[GRASS-SVN] r73113 - in grass/trunk/raster/r.watershed: front ram seg
svn_grass at osgeo.org
Fri Aug 17 04:39:28 PDT 2018
Author: mmetz
Date: 2018-08-17 04:39:27 -0700 (Fri, 17 Aug 2018)
New Revision: 73113
grass/trunk/raster/r.watershed/front/main.c
grass/trunk/raster/r.watershed/front/r.watershed.html
grass/trunk/raster/r.watershed/ram/Gwater.h
grass/trunk/raster/r.watershed/ram/close_maps.c
grass/trunk/raster/r.watershed/ram/do_cum.c
grass/trunk/raster/r.watershed/ram/init_vars.c
grass/trunk/raster/r.watershed/ram/main.c
grass/trunk/raster/r.watershed/ram/usage.c
grass/trunk/raster/r.watershed/seg/Gwater.h
grass/trunk/raster/r.watershed/seg/bseg_read.c
grass/trunk/raster/r.watershed/seg/bseg_write.c
grass/trunk/raster/r.watershed/seg/close_maps.c
grass/trunk/raster/r.watershed/seg/cseg_read.c
grass/trunk/raster/r.watershed/seg/cseg_write.c
grass/trunk/raster/r.watershed/seg/do_cum.c
grass/trunk/raster/r.watershed/seg/dseg_read.c
grass/trunk/raster/r.watershed/seg/dseg_write.c
grass/trunk/raster/r.watershed/seg/init_vars.c
grass/trunk/raster/r.watershed/seg/main.c
grass/trunk/raster/r.watershed/seg/sseg_open.c
r.watershed: +retention for flow distribution, credits to Andreas Gericke (IGB Berlin)
Modified: grass/trunk/raster/r.watershed/front/main.c
--- grass/trunk/raster/r.watershed/front/main.c 2018-08-16 16:26:31 UTC (rev 73112)
+++ grass/trunk/raster/r.watershed/front/main.c 2018-08-17 11:39:27 UTC (rev 73113)
@@ -60,6 +60,7 @@
struct Option *opt16;
struct Option *opt17;
struct Option *opt18;
+ struct Option *opt19;
struct Flag *flag_sfd;
struct Flag *flag_flow;
struct Flag *flag_seg;
@@ -116,6 +117,13 @@
opt5->required = NO;
opt5->guisection = _("Inputs");
+ opt19 = G_define_standard_option(G_OPT_R_INPUT);
+ opt19->key = "retention";
+ opt19->description =
+ _("Name of input raster map with percentages for flow accumulation.");
+ opt19->required = NO;
+ opt19->guisection = _("Inputs");
opt6 = G_define_option();
opt6->key = "threshold";
opt6->description = _("Minimum size of exterior watershed basin");
@@ -306,6 +314,7 @@
do_opt(opt3);
do_opt(opt4);
do_opt(opt5);
+ do_opt(opt19);
do_opt(opt6);
do_opt(opt7);
do_opt(opt8);
Modified: grass/trunk/raster/r.watershed/front/r.watershed.html
--- grass/trunk/raster/r.watershed/front/r.watershed.html 2018-08-16 16:26:31 UTC (rev 73112)
+++ grass/trunk/raster/r.watershed/front/r.watershed.html 2018-08-17 11:39:27 UTC (rev 73113)
@@ -73,6 +73,12 @@
flow. If omitted, a value of one (1) is assumed.
<p>
+Raster <b>retention</b> map specifies correction factors per cell for
+flow distribution. This map indicates the percentage of overland flow
+units leaving each cell. Values should be between zero and 100. If
+omitted, a value of 100 is assumed.
