[GRASS-SVN] r73848 - grass/trunk
svn_grass at osgeo.org
Wed Dec 26 02:20:41 PST 2018
Author: neteler
Date: 2018-12-26 02:20:41 -0800 (Wed, 26 Dec 2018)
New Revision: 73848
grass/trunk/config.guess
grass/trunk/config.sub
config.guess + config.sub: updated from http://git.savannah.gnu.org/cgit/config.git/plain/
Modified: grass/trunk/config.guess
--- grass/trunk/config.guess 2018-12-26 10:17:37 UTC (rev 73847)
+++ grass/trunk/config.guess 2018-12-26 10:20:41 UTC (rev 73848)
@@ -2,7 +2,7 @@
# Attempt to guess a canonical system name.
# Copyright 1992-2018 Free Software Foundation, Inc.
-timestamp='2018-03-08'
+timestamp='2018-12-07'
# This file is free software; you can redistribute it and/or modify it
# under the terms of the GNU General Public License as published by
@@ -84,8 +84,6 @@
exit 1
fi
-trap 'exit 1' 1 2 15
# CC_FOR_BUILD -- compiler used by this script. Note that the use of a
# compiler to aid in system detection is discouraged as it requires
# temporary files to be created and, as you can see below, it is a
@@ -96,34 +94,38 @@
# Portable tmp directory creation inspired by the Autoconf team.
-set_cc_for_build='
-trap "exitcode=\$?; (rm -f \$tmpfiles 2>/dev/null; rmdir \$tmp 2>/dev/null) && exit \$exitcode" 0 ;
-trap "rm -f \$tmpfiles 2>/dev/null; rmdir \$tmp 2>/dev/null; exit 1" 1 2 13 15 ;
-: ${TMPDIR=/tmp} ;
- { tmp=`(umask 077 && mktemp -d "$TMPDIR/cgXXXXXX") 2>/dev/null` && test -n "$tmp" && test -d "$tmp" ; } ||
- { test -n "$RANDOM" && tmp=$TMPDIR/cg$$-$RANDOM && (umask 077 && mkdir $tmp) ; } ||
- { tmp=$TMPDIR/cg-$$ && (umask 077 && mkdir $tmp) && echo "Warning: creating insecure temp directory" >&2 ; } ||
- { echo "$me: cannot create a temporary directory in $TMPDIR" >&2 ; exit 1 ; } ;
-dummy=$tmp/dummy ;
-tmpfiles="$dummy.c $dummy.o $dummy.rel $dummy" ;
-case $CC_FOR_BUILD,$HOST_CC,$CC in
- ,,) echo "int x;" > "$dummy.c" ;
- for c in cc gcc c89 c99 ; do
- if ($c -c -o "$dummy.o" "$dummy.c") >/dev/null 2>&1 ; then
- CC_FOR_BUILD="$c"; break ;
- fi ;
- done ;
- if test x"$CC_FOR_BUILD" = x ; then
- CC_FOR_BUILD=no_compiler_found ;
- fi
- ,,*) CC_FOR_BUILD=$CC ;;
- ,*,*) CC_FOR_BUILD=$HOST_CC ;;
-esac ; set_cc_for_build= ;'
+tmp=
+# shellcheck disable=SC2172
+trap 'test -z "$tmp" || rm -fr "$tmp"' 0 1 2 13 15
+set_cc_for_build() {
+ : "${TMPDIR=/tmp}"
+ # shellcheck disable=SC2039
+ { tmp=`(umask 077 && mktemp -d "$TMPDIR/cgXXXXXX") 2>/dev/null` && test -n "$tmp" && test -d "$tmp" ; } ||
+ { test -n "$RANDOM" && tmp=$TMPDIR/cg$$-$RANDOM && (umask 077 && mkdir "$tmp" 2>/dev/null) ; } ||
+ { tmp=$TMPDIR/cg-$$ && (umask 077 && mkdir "$tmp" 2>/dev/null) && echo "Warning: creating insecure temp directory" >&2 ; } ||
+ { echo "$me: cannot create a temporary directory in $TMPDIR" >&2 ; exit 1 ; }
+ dummy=$tmp/dummy
+ case ${CC_FOR_BUILD-},${HOST_CC-},${CC-} in
+ ,,) echo "int x;" > "$dummy.c"
+ for driver in cc gcc c89 c99 ; do
+ if ($driver -c -o "$dummy.o" "$dummy.c") >/dev/null 2>&1 ; then
+ CC_FOR_BUILD="$driver"
+ break
+ fi
+ done
+ if test x"$CC_FOR_BUILD" = x ; then
+ CC_FOR_BUILD=no_compiler_found
+ fi
+ ,,*) CC_FOR_BUILD=$CC ;;
+ ,*,*) CC_FOR_BUILD=$HOST_CC ;;
