[GRASS-SVN] r73201 -	grass-addons/grass7/imagery/i.ann.maskrcnn/maskrcnnlib
    svn_grass at osgeo.org
    Tue Aug 28 06:02:06 PDT 2018
Author: pesekon2
Date: 2018-08-28 06:02:06 -0700 (Tue, 28 Aug 2018)
New Revision: 73201
   grass-addons/grass7/imagery/i.ann.maskrcnn/maskrcnnlib/config.py
   grass-addons/grass7/imagery/i.ann.maskrcnn/maskrcnnlib/model.py
   grass-addons/grass7/imagery/i.ann.maskrcnn/maskrcnnlib/utils.py
spellcheck and update API for newer versions of libraries
Modified: grass-addons/grass7/imagery/i.ann.maskrcnn/maskrcnnlib/config.py
--- grass-addons/grass7/imagery/i.ann.maskrcnn/maskrcnnlib/config.py	2018-08-28 08:40:12 UTC (rev 73200)
+++ grass-addons/grass7/imagery/i.ann.maskrcnn/maskrcnnlib/config.py	2018-08-28 13:02:06 UTC (rev 73201)
@@ -57,7 +57,7 @@
     # How many anchors per image to use for RPN training
     RPN_TRAIN_ANCHORS_PER_IMAGE = 256
-    # ROIs kept after non-maximum supression (training and inference)
+    # ROIs kept after non-maximum suppression (training and inference)
     POST_NMS_ROIS_TRAINING = 2000
     POST_NMS_ROIS_INFERENCE = 1000
@@ -100,7 +100,7 @@
     # Learning rate and momentum
     # The Mask RCNN paper uses lr=0.02, but on TensorFlow it causes
-    # weights to explode. Likely due to differences in optimzer
+    # weights to explode. Likely due to differences in optimizer
     # implementation.
     LEARNING_RATE = 0.001  # 0.002 before change
     LEARNING_MOMENTUM = 0.9
@@ -161,7 +161,7 @@
         self.VALIDATION_STEPS = validationSteps
         # Input image resizing
-        # Generally, use the "square" resizing mode for training and inferencing
+        # Generally, use the "square" resizing mode for training and predicting
         # and it should work well in most cases. In this mode, images are scaled
         # up such that the small side is = IMAGE_MIN_DIM, but ensuring that the
         # scaling doesn't make the long side > IMAGE_MAX_DIM. Then the image is
@@ -204,6 +204,8 @@
             [self.IMAGE_MAX_DIM, self.IMAGE_MAX_DIM, 3])
         # Compute backbone size from input image size
+        # TODO Ondrej Pesek: Maybe delete it and see Matterport's (avoid math
+        #  import)
         self.BACKBONE_SHAPES = np.array(
             [[int(math.ceil(self.IMAGE_SHAPE[0] / stride)),
               int(math.ceil(self.IMAGE_SHAPE[1] / stride))]
@@ -212,7 +214,7 @@
         # Train or freeze batch normalization layers
         #  None: Train BN layers in a normal mode
         #  False: Freeze BN layers (recommended for small batch size)
-        #  True: Set layer in training mode even when inferencing
+        #  True: Set layer in training mode even when predicting
         self.TRAIN_BN = trainBatchNorm
         # Image meta data length
Modified: grass-addons/grass7/imagery/i.ann.maskrcnn/maskrcnnlib/model.py
--- grass-addons/grass7/imagery/i.ann.maskrcnn/maskrcnnlib/model.py	2018-08-28 08:40:12 UTC (rev 73200)
+++ grass-addons/grass7/imagery/i.ann.maskrcnn/maskrcnnlib/model.py	2018-08-28 13:02:06 UTC (rev 73201)
@@ -1,6 +1,6 @@
 Mask R-CNN
-The main Mask R-CNN model implemenetation.
+The main Mask R-CNN model implementation.
 Copyright (c) 2017 Matterport, Inc.
