[GRASS-SVN] r73214 - in grass/trunk: . display/d.mon doc general/g.findfile general/g.message gui/icons gui/wxpython gui/wxpython/docs gui/wxpython/xml imagery/i.topo.corr lib/gis lib/gpde lib/init lib/python/docs/src lib/python/gunittest lib/python/pygrass/modules lib/python/script locale man man/sphinx mswindows/Installer-Files temporal/t.rast.accumulate vector/v.info
Fri Aug 31 06:52:55 PDT 2018
Author: neteler
Date: 2018-08-31 06:52:55 -0700 (Fri, 31 Aug 2018)
New Revision: 73214
   grass/trunk/INSTALL
   grass/trunk/README
   grass/trunk/display/d.mon/main.c
   grass/trunk/doc/grass_database.html
   grass/trunk/doc/howto_release.txt
   grass/trunk/general/g.findfile/g.findfile.html
   grass/trunk/general/g.message/g.message.html
   grass/trunk/grasslib.dox
   grass/trunk/gui/icons/grass.desktop
   grass/trunk/gui/wxpython/README
   grass/trunk/gui/wxpython/docs/wxGUI.html
   grass/trunk/gui/wxpython/xml/menudata.README
   grass/trunk/imagery/i.topo.corr/test_i.topo.corr_synthetic_DEM_NC.sh
   grass/trunk/lib/gis/parser_wps.c
   grass/trunk/lib/gpde/gpdelib.dox
   grass/trunk/lib/init/README
   grass/trunk/lib/init/grass.sh
   grass/trunk/lib/init/grass7.html
   grass/trunk/lib/init/helptext.html
   grass/trunk/lib/python/docs/src/gunittest_running_tests.rst
   grass/trunk/lib/python/docs/src/pygrass_gis.rst
   grass/trunk/lib/python/gunittest/multirunner.py
   grass/trunk/lib/python/pygrass/modules/shortcuts.py
   grass/trunk/lib/python/script/core.py
   grass/trunk/lib/python/script/setup.py
   grass/trunk/locale/README
   grass/trunk/man/build_graphical_index.py
   grass/trunk/man/sphinx/conf.py
   grass/trunk/mswindows/Installer-Files/WinGRASS-README.url
   grass/trunk/temporal/t.rast.accumulate/t.rast.accumulate.html
   grass/trunk/vector/v.info/v.info.html
version bump: grass75 -> grass76 related updates
Modified: grass/trunk/INSTALL
--- grass/trunk/INSTALL	2018-08-31 13:51:11 UTC (rev 73213)
+++ grass/trunk/INSTALL	2018-08-31 13:52:55 UTC (rev 73214)
@@ -54,7 +54,7 @@
   (*.tar.gz package) of that SVN repository. The SVN snapshot name
   contains the date when the snapshot was created (checked out from
   the SVN repository), e.g. grass-7.2.svn_src_snapshot_2016_06_11.tar.gz
-  from https://grass.osgeo.org/grass75/source/snapshot/
+  from https://grass.osgeo.org/grass76/source/snapshot/
   Further instructions at https://trac.osgeo.org/grass/wiki/DownloadSource
@@ -151,16 +151,16 @@
 After compilation, the resulting code is stored in the directory
     ./dist.$ARCH
-and the scripts (grass75, ...) in
+and the scripts (grass76, ...) in
     ./bin.$ARCH
 To run GRASS, simply start
-    ./bin.$ARCH/grass75
+    ./bin.$ARCH/grass76
 or run
     make install
-    grass75
+    grass76
 (E) INSTALLATION ON MACOSX
Modified: grass/trunk/README
--- grass/trunk/README	2018-08-31 13:51:11 UTC (rev 73213)
+++ grass/trunk/README	2018-08-31 13:52:55 UTC (rev 73214)
@@ -48,7 +48,7 @@
    make pdfdocs
 An online version is available at:
-http://grass.osgeo.org/programming7/
+https://grass.osgeo.org/programming7/
 ## Docker
@@ -55,26 +55,26 @@
 Build using the downloaded source code (in the directory with the
 source code):
-    docker build -t grassgis75 .
+    docker build -t grassgis76 .
 A test run (assuming you have existing GRASS GIS location; it can be downloaded from
 https://grass.osgeo.org/sampledata/north_carolina/nc_basic_spm_grass7.zip)
     # case 1: launching in the grassdata directory in which the location is stored:
-    docker run -it --rm --user=$(id -u):$(id -g) --volume $(pwd):/data --env HOME=/data/ grassgis75 \
+    docker run -it --rm --user=$(id -u):$(id -g) --volume $(pwd):/data --env HOME=/data/ grassgis76 \
         grass --text nc_spm_08_grass7/user1 --exec g.region -p
     # case 2: launching anywhere
-    docker run -it --rm --user=$(id -u):$(id -g) --volume /your/test/grassdata/:/data --env HOME=/data/ grassgis75 \
+    docker run -it --rm --user=$(id -u):$(id -g) --volume /your/test/grassdata/:/data --env HOME=/data/ grassgis76 \
         grass /data/nc_basic_spm/PERMANENT --exec g.region -p
-Note that the first `grassgis75` is the name of the image while the second
+Note that the first `grassgis76` is the name of the image while the second
 `grass` is the name of the executable.