+ esac
# This is needed to find uname on a Pyramid OSx when run in the BSD universe.
# (ghazi at noc.rutgers.edu 1994-08-24)
-if (test -f /.attbin/uname) >/dev/null 2>&1 ; then
+if test -f /.attbin/uname ; then
PATH=$PATH:/.attbin ; export PATH
fi
@@ -138,7 +140,7 @@
# We could probably try harder.
LIBC=gnu
- eval "$set_cc_for_build"
+ set_cc_for_build
cat <<-EOF > "$dummy.c"
#include <features.h>
#if defined(__UCLIBC__)
@@ -199,7 +201,7 @@
os=netbsdelf
arm*|i386|m68k|ns32k|sh3*|sparc|vax)
+ set_cc_for_build
if echo __ELF__ | $CC_FOR_BUILD -E - 2>/dev/null \
| grep -q __ELF__
then
@@ -237,7 +239,7 @@
# Since CPU_TYPE-MANUFACTURER-KERNEL-OPERATING_SYSTEM:
# contains redundant information, the shorter form:
# CPU_TYPE-MANUFACTURER-OPERATING_SYSTEM is used.
- echo "$machine-${os}${release}${abi}"
+ echo "$machine-${os}${release}${abi-}"
exit ;;
*:Bitrig:*:*)
UNAME_MACHINE_ARCH=`arch | sed 's/Bitrig.//'`
@@ -389,7 +391,7 @@
echo i386-pc-auroraux"$UNAME_RELEASE"
exit ;;
i86pc:SunOS:5.*:* | i86xen:SunOS:5.*:*)
+ set_cc_for_build
SUN_ARCH=i386
# If there is a compiler, see if it is configured for 64-bit objects.
# Note that the Sun cc does not turn __LP64__ into 1 like gcc does.
@@ -482,7 +484,7 @@
echo clipper-intergraph-clix"$UNAME_RELEASE"
exit ;;
mips:*:*:UMIPS | mips:*:*:RISCos)
+ set_cc_for_build
sed 's/^ //' << EOF > "$dummy.c"
#ifdef __cplusplus
#include <stdio.h> /* for printf() prototype */
@@ -579,7 +581,7 @@
exit ;;
*:AIX:2:3)
if grep bos325 /usr/include/stdio.h >/dev/null 2>&1; then
+ set_cc_for_build
#include <sys/systemcfg.h>
@@ -660,7 +662,7 @@
esac
fi
if [ "$HP_ARCH" = "" ]; then
+ set_cc_for_build
#define _HPUX_SOURCE
@@ -700,7 +702,7 @@
esac
if [ "$HP_ARCH" = hppa2.0w ]
then
+ set_cc_for_build
# hppa2.0w-hp-hpux* has a 64-bit kernel and a compiler generating
# 32-bit code. hppa64-hp-hpux* has the same kernel and a compiler
@@ -726,7 +728,7 @@
echo ia64-hp-hpux"$HPUX_REV"
exit ;;
3050*:HI-UX:*:*)
+ set_cc_for_build
#include <unistd.h>
int
@@ -840,6 +842,17 @@
*:BSD/OS:*:*)
echo "$UNAME_MACHINE"-unknown-bsdi"$UNAME_RELEASE"
exit ;;
+ arm:FreeBSD:*:*)
+ UNAME_PROCESSOR=`uname -p`
+ set_cc_for_build
+ if echo __ARM_PCS_VFP | $CC_FOR_BUILD -E - 2>/dev/null \
+ | grep -q __ARM_PCS_VFP
+ then
+ echo "${UNAME_PROCESSOR}"-unknown-freebsd"`echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'`"-gnueabi
