[GRASS-SVN] r73199 - grass/trunk/lib/init
svn_grass at osgeo.org
Mon Aug 27 20:43:35 PDT 2018
Author: wenzeslaus
Date: 2018-08-27 20:43:35 -0700 (Mon, 27 Aug 2018)
New Revision: 73199
grass/trunk/lib/init/grass.py
init: more detailed info about creating locations and mapsets and error states
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2018-08-28 02:43:53 UTC (rev 73198)
+++ grass/trunk/lib/init/grass.py 2018-08-28 03:43:35 UTC (rev 73199)
@@ -894,6 +894,42 @@
mapset=mapset, loc=location)
+def can_create_location(gisdbase, location):
+ """Checks if location can be created"""
+ path = os.path.join(gisdbase, location)
+ if os.path.exists(path):
+ return False
+ return True
+def cannot_create_location_reason(gisdbase, location):
+ """Returns a message describing why location cannot be created
+ The goal is to provide the most suitable error message
+ (rather than to do a quick check).
+ :param gisdbase: Path to GRASS GIS database directory
+ :param location: name of a Location
+ :returns: translated message
+ if is_location_valid(gisdbase, location):
+ return _("Unable to create new location because"
+ " the location <{location}>"
+ " already exists.").format(**locals())
+ elif os.path.isfile(path):
+ return _("Unable to create new location <{location}> because"
+ " <{path}> is a file.").format(**locals())
+ elif os.path.isdir(path):
+ " the directory <{path}>"
+ else:
+ return _("Unable to create new location in"
+ " for an unknown reason.").format(**locals())
def set_mapset(gisrc, arg=None, geofile=None, create_new=False,
tmp_location=False, tmpdir=None):
"""Selected Location and Mapset are checked and created if requested
@@ -932,15 +968,21 @@
if gisdbase and location_name and mapset:
path = os.path.join(gisdbase, location_name, mapset)
+ # check if 'path' is a valid GRASS location/mapset
+ path_is_valid_mapset = is_mapset_valid(path)
- # check if 'path' is a valid GRASS location/mapset
- if not is_mapset_valid(path):
+ if path_is_valid_mapset and create_new:
+ warning(_("Mapset <{}> already exists. Ignoring the"
+ " request to create it. Note that this warning"
+ " may become an error in future versions.")
+ .format(path))
+ if not path_is_valid_mapset:
if not create_new:
- # 'path' is not a valid mapset and users does not
+ # 'path' is not a valid mapset and user does not
# want to create anything new
fatal(get_mapset_invalid_reason(gisdbase, location_name, mapset))
else:
- message(_("Creating new GRASS GIS location/mapset..."))
# 'path' is not valid and the user wants to create
# mapset on the fly
# check if 'location_name' is a valid GRASS location
@@ -954,18 +996,32 @@
gisdbase = os.path.join(gisdbase, location_name)
location_name = mapset
mapset = "PERMANENT"
- if is_location_valid(gisdbase, location_name):
- fatal(_("Failed to create new location. "
- "The location <%s> already exists." % location_name))
+ if not can_create_location(gisdbase, location_name):
+ fatal(cannot_create_location_reason(
+ gisdbase, location_name))
# create new location based on the provided EPSG/...
+ message(_("Creating new GRASS GIS location <{}>...")
+ .format(location_name))
create_location(gisdbase, location_name, geofile)
else:
# 'location_name' is a valid GRASS location,
# create new mapset
- if os.path.exists(path):
+ message(_("Creating new GRASS GIS mapset <{}>...")
+ .format(mapset))
+ if os.path.isfile(path):
# not a valid mapset, but dir exists, assuming
# broken/incomplete mapset
- warning(_("Missing WIND file"))
+ fatal(_("Unable to create new mapset <{mapset}>"
+ " because <{path}> is a file.")
+ .format(mapset=mapset, path=path))
+ # not a valid mapset, but dir exists, assuming
+ # broken/incomplete mapset
+ warning(_("The mapset <{}> is missing the WIND file"
+ " (computational region). It will be"
+ " fixed now. Note that this warning"
+ .format(mapset))
else:
# create mapset directory
os.mkdir(path)