 Licensed under the MIT License (see LICENSE for details)
@@ -61,13 +61,12 @@
     so this layer is often frozen (via setting in Config class) and functions
     as linear layer.
     def call(self, inputs, training=None):
         Note about training values:
             None: Train BN layers. This is the normal mode
             False: Freeze BN layers. Good when batch size is small
-            True: (don't use). Set layer in training mode even when inferencing
+            True: (don't use). Set layer in training mode even when making inferences
         return super(self.__class__, self).call(inputs, training=training)
@@ -101,12 +100,12 @@
     """The identity_block is the block that has no conv layer at shortcut
     # Arguments
         input_tensor: input tensor
-        kernel_size: defualt 3, the kernel size of middle conv layer at main path
+        kernel_size: default 3, the kernel size of middle conv layer at main path
         filters: list of integers, the nb_filters of 3 conv layer at main path
         stage: integer, current stage label, used for generating layer names
         block: 'a','b'..., current block label, used for generating layer names
         use_bias: Boolean. To use or not use a bias in conv layers.
-        train_bn: Boolean. Train or freeze Batch Norm layres
+        train_bn: Boolean. Train or freeze Batch Norm layers
     nb_filter1, nb_filter2, nb_filter3 = filters
     conv_name_base = 'res' + str(stage) + block + '_branch'
@@ -136,12 +135,12 @@
     """conv_block is the block that has a conv layer at shortcut
     # Arguments
     Note that from stage 3, the first conv layer at main path is with subsample=(2,2)
     And the shortcut should have subsample=(2,2) as well
@@ -176,7 +175,7 @@
     """Build a ResNet graph.
         architecture: Can be resnet50 or resnet101
         stage5: Boolean. If False, stage5 of the network is not created
     assert architecture in ["resnet50", "resnet101"]
     # Stage 1
@@ -271,8 +270,7 @@
         Proposals in normalized coordinates [batch, rois, (y1, x1, y2, x2)]
-    def __init__(self, proposal_count, nms_threshold,
-                 config=None, **kwargs):
+    def __init__(self, proposal_count, nms_threshold, config=None, **kwargs):
         super(ProposalLayer, self).__init__(**kwargs)
         self.config = config
         self.proposal_count = proposal_count
@@ -342,7 +340,7 @@
 def log2_graph(x):
-    """Implementatin of Log2. TF doesn't have a native implemenation."""
+    """Implementation of Log2. TF doesn't have a native implementation."""
     return tf.log(x) / tf.log(2.0)
@@ -404,7 +402,7 @@
             ix = tf.where(tf.equal(roi_level, level))
             level_boxes = tf.gather_nd(boxes, ix)
-            # Box indicies for crop_and_resize.
+            # Box indices for crop_and_resize.
             box_indices = tf.cast(ix[:, 0], tf.int32)
             # Keep track of which box is mapped to which level
@@ -462,9 +460,9 @@
     """Computes IoU overlaps between two sets of boxes.
     boxes1, boxes2: [N, (y1, x1, y2, x2)].
-    # 1. Tile boxes2 and repeate boxes1. This allows us to compare
+    # 1. Tile boxes2 and repeat boxes1. This allows us to compare
     # every boxes1 against every boxes2 without loops.
-    # TF doesn't have an equivalent to np.repeate() so simulate it
+    # TF doesn't have an equivalent to np.repeat() so simulate it
     # using tf.tile() and tf.reshape.
     b1 = tf.reshape(tf.tile(tf.expand_dims(boxes1, 1),
                             [1, 1, tf.shape(boxes2)[0]]), [-1, 4])
@@ -544,7 +542,7 @@
     crowd_iou_max = tf.reduce_max(crowd_overlaps, axis=1)
     no_crowd_bool = (crowd_iou_max < 0.001)
-    # Determine postive and negative ROIs
+    # Determine positive and negative ROIs
     roi_iou_max = tf.reduce_max(overlaps, axis=1)
     # 1. Positive ROIs are those with >= 0.5 IoU with a GT box
     positive_roi_bool = (roi_iou_max >= 0.5)
@@ -589,7 +587,7 @@
     # Compute mask targets
     boxes = positive_rois
     if config.USE_MINI_MASK:
