+++ grass/trunk/raster/r.watershed/seg/over_cells.c	2018-08-07 21:29:35 UTC (rev 73061)
@@ -2,7 +2,8 @@
 int
+			 CELL * hih_ele)
     int r, rr, c, cc;
     CELL new_ele, new_max_ele;
@@ -26,15 +27,15 @@
-    if (arm_flag) {
-	else {
+       if (arm_flag) {
+       else {
     return 0;
@@ -72,7 +73,10 @@
+			    ocs =
+						       ocs_alloced *
 			ocs[top].row = r;
 			ocs[top].col = c;
@@ -83,19 +87,19 @@
-    if (arm_flag) {
-	else {
+       if (arm_flag) {
+       else {
     return 0;
Modified: grass/trunk/raster/r.watershed/seg/sg_factor.c
--- grass/trunk/raster/r.watershed/seg/sg_factor.c	2018-08-07 21:10:33 UTC (rev 73060)
+++ grass/trunk/raster/r.watershed/seg/sg_factor.c	2018-08-07 21:29:35 UTC (rev 73061)
@@ -18,8 +18,8 @@
 	    seg_get(&aspflag, (char *)&af, r, c);
 	    if (FLAG_GET(af.flag, NULLFLAG))
 		continue;
-	    seg_get(&watalt, (char *) &wa, r, c);
+	    seg_get(&watalt, (char *)&wa, r, c);
 	    low_elev = wa.ele;
 	    cseg_get(&r_h, &hih_elev, r, c);
 	    dseg_get(&s_l, &length, r, c);
Modified: grass/trunk/raster/r.watershed/seg/slope_len.c
--- grass/trunk/raster/r.watershed/seg/slope_len.c	2018-08-07 21:10:33 UTC (rev 73060)
+++ grass/trunk/raster/r.watershed/seg/slope_len.c	2018-08-07 21:29:35 UTC (rev 73061)
@@ -20,9 +20,9 @@
     else
 	top_ls += res;
     dseg_put(&s_l, &top_ls, r, c);
     top_alt = wa.ele;
-    seg_get(&watalt, (char *) &wa, dr, dc);
+    seg_get(&watalt, (char *)&wa, dr, dc);
     bot_alt = wa.ele;
     if (top_alt > bot_alt) {
 	dseg_get(&s_l, &bot_ls, dr, dc);
Modified: grass/trunk/raster/r.watershed/seg/split_str.c
--- grass/trunk/raster/r.watershed/seg/split_str.c	2018-08-07 21:10:33 UTC (rev 73060)
+++ grass/trunk/raster/r.watershed/seg/split_str.c	2018-08-07 21:29:35 UTC (rev 73061)
@@ -41,8 +41,7 @@
 		    if (doit) {
 			case LEFT:
 					   &new_elev);
@@ -68,7 +67,7 @@
     old_basin = basin_num;
     if (arm_flag) {
 	new_elev = wa.ele;
 	if ((slope = (new_elev - old_elev) / stream_length) < MIN_SLOPE)
 	    slope = MIN_SLOPE;
Modified: grass/trunk/raster/r.watershed/seg/sseg_open.c
--- grass/trunk/raster/r.watershed/seg/sseg_open.c	2018-08-07 21:10:33 UTC (rev 73060)
+++ grass/trunk/raster/r.watershed/seg/sseg_open.c	2018-08-07 21:29:35 UTC (rev 73061)
@@ -5,8 +5,8 @@
 #include "Gwater.h"
 int
-seg_open(SSEG * sseg, GW_LARGE_INT nrows, GW_LARGE_INT ncols, int row_in_seg, int col_in_seg,
-	 int nsegs_in_memory, int size_struct)
+seg_open(SSEG * sseg, GW_LARGE_INT nrows, GW_LARGE_INT ncols, int row_in_seg,
+	 int col_in_seg, int nsegs_in_memory, int size_struct)
     char *filename;
     int errflag;
