[GRASS-SVN] r73788 - grass-addons/grass7/vector/v.clean.ogr
svn_grass at osgeo.org
Mon Dec 10 13:40:30 PST 2018
Author: neteler
Date: 2018-12-10 13:40:30 -0800 (Mon, 10 Dec 2018)
New Revision: 73788
grass-addons/grass7/vector/v.clean.ogr/v.clean.ogr.py
v.clean.ogr addon: fix inconsistent use of tabs and spaces in indentation (needed for Python3)
Modified: grass-addons/grass7/vector/v.clean.ogr/v.clean.ogr.py
--- grass-addons/grass7/vector/v.clean.ogr/v.clean.ogr.py 2018-12-10 19:21:47 UTC (rev 73787)
+++ grass-addons/grass7/vector/v.clean.ogr/v.clean.ogr.py 2018-12-10 21:40:30 UTC (rev 73788)
@@ -193,16 +193,16 @@
# list input layers
if flags['l']:
- try:
- grass.run_command('v.in.ogr', input=indsn, flags = 'l')
- except CalledModuleError:
- grass.fatal(_("Unable to list layers in OGR datasource <%s>") % indsn)
- return 0
+ try:
+ grass.run_command('v.in.ogr', input=indsn, flags = 'l')
+ except CalledModuleError:
+ grass.fatal(_("Unable to list layers in OGR datasource <%s>") % indsn)
+ return 0
# list output formats
if flags['f']:
- grass.run_command('v.out.ogr', flags = 'l')
- return 0
+ grass.run_command('v.out.ogr', flags = 'l')
+ return 0
# import options
vopts = {}
@@ -247,7 +247,7 @@
outvect = 'vector_clean'
outvect_tmp = 'vector_clean'
if float(min_area) > 0:
- outvect_tmp = 'vector_clean_import'
+ outvect_tmp = 'vector_clean_import'
# import into temp location
grass.message(_("Importing <%s>, layer <%s> ...") % (indsn, inlayer))
@@ -259,25 +259,25 @@
# remove small areas
- grass.message(_("Removing small areas in data source <%s>, layer <%s> ...") % (indsn, inlayer))
- try:
- grass.run_command('v.clean', input=outvect_tmp, output=outvect,
- type='area', tool='rmarea', threshold=min_area, overwrite=overwrite)
- grass.fatal(_("Removing small areas in data source <%s>, layer <%s> failed") % (indsn, inlayer))
+ grass.message(_("Removing small areas in data source <%s>, layer <%s> ...") % (indsn, inlayer))
+ try:
+ grass.run_command('v.clean', input=outvect_tmp, output=outvect,
+ type='area', tool='rmarea', threshold=min_area, overwrite=overwrite)
+ grass.fatal(_("Removing small areas in data source <%s>, layer <%s> failed") % (indsn, inlayer))
# export
oflags = 'sm'
if flags['u']:
- oflags = 'smu'
- overwrite = True
+ oflags = 'smu'
+ overwrite = True
outlayer = '%s_clean' % inlayer
grass.message=(_("Exporting cleaned layer as <%s>") % outlayer)
try:
- grass.run_command('v.out.ogr', input=outvect, layer='1', output=outdsn,
- output_layer=outlayer, format=outformat, flags=oflags,
- overwrite=overwrite)
+ grass.run_command('v.out.ogr', input=outvect, layer='1', output=outdsn,
+ output_layer=outlayer, format=outformat, flags=oflags,
+ overwrite=overwrite)
grass.fatal(_("Unable to export to OGR datasource <%s>") % outdsn)
@@ -289,15 +289,15 @@
# nlayers += 1
if nlayers == 2:
- outlayer = '%s_overlaps' % inlayer
- oflags = 'smu'
- grass.message=(_("Exporting overlaps as <%s>") % outlayer)
- try:
- grass.run_command('v.out.ogr', input=outvect, layer='2', output=outdsn,
- overwrite=True)
- grass.fatal(_("Unable to export to OGR datasource <%s>") % outdsn)
+ outlayer = '%s_overlaps' % inlayer
+ oflags = 'smu'
+ grass.message=(_("Exporting overlaps as <%s>") % outlayer)
+ try:
+ grass.run_command('v.out.ogr', input=outvect, layer='2', output=outdsn,
+ overwrite=True)
+ grass.fatal(_("Unable to export to OGR datasource <%s>") % outdsn)
# switch to target location
os.environ['GISRC'] = str(tgtgisrc)