-        # Transform ROI corrdinates from normalized image space
+        # Transform ROI coordinates from normalized image space
         # to normalized mini-mask space.
         y1, x1, y2, x2 = tf.split(positive_rois, 4, axis=1)
         gt_y1, gt_x1, gt_y2, gt_x2 = tf.split(roi_gt_boxes, 4, axis=1)
@@ -746,7 +744,7 @@
                 tf.gather(pre_nms_scores, ixs),
                 max_output_size=config.DETECTION_MAX_INSTANCES,
                 iou_threshold=config.DETECTION_NMS_THRESHOLD)
-        # Map indicies
+        # Map indices
         class_keep = tf.gather(keep, tf.gather(ixs, class_keep))
         # Pad with -1 so returned tensors have the same shape
         gap = config.DETECTION_MAX_INSTANCES - tf.shape(class_keep)[0]
@@ -849,8 +847,8 @@
         rpn_bbox: [batch, H, W, (dy, dx, log(dh), log(dw))] Deltas to be
                   applied to anchors.
-    # TODO: check if stride of 2 causes alignment issues if the featuremap
-    #       is not even.
+    # TODO: check if stride of 2 causes alignment issues if the feature map
+    # is not even.
     # Shared convolutional base of the RPN
     shared = KL.Conv2D(512, (3, 3), padding='same', activation='relu',
                        strides=anchor_stride,
@@ -913,12 +911,12 @@
     rois: [batch, num_rois, (y1, x1, y2, x2)] Proposal boxes in normalized
           coordinates.
-    feature_maps: List of feature maps from diffent layers of the pyramid,
+    feature_maps: List of feature maps from different layers of the pyramid,
                   [P2, P3, P4, P5]. Each has a different resolution.
     - image_meta: [batch, (meta data)] Image details. See compose_image_meta()
     pool_size: The width of the square feature map generated from ROI Pooling.
     num_classes: number of classes, which determines the depth of the results
     fc_layers_size: Size of the 2 FC layers
     Returns:
@@ -930,8 +928,7 @@
     # ROI Pooling
     # Shape: [batch, num_boxes, pool_height, pool_width, channels]
     x = PyramidROIAlign([pool_size, pool_size],
-                        name="roi_align_classifier")(
-                            [rois, image_meta] + feature_maps)
+                        name="roi_align_classifier")([rois, image_meta] + feature_maps)
     # Two 1024 FC layers (implemented with Conv2D for consistency)
     x = KL.TimeDistributed(KL.Conv2D(fc_layers_size, (pool_size, pool_size), padding="valid"),
                            name="mrcnn_class_conv1")(x)
@@ -968,12 +965,12 @@
           coordinates.
     Returns: Masks [batch, roi_count, height, width, num_classes]
@@ -1020,7 +1017,7 @@
 def smooth_l1_loss(y_true, y_pred):
     """Implements Smooth-L1 loss.
-    y_true and y_pred are typicallly: [N, 4], but could be any shape.
+    y_true and y_pred are typically: [N, 4], but could be any shape.
     diff = K.abs(y_true - y_pred)
     less_than_one = K.cast(K.less(diff, 1.0), "float32")
@@ -1045,7 +1042,7 @@
     # Pick rows that contribute to the loss and filter out the rest.
     rpn_class_logits = tf.gather_nd(rpn_class_logits, indices)
     anchor_class = tf.gather_nd(anchor_class, indices)
-    # Crossentropy loss
+    # Cross entropy loss
     loss = K.sparse_categorical_crossentropy(target=anchor_class,
                                              output=rpn_class_logits,
                                              from_logits=True)
@@ -1135,7 +1132,7 @@
     pred_bbox = K.reshape(pred_bbox, (-1, K.int_shape(pred_bbox)[2], 4))
     # Only positive ROIs contribute to the loss. And only
-    # the right class_id of each ROI. Get their indicies.