+<p>
Input Raster map or value containing the percent of disturbed land
(i.e., croplands, and construction sites) where the raster or input
value of 17 equals 17%. If no map or value is
@@ -567,6 +573,8 @@
<br>
Faster sorting algorithm and MFD support:
Markus Metz <markus.metz.giswork at gmail.com>
+<br>
+Retention for flow distribution by Andreas Gericke (IGB Berlin)
<p>
<i>Last changed: $Date$</i>
Modified: grass/trunk/raster/r.watershed/ram/Gwater.h
--- grass/trunk/raster/r.watershed/ram/Gwater.h 2018-08-16 16:26:31 UTC (rev 73112)
+++ grass/trunk/raster/r.watershed/ram/Gwater.h 2018-08-17 11:39:27 UTC (rev 73113)
@@ -56,10 +56,11 @@
extern int ocs_alloced;
extern FLAG *worked, *in_list, *s_b, *swale, *flat_done;
extern RAMSEG dis_seg, alt_seg, wat_seg, asp_seg, bas_seg, haf_seg;
-extern RAMSEG r_h_seg, dep_seg;
+extern RAMSEG r_h_seg, dep_seg, rtn_seg;
extern RAMSEG slp_seg, s_l_seg, s_g_seg, l_s_seg;
extern int *astar_pts;
extern CELL *dis, *alt, *asp, *bas, *haf, *r_h, *dep;
+extern char *rtn;
extern DCELL *wat, *sca, *tanb;
extern int ril_fd;
extern double *s_l, *s_g, *l_s;
@@ -72,13 +73,13 @@
extern int nextdc[8];
extern char ele_name[GNAME_MAX], pit_name[GNAME_MAX];
extern char run_name[GNAME_MAX], ob_name[GNAME_MAX];
-extern char ril_name[GNAME_MAX], dep_name[GNAME_MAX];
+extern char ril_name[GNAME_MAX], rtn_name[GNAME_MAX], dep_name[GNAME_MAX];
extern const char *this_mapset;
extern char seg_name[GNAME_MAX], bas_name[GNAME_MAX], haf_name[GNAME_MAX], thr_name[8];
extern char ls_name[GNAME_MAX], st_name[GNAME_MAX], sl_name[GNAME_MAX], sg_name[GNAME_MAX];
extern char wat_name[GNAME_MAX], asp_name[GNAME_MAX], tci_name[GNAME_MAX], spi_name[GNAME_MAX];
extern char arm_name[GNAME_MAX], dis_name[GNAME_MAX];
-extern char ele_flag, pit_flag, run_flag, dis_flag, ob_flag, flat_flag;
+extern char ele_flag, pit_flag, run_flag, dis_flag, ob_flag, flat_flag, rtn_flag;
extern char wat_flag, asp_flag, arm_flag, ril_flag, dep_flag, tci_flag, spi_flag, atanb_flag;
extern char bas_flag, seg_flag, haf_flag, er_flag;
extern char st_flag, sb_flag, sg_flag, sl_flag, ls_flag;
Modified: grass/trunk/raster/r.watershed/ram/close_maps.c
--- grass/trunk/raster/r.watershed/ram/close_maps.c 2018-08-16 16:26:31 UTC (rev 73112)
+++ grass/trunk/raster/r.watershed/ram/close_maps.c 2018-08-17 11:39:27 UTC (rev 73113)
@@ -21,6 +21,9 @@
if (wat_flag || ls_flag || sl_flag || sg_flag || atanb_flag)
dbuf = Rast_allocate_d_buf();
G_free(alt);
+ if (rtn_flag)
+ G_free(rtn);
if (ls_flag || sg_flag)
G_free(r_h);
Modified: grass/trunk/raster/r.watershed/ram/do_cum.c
--- grass/trunk/raster/r.watershed/ram/do_cum.c 2018-08-16 16:26:31 UTC (rev 73112)
+++ grass/trunk/raster/r.watershed/ram/do_cum.c 2018-08-17 11:39:27 UTC (rev 73113)
@@ -140,6 +140,10 @@
if (dr >= 0 && dr < nrows && dc >= 0 && dc < ncols) { /* if ((dr = astar_pts[killer].downr) > -1) { */
down_index = SEG_INDEX(wat_seg, dr, dc);
value = wat[this_index];
+ /* apply retention to adjust flow accumulation */
+ if (rtn_flag)
+ value *= rtn[this_index] / 100.0;
if (fabs(value) >= threshold)