 To run the tests (again assuming local location):
     docker run -it --rm --user=$(id -u):$(id -g) --volume /your/test/grassdata/:/data --env HOME=/data/ -w /code/grass \
-        grassgis75 grass /data/nc_basic_spm/PERMANENT --exec \
+        grassgis76 grass /data/nc_basic_spm/PERMANENT --exec \
             python -m grass.gunittest.main \
                 --location nc_basic_spm --location-type nc
Modified: grass/trunk/display/d.mon/main.c
--- grass/trunk/display/d.mon/main.c	2018-08-31 13:51:11 UTC (rev 73213)
+++ grass/trunk/display/d.mon/main.c	2018-08-31 13:52:55 UTC (rev 73214)
@@ -20,7 +20,7 @@
  [1] https://trac.osgeo.org/grass/browser/grass/trunk/display/d.mon/render_cmd.py
  [2] https://trac.osgeo.org/grass/browser/grass/trunk/lib/display/r_raster.c#L107
- [3] https://grass.osgeo.org/grass75/manuals/displaydrivers.html
+ [3] https://grass.osgeo.org/grass76/manuals/displaydrivers.html
Modified: grass/trunk/doc/grass_database.html
--- grass/trunk/doc/grass_database.html	2018-08-31 13:51:11 UTC (rev 73213)
+++ grass/trunk/doc/grass_database.html	2018-08-31 13:52:55 UTC (rev 73214)
@@ -222,7 +222,7 @@
 in a given Mapset with only command line interface:
 <div class="code"><pre>
-grass75 -text ~/grassdata/mylocation/mymapset
+grass76 -text ~/grassdata/mylocation/mymapset
 </pre></div>
 And the following will create the given Location with projection given
@@ -230,7 +230,7 @@
 (GUI or command line):
-grass75 -c EPSG:5514:3 ~/grassdata/mylocation
+grass76 -c EPSG:5514:3 ~/grassdata/mylocation
 </pre></div>
 See <a href="grass7.html"><em>grass</em></a> command manual for more details.
Modified: grass/trunk/doc/howto_release.txt
--- grass/trunk/doc/howto_release.txt	2018-08-31 13:51:11 UTC (rev 73213)
+++ grass/trunk/doc/howto_release.txt	2018-08-31 13:52:55 UTC (rev 73214)
@@ -191,8 +191,8 @@
 # write announcement
   - store in trac:
-    https://trac.osgeo.org/grass/wiki/Release/7.4.x-News
-    https://trac.osgeo.org/grass/wiki/Grass7/NewFeatures74  <- add content of major changes only
+    https://trac.osgeo.org/grass/wiki/Release/7.6.x-News
+    https://trac.osgeo.org/grass/wiki/Grass7/NewFeatures76  <- add content of major changes only
   - update version in https://grasswiki.osgeo.org/wiki/GRASS-Wiki
   - store in Web as announces/announce_grass$MAJOR$MINOR$RELEASE.html <- how? with protected PHP upload page? (dropped since CMS)
@@ -227,11 +227,11 @@
   - Update addons (grass_addons.sh) rules, eg.
-     compile $SVN_PATH/grass7 $GISBASE_PATH/grass740RC1   $ADDON_PATH/grass740RC1/addons
+     compile $SVN_PATH/grass7 $GISBASE_PATH/grass760RC1   $ADDON_PATH/grass760RC1/addons
   - Modify grass_copy_wwwroot.sh accordingly, eg.
-     copy_addon 741RC1 7.4.1RC1
+     copy_addon 761RC1 7.666666.1RC1
 # Launchpad notes:
@@ -305,23 +305,24 @@
 1. see SVN book:
    http://svnbook.red-bean.com/en/1.1/ch04s07.html
-   GRASS 7.4 release branch:
-          BRANCH=releasebranch_7_4
-          URL=https://svn.osgeo.org/grass
-          svn copy $URL/grass/trunk \
-                   $URL/grass/branches/$BRANCH \
-                   -m "Release branch for GRASS 7.4.x"
+   GRASS 7.6 release branch:
+# see below for real example
+#          BRANCH=releasebranch_7_6
+#          URL=https://svn.osgeo.org/grass
+#          svn copy $URL/grass/trunk \
+#                   $URL/grass/branches/$BRANCH \
+#                   -m "Release branch for GRASS 7.6.x"
-   Switching current local copy to above development branch:
-   (http://svnbook.red-bean.com/en/1.1/ch04s05.html)
-           cd /path/to/your/local/copy/trunk
-           svn switch https://svn.osgeo.org/grass/grass/branches/releasebranch_7_4 .
+Branch creation example: GRASS GIS 7.6 release branch creation
+svn copy https://svn.osgeo.org/grass/grass/trunk/ \
+    https://svn.osgeo.org/grass/grass/branches/releasebranch_7_6 \
+    -m "Release branch for GRASS GIS 7.6.x"
-Example: GRASS GIS 7.4 release branch creation
+Switching current local copy to above development branch:
+   (http://svnbook.red-bean.com/en/1.1/ch04s05.html)
-svn copy https://svn.osgeo.org/grass/grass/trunk/ \
-    https://svn.osgeo.org/grass/grass/branches/releasebranch_7_4 \
-    -m "Release branch for GRASS GIS 7.4.x"
+           cd /path/to/your/local/copy/trunk
+           svn switch https://svn.osgeo.org/grass/grass/branches/releasebranch_7_6 .
Modified: grass/trunk/general/g.findfile/g.findfile.html
--- grass/trunk/general/g.findfile/g.findfile.html	2018-08-31 13:51:11 UTC (rev 73213)
+++ grass/trunk/general/g.findfile/g.findfile.html	2018-08-31 13:52:55 UTC (rev 73214)
@@ -75,7 +75,7 @@
 <h3>PYTHON</h3>
-See <em><a href="http://grass.osgeo.org/grass75/manuals/libpython/">Python
+See <em><a href="https://grass.osgeo.org/grass76/manuals/libpython/">Python
 Scripting Library</a></em> for more info.