+    # the right class_id of each ROI. Get their indices.
     positive_roi_ix = tf.where(target_class_ids > 0)[:, 0]
     positive_roi_class_ids = tf.cast(
         tf.gather(target_class_ids, positive_roi_ix), tf.int64)
@@ -1198,10 +1195,9 @@
 def load_image_gt(dataset, config, image_id, augment=False, augmentation=None,
                   use_mini_mask=False):
-    Load and return ground truth data for an image (image, mask, bounding boxes).
+    """Load and return ground truth data for an image (image, mask, bounding boxes).
-    augment: (Depricated. Use augmentation instead). If true, apply random
+    augment: (deprecated. Use augmentation instead). If true, apply random
         image augmentation. Currently, only horizontal flipping is offered.
     augmentation: Optional. An imgaug (https://github.com/aleju/imgaug) augmentation.
         For example, passing imgaug.augmenters.Fliplr(0.5) flips images
@@ -1240,7 +1236,7 @@
     # Random horizontal flips.
     # TODO: will be removed in a future update in favor of augmentation
     if augment:
-        logging.warning("'augment' is depricated. Use 'augmentation' instead.")
+        logging.warning("'augment' is deprecated. Use 'augmentation' instead.")
         if random.randint(0, 1):
             image = np.fliplr(image)
             mask = np.fliplr(mask)
@@ -1250,7 +1246,7 @@
     if augmentation:
         import imgaug
-        # Augmentors that are safe to apply to masks
+        # Augmenters that are safe to apply to masks
         # Some, such as Affine, have settings that make them unsafe, so always
         # test your augmentation on masks
         MASK_AUGMENTERS = ["Sequential", "SomeOf", "OneOf", "Sometimes",
@@ -1259,7 +1255,7 @@
         def hook(images, augmenter, parents, default):
             """Determines which augmenters to apply to masks."""
-            return (augmenter.__class__.__name__ in MASK_AUGMENTERS)
+            return augmenter.__class__.__name__ in MASK_AUGMENTERS
         # Store shapes before augmentation to compare
         image_shape = image.shape
@@ -1313,7 +1309,7 @@
     rpn_rois: [N, (y1, x1, y2, x2)] proposal boxes.
     gt_class_ids: [instance count] Integer class IDs
     gt_boxes: [instance count, (y1, x1, y2, x2)]
-    gt_masks: [height, width, instance count] Grund truth masks. Can be full
+    gt_masks: [height, width, instance count] Ground truth masks. Can be full
               size or mini-masks.
     Returns:
@@ -1368,7 +1364,7 @@
     # Negative ROIs are those with max IoU 0.1-0.5 (hard example mining)
     # TODO: To hard example mine or not to hard example mine, that's the question
-#     bg_ids = np.where((rpn_roi_iou_max >= 0.1) & (rpn_roi_iou_max < 0.5))[0]
+    # bg_ids = np.where((rpn_roi_iou_max >= 0.1) & (rpn_roi_iou_max < 0.5))[0]
     bg_ids = np.where(rpn_roi_iou_max < 0.5)[0]
     # Subsample ROIs. Aim for 33% foreground.
@@ -1384,7 +1380,7 @@
         keep_bg_ids = np.random.choice(bg_ids, remaining, replace=False)
     else:
         keep_bg_ids = bg_ids
-    # Combine indicies of ROIs to keep
+    # Combine indices of ROIs to keep
     keep = np.concatenate([keep_fg_ids, keep_bg_ids])