+ else
+ echo "${UNAME_PROCESSOR}"-unknown-freebsd"`echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'`"-gnueabihf
+ fi
+ exit ;;
*:FreeBSD:*:*)
UNAME_PROCESSOR=`/usr/bin/uname -p`
case "$UNAME_PROCESSOR" in
@@ -881,7 +894,7 @@
echo "$UNAME_MACHINE"-pc-uwin
exit ;;
amd64:CYGWIN*:*:* | x86_64:CYGWIN*:*:*)
- echo x86_64-unknown-cygwin
+ echo x86_64-pc-cygwin
exit ;;
prep*:SunOS:5.*:*)
echo powerpcle-unknown-solaris2"`echo "$UNAME_RELEASE"|sed -e 's/[^.]*//'`"
@@ -894,8 +907,8 @@
# other systems with GNU libc and userland
echo "$UNAME_MACHINE-unknown-`echo "$UNAME_SYSTEM" | sed 's,^[^/]*/,,' | tr "[:upper:]" "[:lower:]"``echo "$UNAME_RELEASE"|sed -e 's/[-(].*//'`-$LIBC"
exit ;;
- i*86:Minix:*:*)
- echo "$UNAME_MACHINE"-pc-minix
+ *:Minix:*:*)
+ echo "$UNAME_MACHINE"-unknown-minix
exit ;;
aarch64:Linux:*:*)
echo "$UNAME_MACHINE"-unknown-linux-"$LIBC"
@@ -922,7 +935,7 @@
exit ;;
arm*:Linux:*:*)
+ set_cc_for_build
if echo __ARM_EABI__ | $CC_FOR_BUILD -E - 2>/dev/null \
| grep -q __ARM_EABI__
then
@@ -971,7 +984,7 @@
exit ;;
mips:Linux:*:* | mips64:Linux:*:*)
+ set_cc_for_build
#undef CPU
#undef ${UNAME_MACHINE}
@@ -1285,7 +1298,7 @@
exit ;;
*:Darwin:*:*)
UNAME_PROCESSOR=`uname -p` || UNAME_PROCESSOR=unknown
+ set_cc_for_build
if test "$UNAME_PROCESSOR" = unknown ; then
UNAME_PROCESSOR=powerpc
fi
@@ -1358,6 +1371,7 @@
# "uname -m" is not consistent, so use $cputype instead. 386
# is converted to i386 for consistency with other x86
# operating systems.
+ # shellcheck disable=SC2154
if test "$cputype" = 386; then
UNAME_MACHINE=i386
else
@@ -1414,6 +1428,9 @@
amd64:Isilon\ OneFS:*:*)
echo x86_64-unknown-onefs
exit ;;
+ *:Unleashed:*:*)
+ echo "$UNAME_MACHINE"-unknown-unleashed"$UNAME_RELEASE"
+ exit ;;
esac
echo "$0: unable to guess system type" >&2
Modified: grass/trunk/config.sub
--- grass/trunk/config.sub 2018-12-26 10:17:37 UTC (rev 73847)
+++ grass/trunk/config.sub 2018-12-26 10:20:41 UTC (rev 73848)
@@ -2,7 +2,7 @@
# Configuration validation subroutine script.
-timestamp='2018-05-03'
+timestamp='2018-12-16'
@@ -89,7 +89,7 @@
- ) # Use stdin as input.
break ;;
- echo "$me: invalid option $1$help"
+ echo "$me: invalid option $1$help" >&2
exit 1 ;;
*local*)
@@ -110,1234 +110,1160 @@
exit 1;;
esac
-# Separate what the user gave into CPU-COMPANY and OS or KERNEL-OS (if any).