 <p>
 Note: The Python tab in the <em>wxGUI</em> can be used for entering the
Modified: grass/trunk/general/g.message/g.message.html
--- grass/trunk/general/g.message/g.message.html	2018-08-31 13:51:11 UTC (rev 73213)
+++ grass/trunk/general/g.message/g.message.html	2018-08-31 13:52:55 UTC (rev 73214)
@@ -47,7 +47,7 @@
 <h3>Usage in Python scripts</h3>
-<a href="http://grass.osgeo.org/grass75/manuals/libpython/">GRASS
+<a href="https://grass.osgeo.org/grass76/manuals/libpython/">GRASS
 Python Scripting Library</a> defines special wrappers
 for <em>g.message</em>.
Modified: grass/trunk/grasslib.dox
--- grass/trunk/grasslib.dox	2018-08-31 13:51:11 UTC (rev 73213)
+++ grass/trunk/grasslib.dox	2018-08-31 13:52:55 UTC (rev 73214)
@@ -1,10 +1,10 @@
 /*! \mainpage GRASS GIS 7 Programmer's Manual
 <!-- * doxygenized from "GRASS 5 Programmer's Manual"
        by M. Neteler 2/2004
-     * updated 8/2005, 2006-2008, 2010-2011, 2017
+     * updated 8/2005, 2006-2008, 2010-2011, 2017, 2018
-<a href="http://grass.osgeo.org">GRASS GIS</a> (<b>Geographic
+<a href="https://grass.osgeo.org">GRASS GIS</a> (<b>Geographic
 Resources Analysis Support System</b>) is an open source, free
 software <em>Geographical Information System</em> (GIS) with raster,
 topological %vector, image processing, and graphics production
@@ -51,7 +51,7 @@
  - gis: \ref gislib
  - raster: \ref rasterlib
  - vector: \ref vectorlib
- - Temporal GIS API: See http://grass.osgeo.org/grass75/manuals/libpython/temporal_framework.html
+ - Temporal GIS API: See https://grass.osgeo.org/grass76/manuals/libpython/temporal_framework.html
 \section libs Further libraries
@@ -112,7 +112,7 @@
 \subsection pythonlibs Python API
- - python:	See GRASS GIS Python library (http://grass.osgeo.org/grass75/manuals/libpython/)
+ - python:	See GRASS GIS Python library (https://grass.osgeo.org/grass76/manuals/libpython/)
 \subsection projlibs Projection Libraries
Modified: grass/trunk/gui/icons/grass.desktop
--- grass/trunk/gui/icons/grass.desktop	2018-08-31 13:51:11 UTC (rev 73213)
+++ grass/trunk/gui/icons/grass.desktop	2018-08-31 13:52:55 UTC (rev 73214)
@@ -47,8 +47,8 @@
 GenericName[uk]=Геоінформаційна система
 GenericName[uz]=Geografik axborot tizimi
 Icon=grass
-TryExec=/usr/bin/grass75
-Exec=grass75
+TryExec=/usr/bin/grass76
+Exec=grass76
 Terminal=true
 Keywords=gis;spatial;geospatial;database;remote sensing;hydrology;vector;raster;visualization;maps;wms;wfs;ogc;osgeo;
 Categories=Education;Science;Geoscience;Geography;
Modified: grass/trunk/gui/wxpython/README
--- grass/trunk/gui/wxpython/README	2018-08-31 13:51:11 UTC (rev 73213)
+++ grass/trunk/gui/wxpython/README	2018-08-31 13:52:55 UTC (rev 73214)
@@ -18,7 +18,7 @@
 If you want to launch wxPython GUI automatically, start GRASS with
 `-gui` parameter
-$ grass75 -gui
+$ grass76 -gui
 3 - STARTUP FROM GRASS TERMINAL
Modified: grass/trunk/gui/wxpython/docs/wxGUI.html
--- grass/trunk/gui/wxpython/docs/wxGUI.html	2018-08-31 13:51:11 UTC (rev 73213)
+++ grass/trunk/gui/wxpython/docs/wxGUI.html	2018-08-31 13:52:55 UTC (rev 73214)
@@ -687,7 +687,7 @@
 specifying the <tt>-gui</tt> (or <tt>-wxpython</tt>) switch:
-grass75 -gui
+grass76 -gui
 </pre></div>
@@ -707,11 +707,11 @@
 </em>
 <p>
-See also wxGUI <a href="http://grasswiki.osgeo.org/wiki/WxGUI">wiki</a>
+See also wxGUI <a href="https://grasswiki.osgeo.org/wiki/WxGUI">wiki</a>
 page
-(especially various <a href="http://grasswiki.osgeo.org/wiki/WxGUI#Video_tutorials">video
+(especially various <a href="https://grasswiki.osgeo.org/wiki/WxGUI#Video_tutorials">video
 tutorials</a>),
-and <a href="http://grasswiki.osgeo.org/wiki/Quick_wxGUI_tutorial">Quick
+and <a href="https://grasswiki.osgeo.org/wiki/Quick_wxGUI_tutorial">Quick
 wxGUI Tutorial</a>.