     # Need more?
     remaining = config.TRAIN_ROIS_PER_IMAGE - keep.shape[0]
@@ -1448,10 +1444,7 @@
             # Resize mini mask to size of GT box
             placeholder[gt_y1:gt_y2, gt_x1:gt_x2] = \
                 np.round(skimage.transform.resize(
-                    class_mask,
-                    (gt_h, gt_w),
-                    order=1,
-                    mode="constant")).astype(bool)
+                    class_mask, (gt_h, gt_w), order=1, mode="constant")).astype(bool)
             # Place the mini batch in the placeholder
             class_mask = placeholder
@@ -1458,8 +1451,7 @@
         # Pick part of the mask and resize it
         y1, x1, y2, x2 = rois[i].astype(np.int32)
         m = class_mask[y1:y2, x1:x2]
-        mask = skimage.transform.resize(m, config.MASK_SHAPE, order=1,
-                                        mode="constant")
+        mask = skimage.transform.resize(m, config.MASK_SHAPE, order=1, mode="constant")
         masks[i, :, :, class_id] = mask
     return rois, roi_gt_class_ids, bboxes, masks
@@ -1651,7 +1643,8 @@
 def data_generator(dataset, config, shuffle=True, augment=False, augmentation=None,
-                   random_rois=0, batch_size=1, detection_targets=False):
+                   random_rois=0, batch_size=1, detection_targets=False,
+                   no_augmentation_sources=None):
     """A generator that returns images and corresponding target class ids,
     bounding box deltas, and masks.
@@ -1658,7 +1651,7 @@
     dataset: The Dataset object to pick data from
     config: The model config object
     shuffle: If True, shuffles the samples before every epoch
@@ -1670,9 +1663,12 @@
     detection_targets: If True, generate detection targets (class IDs, bbox
         deltas, and masks). Typically for debugging or visualizations because
         in trainig detection targets are generated by DetectionTargetLayer.
+    no_augmentation_sources: Optional. List of sources to exclude for
+        augmentation. A source is string that identifies a dataset and is
+        defined in the Dataset class.
     Returns a Python generator. Upon calling next() on it, the
-    generator returns two lists, inputs and outputs. The containtes
+    generator returns two lists, inputs and outputs. The contents
     of the lists differs depending on the received arguments:
     inputs list:
     - images: [batch, H, W, C]
@@ -1693,6 +1689,7 @@
     image_index = -1
     image_ids = np.copy(dataset.image_ids)
     error_count = 0
+    no_augmentation_sources = no_augmentation_sources or []
     # Anchors
     # [anchor_count, (y1, x1, y2, x2)]
@@ -1703,7 +1700,7 @@
                                              config.BACKBONE_STRIDES,
                                              config.RPN_ANCHOR_STRIDE)
-    # Keras requires a generator to run indefinately.
+    # Keras requires a generator to run indefinitely.
     while True:
         try:
             # Increment index to pick next image. Shuffle if at the start of an epoch.
@@ -1713,10 +1710,18 @@
             # Get GT bounding boxes and masks for image.
             image_id = image_ids[image_index]
-            image, image_meta, gt_class_ids, gt_boxes, gt_masks, error = \
+            # If the image source is not to be augmented pass None as augmentation
+            if dataset.image_info[image_id]['source'] in no_augmentation_sources:
+                image, image_meta, gt_class_ids, gt_boxes, gt_masks, error = \
                 load_image_gt(dataset, config, image_id, augment=augment,
-                              augmentation=augmentation,
+                              augmentation=None,
                               use_mini_mask=config.USE_MINI_MASK)
+            else:
+                image, image_meta, gt_class_ids, gt_boxes, gt_masks = \
+                    load_image_gt(dataset, config, image_id, augment=augment,
+                                augmentation=augmentation,
+                                use_mini_mask=config.USE_MINI_MASK)
             if error:
                 import warnings
@@ -1948,8 +1953,7 @@
             anchors = self.get_anchors(config.IMAGE_SHAPE)
