[GRASS-SVN] r73759 - grass/trunk/locale/po
svn_grass at osgeo.org
Tue Dec 4 08:55:37 PST 2018
Author: hcho
Date: 2018-12-04 08:55:36 -0800 (Tue, 04 Dec 2018)
New Revision: 73759
grass/trunk/locale/po/grassmods_ar.po
grass/trunk/locale/po/grassmods_bn.po
grass/trunk/locale/po/grassmods_cs.po
grass/trunk/locale/po/grassmods_de.po
grass/trunk/locale/po/grassmods_el.po
grass/trunk/locale/po/grassmods_es.po
grass/trunk/locale/po/grassmods_fi.po
grass/trunk/locale/po/grassmods_fr.po
grass/trunk/locale/po/grassmods_hu.po
grass/trunk/locale/po/grassmods_id_ID.po
grass/trunk/locale/po/grassmods_it.po
grass/trunk/locale/po/grassmods_ja.po
grass/trunk/locale/po/grassmods_ko.po
grass/trunk/locale/po/grassmods_lv.po
grass/trunk/locale/po/grassmods_ml.po
grass/trunk/locale/po/grassmods_pl.po
grass/trunk/locale/po/grassmods_pt.po
grass/trunk/locale/po/grassmods_pt_BR.po
grass/trunk/locale/po/grassmods_ro.po
grass/trunk/locale/po/grassmods_ru.po
grass/trunk/locale/po/grassmods_si.po
grass/trunk/locale/po/grassmods_sl.po
grass/trunk/locale/po/grassmods_ta.po
grass/trunk/locale/po/grassmods_th.po
grass/trunk/locale/po/grassmods_tr.po
grass/trunk/locale/po/grassmods_uk.po
grass/trunk/locale/po/grassmods_vi.po
grass/trunk/locale/po/grassmods_zh.po
PO files: r7375[45]
Modified: grass/trunk/locale/po/grassmods_ar.po
--- grass/trunk/locale/po/grassmods_ar.po 2018-12-04 16:52:40 UTC (rev 73758)
+++ grass/trunk/locale/po/grassmods_ar.po 2018-12-04 16:55:36 UTC (rev 73759)
@@ -13833,7 +13833,7 @@
#: ../raster/r.in.lidar/main.c:601
#, c-format
msgid ""
-"Unable to process the hole map at once. Please set the '%s' option to some "
+"Unable to process the whole map at once. Please set the '%s' option to some "
"value lower than 100."
msgstr ""
@@ -15091,7 +15091,7 @@
#: ../raster/r.in.xyz/main.c:536
#, c-format
msgid ""
-"Unable to process the hole map at once. Please set the %s option to some "
+"Unable to process the whole map at once. Please set the %s option to some "
msgstr ""
Modified: grass/trunk/locale/po/grassmods_bn.po
--- grass/trunk/locale/po/grassmods_bn.po 2018-12-04 16:52:40 UTC (rev 73758)
+++ grass/trunk/locale/po/grassmods_bn.po 2018-12-04 16:55:36 UTC (rev 73759)
@@ -2241,7 +2241,7 @@
#, c-format
-msgid "Unable to process the hole map at once. Please set the %s option to some value lower than 100."
+msgid "Unable to process the whole map at once. Please set the %s option to some value lower than 100."
msgstr ""
#: ../raster/r.in.xyz/main.c:589
@@ -7749,7 +7749,7 @@
#: ../raster/r.in.lidar/main.c:596
#, c-format
-msgid "Unable to process the hole map at once. Please set the '%s' option to some value lower than 100."