 <h2>AUTHORS</h2>
Modified: grass/trunk/gui/wxpython/xml/menudata.README
--- grass/trunk/gui/wxpython/xml/menudata.README	2018-08-31 13:51:11 UTC (rev 73213)
+++ grass/trunk/gui/wxpython/xml/menudata.README	2018-08-31 13:52:55 UTC (rev 73214)
@@ -2,7 +2,7 @@
 - the entries in menudata.xml and module_tree_menudata.xml are autogenerated
   via tools/build_modules_xml.py (see ../Makefile)
 - Find more info at
-  https://grass.osgeo.org/grass75/manuals/wxGUI.toolboxes.html
+  https://grass.osgeo.org/grass76/manuals/wxGUI.toolboxes.html
   (../docs/wxgui_sphinx/src/)
 - additionally
   https://trac.osgeo.org/grass/wiki/wxGUIDevelopment/Toolboxes
Modified: grass/trunk/imagery/i.topo.corr/test_i.topo.corr_synthetic_DEM_NC.sh
--- grass/trunk/imagery/i.topo.corr/test_i.topo.corr_synthetic_DEM_NC.sh	2018-08-31 13:51:11 UTC (rev 73213)
+++ grass/trunk/imagery/i.topo.corr/test_i.topo.corr_synthetic_DEM_NC.sh	2018-08-31 13:52:55 UTC (rev 73214)
@@ -3,7 +3,7 @@
 # Script to test i.topo.corr with a synthetic map
 # Use North Carolina location to test:
-#   grass75 ~/grassdata/nc_spm_08_grass7/user1
+#   grass76 ~/grassdata/nc_spm_08_grass7/user1
 if test "$GISBASE" = ""; then
  echo "You must be in GRASS to run this program."
Modified: grass/trunk/lib/gis/parser_wps.c
--- grass/trunk/lib/gis/parser_wps.c	2018-08-31 13:51:11 UTC (rev 73213)
+++ grass/trunk/lib/gis/parser_wps.c	2018-08-31 13:52:55 UTC (rev 73214)
@@ -578,7 +578,7 @@
     if(abstract)
         fprintf(stdout,"\t\t<ows:Abstract>");
-        fprintf(stdout, "http://grass.osgeo.org/grass75/manuals/%s.html", identifier);
+        fprintf(stdout, "https://grass.osgeo.org/grass76/manuals/%s.html", identifier);
         fprintf(stdout, "</ows:Abstract>\n");
Modified: grass/trunk/lib/gpde/gpdelib.dox
--- grass/trunk/lib/gpde/gpdelib.dox	2018-08-31 13:51:11 UTC (rev 73213)
+++ grass/trunk/lib/gpde/gpdelib.dox	2018-08-31 13:52:55 UTC (rev 73214)
@@ -223,7 +223,7 @@
 <P>
 <b>Example implementation:</b><br>
-The GRASS module <a href="http://grass.osgeo.org/grass75/manuals/r.gwflow.html">r.gwflow</a>
+The GRASS module <a href="https://grass.osgeo.org/grass76/manuals/r.gwflow.html">r.gwflow</a>
 implements numerical calculation program for transient,
 confined and unconfined groundwater flow in two dimensions.
@@ -294,7 +294,7 @@
 <P>
-The GRASS module <a href="http://grass.itc.it/grass75/manuals/r3.gwflow.html">r3.gwflow</a>
+The GRASS module <a href="http://grass.itc.it/grass76/manuals/r3.gwflow.html">r3.gwflow</a>
 implements numerical calculation program for transient, confined
 groundwater flow in three dimensions.
Modified: grass/trunk/lib/init/README
--- grass/trunk/lib/init/README	2018-08-31 13:51:11 UTC (rev 73213)
+++ grass/trunk/lib/init/README	2018-08-31 13:52:55 UTC (rev 73214)
@@ -1,10 +1,10 @@
 o GRASS text mode startup
-  "grass75" starts up d.m by default (if not first time user).
-  "grass75 -text" will start up in text mode.
-  "grass75 -wxpython" or "grass75 -gui" will start up in wxpython mode.
+  "grass76" starts up d.m by default (if not first time user).
+  "grass76 -text" will start up in text mode.
+  "grass76 -wxpython" or "grass76 -gui" will start up in wxpython mode.
-  You can use alias "grass75" to "grass75 -text" to use text mode by default.
+  You can use alias "grass76" to "grass76 -text" to use text mode by default.
   Or set env var GRASS_GUI=text.
@@ -25,7 +25,7 @@
 	export LOCATION_NAME=loc1
 	export MAPSET=map1
-	grass75 -	# non-interactive startup using LOCATION location
+	grass76 -	# non-interactive startup using LOCATION location
   ex2)
 	export GISDBASE=/usr/home/grass/usr/data1
@@ -32,11 +32,11 @@
 	export MAPSET=map1
 			# GISDBASE/LOCATION_NAME/MAPSET location
-  Also, the first argument of grass75 can override these env vars.
+  Also, the first argument of grass76 can override these env vars.
