[GRASS-SVN] r73115 - grass/trunk/vector/v.vect.stats
svn_grass at osgeo.org
Fri Aug 17 06:00:12 PDT 2018
Author: martinl
Date: 2018-08-17 06:00:12 -0700 (Fri, 17 Aug 2018)
New Revision: 73115
grass/trunk/vector/v.vect.stats/main.c
v.vect.stats: guisections improvement
Modified: grass/trunk/vector/v.vect.stats/main.c
--- grass/trunk/vector/v.vect.stats/main.c 2018-08-17 12:42:49 UTC (rev 73114)
+++ grass/trunk/vector/v.vect.stats/main.c 2018-08-17 13:00:12 UTC (rev 73115)
@@ -150,6 +150,7 @@
point_type_opt->answer = "point";
point_type_opt->label = _("Feature type");
point_type_opt->required = NO;
+ point_type_opt->guisection = _("Selection");
point_field_opt = G_define_standard_option(G_OPT_V_FIELD);
point_field_opt->key = "points_layer";
@@ -179,7 +180,7 @@
area_where_opt = G_define_standard_option(G_OPT_DB_WHERE);
area_where_opt->key = "areas_where";
area_where_opt->label = _("WHERE conditions of SQL statement without 'where' keyword for area map");;
- area_opt->guisection = _("Selection");
+ area_where_opt->guisection = _("Selection");
method_opt = G_define_option();
method_opt->key = "method";
@@ -199,38 +200,33 @@
point_column_opt = G_define_standard_option(G_OPT_DB_COLUMN);
point_column_opt->key = "points_column";
- point_column_opt->required = NO;
- point_column_opt->multiple = NO;
point_column_opt->label =
_("Column name of points map to use for statistics");
point_column_opt->description = _("Column of points map must be numeric");
- count_column_opt = G_define_option();
+ count_column_opt = G_define_standard_option(G_OPT_DB_COLUMN);
count_column_opt->key = "count_column";
count_column_opt->type = TYPE_STRING;
- count_column_opt->required = NO;
- count_column_opt->multiple = NO;
count_column_opt->label = _("Column name to upload points count");
count_column_opt->description =
_("Column to hold points count, must be of type integer, will be created if not existing");
- stats_column_opt = G_define_option();
+ stats_column_opt = G_define_standard_option(G_OPT_DB_COLUMN);
stats_column_opt->key = "stats_column";
- stats_column_opt->type = TYPE_STRING;
- stats_column_opt->required = NO;
- stats_column_opt->multiple = NO;
stats_column_opt->label = _("Column name to upload statistics");
stats_column_opt->description =
_("Column to hold statistics, must be of type double, will be created if not existing");
fs_opt = G_define_standard_option(G_OPT_F_SEP);
+ fs_opt->guisection = _("Print");
print_flag = G_define_flag();
print_flag->key = 'p';
print_flag->label =
_("Print output to stdout, do not update attribute table");
print_flag->description = _("First column is always area category");
+ print_flag->guisection = _("Print");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
