[GRASS-SVN] r73164 - grass-addons/grass7/vector/v.rast.bufferstats
Fri Aug 24 04:35:59 PDT 2018
Author: sbl
Date: 2018-08-24 04:35:59 -0700 (Fri, 24 Aug 2018)
New Revision: 73164
   grass-addons/grass7/vector/v.rast.bufferstats/v.rast.bufferstats.html
v.rast.bufferstats: rmove dif tags
Modified: grass-addons/grass7/vector/v.rast.bufferstats/v.rast.bufferstats.html
--- grass-addons/grass7/vector/v.rast.bufferstats/v.rast.bufferstats.html	2018-08-24 11:25:11 UTC (rev 73163)
+++ grass-addons/grass7/vector/v.rast.bufferstats/v.rast.bufferstats.html	2018-08-24 11:35:59 UTC (rev 73164)
@@ -1,8 +1,8 @@
 <h2>DESCRIPTION:</h2>
-<p>The purpose of the <em>v.rast.bufferstats</em> module is "to provide
-local environmental context to" a series of input geometries.
+The purpose of the <em>v.rast.bufferstats</em> module is to provide
+local environmental context to a series of input geometries.
 It computes statistics from multiple input raster maps within multiple
-buffers around selected geometries in the input vector map.</p>
+buffers around selected geometries in the input vector map.
 <p>Available statistics are either</p>
 <ol type="a">
 <li>statistics provided by <em>r.univar</em> or</li>
@@ -16,14 +16,10 @@
 cat | prefix | buffer| statistic/measure | value<br>
 separated by the user defined separator (default is |).</p>
-<div id="note">
 <h2>NOTE</h2>
-<p>The module temporarily modifies the computational region. The region is set to the
-extent of the respecive buffers, while the alignement of the current region is kept.</p>
-</div>
+The module temporarily modifies the computational region. The region is set to the
+extent of the respecive buffers, while the alignement of the current region is kept.
-<div id="examples">
 <h2>EXAMPLES</h2>
 <div class="code"><pre>
@@ -40,15 +36,13 @@
 v.rast.bufferstats input= raster=altitude,slope,aspect buffers=100,250,500 column_prefix=altitude,slope,aspect methods=minimum,maximum,average,stddev percentile=5,95
 </pre></div>
-</div>
-<div id="known_issues">
 <h2>KNOWN ISSUES</h2>
-<p>In order to avoid topological issues with overlapping buffers, the module loops over the
+In order to avoid topological issues with overlapping buffers, the module loops over the
 input geometries. However, this comes at costs with regards to performance.
 For a larger number of geometries in the vector map, it can be therefore more appropriate to
 compute neighborhood statistics with <em>r.neighbors</em> and to extract (<em>v.what.rast</em>,
-<em>r.what</em>) or aggregate (<em>v.rast.stats</em>) from those maps with neighborhood statistics.</p>
+<em>r.what</em>) or aggregate (<em>v.rast.stats</em>) from those maps with neighborhood statistics.
 <p>
 The module is affected by the following underlying library issues:
@@ -61,18 +55,13 @@
 https://trac.osgeo.org/grass/ticket/3628
 </p>
-</div>
-<div id="seealso">
 <h2>SEE ALSO</h2>
 <a href="r.univar.html">r.univar</a>
 <a href="r.stats.html">r.stats</a>
 <a href="v.rast.stats.html">v.rast.stats</a>
-</div>
-<div id="author">
 <h2>AUTHOR</h2>
 Stefan Blumentrath, Norwegian Institute for Nature Research, Oslo, Norway
-</div>
+<p><i>Last changed: $Date$</i>