   ex3)
   	export LOCATION=/usr/home/grass/usr/data1/loc1/map1
@@ -44,7 +44,7 @@
 	export MAPSET=map1
-	grass75 /usr/home/grass/usr/data2/loc2-1/map1-1
+	grass76 /usr/home/grass/usr/data2/loc2-1/map1-1
 			# /usr/home/grass/usr/data2/loc2-1/map1-1 location
@@ -53,7 +53,7 @@
 	export MAPSET=map1
@@ -63,7 +63,7 @@
 	export MAPSET=map1
-	grass75 map1-1	# non-interactive startup using
+	grass76 map1-1	# non-interactive startup using
 			# GISDBASE/LOCATION_NAME/map1-1 location
   ex6)
@@ -72,7 +72,7 @@
 	export MAPSET=map1
-	grass75 loc2-1/map1-1
+	grass76 loc2-1/map1-1
 			# GISDBASE/loc2-1/map1-1 location
Modified: grass/trunk/lib/init/grass.sh
--- grass/trunk/lib/init/grass.sh	2018-08-31 13:51:11 UTC (rev 73213)
+++ grass/trunk/lib/init/grass.sh	2018-08-31 13:52:55 UTC (rev 73214)
@@ -28,4 +28,4 @@
 fi
 export GRASS_PYTHON
-exec "$GRASS_PYTHON" "@BINDIR@/grass75.py" "$@" &
+exec "$GRASS_PYTHON" "@BINDIR@/grass76.py" "$@" &
Modified: grass/trunk/lib/init/grass7.html
--- grass/trunk/lib/init/grass7.html	2018-08-31 13:51:11 UTC (rev 73213)
+++ grass/trunk/lib/init/grass7.html	2018-08-31 13:52:55 UTC (rev 73214)
@@ -2,7 +2,7 @@
 <h2>SYNOPSIS</h2>
-<b>grass75</b> [<b>-h</b> | <b>-help</b> | <b>--help</b>] [<b>-v</b> | <b>--version</b>]
+<b>grass76</b> [<b>-h</b> | <b>-help</b> | <b>--help</b>] [<b>-v</b> | <b>--version</b>]
     [<b>-c</b> | <b>-c geofile</b> | <b>-c EPSG:code[:datum_trans]</b>]
     [<b>-text</b> | <b>-gtext</b> | <b>-gui</b>]
     [[[<b><GISDBASE>/</b>]<b><LOCATION_NAME>/</b>]
@@ -94,13 +94,13 @@
 <p>The startup program will remember both the desired user interface
 and mapset. Thus, the next time the user runs GRASS, typing
-<em>grass75</em> (without any options) will start GRASS with the
+<em>grass76</em> (without any options) will start GRASS with the
 previous settings for the user interface and mapset selected.
 <p>If you specify a graphical user interface (<b>-gui</b>)
-the <em>grass75</em> program will try to verify that the system you
+the <em>grass76</em> program will try to verify that the system you
 specified exists and that you can access it successfully. If any of
-these checks fail then <em>grass75</em> will automatically switch back
+these checks fail then <em>grass76</em> will automatically switch back
 to the text user interface mode.
 <h2>SAMPLE DATA</h2>
@@ -136,14 +136,14 @@
 <h3>User Interface Environment Variable</h3>
-<p>The <em>grass75</em> program will check for the existence of an
+<p>The <em>grass76</em> program will check for the existence of an
 environment variable called GRASS_GUI which indicates the type of user
 interface for GRASS to use. If this variable is not set
-when <em>grass75</em> is run, then it will be created and then saved
+when <em>grass76</em> is run, then it will be created and then saved
 in the <tt>$HOME/.grass7/rc</tt> file for the next time GRASS is
 run. It can be set to <tt>text</tt>, <tt>gtext</tt> or <tt>gui</tt>.
-<p>There is an order of precedence in the way <em>grass75</em>
+<p>There is an order of precedence in the way <em>grass76</em>
 determines the user interface to use. The following is the hierarchy
 from highest precedence to lowest.
 <ol>
@@ -187,7 +187,7 @@
 This environment variable allows the user to extend the GRASS program
 search paths to include locally installed
 (see <em><a href="g.extension.html">g.extension</a></em> for details)
-<a href="http://grasswiki.osgeo.org/wiki/GRASS_AddOns">GRASS Addon</a>
+<a href="https://grasswiki.osgeo.org/wiki/GRASS_AddOns">GRASS Addon</a>
 modules which are not distributed with the standard GRASS release.
    GRASS_ADDON_BASE=/usr/grass-addons
@@ -242,44 +242,44 @@
 <p>The following are some examples of how you could start GRASS
 <dl>
-<dt><b>grass75</b>
+<dt><b>grass76</b>
 <dd> Start GRASS using the default user interface. The user will be
     prompted to choose the appropriate location and mapset.
-<dt><b>grass75 -gui</b>
+<dt><b>grass76 -gui</b>
 <dd> Start GRASS using the graphical user interface. The user will be
-<dt><b>grass75 -text</b>
+<dt><b>grass76 -text</b>
 <dd> Start GRASS using the text-based user interface. Appropriate
 location and mapset must be set by environmental variables (see
 examples below) otherwise taken from the last GRASS session.</dd>
-<dt><b>grass75 -gtext</b>
+<dt><b>grass76 -gtext</b>
 <dd> Start GRASS using the text-based user interface. The user will be
-<dt><b>grass75 $HOME/grassdata/spearfish70/user1</b>
+<dt><b>grass76 $HOME/grassdata/spearfish70/user1</b>
 <dd> Start GRASS using the default user interface and automatically
     launch into the given mapset, bypassing the mapset selection menu.
-<dt><b>grass75 -gui -</b>
+<dt><b>grass76 -gui -</b>
 <dd> Start GRASS using the graphical user interface and try to
     obtain the location and mapset from environment variables.
