[GRASS-SVN] r73121 - grass/branches/releasebranch_7_4/vector/v.vect.stats
svn_grass at osgeo.org
Fri Aug 17 09:11:37 PDT 2018
Author: martinl
Date: 2018-08-17 09:11:37 -0700 (Fri, 17 Aug 2018)
New Revision: 73121
grass/branches/releasebranch_7_4/vector/v.vect.stats/main.c
v.vect.stats: map label/description UI fix (merge r73120 from trunk)
Modified: grass/branches/releasebranch_7_4/vector/v.vect.stats/main.c
--- grass/branches/releasebranch_7_4/vector/v.vect.stats/main.c 2018-08-17 16:09:43 UTC (rev 73120)
+++ grass/branches/releasebranch_7_4/vector/v.vect.stats/main.c 2018-08-17 16:11:37 UTC (rev 73121)
@@ -136,12 +136,12 @@
point_opt = G_define_standard_option(G_OPT_V_INPUT);
point_opt->key = "points";
- point_opt->description = _("Name of existing vector map with points");
+ point_opt->label = _("Name of existing vector map with points");
/* point_opt->guisection = _("Required"); */
area_opt = G_define_standard_option(G_OPT_V_INPUT);
area_opt->key = "areas";
- area_opt->description = _("Name of existing vector map with areas");
+ area_opt->label = _("Name of existing vector map with areas");
/* area_opt->guisection = _("Required"); */
point_type_opt = G_define_standard_option(G_OPT_V_TYPE);
