[GRASS-SVN] r73162 - grass/branches/releasebranch_7_4/raster/r.compress
Fri Aug 24 03:37:52 PDT 2018
Author: neteler
Date: 2018-08-24 03:37:52 -0700 (Fri, 24 Aug 2018)
New Revision: 73162
   grass/branches/releasebranch_7_4/raster/r.compress/r.compress.html
r.compress manual: example update to current state of r.compress
Modified: grass/branches/releasebranch_7_4/raster/r.compress/r.compress.html
--- grass/branches/releasebranch_7_4/raster/r.compress/r.compress.html	2018-08-24 10:37:09 UTC (rev 73161)
+++ grass/branches/releasebranch_7_4/raster/r.compress/r.compress.html	2018-08-24 10:37:52 UTC (rev 73162)
@@ -42,11 +42,10 @@
 <tt>GRASS_ZLIB_LEVEL</tt>.
 <p>
-Compressed raster maps may be decompressed using <em>r.compress</em> to
-return them to their original format, using the <b>-u</b> flag. If a
-raster map was already decompressed and the <b>-u</b> flag is set, the
-module simply informs the user that the map is already decompressed and
-exits.
+Compressed raster maps may be decompressed using <em>r.compress</em>
+with the <b>-u</b> flag. If a raster map was already decompressed and
+the <b>-u</b> flag is set, the module simply informs the user that the
+map is already decompressed and exits.
 <p>
 Information about the compression method and data type of the input
@@ -90,10 +89,10 @@
 <li><tt>BZIP2</tt> (slowest, high compression)</li>
 </ul>
-Important: the NULL file compression must be explicitly turned on with
-<tt>export GRASS_COMPRESS_NULLS=1</tt> - such raster maps can then only
-be opened with GRASS GIS 7.2.0 or later. NULL file compression can be
-managed with <b>r.null -z</b>.
+Important: the NULL file compression can be turned off with
+<tt>export GRASS_COMPRESS_NULLS=0</tt>. Raster maps with NULL file
+compression can only be opened with GRASS GIS 7.2.0 or later. NULL file
+compression for a particular raster map can be managed with <b>r.null -z</b>.
 The NULL file compression is using the LZ4 method as being the best compromise
 between speed and compression rate.
@@ -188,40 +187,47 @@
 <h2>EXAMPLES</h2>
-Printing of current compression state:
+<h3>Printing of current compression state</h3>
+Example for an uncompressed raster map:
 <div class="code"><pre>
 r.compress compressed_no -p
   <compressed_no> (method 0: NONE). Data type: <CELL>
 </pre></div>
-<p>
-Applying RLE compression to a copy of the uncompressed map (not recommended!):
+<!-- do no advertise not recommended and deprecated compressions!
+<h3>Applying RLE compression to a copy of the uncompressed map (not recommended!)</h3>
 # compression of map using the deprecated RLE compression
 g.copy raster=compressed_no,compressed_RLE
-export GRASS_INT_ZLIB=0 # RLE
+export GRASS_COMPRESSOR=RLE # RLE
 r.compress compressed_RLE
 r.compress compressed_RLE -p
   <compressed_RLE> is compressed (method 1: RLE). Data type: <CELL>
-unset GRASS_INT_ZLIB
+unset GRASS_COMPRESSOR # switch back to default
 </pre></div>
-<p>
-Applying ZLIB compression to a copy of the uncompressed map:
+<h3>Applying ZLIB compression</h3>
+Applying ZLIB compression to a copy of the uncompressed map from above:
 # compression of map using ZLIB compression
 g.copy raster=compressed_no,compressed_ZLIB
-export GRASS_INT_ZLIB=1 # ZLIB
+export GRASS_COMPRESSOR=ZLIB # ZLIB
 r.compress compressed_ZLIB
 r.compress compressed_ZLIB -p
   <compressed_ZLIB> is compressed (method 2: ZLIB). Data type: <CELL>
 </pre></div>
-<p>
-Applying BZIP2 compression to a copy of the ZLIB-compressed map:
+<h3>Applying BZIP2 compression</h3>
+Applying BZIP2 compression to a copy of the ZLIB-compressed map from above:
 # compression of map using BZIP2 compression
 g.copy raster=compressed_ZLIB,compressed_BZIP2
@@ -230,7 +236,7 @@
 r.compress compressed_BZIP2
 r.compress compressed_BZIP2 -p
   <compressed_BZIP2> is compressed (method 4: BZIP2). Data type: <CELL>
-unset GRASS_COMPRESSOR
 </pre></div>
 <h2>SEE ALSO</h2>