-<dt><b>grass75 -c EPSG:4326 $HOME/grassdata/mylocation</b>
+<dt><b>grass76 -c EPSG:4326 $HOME/grassdata/mylocation</b>
 <dd> Creates new GRASS location with EPSG code 4326 (latitude-longitude, WGS84)
     in the specified GISDBASE
-<dt><b>grass75 -c EPSG:5514:3 $HOME/grassdata/mylocation</b>
+<dt><b>grass76 -c EPSG:5514:3 $HOME/grassdata/mylocation</b>
 <dd> Creates new GRASS location with EPSG code 5514 (S-JTSK / Krovak
     East North - SJTSK) with datum transformation parameters used in
     Czech Republic in the specified GISDBASE
-<dt><b>grass75 -c myvector.shp $HOME/grassdata/mylocation</b>
+<dt><b>grass76 -c myvector.shp $HOME/grassdata/mylocation</b>
 <dd> Creates new GRASS location based on georeferenced Shapefile
-<dt><b>grass75 -c myraster.tif $HOME/grassdata/mylocation</b>
+<dt><b>grass76 -c myraster.tif $HOME/grassdata/mylocation</b>
 <dd> Creates new GRASS location based on georeferenced GeoTIFF file
 </dl>
@@ -296,26 +296,26 @@
 and exit (<b>-e</b>) immediately:
-grass75 -c elevation.tiff -e /path/to/grassdata/test1/
+grass76 -c elevation.tiff -e /path/to/grassdata/test1/
 </pre></div>
 Linking external raster data to PERMANENT Mapset:
-grass75 /path/to/grassdata/test1/PERMANENT/ --exec r.external input=basins.tiff output=basins
-grass75 /path/to/grassdata/test1/PERMANENT/ --exec r.external input=elevation.tiff output=elevation
+grass76 /path/to/grassdata/test1/PERMANENT/ --exec r.external input=basins.tiff output=basins
+grass76 /path/to/grassdata/test1/PERMANENT/ --exec r.external input=elevation.tiff output=elevation
 </pre></div>
 Get statistics for one raster map:
-grass75 /path/to/grassdata/test1/PERMANENT/ --exec r.univar map=elevation
+grass76 /path/to/grassdata/test1/PERMANENT/ --exec r.univar map=elevation
 </pre></div>
 Compare the rasters visually:
-grass75 /path/to/grassdata/test1/PERMANENT/ --exec g.gui.mapswipe first=elevation second=basins
+grass76 /path/to/grassdata/test1/PERMANENT/ --exec g.gui.mapswipe first=elevation second=basins
 </pre></div>
 <h4>Execution of shell and Python scripts instead of single commands</h4>
@@ -326,7 +326,7 @@
 <b>Shell script example:</b> the command to execute a shell script might be:
-grass75 /path/to/grassdata/test1/PERMANENT/ --exec sh test.sh
+grass76 /path/to/grassdata/test1/PERMANENT/ --exec sh test.sh
 </pre></div>
 A very simple bash script ("test.sh") may look like this:
@@ -343,7 +343,7 @@
 <b>Python script example:</b> the command to execute a Python script might be:
-grass75 /path/to/grassdata/test1/PERMANENT/ --exec python test.py
+grass76 /path/to/grassdata/test1/PERMANENT/ --exec python test.py
 </pre></div>
 A very simple Python script ("test.py") may look like this:
@@ -374,19 +374,19 @@
 computation in a shell script:
-grass75 --tmp-location elevation.tiff --exec test.sh
+grass76 --tmp-location elevation.tiff --exec test.sh
 </pre></div>
 The same, but using an EPSG code and a Python script:
-grass75 --tmp-location EPSG:3358 --exec test.py
+grass76 --tmp-location EPSG:3358 --exec test.py
 </pre></div>
 Finally, for special cases, we can create an XY location without any CRS:
-grass75 --tmp-location XY --exec test.py
+grass76 --tmp-location XY --exec test.py
 </pre></div>
 Temporary location is automatically deleted after computation,
@@ -398,7 +398,7 @@
 temporary location:
-grass75 --tmp-location EPSG:3358 --exec g.proj -p
+grass76 --tmp-location EPSG:3358 --exec g.proj -p
 </pre></div>
 A temporary XY location with single command is useful, e.g. to show
@@ -405,7 +405,7 @@
 help text of a module:
-grass75 --tmp-location XY --exec r.neighbors --help
+grass76 --tmp-location XY --exec r.neighbors --help
 </pre></div>
 <h4>Troubleshooting</h4>
Modified: grass/trunk/lib/init/helptext.html
--- grass/trunk/lib/init/helptext.html	2018-08-31 13:51:11 UTC (rev 73213)
+++ grass/trunk/lib/init/helptext.html	2018-08-31 13:52:55 UTC (rev 73214)
@@ -167,7 +167,7 @@
 If data were already imported, you can add them into the Layer Manager now
 and display them. If your LOCATION is empty you can import your data from
 the menu: Go to "File" -> "Import raster/vector data" (see also the
-related Wiki page on <a href="http://grasswiki.osgeo.org/wiki/Importing_data">Importing data</a>).
+related Wiki page on <a href="https://grasswiki.osgeo.org/wiki/Importing_data">Importing data</a>).
 <h2>5. Text-based startup and location creation</h2>
@@ -180,13 +180,13 @@
      without entering the new location:
 <ul>
     <li>Using an EPSG code:<br>
-         <tt>grass75 -e -c EPSG:32630 /home/user/grassdata/mylocation</tt></li>
+         <tt>grass76 -e -c EPSG:32630 /home/user/grassdata/mylocation</tt></li>
     <li>Using a georeferenced raster or vector file:<br>
-         <tt>grass75 -e -c MyGeoReferenceFile.tif /home/user/grassdata/mylocation</tt></li>
+         <tt>grass76 -e -c MyGeoReferenceFile.tif /home/user/grassdata/mylocation</tt></li>
 </ul></li>
 <li> Create new mapset within the new location and launch GRASS GIS within
      that mapset: <br>
-         <tt>grass75 -c /home/user/grassdata/mylocation/mymapset</tt>
+         <tt>grass76 -c /home/user/grassdata/mylocation/mymapset</tt>
 </ol>
Modified: grass/trunk/lib/python/docs/src/gunittest_running_tests.rst
--- grass/trunk/lib/python/docs/src/gunittest_running_tests.rst	2018-08-31 13:51:11 UTC (rev 73213)
+++ grass/trunk/lib/python/docs/src/gunittest_running_tests.rst	2018-08-31 13:52:55 UTC (rev 73214)
@@ -89,7 +89,7 @@
     REPORTS=".../testreports"
     GRASSSRC=".../grass-src"
     # here we suppose default compilation settings of GRASS and no make install
-    GRASSBIN="$GRASSSRC/bin.../grass75"
+    GRASSBIN="$GRASSSRC/bin.../grass76"
     GRASSDIST="$GRASSSRC/dist..."
