[GRASS-SVN] r73781 - grass/trunk/vector/v.split
Sun Dec 9 03:29:01 PST 2018
Author: neteler
Date: 2018-12-09 03:29:01 -0800 (Sun, 09 Dec 2018)
New Revision: 73781
   grass/trunk/vector/v.split/v.split.html
v.split manual: added info on how to obtain segment length info (source: mlennert, https://lists.osgeo.org/pipermail/grass-user/2018-November/079761.html)
Modified: grass/trunk/vector/v.split/v.split.html
--- grass/trunk/vector/v.split/v.split.html	2018-12-08 13:59:35 UTC (rev 73780)
+++ grass/trunk/vector/v.split/v.split.html	2018-12-09 11:29:01 UTC (rev 73781)
@@ -5,6 +5,40 @@
 is expected to be equal and not higher than the given <b>length</b>
 parameter.
+<h2>NOTES</h2>
+<em>v.split</em> does not change the layer, nor the category information,
+nor the attribute table links of the original file. It just splits each
+line in segments and attributes the same category to all segments of the same
+original line. As the attribute table is linked to the features with
+their category as key, all segments originating from the same original
+line are linked to the same line in the original attribute table which
+is just copied to the new map.
+<h3>Notes on segment length information</h3>
+When running <em>v.to.db</em> on a map produced by <em>v.split</em>, it
+will add length information for each segment in its respective attribute
+line, but since all the segments of the same original line share the
+same attribute table line, it only gets updated once.
+<p>
+To obtain the length of each segment, the user will have to attribute
+different category values to all of them. The best is to do this on a
+separate layer, using <em>v.category</em>
+<div class="code"><pre>
+v.category v_split op=add layer=2 output=v_split_2
+</pre></div>
+and then run above commands on the new layer 2:
+v.db.addcolumn map=v_split_2 column="length double precision" layer=2
+v.to.db map=v_split_2 type=line option=length columns=length units=meters layer=2
+</pre></div>
 <h2>EXAMPLES</h2>
 The examples are based on the North Carolina sample data location.
