[GRASS-SVN] r73774 - grass-addons/grass7/vector/v.out.png
svn_grass at osgeo.org
Thu Dec 6 03:09:58 PST 2018
Author: neteler
Date: 2018-12-06 03:09:58 -0800 (Thu, 06 Dec 2018)
New Revision: 73774
grass-addons/grass7/vector/v.out.png/v.out.png.py
v.out.png addon: run d.info region task initially since it erases the display
Modified: grass-addons/grass7/vector/v.out.png/v.out.png.py
--- grass-addons/grass7/vector/v.out.png/v.out.png.py 2018-12-06 10:55:19 UTC (rev 73773)
+++ grass-addons/grass7/vector/v.out.png/v.out.png.py 2018-12-06 11:09:58 UTC (rev 73774)
@@ -71,6 +71,11 @@
os.environ['GRASS_RENDER_WIDTH'] = options['width']
os.environ['GRASS_RENDER_HEIGHT'] = options['height']
+ if flags['w']:
+ # get display region info
+ s = grass.read_command('d.info', flags='g')
+ win = grassutils.parse_key_val(s, val_type=float)
monitor_old = None
genv = gisenv()
if 'MONITOR' in genv:
@@ -86,11 +91,8 @@
if monitor_old:
g.gisenv(set='MONITOR=%s' % monitor_old)
- # get display region info
- s = grass.read_command('d.info', flags='g')
- win = grassutils.parse_key_val(s, val_type=float)
if flags['w']:
wldfile = options['output'].split('.')[0] + '.wld'
file_ = open(wldfile, "w")
file_.write("%36.15f \n" % win['ewres'])