     # necessary hardcoded GRASS paths
Modified: grass/trunk/lib/python/docs/src/pygrass_gis.rst
--- grass/trunk/lib/python/docs/src/pygrass_gis.rst	2018-08-31 13:51:11 UTC (rev 73213)
+++ grass/trunk/lib/python/docs/src/pygrass_gis.rst	2018-08-31 13:52:55 UTC (rev 73214)
@@ -14,7 +14,7 @@
 GIS data directory, Location and Mapset. Details about the GRASS GIS
 database management (locations and mapsets) can be found in the `GRASS
 GIS 7 User's Manual: GRASS GIS Quickstart
-<http://grass.osgeo.org/grass75/manuals/helptext.html>`_.
+<https://grass.osgeo.org/grass76/manuals/helptext.html>`_.
 .. _Region-label:
@@ -25,6 +25,6 @@
 information about the computational region and to change it. Details
 about the GRASS GIS computational region management can be found in
 the `GRASS GIS Wiki: Computational region
-<http://grasswiki.osgeo.org/wiki/Computational_region>`_.
+<https://grasswiki.osgeo.org/wiki/Computational_region>`_.
 The classes are part of the :mod:`~pygrass.gis` module.
Modified: grass/trunk/lib/python/gunittest/multirunner.py
--- grass/trunk/lib/python/gunittest/multirunner.py	2018-08-31 13:51:11 UTC (rev 73213)
+++ grass/trunk/lib/python/gunittest/multirunner.py	2018-08-31 13:52:55 UTC (rev 73214)
@@ -56,7 +56,7 @@
     # TODO: create directory according to date and revision and create reports there
     # some predefined variables, name of the GRASS launch script + location/mapset
-    #grass7bin = 'C:\Program Files (x86)\GRASS GIS 7.2.svn\grass75svn.bat'
+    #grass7bin = 'C:\Program Files (x86)\GRASS GIS 7.2.svn\grass76svn.bat'
     grass7bin = args.grassbin  # TODO: can be used if pressent
     ########### SOFTWARE
Modified: grass/trunk/lib/python/pygrass/modules/shortcuts.py
--- grass/trunk/lib/python/pygrass/modules/shortcuts.py	2018-08-31 13:51:11 UTC (rev 73213)
+++ grass/trunk/lib/python/pygrass/modules/shortcuts.py	2018-08-31 13:52:55 UTC (rev 73214)
@@ -59,7 +59,7 @@
                                    name.strip('_').replace('_', '.')))
-# http://grass.osgeo.org/grass75/manuals/full_index.html
+# https://grass.osgeo.org/grass76/manuals/full_index.html
 #[ d.* | db.* | g.* | i.* | m.* | ps.* | r.* | r3.* | t.* | v.* ]
 #  d.*	display commands
Modified: grass/trunk/lib/python/script/core.py
--- grass/trunk/lib/python/script/core.py	2018-08-31 13:51:11 UTC (rev 73213)
+++ grass/trunk/lib/python/script/core.py	2018-08-31 13:52:55 UTC (rev 73214)
@@ -770,7 +770,7 @@
     "flags" are Python booleans.
     Overview table of parser standard options:
-    https://grass.osgeo.org/grass75/manuals/parser_standard_options.html
+    https://grass.osgeo.org/grass76/manuals/parser_standard_options.html
     if not os.getenv("GISBASE"):
         print("You must be in GRASS GIS to run this program.", file=sys.stderr)
Modified: grass/trunk/lib/python/script/setup.py
--- grass/trunk/lib/python/script/setup.py	2018-08-31 13:51:11 UTC (rev 73213)
+++ grass/trunk/lib/python/script/setup.py	2018-08-31 13:52:55 UTC (rev 73214)
@@ -24,12 +24,12 @@
     # query GRASS itself for its GISBASE
     # (with fixes for specific platforms)
     # needs to be edited by the user
-    grass7bin = 'grass75'
+    grass7bin = 'grass76'
     if sys.platform.startswith('win'):
         # MS Windows
-        grass7bin = r'C:\OSGeo4W\bin\grass75.bat'
+        grass7bin = r'C:\OSGeo4W\bin\grass76.bat'
         # uncomment when using standalone WinGRASS installer
-        # grass7bin = r'C:\Program Files (x86)\GRASS GIS 7.2.0\grass75.bat'
+        # grass7bin = r'C:\Program Files (x86)\GRASS GIS 7.2.0\grass76.bat'
         # this can be avoided if GRASS executable is added to PATH
     elif sys.platform == 'darwin':
         # Mac OS X
Modified: grass/trunk/locale/README
--- grass/trunk/locale/README	2018-08-31 13:51:11 UTC (rev 73213)
+++ grass/trunk/locale/README	2018-08-31 13:52:55 UTC (rev 73214)
@@ -123,11 +123,11 @@
  see also: https://grasswiki.osgeo.org/wiki/GRASS_messages_translation#Get_the_translated_po_files
 [1] .pot files are auto-generated on grass.osgeo.org and
-    stored in https://grass.osgeo.org/grass75/binary/linux/snapshot/transifex/
-     --> cronjob: /home/neteler/cronjobs/cron_grass75_releasebranch_72_build_bins.sh
