[GRASS-SVN] r73153 - in grass/trunk/gui/wxpython: . startup
svn_grass at osgeo.org
Thu Aug 23 20:05:13 PDT 2018
Author: wenzeslaus
Date: 2018-08-23 20:05:13 -0700 (Thu, 23 Aug 2018)
New Revision: 73153
Added:
grass/trunk/gui/wxpython/startup/guiutils.py
grass/trunk/gui/wxpython/gis_set.py
grass/trunk/gui/wxpython/startup/utils.py
wxGUI/startup: file to separate GUI-dependent utils (now only db/loc/mapset setting)
Modified: grass/trunk/gui/wxpython/gis_set.py
--- grass/trunk/gui/wxpython/gis_set.py 2018-08-24 02:45:39 UTC (rev 73152)
+++ grass/trunk/gui/wxpython/gis_set.py 2018-08-24 03:05:13 UTC (rev 73153)
@@ -39,6 +39,7 @@
from core.utils import GetListOfLocations, GetListOfMapsets
from startup.utils import (
get_lockfile_if_present, get_possible_database_path)
+from startup.guiutils import SetSessionMapset
from location_wizard.dialogs import RegionDef
from gui_core.dialogs import TextEntryDialog
from gui_core.widgets import GenericValidator, StaticWrapText
@@ -877,12 +878,7 @@
for line in ret.splitlines():
self.listOfMapsetsSelectable += line.split(' ')
else:
- RunCommand("g.gisenv",
- set="GISDBASE=%s" % self.gisdbase)
- set="LOCATION_NAME=%s" % locationName)
- set="MAPSET=PERMANENT")
+ self.SetLocation(self.gisdbase, locationName, "PERMANENT")
# first run only
self.listOfMapsetsSelectable = copy.copy(self.listOfMapsets)
@@ -1110,12 +1106,7 @@
self.ExitSuccessfully()
def SetLocation(self, dbase, location, mapset):
- set="GISDBASE=%s" % dbase)
- set="LOCATION_NAME=%s" % location)
- set="MAPSET=%s" % mapset)
+ SetSessionMapset(dbase, location, mapset)
def _getDefaultMapsetName(self):
"""Returns default name for mapset."""
Added: grass/trunk/gui/wxpython/startup/guiutils.py
--- grass/trunk/gui/wxpython/startup/guiutils.py (rev 0)
+++ grass/trunk/gui/wxpython/startup/guiutils.py 2018-08-24 03:05:13 UTC (rev 73153)
@@ -0,0 +1,24 @@
+ at package startup.guiutils
+ at brief General GUI-dependent utilities for GUI startup of GRASS GIS
+(C) 2018 by Vaclav Petras the GRASS Development Team
+This program is free software under the GNU General Public License
+(>=v2). Read the file COPYING that comes with GRASS for details.
+ at author Vaclav Petras <wenzeslaus gmail com>
+This is for code which depend on something from GUI (wx or wxGUI).
+from core.gcmd import RunCommand
+def SetSessionMapset(database, location, mapset):
+ """Sets database, location and mapset for the current session"""
+ RunCommand("g.gisenv", set="GISDBASE=%s" % database)
+ RunCommand("g.gisenv", set="LOCATION_NAME=%s" % location)
+ RunCommand("g.gisenv", set="MAPSET=%s" % mapset)
Property changes on: grass/trunk/gui/wxpython/startup/guiutils.py
___________________________________________________________________
Added: svn:mime-type
## -0,0 +1 ##
+text/x-python
\ No newline at end of property
Added: svn:eol-style
## -0,0 +1 ##
+native
Modified: grass/trunk/gui/wxpython/startup/utils.py
--- grass/trunk/gui/wxpython/startup/utils.py 2018-08-24 02:45:39 UTC (rev 73152)
+++ grass/trunk/gui/wxpython/startup/utils.py 2018-08-24 03:05:13 UTC (rev 73153)
@@ -1,7 +1,7 @@
@package startup.utils
- at brief General utilities for GUI startup of GRASS GIS
+ at brief General GUI-independent utilities for GUI startup of GRASS GIS
(C) 2017-2018 by Vaclav Petras the GRASS Development Team
@@ -9,6 +9,10 @@
@author Vaclav Petras <wenzeslaus gmail com>
+This file should not use (import) anything from GUI code (wx or wxGUI).
+This can potentially be part of the Python library (i.e. it needs to
+solve the errors etc. in a general manner).
