[GRASS-SVN] r73793 - grass/trunk/scripts/g.extension
svn_grass at osgeo.org
Tue Dec 11 01:57:10 PST 2018
Author: martinl
Date: 2018-12-11 01:57:10 -0800 (Tue, 11 Dec 2018)
New Revision: 73793
grass/trunk/scripts/g.extension/g.extension.py
fix g.extension for python3, see #3446
Modified: grass/trunk/scripts/g.extension/g.extension.py
--- grass/trunk/scripts/g.extension/g.extension.py 2018-12-11 06:30:28 UTC (rev 73792)
+++ grass/trunk/scripts/g.extension/g.extension.py 2018-12-11 09:57:10 UTC (rev 73793)
@@ -1036,21 +1036,29 @@
Binary files are ignored. Recurses into subdirectories.
+ # skip binary files
+ # see https://stackoverflow.com/a/7392391
+ textchars = bytearray({7,8,9,10,12,13,27} | set(range(0x20, 0x100)) - {0x7f})
+ is_binary_string = lambda bytes: bool(bytes.translate(None, textchars))
for root, unused, files in os.walk(directory):
for name in files:
filename = os.path.join(root, name)
- data = open(filename, 'rb').read()
- if '\0' in data:
+ if is_binary_string(open(filename, 'rb').read(1024)):
continue # ignore binary files
- # we don't expect there would be CRLF file by purpose
- # if we want to allow CRLF files we would have to whitelite .py etc
+ # read content of text file
+ with open(filename, 'rb') as fd:
+ data = fd.read()
+ # we don't expect there would be CRLF file by
+ # purpose if we want to allow CRLF files we would
+ # have to whitelite .py etc
newdata = data.replace(b'\r\n', b'\n')
if newdata != data:
- newfile = open(filename, 'wb')
- newfile.write(newdata)
- newfile.close()
+ with open(filename, 'wb') as newfile:
+ newfile.write(newdata)
def extract_zip(name, directory, tmpdir):
"""Extract a ZIP file into a directory"""
gscript.debug("extract_zip(name={name}, directory={directory},"