+msgid "Unable to process the whole map at once. Please set the '%s' option to some value lower than 100."
msgstr ""
#: ../raster/r.in.lidar/main.c:608 ../raster/r.contour/main.c:237
Modified: grass/trunk/locale/po/grassmods_cs.po
--- grass/trunk/locale/po/grassmods_cs.po 2018-12-04 16:52:40 UTC (rev 73758)
+++ grass/trunk/locale/po/grassmods_cs.po 2018-12-04 16:55:36 UTC (rev 73759)
@@ -12223,7 +12223,7 @@
#, c-format
msgstr ""
#: ../raster/r.in.lidar/main.c:621
@@ -13368,7 +13368,7 @@
#, c-format
msgstr ""
Modified: grass/trunk/locale/po/grassmods_de.po
--- grass/trunk/locale/po/grassmods_de.po 2018-12-04 16:52:40 UTC (rev 73758)
+++ grass/trunk/locale/po/grassmods_de.po 2018-12-04 16:55:36 UTC (rev 73759)
@@ -12191,7 +12191,7 @@
#, c-format
msgstr ""
@@ -13336,7 +13336,7 @@
#, c-format
msgstr ""
Modified: grass/trunk/locale/po/grassmods_el.po
--- grass/trunk/locale/po/grassmods_el.po 2018-12-04 16:52:40 UTC (rev 73758)
+++ grass/trunk/locale/po/grassmods_el.po 2018-12-04 16:55:36 UTC (rev 73759)
@@ -12178,7 +12178,7 @@
#, c-format
msgstr ""
@@ -13321,7 +13321,7 @@
#, c-format
msgstr ""
Modified: grass/trunk/locale/po/grassmods_es.po
--- grass/trunk/locale/po/grassmods_es.po 2018-12-04 16:52:40 UTC (rev 73758)
+++ grass/trunk/locale/po/grassmods_es.po 2018-12-04 16:55:36 UTC (rev 73759)
@@ -12203,7 +12203,7 @@
#, c-format
msgstr ""
@@ -13350,7 +13350,7 @@
#, c-format
msgstr "No ha sido posible procesar todo el mapa de una sola vez. Por favor defina la opción %s a una valor menor que 100."
Modified: grass/trunk/locale/po/grassmods_fi.po
--- grass/trunk/locale/po/grassmods_fi.po 2018-12-04 16:52:40 UTC (rev 73758)
+++ grass/trunk/locale/po/grassmods_fi.po 2018-12-04 16:55:36 UTC (rev 73759)
@@ -12166,7 +12166,7 @@
#, c-format
msgstr ""
@@ -13309,7 +13309,7 @@
#, c-format
msgstr ""
Modified: grass/trunk/locale/po/grassmods_fr.po
--- grass/trunk/locale/po/grassmods_fr.po 2018-12-04 16:52:40 UTC (rev 73758)
+++ grass/trunk/locale/po/grassmods_fr.po 2018-12-04 16:55:36 UTC (rev 73759)
@@ -12189,7 +12189,7 @@
#, c-format
msgstr ""
@@ -13332,7 +13332,7 @@
#, c-format
msgstr ""
Modified: grass/trunk/locale/po/grassmods_hu.po
--- grass/trunk/locale/po/grassmods_hu.po 2018-12-04 16:52:40 UTC (rev 73758)
+++ grass/trunk/locale/po/grassmods_hu.po 2018-12-04 16:55:36 UTC (rev 73759)
@@ -12163,7 +12163,7 @@
#, c-format
msgstr ""
@@ -13306,7 +13306,7 @@
#, c-format
msgstr ""
Modified: grass/trunk/locale/po/grassmods_id_ID.po
--- grass/trunk/locale/po/grassmods_id_ID.po 2018-12-04 16:52:40 UTC (rev 73758)
+++ grass/trunk/locale/po/grassmods_id_ID.po 2018-12-04 16:55:36 UTC (rev 73759)
@@ -12148,7 +12148,7 @@
#, c-format