+    stored in https://grass.osgeo.org/grass76/binary/linux/snapshot/transifex/
+     --> cronjob: /home/neteler/cronjobs/cron_grass76_releasebranch_72_build_bins.sh
 [2] Transifex job copies daily from [1] to here:
-	https://www.transifex.com/grass-gis/grass75/
+	https://www.transifex.com/grass-gis/grass76/
 [3] Translators work in Transifex,
Modified: grass/trunk/man/build_graphical_index.py
--- grass/trunk/man/build_graphical_index.py	2018-08-31 13:51:11 UTC (rev 73213)
+++ grass/trunk/man/build_graphical_index.py	2018-08-31 13:52:55 UTC (rev 73214)
@@ -102,7 +102,7 @@
     ('postscript_graphical.html', std_img_name('cartography'), 'Cartography'),
     ('wxGUI_graphical.html', std_img_name('gui'), 'GUI'),
     ('wxGUI.nviz.html', std_img_name('3dview'), '3D view'),
-    ('https://grass.osgeo.org/grass75/manuals/libpython/index.html', std_img_name('python'), 'Python'),
+    ('https://grass.osgeo.org/grass76/manuals/libpython/index.html', std_img_name('python'), 'Python'),
     ('https://grass.osgeo.org/programming7/', std_img_name('c'), 'C library'),
     ('manual_gallery.html', std_img_name('gallery'), 'Gallery'),
     ('https://grass.osgeo.org/grass7/manuals/addons/', std_img_name('addons'), 'Addons'),
Modified: grass/trunk/man/sphinx/conf.py
--- grass/trunk/man/sphinx/conf.py	2018-08-31 13:51:11 UTC (rev 73213)
+++ grass/trunk/man/sphinx/conf.py	2018-08-31 13:52:55 UTC (rev 73214)
@@ -164,7 +164,7 @@
 #html_file_suffix = None
 # Output file base name for HTML help builder.
-htmlhelp_basename = 'grass75Documentationdoc'
+htmlhelp_basename = 'grass76Documentationdoc'
 # -- Options for LaTeX output --------------------------------------------------
@@ -183,7 +183,7 @@
 # Grouping the document tree into LaTeX files. List of tuples
 # (source start file, target name, title, author, documentclass [howto/manual]).
 latex_documents = [
-  ('content', 'grass75Documentation.tex', u'GRASS 7.4 Documentation Documentation',
+  ('content', 'grass76Documentation.tex', u'GRASS 7.4 Documentation Documentation',
    u'GRASS Development Team', 'manual'),
@@ -213,7 +213,7 @@
 # One entry per manual page. List of tuples
 # (source start file, name, description, authors, manual section).
 man_pages = [
-    ('content', 'grass75documentation', u'GRASS 7.4 Documentation Documentation',
+    ('content', 'grass76documentation', u'GRASS 7.4 Documentation Documentation',
      [u'GRASS Development Team'], 1)
@@ -227,8 +227,8 @@
 #  dir menu entry, description, category)
 texinfo_documents = [
-  ('content', 'grass75Documentation', u'GRASS 7.4 Documentation Documentation',
-   u'GRASS Development Team', 'grass75Documentation', 'One line description of project.',
+  ('content', 'grass76Documentation', u'GRASS 7.4 Documentation Documentation',
+   u'GRASS Development Team', 'grass76Documentation', 'One line description of project.',
    'Miscellaneous'),
Modified: grass/trunk/mswindows/Installer-Files/WinGRASS-README.url
--- grass/trunk/mswindows/Installer-Files/WinGRASS-README.url	2018-08-31 13:51:11 UTC (rev 73213)
+++ grass/trunk/mswindows/Installer-Files/WinGRASS-README.url	2018-08-31 13:52:55 UTC (rev 73214)
@@ -1,5 +1,5 @@
 [InternetShortcut]
-URL=http://grass.osgeo.org/grass75/binary/mswindows/native/README.html
+URL=https://grass.osgeo.org/grass76/binary/mswindows/native/README.html
 IDList=
 IconFile=http://grass.osgeo.org/favicon.ico
 IconIndex=1
Modified: grass/trunk/temporal/t.rast.accumulate/t.rast.accumulate.html
--- grass/trunk/temporal/t.rast.accumulate/t.rast.accumulate.html	2018-08-31 13:51:11 UTC (rev 73213)
+++ grass/trunk/temporal/t.rast.accumulate/t.rast.accumulate.html	2018-08-31 13:52:55 UTC (rev 73214)
@@ -66,7 +66,7 @@
 mkdir -p /tmp/grassdata/LL
 # Start GRASS and create a new location with PERMANENT mapset
-grass75 -c EPSG:4326 /tmp/grassdata/LL/PERMANENT
+grass76 -c EPSG:4326 /tmp/grassdata/LL/PERMANENT
 # Import the temperature data
 t.rast.import input=temperature_mean_1990_2000_daily_celsius.tar.gz \
Modified: grass/trunk/vector/v.info/v.info.html
--- grass/trunk/vector/v.info/v.info.html	2018-08-31 13:51:11 UTC (rev 73213)
+++ grass/trunk/vector/v.info/v.info.html	2018-08-31 13:52:55 UTC (rev 73214)
@@ -128,7 +128,7 @@
 <h2>PYTHON</h2>
 <p>
