[GRASS-SVN] r73801 - grass/trunk/lib/htmldriver
svn_grass at osgeo.org
Fri Dec 14 13:31:53 PST 2018
Author: neteler
Date: 2018-12-14 13:31:53 -0800 (Fri, 14 Dec 2018)
New Revision: 73801
grass/trunk/lib/htmldriver/htmldriver.html
htmldriver: changed example to NC dataset
Modified: grass/trunk/lib/htmldriver/htmldriver.html
--- grass/trunk/lib/htmldriver/htmldriver.html 2018-12-14 13:23:10 UTC (rev 73800)
+++ grass/trunk/lib/htmldriver/htmldriver.html 2018-12-14 21:31:53 UTC (rev 73801)
@@ -100,6 +100,7 @@
Start up the driver
<div class="code"><pre>
+g.region vector=zipcodes_wake
d.mon start=html
</pre></div>
@@ -106,14 +107,14 @@
Display text strings (HREF's) and polygons
-echo "http://www.no-such-place.net/area51/" | d.text
-d.vect map=area51
-echo "http://www.roswell-nm.net/little/green/men.html" | d.text
-d.vect map=roswell
+echo "https://en.wikipedia.org/wiki/Raleigh,_North_Carolina" | d.text
+d.vect map=zipcodes_wake where="ZIPNAME = 'RALEIGH'"
+echo "https://en.wikipedia.org/wiki/Cary,_North_Carolina" | d.text
+d.vect map=zipcodes_wake where="ZIPNAME = 'CARY'" fill_color=180:200:210
</pre></div>
-Stop the driver when all polygon have been displayed. This will cause
-a file named 'htmlmap' to be created in your current directory.
+Stop the driver once all polygon have been displayed. This will create
+a file named 'htmlmap' in your current directory:
d.mon stop=html