msgstr ""
@@ -13291,7 +13291,7 @@
#, c-format
msgstr ""
Modified: grass/trunk/locale/po/grassmods_it.po
--- grass/trunk/locale/po/grassmods_it.po 2018-12-04 16:52:40 UTC (rev 73758)
+++ grass/trunk/locale/po/grassmods_it.po 2018-12-04 16:55:36 UTC (rev 73759)
@@ -12196,7 +12196,7 @@
#, c-format
msgstr ""
@@ -13341,7 +13341,7 @@
#, c-format
msgstr ""
Modified: grass/trunk/locale/po/grassmods_ja.po
--- grass/trunk/locale/po/grassmods_ja.po 2018-12-04 16:52:40 UTC (rev 73758)
+++ grass/trunk/locale/po/grassmods_ja.po 2018-12-04 16:55:36 UTC (rev 73759)
@@ -12177,7 +12177,7 @@
#, c-format
msgstr ""
@@ -13320,7 +13320,7 @@
#, c-format
msgstr ""
Modified: grass/trunk/locale/po/grassmods_ko.po
--- grass/trunk/locale/po/grassmods_ko.po 2018-12-04 16:52:40 UTC (rev 73758)
+++ grass/trunk/locale/po/grassmods_ko.po 2018-12-04 16:55:36 UTC (rev 73759)
@@ -12160,7 +12160,7 @@
#, c-format
msgstr ""
@@ -13303,7 +13303,7 @@
#, c-format
msgstr ""
Modified: grass/trunk/locale/po/grassmods_lv.po
--- grass/trunk/locale/po/grassmods_lv.po 2018-12-04 16:52:40 UTC (rev 73758)
+++ grass/trunk/locale/po/grassmods_lv.po 2018-12-04 16:55:36 UTC (rev 73759)
@@ -12746,7 +12746,7 @@
#, c-format
msgid ""
msgstr ""
@@ -13931,7 +13931,7 @@
#, c-format
msgid ""
msgstr ""
Modified: grass/trunk/locale/po/grassmods_ml.po
--- grass/trunk/locale/po/grassmods_ml.po 2018-12-04 16:52:40 UTC (rev 73758)
+++ grass/trunk/locale/po/grassmods_ml.po 2018-12-04 16:55:36 UTC (rev 73759)
@@ -12162,7 +12162,7 @@
#, c-format
msgstr ""
@@ -13305,7 +13305,7 @@
#, c-format
msgstr ""
Modified: grass/trunk/locale/po/grassmods_pl.po
--- grass/trunk/locale/po/grassmods_pl.po 2018-12-04 16:52:40 UTC (rev 73758)
+++ grass/trunk/locale/po/grassmods_pl.po 2018-12-04 16:55:36 UTC (rev 73759)
@@ -12211,7 +12211,7 @@
#, c-format
msgstr ""
@@ -13354,7 +13354,7 @@
#, c-format
msgstr ""
Modified: grass/trunk/locale/po/grassmods_pt.po
--- grass/trunk/locale/po/grassmods_pt.po 2018-12-04 16:52:40 UTC (rev 73758)
+++ grass/trunk/locale/po/grassmods_pt.po 2018-12-04 16:55:36 UTC (rev 73759)
@@ -12180,7 +12180,7 @@
#, c-format
msgstr ""
@@ -13323,7 +13323,7 @@
#, c-format
msgstr ""
Modified: grass/trunk/locale/po/grassmods_pt_BR.po
--- grass/trunk/locale/po/grassmods_pt_BR.po 2018-12-04 16:52:40 UTC (rev 73758)
+++ grass/trunk/locale/po/grassmods_pt_BR.po 2018-12-04 16:55:36 UTC (rev 73759)
@@ -12176,7 +12176,7 @@
#, c-format
msgstr ""
#, c-format
msgstr ""
Modified: grass/trunk/locale/po/grassmods_ro.po
--- grass/trunk/locale/po/grassmods_ro.po 2018-12-04 16:52:40 UTC (rev 73758)
+++ grass/trunk/locale/po/grassmods_ro.po 2018-12-04 16:55:36 UTC (rev 73759)
@@ -12194,7 +12194,7 @@