FLAG_SET(swale, r, c);
valued = wat[down_index];
@@ -197,7 +201,7 @@
/* topographic wetness index ln(a / tan(beta)) and
* stream power index a * tan(beta) */
if (atanb_flag) {
- sca[this_index] = fabs(wat[this_index]) *
+ sca[this_index] = fabs(value) *
(cell_size / contour[np_side]);
tanb[this_index] = get_slope_tci(alt[this_index],
alt[down_index],
@@ -321,6 +325,9 @@
dr = dc = -1;
+ if (rtn_flag)
/* get weights */
@@ -489,7 +496,7 @@
if (atanb_flag) {
(cell_size / sum_contour);
tanb[this_index] = tci_div;
Modified: grass/trunk/raster/r.watershed/ram/init_vars.c
--- grass/trunk/raster/r.watershed/ram/init_vars.c 2018-08-16 16:26:31 UTC (rev 73112)
+++ grass/trunk/raster/r.watershed/ram/init_vars.c 2018-08-17 11:39:27 UTC (rev 73113)
@@ -20,7 +20,7 @@
G_gisinit(argv[0]);
/* input */
- ele_flag = pit_flag = run_flag = ril_flag = 0;
+ ele_flag = pit_flag = run_flag = ril_flag = rtn_flag = 0;
/* output */
wat_flag = asp_flag = tci_flag = spi_flag = atanb_flag = 0;
bas_flag = seg_flag = haf_flag = 0;
@@ -67,6 +67,8 @@
haf_flag++;
else if (sscanf(argv[r], "flow=%s", run_name) == 1)
run_flag++;
+ else if (sscanf(argv[r], "retention=%s", rtn_name) == 1)
+ rtn_flag++;
else if (sscanf(argv[r], "ar=%s", arm_name) == 1)
arm_flag++;
/* slope length
@@ -266,6 +268,42 @@
G_free(dbuf);
+ /* read retention map to adjust flow distribution (AG) */
+ rtn = NULL;
+ if (rtn_flag) {
+ rtn = (char *) G_malloc(sizeof(char) *
+ size_array(&rtn_seg, nrows, ncols));
+ buf = Rast_allocate_c_buf();
+ fd = Rast_open_old(rtn_name, "");
+ for (r = 0; r < nrows; r++) {
+ Rast_get_c_row(fd, buf, r);
+ for (c = 0; c < ncols; c++) {
+ if (MASK_flag) {
+ block_value = FLAG_GET(worked, r, c);
+ if (!block_value) {
+ block_value = buf[c];
+ else
+ block_value = 100;
+ else
+ if (!Rast_is_c_null_value(&block_value)) {
+ if (block_value < 0)
+ block_value = 0;
+ if (block_value > 100)
+ rtn[SEG_INDEX(rtn_seg, r, c)] = block_value;
+ else
+ rtn[SEG_INDEX(rtn_seg, r, c)] = 100;
+ Rast_close(fd);
+ G_free(buf);
/* overland blocking map; this is also creating streams... */
if (ob_flag) {
Modified: grass/trunk/raster/r.watershed/ram/main.c
--- grass/trunk/raster/r.watershed/ram/main.c 2018-08-16 16:26:31 UTC (rev 73112)
+++ grass/trunk/raster/r.watershed/ram/main.c 2018-08-17 11:39:27 UTC (rev 73113)
@@ -35,10 +35,11 @@
int ocs_alloced;
-RAMSEG r_h_seg, dep_seg;
+RAMSEG r_h_seg, dep_seg, rtn_seg;
int *astar_pts;
+char *rtn;
int ril_fd;
@@ -52,7 +53,7 @@
-char ril_name[GNAME_MAX], dep_name[GNAME_MAX];
+char ril_name[GNAME_MAX], rtn_name[GNAME_MAX], dep_name[GNAME_MAX];
thr_name[8];
@@ -62,7 +63,7 @@
-char wat_flag, asp_flag, arm_flag, ril_flag, dep_flag;
+char wat_flag, asp_flag, arm_flag, ril_flag, dep_flag, rtn_flag;
char bas_flag, seg_flag, haf_flag, er_flag, tci_flag, spi_flag, atanb_flag;
FILE *fp;
Modified: grass/trunk/raster/r.watershed/ram/usage.c
--- grass/trunk/raster/r.watershed/ram/usage.c 2018-08-16 16:26:31 UTC (rev 73112)
+++ grass/trunk/raster/r.watershed/ram/usage.c 2018-08-17 11:39:27 UTC (rev 73113)
@@ -10,11 +10,12 @@
