[GRASS-SVN] r73091 - in grass/branches/releasebranch_7_4: gui/wxpython/psmap ps/ps.map
svn_grass at osgeo.org
Mon Aug 13 17:59:58 PDT 2018
Author: annakrat
Date: 2018-08-13 17:59:58 -0700 (Mon, 13 Aug 2018)
New Revision: 73091
grass/branches/releasebranch_7_4/gui/wxpython/psmap/g.gui.psmap.html
grass/branches/releasebranch_7_4/ps/ps.map/ps.map.html
ps.map/composer: small changes in manual (merge from trunk, r73090)
Modified: grass/branches/releasebranch_7_4/gui/wxpython/psmap/g.gui.psmap.html
--- grass/branches/releasebranch_7_4/gui/wxpython/psmap/g.gui.psmap.html 2018-08-14 00:58:15 UTC (rev 73090)
+++ grass/branches/releasebranch_7_4/gui/wxpython/psmap/g.gui.psmap.html 2018-08-14 00:59:58 UTC (rev 73091)
@@ -30,8 +30,9 @@
</center>
<p>
-Cartographic Composer enables to load in saved instructions file. It
-works better with files created by wx.psmap (more tested).
+Cartographic Composer enables to load in saved instructions file.
+Loading instruction files created by Cartographic Composer is more robust,
+as opposed to loading files created manually.
<p>
Currently supported <em><a href="ps.map.html">ps.map</a></em> instructions:
Modified: grass/branches/releasebranch_7_4/ps/ps.map/ps.map.html
--- grass/branches/releasebranch_7_4/ps/ps.map/ps.map.html 2018-08-14 00:58:15 UTC (rev 73090)
+++ grass/branches/releasebranch_7_4/ps/ps.map/ps.map.html 2018-08-14 00:59:58 UTC (rev 73091)
@@ -1622,15 +1622,6 @@
help site.
<p>
-<h2>CHANGES BETWEEN VERSION 5.0.x/5.4.x and 6.0</h2>
-<UL>
-<li>Devices and ps.select do not exist any more. Paper is defined by the
-<em>paper</em> instruction.</LI>
-<li><em>vpoints</em> are used instead of <em>sites</em> (points are read from vector).</LI>
-<li><em>vector</em> is substituted by <em>vpoints</em>, <em>vlines</em> and <em>vareas</em>.</LI>
-<li>Symbols are used instead of icons (different format and directory).</LI>
-<li>Map legend can be printed in columns.</LI>
-</UL>
<h2>SEE ALSO</h2>
