[GRASS-SVN] r73174 - in grass/trunk/gui/wxpython: . startup
Fri Aug 24 18:06:26 PDT 2018
Author: wenzeslaus
Date: 2018-08-24 18:06:26 -0700 (Fri, 24 Aug 2018)
New Revision: 73174
   grass/trunk/gui/wxpython/gis_set.py
   grass/trunk/gui/wxpython/startup/utils.py
wxGUI/startup: move delete mapset and location to separate functions
Modified: grass/trunk/gui/wxpython/gis_set.py
--- grass/trunk/gui/wxpython/gis_set.py	2018-08-25 00:52:12 UTC (rev 73173)
+++ grass/trunk/gui/wxpython/gis_set.py	2018-08-25 01:06:26 UTC (rev 73174)
@@ -22,7 +22,6 @@
 import os
 import sys
-import shutil
 import copy
 import platform
 import codecs
@@ -39,6 +38,7 @@
 from core.utils import GetListOfLocations, GetListOfMapsets
 from startup.utils import (
     get_lockfile_if_present, get_possible_database_path, create_mapset)
+import startup.utils as sutils
 from startup.guiutils import SetSessionMapset, NewMapsetDialog
 from location_wizard.dialogs import RegionDef
 from gui_core.dialogs import TextEntryDialog
@@ -758,7 +758,7 @@
         if dlg.ShowModal() == wx.ID_YES:
             try:
-                shutil.rmtree(os.path.join(self.gisdbase, location, mapset))
+                sutils.delete_mapset(self.gisdbase, location, mapset)
                 self.OnSelectLocation(None)
                 self.lbmapsets.SetSelection(0)
             except:
@@ -786,7 +786,7 @@
             try:
-                shutil.rmtree(os.path.join(self.gisdbase, location))
+                sutils.delete_location(self.gisdbase, location)
                 self.UpdateLocations(self.gisdbase)
                 self.lblocations.SetSelection(0)
Modified: grass/trunk/gui/wxpython/startup/utils.py
--- grass/trunk/gui/wxpython/startup/utils.py	2018-08-25 00:52:12 UTC (rev 73173)
+++ grass/trunk/gui/wxpython/startup/utils.py	2018-08-25 01:06:26 UTC (rev 73174)
@@ -82,3 +82,17 @@
     shutil.copy(region_path, mapset_path)
     # set permissions to u+rw,go+r (disabled)
     # os.chmod(os.path.join(database,location,mapset,'WIND'), 0644)
+def delete_mapset(database, location, mapset):
+    """Deletes a specified mapset"""
+    if mapset == 'PERMANENT':
+        # TODO: translatable or not?
+        raise ValueError("Mapset PERMANENT cannot be deleted"
+                         " (whole location can be)")
+    shutil.rmtree(os.path.join(database, location, mapset))
+def delete_location(database, location):
+    """Deletes a specified location"""
+    shutil.rmtree(os.path.join(database, location))