"threshold=swale_threshold [flow=overland_flow_map] "
"[drainage=drain_direction_map] [depression=depression_map] "
"[accumulation=accumulation_map] [basin=watershed_basin_map] "
- "[stream=stream_segment_map]\n\n"
+ "[retention=retention_map] [stream=stream_segment_map]\n\n"
"USAGE for slope length determination:\n%s [-4] "
"elevation=elevation_map threshold=swale_threshold "
- "[accumulation=accumulation_map] [max_slope_length=max_slope_length] "
+ "[accumulation=accumulation_map] [retention=retention_map] "
+ "[max_slope_length=max_slope_length] "
"[blocking=overland_blocking_map] [slope_steepness=slope_steepness_map] "
"length_slope=length_slope_map [disturbed_land=rill_erosion_map] "
"[slope_deposition=slope_deposition value or map]"
@@ -23,5 +24,5 @@
"[stream=stream_segment_map] [half_basin=half_basin_map] "
- "ar=ARMSED_file_name\n\n"), me, me, me);
+ "[retention=retention_map] ar=ARMSED_file_name\n\n"), me, me, me);
Modified: grass/trunk/raster/r.watershed/seg/Gwater.h
--- grass/trunk/raster/r.watershed/seg/Gwater.h 2018-08-16 16:26:31 UTC (rev 73112)
+++ grass/trunk/raster/r.watershed/seg/Gwater.h 2018-08-17 11:39:27 UTC (rev 73113)
@@ -93,7 +93,7 @@
extern double half_res, diag, max_length, dep_slope;
extern int bas_thres, tot_parts;
extern SSEG astar_pts;
-extern BSEG s_b;
+extern BSEG s_b, rtn;
extern CSEG dis, bas, haf, r_h, dep;
extern SSEG watalt, aspflag;
extern DSEG slp, s_l, s_g, l_s, ril;
@@ -108,7 +108,7 @@
@@ -116,7 +116,7 @@
extern char wat_name[GNAME_MAX], asp_name[GNAME_MAX];
extern char tci_name[GNAME_MAX], spi_name[GNAME_MAX];
-extern char ele_flag, pit_flag, run_flag, dis_flag, ob_flag;
+extern char ele_flag, pit_flag, run_flag, dis_flag, ob_flag, rtn_flag;
Modified: grass/trunk/raster/r.watershed/seg/bseg_read.c
--- grass/trunk/raster/r.watershed/seg/bseg_read.c 2018-08-16 16:26:31 UTC (rev 73112)
+++ grass/trunk/raster/r.watershed/seg/bseg_read.c 2018-08-17 11:39:27 UTC (rev 73113)
@@ -5,8 +5,8 @@
int bseg_read_cell(BSEG * bseg, char *map_name, char *mapset)
- int row, nrows;
- int col, ncols;
+ int row, rows;
+ int col, cols;
int map_fd;
CELL *buffer;
char cbuf;
@@ -15,12 +15,12 @@
bseg->mapset = NULL;
map_fd = Rast_open_old(map_name, mapset);
- nrows = Rast_window_rows();
- ncols = Rast_window_cols();
+ rows = Rast_window_rows();
+ cols = Rast_window_cols();
buffer = Rast_allocate_c_buf();
- for (row = 0; row < nrows; row++) {
+ for (row = 0; row < rows; row++) {
Rast_get_c_row(map_fd, buffer, row);
- for (col = ncols; col >= 0; col--) {
+ for (col = cols; col >= 0; col--) {
cbuf = (char)buffer[col];
bseg_put(bseg, &cbuf, row, col);
Modified: grass/trunk/raster/r.watershed/seg/bseg_write.c
--- grass/trunk/raster/r.watershed/seg/bseg_write.c 2018-08-16 16:26:31 UTC (rev 73112)
+++ grass/trunk/raster/r.watershed/seg/bseg_write.c 2018-08-17 11:39:27 UTC (rev 73113)
@@ -5,24 +5,24 @@
int bseg_write_cellfile(BSEG * bseg, char *map_name)
int map_fd;
- int row, nrows;
- int col, ncols;
+ int row, rows;
+ int col, cols;
CELL *buffer;
char value;
map_fd = Rast_open_c_new(map_name);