#, c-format
msgstr ""
@@ -13337,7 +13337,7 @@
#, c-format
msgstr ""
Modified: grass/trunk/locale/po/grassmods_ru.po
--- grass/trunk/locale/po/grassmods_ru.po 2018-12-04 16:52:40 UTC (rev 73758)
+++ grass/trunk/locale/po/grassmods_ru.po 2018-12-04 16:55:36 UTC (rev 73759)
@@ -12199,7 +12199,7 @@
#, c-format
msgstr ""
@@ -13342,7 +13342,7 @@
#, c-format
msgstr ""
Modified: grass/trunk/locale/po/grassmods_si.po
--- grass/trunk/locale/po/grassmods_si.po 2018-12-04 16:52:40 UTC (rev 73758)
+++ grass/trunk/locale/po/grassmods_si.po 2018-12-04 16:55:36 UTC (rev 73759)
#, c-format
msgstr ""
#, c-format
msgstr ""
Modified: grass/trunk/locale/po/grassmods_sl.po
--- grass/trunk/locale/po/grassmods_sl.po 2018-12-04 16:52:40 UTC (rev 73758)
+++ grass/trunk/locale/po/grassmods_sl.po 2018-12-04 16:55:36 UTC (rev 73759)
@@ -13971,7 +13971,7 @@
#, c-format
msgid ""
msgstr ""
@@ -15236,7 +15236,7 @@
#, c-format
msgid ""
msgstr ""
Modified: grass/trunk/locale/po/grassmods_ta.po
--- grass/trunk/locale/po/grassmods_ta.po 2018-12-04 16:52:40 UTC (rev 73758)
+++ grass/trunk/locale/po/grassmods_ta.po 2018-12-04 16:55:36 UTC (rev 73759)
@@ -12165,7 +12165,7 @@
#, c-format
msgstr ""
@@ -13308,7 +13308,7 @@
#, c-format
msgstr ""
Modified: grass/trunk/locale/po/grassmods_th.po
--- grass/trunk/locale/po/grassmods_th.po 2018-12-04 16:52:40 UTC (rev 73758)
+++ grass/trunk/locale/po/grassmods_th.po 2018-12-04 16:55:36 UTC (rev 73759)
#, c-format
msgstr ""
#, c-format
msgstr ""
Modified: grass/trunk/locale/po/grassmods_tr.po
--- grass/trunk/locale/po/grassmods_tr.po 2018-12-04 16:52:40 UTC (rev 73758)
+++ grass/trunk/locale/po/grassmods_tr.po 2018-12-04 16:55:36 UTC (rev 73759)
@@ -12182,7 +12182,7 @@
#, c-format
msgstr ""
@@ -13325,7 +13325,7 @@
#, c-format
msgstr ""
Modified: grass/trunk/locale/po/grassmods_uk.po
--- grass/trunk/locale/po/grassmods_uk.po 2018-12-04 16:52:40 UTC (rev 73758)
+++ grass/trunk/locale/po/grassmods_uk.po 2018-12-04 16:55:36 UTC (rev 73759)
@@ -12190,7 +12190,7 @@
#, c-format
msgstr ""
@@ -13333,7 +13333,7 @@
#, c-format
msgstr ""
Modified: grass/trunk/locale/po/grassmods_vi.po
--- grass/trunk/locale/po/grassmods_vi.po 2018-12-04 16:52:40 UTC (rev 73758)
+++ grass/trunk/locale/po/grassmods_vi.po 2018-12-04 16:55:36 UTC (rev 73759)
@@ -12161,7 +12161,7 @@
#, c-format
msgstr ""
@@ -13304,7 +13304,7 @@
#, c-format
msgstr ""
Modified: grass/trunk/locale/po/grassmods_zh.po
--- grass/trunk/locale/po/grassmods_zh.po 2018-12-04 16:52:40 UTC (rev 73758)
+++ grass/trunk/locale/po/grassmods_zh.po 2018-12-04 16:55:36 UTC (rev 73759)
@@ -12175,7 +12175,7 @@
#, c-format
msgstr ""
@@ -13318,7 +13318,7 @@
#, c-format
msgstr ""
