[GRASS-SVN] r73133 - in grass/branches/releasebranch_7_4: gui/wxpython/gui_core vector/v.vect.stats
svn_grass at osgeo.org
Tue Aug 21 13:24:34 PDT 2018
Author: martinl
Date: 2018-08-21 13:24:34 -0700 (Tue, 21 Aug 2018)
New Revision: 73133
grass/branches/releasebranch_7_4/gui/wxpython/gui_core/forms.py
grass/branches/releasebranch_7_4/gui/wxpython/gui_core/gselect.py
grass/branches/releasebranch_7_4/vector/v.vect.stats/main.c
G_OPT_DB_WHERE - non-functional 'table' icon in gui, closes #3619
(merge r73114, r73118-73119 from trunk)
Modified: grass/branches/releasebranch_7_4/gui/wxpython/gui_core/forms.py
--- grass/branches/releasebranch_7_4/gui/wxpython/gui_core/forms.py 2018-08-21 19:41:15 UTC (rev 73132)
+++ grass/branches/releasebranch_7_4/gui/wxpython/gui_core/forms.py 2018-08-21 20:24:34 UTC (rev 73133)
@@ -270,7 +270,11 @@
pMapL = self.task.get_param(
p['wxId'][0], element='wxId-bind', raiseError=False)
if pMapL:
- map = pMapL.get('value', '')
+ gui_deps = pMapL.get('guidependency', None)
+ if gui_deps:
+ gui_deps = gui_deps.split(',')
+ if not gui_deps or (gui_deps and p.get('name', '') in gui_deps):
+ map = pMapL.get('value', '')
if name == 'TableSelect' or \
(name == 'ColumnSelect' and not map):
@@ -292,12 +296,13 @@
# determine format
native = True
- for id in pMap['wxId']:
- winVec = self.parent.FindWindowById(id)
- if winVec.GetName() == 'VectorFormat' and \
- winVec.GetSelection() != 0:
- native = False
- break
+ if pMap:
+ for id in pMap['wxId']:
+ winVec = self.parent.FindWindowById(id)
+ if winVec.GetName() == 'VectorFormat' and \
+ winVec.GetSelection() != 0:
+ native = False
+ break
# TODO: update only if needed
if native:
if map:
Modified: grass/branches/releasebranch_7_4/gui/wxpython/gui_core/gselect.py
--- grass/branches/releasebranch_7_4/gui/wxpython/gui_core/gselect.py 2018-08-21 19:41:15 UTC (rev 73132)
+++ grass/branches/releasebranch_7_4/gui/wxpython/gui_core/gselect.py 2018-08-21 20:24:34 UTC (rev 73133)
@@ -2708,6 +2708,7 @@
super(SqlWhereSelect, self).__init__(parent=parent, id=wx.ID_ANY)
self.parent = parent
+ self.vector_map = None
self.sqlField = wx.TextCtrl(parent=self, id=wx.ID_ANY,
size=globalvar.DIALOG_TEXTCTRL_SIZE)
@@ -2738,6 +2739,8 @@
def _onClick(self, event):
from dbmgr.sqlbuilder import SQLBuilderWhere
try:
+ if not self.vector_map:
+ raise GException(_('No vector map selected'))
win = SQLBuilderWhere(parent=self,
vectmap=self.vector_map,
layer=self.vector_layer)
Modified: grass/branches/releasebranch_7_4/vector/v.vect.stats/main.c
--- grass/branches/releasebranch_7_4/vector/v.vect.stats/main.c 2018-08-21 19:41:15 UTC (rev 73132)
+++ grass/branches/releasebranch_7_4/vector/v.vect.stats/main.c 2018-08-21 20:24:34 UTC (rev 73133)
@@ -138,7 +138,7 @@
point_opt->key = "points";
point_opt->label = _("Name of existing vector map with points");
/* point_opt->guisection = _("Required"); */
area_opt = G_define_standard_option(G_OPT_V_INPUT);
area_opt->key = "areas";
area_opt->label = _("Name of existing vector map with areas");
@@ -226,7 +226,18 @@
_("Print output to stdout, do not update attribute table");
print_flag->description = _("First column is always area category");
print_flag->guisection = _("Print");
+ /* GUI dependencies */
+ G_asprintf((char **) &(point_opt->guidependency), "%s,%s,%s",
+ point_field_opt->key, point_where_opt->key, point_column_opt->key);
+ G_asprintf((char **) &(point_field_opt->guidependency), "%s,%s",
+ point_where_opt->key, point_column_opt->key);
+ G_asprintf((char **) &(area_opt->guidependency), "%s,%s,%s,%s",
+ area_field_opt->key, area_where_opt->key,
+ count_column_opt->key, stats_column_opt->key);
+ G_asprintf((char **) &(area_field_opt->guidependency), "%s,%s,%s",
+ area_where_opt->key, count_column_opt->key, stats_column_opt->key);
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