- G_percent(row, nrows, 1);
- for (col = 0; col < ncols; col++) {
+ G_percent(row, rows, 1);
+ for (col = 0; col < cols; col++) {
bseg_get(bseg, &value, row, col);
buffer[col] = value;
Rast_put_row(map_fd, buffer, CELL_TYPE);
- G_percent(row, nrows, 1); /* finish it */
+ G_percent(row, rows, 1); /* finish it */
G_free(buffer);
Rast_close(map_fd);
return 0;
Modified: grass/trunk/raster/r.watershed/seg/close_maps.c
--- grass/trunk/raster/r.watershed/seg/close_maps.c 2018-08-16 16:26:31 UTC (rev 73112)
+++ grass/trunk/raster/r.watershed/seg/close_maps.c 2018-08-17 11:39:27 UTC (rev 73113)
@@ -16,6 +16,9 @@
WAT_ALT *wabuf;
ASP_FLAG *afbuf;
+ if (rtn_flag)
+ bseg_close(&rtn);
if (wat_flag) {
G_message(_("Closing accumulation map"));
sum = sum_sqr = stddev = 0.0;
Modified: grass/trunk/raster/r.watershed/seg/cseg_read.c
--- grass/trunk/raster/r.watershed/seg/cseg_read.c 2018-08-16 16:26:31 UTC (rev 73112)
+++ grass/trunk/raster/r.watershed/seg/cseg_read.c 2018-08-17 11:39:27 UTC (rev 73113)
@@ -7,7 +7,7 @@
int cseg_read_cell(CSEG * cseg, char *map_name, char *mapset)
- GW_LARGE_INT row, nrows;
+ GW_LARGE_INT row, rows;
int map_fd;
CELL *buffer;
@@ -15,9 +15,9 @@
cseg->mapset = NULL;
if (Segment_put_row(&(cseg->seg), buffer, row) < 0) {
G_free(buffer);
Modified: grass/trunk/raster/r.watershed/seg/cseg_write.c
--- grass/trunk/raster/r.watershed/seg/cseg_write.c 2018-08-16 16:26:31 UTC (rev 73112)
+++ grass/trunk/raster/r.watershed/seg/cseg_write.c 2018-08-17 11:39:27 UTC (rev 73113)
@@ -6,19 +6,19 @@
int cseg_write_cellfile(CSEG * cseg, char *map_name)
int map_fd;
CELL *buffer;
Segment_flush(&(cseg->seg));
Segment_get_row(&(cseg->seg), buffer, row);
G_free(buffer);
Rast_close(map_fd);
return 0;
Modified: grass/trunk/raster/r.watershed/seg/do_cum.c
--- grass/trunk/raster/r.watershed/seg/do_cum.c 2018-08-16 16:26:31 UTC (rev 73112)
+++ grass/trunk/raster/r.watershed/seg/do_cum.c 2018-08-17 11:39:27 UTC (rev 73113)
@@ -113,6 +113,7 @@
int asp_r[9] = { 0, -1, -1, -1, 0, 1, 1, 1, 0 };
int asp_c[9] = { 0, 1, 0, -1, -1, -1, 0, 1, 1 };
WAT_ALT wa, wadown;
+ char rtn_value;
ASP_FLAG af, afdown;
A_TANB sca_tanb;
double *dist_to_nbr, *contour;
@@ -176,6 +177,10 @@
seg_get(&watalt, (char *)&wa, r, c);
value = wa.wat;
+ if (rtn_flag) {
+ bseg_get(&rtn, (char *)&rtn_value, dr, dc);
+ value *= rtn_value / 100.0;
is_swale = FLAG_GET(af.flag, SWALEFLAG);
if (fabs(value) >= threshold && !is_swale) {
is_swale = 1;
@@ -201,7 +206,7 @@
if (atanb_flag) {
- sca_tanb.sca = fabs(wa.wat) * (cell_size / contour[np_side]);
+ sca_tanb.sca = fabs(value) * (cell_size / contour[np_side]);
sca_tanb.tanb = get_slope_tci(wa.ele, wadown.ele,
dist_to_nbr[np_side]);
@@ -276,6 +281,7 @@
double sum_contour, cell_size;
POINT point;
WAT_ALT wa;
+ char rtn_value;
A_TANB sca_tanb;
GW_LARGE_INT killer;
@@ -351,6 +357,10 @@
value = wa.wat;
+ if (rtn_flag) {
/* get weights */
max_weight = 0;
Modified: grass/trunk/raster/r.watershed/seg/dseg_read.c
--- grass/trunk/raster/r.watershed/seg/dseg_read.c 2018-08-16 16:26:31 UTC (rev 73112)