             # Duplicate across the batch dimension because Keras requires it
             # TODO: can this be optimized to avoid duplicating the anchors?
-            anchors = np.broadcast_to(anchors,
-                                      (config.BATCH_SIZE,) + anchors.shape)
+            anchors = np.broadcast_to(anchors, (config.BATCH_SIZE,) + anchors.shape)
             # A hack to get around Keras's bad support for constants
             anchors = KL.Lambda(lambda x: tf.Variable(anchors), name="anchors")(input_image)
         else:
@@ -2065,8 +2069,7 @@
             # Create masks for detections
             detection_boxes = KL.Lambda(lambda x: x[..., :4])(detections)
-            mrcnn_mask = build_fpn_mask_graph(detection_boxes,
-                                              mrcnn_feature_maps,
+            mrcnn_mask = build_fpn_mask_graph(detection_boxes, mrcnn_feature_maps,
                                               input_image_meta,
                                               config.MASK_POOL_SIZE,
                                               config.NUM_CLASSES,
@@ -2099,8 +2102,7 @@
             import errno
             raise FileNotFoundError(
                 errno.ENOENT,
-                "Could not find model directory under {}".format(
-                    self.model_dir))
+                "Could not find model directory under {}".format(self.model_dir))
         # Pick last directory
         dir_name = os.path.join(self.model_dir, dir_names[-1])
         # Find the last checkpoint
@@ -2110,20 +2112,24 @@
         if not checkpoints:
             import errno
-                errno.ENOENT,
-                "Could not find weight files in {}".format(
-                    dir_name))
+                errno.ENOENT, "Could not find weight files in {}".format(dir_name))
         checkpoint = os.path.join(dir_name, checkpoints[-1])
         return checkpoint
     def load_weights(self, filepath, by_name=False, exclude=None):
-        """Modified version of the correspoding Keras function with
+        """Modified version of the corresponding Keras function with
         the addition of multi-GPU support and the ability to exclude
         some layers from loading.
-        exlude: list of layer names to excluce
+        exclude: list of layer names to exclude
         import h5py
-        from keras.engine import topology
+        # Conditional import to support versions of Keras before 2.2
+        # TODO: remove in about 6 months (end of 2018)
+        try:
+            from keras.engine import saving
+        except ImportError:
+            # Keras before 2.2 used the 'topology' namespace.
+            from keras.engine import topology as saving
         if exclude:
             by_name = True
@@ -2145,9 +2151,9 @@
             layers = filter(lambda l: l.name not in exclude, layers)
         if by_name:
-            topology.load_weights_from_hdf5_group_by_name(f, layers)
+            saving.load_weights_from_hdf5_group_by_name(f, layers)
         else:
-            topology.load_weights_from_hdf5_group(f, layers)
+            saving.load_weights_from_hdf5_group(f, layers)
         if hasattr(f, 'close'):
             f.close()
@@ -2248,7 +2254,7 @@
                 layer.layer.trainable = trainable
             else:
-            # Print trainble layer names
+            # Print trainable layer names
             if trainable and verbose > 0:
                 log("{}{:20}   ({})".format(" " * indent, layer.name,
                                             layer.__class__.__name__))
@@ -2277,7 +2283,7 @@
                                         int(m.group(4)), int(m.group(5)))
                 # Epoch number in file is 1-based, and in Keras code it's 0-based.
                 # So, adjust for that then increment by one to start from the next epoch
-                self.epoch = int(m.group(6))
+                self.epoch = int(m.group(6)) - 1 + 1
                 print('Re-starting from epoch %d' % self.epoch)
         # Directory for training logs
@@ -2295,7 +2301,7 @@
             "*epoch*", "{epoch:04d}")
     def train(self, train_dataset, val_dataset, learning_rate, epochs, layers,
-              augmentation=None):
+              augmentation=None, custom_callbacks=None, no_augmentation_sources=None):
         """Train the model.
         train_dataset, val_dataset: Training and validation Dataset objects.
         learning_rate: The learning rate to train with
@@ -2316,12 +2322,17 @@
             flips images right/left 50% of the time. You can pass complex
             augmentations as well. This augmentation applies 50% of the
             time, and when it does it flips images right/left half the time
-            and adds a Gausssian blur with a random sigma in range 0 to 5.
+            and adds a Gaussian blur with a random sigma in range 0 to 5.
                 augmentation = imgaug.augmenters.Sometimes(0.5, [
                     imgaug.augmenters.Fliplr(0.5),
                     imgaug.augmenters.GaussianBlur(sigma=(0.0, 5.0))
+	    custom_callbacks: Optional. Add custom callbacks to be called
+	        with the keras fit_generator method. Must be list of type keras.callbacks.
         assert self.mode == "training", "Create model in training mode."
