[GRASS-SVN] r73197 - grass/trunk/lib/init
svn_grass at osgeo.org
Mon Aug 27 19:40:46 PDT 2018
Author: wenzeslaus
Date: 2018-08-27 19:40:46 -0700 (Mon, 27 Aug 2018)
New Revision: 73197
grass/trunk/lib/init/grass.py
init: location variable to path, more comments
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2018-08-27 16:33:07 UTC (rev 73196)
+++ grass/trunk/lib/init/grass.py 2018-08-28 02:40:46 UTC (rev 73197)
@@ -931,21 +931,25 @@
gdb=gisdbase, lc=location_name, sep=os.path.sep))
if gisdbase and location_name and mapset:
- location = os.path.join(gisdbase, location_name, mapset)
+ path = os.path.join(gisdbase, location_name, mapset)
- # check if 'location' is a valid GRASS location/mapset
- if not is_mapset_valid(location):
+ # check if 'path' is a valid GRASS location/mapset
+ if not is_mapset_valid(path):
if not create_new:
- # 'location' is not valid, check if 'location_name' is
- # a valid GRASS location
+ # 'path' is not a valid mapset and users does not
+ # want to create anything new
fatal(get_mapset_invalid_reason(gisdbase, location_name, mapset))
else:
- # 'location' is not valid, the user wants to create
+ # 'path' is not valid and the user wants to create
# mapset on the fly
+ # check if 'location_name' is a valid GRASS location
if not is_location_valid(gisdbase, location_name):
if not tmp_location:
- # 'location_name' is not a valid GRASS location,
- # create new location and 'PERMANENT' mapset
+ # 'location_name' is not a valid GRASS location
+ # and user requested its creation, so we parsed
+ # the path wrong and need to move one level
+ # and use 'PERMANENT' mapset
+ # (we already got that right in case of tmploc)
gisdbase = os.path.join(gisdbase, location_name)
location_name = mapset
mapset = "PERMANENT"
@@ -952,18 +956,23 @@
if is_location_valid(gisdbase, location_name):
fatal(_("Failed to create new location. "
"The location <%s> already exists." % location_name))
+ # create new location based on the provided EPSG/...
create_location(gisdbase, location_name, geofile)
else:
# 'location_name' is a valid GRASS location,
# create new mapset
- if os.path.exists(location):
+ if os.path.exists(path):
+ # not a valid mapset, but dir exists, assuming
+ # broken/incomplete mapset
warning(_("Missing WIND file"))
else:
- os.mkdir(location)
+ # create mapset directory
+ os.mkdir(path)
+ # make directory a mapset, add the region
# copy PERMANENT/DEFAULT_WIND to <mapset>/WIND
s = readfile(os.path.join(gisdbase, location_name,
"PERMANENT", "DEFAULT_WIND"))
- writefile(os.path.join(location, "WIND"), s)
+ writefile(os.path.join(path, "WIND"), s)
if os.access(gisrc, os.R_OK):
kv = read_gisrc(gisrc)