+++ grass/trunk/raster/r.watershed/seg/dseg_read.c 2018-08-17 11:39:27 UTC (rev 73113)
@@ -7,7 +7,7 @@
int dseg_read_cell(DSEG * dseg, char *map_name, char *mapset)
- GW_LARGE_INT row, nrows, ncols;
int map_fd;
double *dbuffer;
@@ -15,10 +15,9 @@
dseg->mapset = NULL;
dbuffer = Rast_allocate_d_buf();
Rast_get_d_row(map_fd, dbuffer, row);
if (Segment_put_row(&(dseg->seg), (DCELL *) dbuffer, row) < 0) {
G_free(dbuffer);
Modified: grass/trunk/raster/r.watershed/seg/dseg_write.c
--- grass/trunk/raster/r.watershed/seg/dseg_write.c 2018-08-16 16:26:31 UTC (rev 73112)
+++ grass/trunk/raster/r.watershed/seg/dseg_write.c 2018-08-17 11:39:27 UTC (rev 73113)
@@ -6,20 +6,19 @@
int dseg_write_cellfile(DSEG * dseg, char *map_name)
int map_fd;
double *dbuffer;
map_fd = Rast_open_new(map_name, DCELL_TYPE);
Segment_flush(&(dseg->seg));
Segment_get_row(&(dseg->seg), (DCELL *) dbuffer, row);
Rast_put_row(map_fd, dbuffer, DCELL_TYPE);
G_free(dbuffer);
Rast_close(map_fd);
return 0;
Modified: grass/trunk/raster/r.watershed/seg/init_vars.c
--- grass/trunk/raster/r.watershed/seg/init_vars.c 2018-08-16 16:26:31 UTC (rev 73112)
+++ grass/trunk/raster/r.watershed/seg/init_vars.c 2018-08-17 11:39:27 UTC (rev 73113)
@@ -32,7 +32,7 @@
G_gisinit(argv[0]);
/* input */
/* output */
@@ -78,6 +78,8 @@
haf_flag++;
run_flag++;
+ rtn_flag++;
arm_flag++;
/* slope length
@@ -261,6 +263,10 @@
cseg_read_cell(&r_h, ele_name, "");
+ if (rtn_flag) {
+ bseg_open(&rtn, seg_rows, seg_cols, num_open_segs);
/* read elevation input and mark NULL/masked cells */
/* scattered access: alt, watalt, bitflags, asp */
@@ -398,6 +404,34 @@
MASK_flag = (do_points < nrows * ncols);
+ if (rtn_flag) {
+ char rtn_value;
+ G_percent(r, nrows, 1);
+ if (Rast_is_c_null_value(&block_value))
+ else {
+ block_value = 0;
+ rtn_value = block_value;
+ bseg_put(&rtn, &rtn_value, r, c);
+ G_percent(nrows, nrows, 1); /* finish it */
+ Rast_close(fd);
+ G_free(buf);
/* do RUSLE */
if (er_flag) {
if (ob_flag) {
Modified: grass/trunk/raster/r.watershed/seg/main.c
--- grass/trunk/raster/r.watershed/seg/main.c 2018-08-16 16:26:31 UTC (rev 73112)
+++ grass/trunk/raster/r.watershed/seg/main.c 2018-08-17 11:39:27 UTC (rev 73113)
@@ -36,7 +36,7 @@
SSEG astar_pts;
-BSEG s_b;
+BSEG s_b, rtn;
CSEG dis, alt, bas, haf, r_h, dep;
@@ -52,7 +52,7 @@
thr_name[8];
@@ -62,7 +62,7 @@
FILE *fp;
Modified: grass/trunk/raster/r.watershed/seg/sseg_open.c
--- grass/trunk/raster/r.watershed/seg/sseg_open.c 2018-08-16 16:26:31 UTC (rev 73112)
+++ grass/trunk/raster/r.watershed/seg/sseg_open.c 2018-08-17 11:39:27 UTC (rev 73113)
@@ -5,7 +5,7 @@
#include "Gwater.h"
int
-seg_open(SSEG * sseg, GW_LARGE_INT nrows, GW_LARGE_INT ncols, int row_in_seg,
+seg_open(SSEG * sseg, GW_LARGE_INT rows, GW_LARGE_INT cols, int row_in_seg,
int col_in_seg, int nsegs_in_memory, int size_struct)
char *filename;
@@ -20,7 +20,7 @@
G_warning("seg_open(): unable to create segment file");
return -2;
- if (0 > (errflag = Segment_format(fd, nrows, ncols,
+ if (0 > (errflag = Segment_format(fd, rows, cols,
row_in_seg, col_in_seg, size_struct))) {
close(fd);
unlink(filename);
