[GRASS-SVN] r73099 - grass/trunk/lib/init
svn_grass at osgeo.org
Tue Aug 14 19:24:28 PDT 2018
Author: wenzeslaus
Date: 2018-08-14 19:24:28 -0700 (Tue, 14 Aug 2018)
New Revision: 73099
grass/trunk/lib/init/grass.py
grass/trunk/lib/init/grass7.html
init: update doc for --tmp-location without -c (finishes r73096, see #3585)
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2018-08-15 02:10:00 UTC (rev 73098)
+++ grass/trunk/lib/init/grass.py 2018-08-15 02:24:28 UTC (rev 73099)
@@ -367,7 +367,7 @@
executable=_("GRASS module, script or any other executable"),
executable_params=_("parameters of the executable"),
standard_flags=_("standard flags"),
- tmp_location=_("create temporary location (use with -c and --exec flags)"),
+ tmp_location=_("create temporary location (use with the --exec flag)"),
Modified: grass/trunk/lib/init/grass7.html
--- grass/trunk/lib/init/grass7.html 2018-08-15 02:10:00 UTC (rev 73098)
+++ grass/trunk/lib/init/grass7.html 2018-08-15 02:24:28 UTC (rev 73099)
@@ -55,7 +55,8 @@
<dt><b>--tmp-location</b>
<dd> Run using a temporary location which is created based on the given
coordinate reference system and deleted at the end of the execution
-(use with -c and --exec flags)
+(use the --exec flag).
+The active mapset will be PERMANENT.
</dl>
@@ -373,19 +374,19 @@
computation in a shell script:
<div class="code"><pre>
-grass75 -c elevation.tiff --tmp-location --exec test.sh
+grass75 --tmp-location elevation.tiff --exec test.sh
</pre></div>
The same, but using an EPSG code and a Python script:
-grass75 -c EPSG:3358 --tmp-location --exec test.py
+grass75 --tmp-location EPSG:3358 --exec test.py
</pre></div>
Finally, for special cases, we can create an XY location without any CRS:
-grass75 -c --tmp-location --exec test.py
+grass75 --tmp-location XY --exec test.py
</pre></div>
Temporary location is automatically deleted after computation,
@@ -397,7 +398,7 @@
temporary location:
-grass75 -c EPSG:3358 --tmp-location --exec g.proj -p
+grass75 --tmp-location EPSG:3358 --exec g.proj -p
</pre></div>
A temporary XY location with single command is useful, e.g. to show
@@ -404,7 +405,7 @@
help text of a module:
-grass75 -c --tmp-location --exec r.neighbors --help
+grass75 --tmp-location XY --exec r.neighbors --help
</pre></div>
<h4>Troubleshooting</h4>