@@ -2340,10 +2351,10 @@
             layers = layer_regex[layers]
         # Data generators
-        train_generator = data_generator(train_dataset, self.config,
-                                         shuffle=True,
+        train_generator = data_generator(train_dataset, self.config, shuffle=True,
-                                         batch_size=self.config.BATCH_SIZE)
+                                         batch_size=self.config.BATCH_SIZE,
+                                         no_augmentation_sources=no_augmentation_sources)
         val_generator = data_generator(val_dataset, self.config, shuffle=True,
@@ -2355,6 +2366,10 @@
                                             verbose=0, save_weights_only=True),
+        # Add custom callbacks to the list
+        if custom_callbacks:
+            callbacks += custom_callbacks
         # Train
         log("\nStarting at epoch {}. LR={}\n".format(self.epoch, learning_rate))
         log("Checkpoint Path: {}".format(self.checkpoint_path))
@@ -2386,10 +2401,10 @@
     def mold_inputs(self, images):
         """Takes a list of images and modifies them to the format expected
         as an input to the neural network.
-        images: List of image matricies [height,width,depth]. Images can have
+        images: List of image matrices [height,width,depth]. Images can have
             different sizes.
-        Returns 3 Numpy matricies:
+        Returns 3 Numpy matrices:
         molded_images: [N, h, w, 3]. Images resized and normalized.
         image_metas: [N, length of meta data]. Details about each image.
         windows: [N, (y1, x1, y2, x2)]. The portion of the image that has the
@@ -2555,7 +2570,7 @@
         the model.
         molded_images: List of images loaded using load_image_gt()
-        image_metas: image meta data, also retruned by load_image_gt()
+        image_metas: image meta data, also returned by load_image_gt()
         Returns a list of dicts, one dict per image. The dict contains:
         rois: [N, (y1, x1, y2, x2)] detection bounding boxes
@@ -2683,7 +2698,7 @@
         outputs.
         image_metas: If provided, the images are assumed to be already
-            molded (i.e. resized, padded, and noramlized)
+            molded (i.e. resized, padded, and normalized)
         outputs: List of tuples (name, tensor) to compute. The tensors are
             symbolic TensorFlow tensors and the names are for easy tracking.
@@ -2808,7 +2823,7 @@
 def mold_image(images, config):
-    """Expects an RGB image (or array of images) and subtraces
+    """Expects an RGB image (or array of images) and subtracts
     the mean pixel and converts it to float. Expects image
     colors in RGB order.
@@ -2825,7 +2840,7 @@
 def trim_zeros_graph(boxes, name=None):
-    """Often boxes are represented with matricies of shape [N, 4] and
+    """Often boxes are represented with matrices of shape [N, 4] and
     are padded with zeros. This removes zero boxes.
     boxes: [N, 4] matrix of boxes.
Modified: grass-addons/grass7/imagery/i.ann.maskrcnn/maskrcnnlib/utils.py
--- grass-addons/grass7/imagery/i.ann.maskrcnn/maskrcnnlib/utils.py	2018-08-28 08:40:12 UTC (rev 73200)
+++ grass-addons/grass7/imagery/i.ann.maskrcnn/maskrcnnlib/utils.py	2018-08-28 13:02:06 UTC (rev 73201)
@@ -10,6 +10,7 @@
     Different way of removing the alpha channel (contained in load_mask)
     Deleted download_train_weights
     A little refactoring made
+    # last cross-check with Matterport's implementation: 28/08/2018
 import os
@@ -66,7 +67,7 @@
     boxes_area: array of length boxes_count.
     Note: the areas are passed in rather than calculated here for
-          efficency. Calculate once in the caller to avoid duplicate work.
+    efficiency. Calculate once in the caller to avoid duplicate work.
     # Calculate intersection areas
     y1 = np.maximum(box[0], boxes[:, 0])
@@ -99,9 +100,9 @@
 def compute_overlaps_masks(masks1, masks2):
-    '''Computes IoU overlaps between two sets of masks.
+    """Computes IoU overlaps between two sets of masks.
     masks1, masks2: [Height, Width, instances]
     # If either set of masks is empty return empty result
     if masks1.shape[0] == 0 or masks2.shape[0] == 0:
@@ -121,7 +122,7 @@
 def non_max_suppression(boxes, scores, threshold):
-    """Performs non-maximum supression and returns indicies of kept boxes.
+    """Performs non-maximum suppression and returns indices of kept boxes.
     boxes: [N, (y1, x1, y2, x2)]. Notice that (y2, x2) lays outside the box.
     scores: 1-D array of box scores.
     threshold: Float. IoU threshold to use for filtering.
@@ -148,10 +149,10 @@
         # Compute IoU of the picked box with the rest
         iou = compute_iou(boxes[i], boxes[ixs[1:]], area[i], area[ixs[1:]])
         # Identify boxes with IoU over the threshold. This
-        # returns indicies into ixs[1:], so add 1 to get
-        # indicies into ixs.
+        # returns indices into ixs[1:], so add 1 to get
+        # indices into ixs.
         remove_ixs = np.where(iou > threshold)[0] + 1
-        # Remove indicies of the picked and overlapped boxes.
+        # Remove indices of the picked and overlapped boxes.
         ixs = np.delete(ixs, remove_ixs)
         ixs = np.delete(ixs, 0)
     return np.array(pick, dtype=np.int32)
@@ -318,8 +319,7 @@
                     self.source_class_ids[source].append(i)
     def map_source_class_id(self, source_class_id):
-        Takes a source class ID and returns the int class ID assigned to it.
+        """Takes a source class ID and returns the int class ID assigned to it.
         For example:
         dataset.map_source_class_id("coco.12") -> 23
@@ -327,10 +327,7 @@
         return self.class_from_source_map[source_class_id]
     def get_source_class_id(self, class_id, source):
-        Map an internal class ID to the corresponding class ID in the source
-        dataset.
+        """Map an internal class ID to the corresponding class ID in the source dataset."""
         info = self.class_info[class_id]
         assert info['source'] == source
         return info['id']
@@ -352,14 +349,13 @@
     def source_image_link(self, image_id):
         """Returns the path or URL to the image.
-        Override this to return a URL to the image if it's availble online for
-        easy debugging.
+        Override this to return a URL to the image if it's available online for easy
+        debugging.
         return self.image_info[image_id]["path"]
     def load_image(self, image_id):
-        Load the specified image and return a [H,W,3] Numpy array.
+        """Load the specified image and return a [H,W,3] Numpy array.
         Modified by Ondrej Pesek to not care about alpha channel
@@ -394,16 +390,15 @@
                                path=image)
     def get_mask(self, image_id):
-        Load instance masks for the given image.
+        """Load instance masks for the given image.
         This function converts the different mask format to one format in the
         form of an array of binary masks of shape [height, width, instances].
         Returns:
-        masks: A bool array of shape [height, width, instance count] with
-            a binary mask per instance.
-        class_ids: a 1D array of class IDs of the instance masks.
+            masks: A bool array of shape [height, width, instance count] with
+                a binary mask per instance.
+            class_ids: a 1D array of class IDs of the instance masks.
         Written by Ondrej Pesek
@@ -442,10 +437,8 @@
-def resize_image(image, min_dim=None, max_dim=None, min_scale=None,
-                 mode="square"):
-    Resizes an image keeping the aspect ratio unchanged.
+def resize_image(image, min_dim=None, max_dim=None, min_scale=None, mode="square"):
+    """Resizes an image keeping the aspect ratio unchanged.
     min_dim: if provided, resizes the image such that it's smaller
         dimension == min_dim
@@ -627,8 +620,7 @@
     threshold = 0.5
     y1, x1, y2, x2 = bbox
-    mask = skimage.transform.resize(mask, (y2 - y1, x2 - x1), order=1,
-                                    mode="constant")
+    mask = skimage.transform.resize(mask, (y2 - y1, x2 - x1), order=1, mode="constant")
     mask = np.where(mask >= threshold, 1, 0).astype(np.bool)
     # Put the mask in the right location.