-# Here we must recognize all the valid KERNEL-OS combinations.
-maybe_os=`echo "$1" | sed 's/^\(.*\)-\([^-]*-[^-]*\)$/\2/'`
-case $maybe_os in
- nto-qnx* | linux-gnu* | linux-android* | linux-dietlibc | linux-newlib* | \
- linux-musl* | linux-uclibc* | uclinux-uclibc* | uclinux-gnu* | kfreebsd*-gnu* | \
- knetbsd*-gnu* | netbsd*-gnu* | netbsd*-eabi* | \
- kopensolaris*-gnu* | cloudabi*-eabi* | \
- storm-chaos* | os2-emx* | rtmk-nova*)
- os=-$maybe_os
- basic_machine=`echo "$1" | sed 's/^\(.*\)-\([^-]*-[^-]*\)$/\1/'`
- android-linux)
- os=-linux-android
- basic_machine=`echo "$1" | sed 's/^\(.*\)-\([^-]*-[^-]*\)$/\1/'`-unknown
- basic_machine=`echo "$1" | sed 's/-[^-]*$//'`
- case $1 in
- os=`echo "$1" | sed 's/.*-/-/'`
- os=
- esac
-esac
+# Split fields of configuration type
+IFS="-" read field1 field2 field3 field4 <<EOF
+$1
+EOF
-### Let's recognize common machines as not being operating systems so
-### that things like config.sub decstation-3100 work. We also
-### recognize some manufacturers as not being operating systems, so we
-### can provide default operating systems below.
-case $os in
- -sun*os*)
- # Prevent following clause from handling this invalid input.
+# Separate into logical components for further validation
+case $1 in
+ echo Invalid configuration \`"$1"\': more than four components >&2
+ exit 1
- -dec* | -mips* | -sequent* | -encore* | -pc532* | -sgi* | -sony* | \
- -att* | -7300* | -3300* | -delta* | -motorola* | -sun[234]* | \
- -unicom* | -ibm* | -next | -hp | -isi* | -apollo | -altos* | \
- -convergent* | -ncr* | -news | -32* | -3600* | -3100* | -hitachi* |\
- -c[123]* | -convex* | -sun | -crds | -omron* | -dg | -ultra | -tti* | \
- -harris | -dolphin | -highlevel | -gould | -cbm | -ns | -masscomp | \
- -apple | -axis | -knuth | -cray | -microblaze*)
- os=
- basic_machine=$1
+ basic_machine=$field1-$field2
+ os=$field3-$field4
- -bluegene*)
- os=-cnk
+ # Ambiguous whether COMPANY is present, or skipped and KERNEL-OS is two
+ # parts
+ maybe_os=$field2-$field3
+ case $maybe_os in
+ nto-qnx* | linux-gnu* | linux-android* | linux-dietlibc \
+ | linux-newlib* | linux-musl* | linux-uclibc* | uclinux-uclibc* \
+ | uclinux-gnu* | kfreebsd*-gnu* | knetbsd*-gnu* | netbsd*-gnu* \
+ | netbsd*-eabi* | kopensolaris*-gnu* | cloudabi*-eabi* \
+ | storm-chaos* | os2-emx* | rtmk-nova*)
+ os=$maybe_os
+ android-linux)
+ basic_machine=$field1-unknown
+ os=linux-android
+ os=$field3
+ esac
- -sim | -cisco | -oki | -wec | -winbond)
- os=
- basic_machine=$1
+ # A lone config we happen to match not fitting any pattern
+ case $field1-$field2 in
+ decstation-3100)
+ basic_machine=mips-dec
+ os=
+ # Second component is usually, but not always the OS
+ case $field2 in
+ # Prevent following clause from handling this valid os
+ sun*os*)
+ os=$field2
+ # Manufacturers
+ dec* | mips* | sequent* | encore* | pc533* | sgi* | sony* \
+ | att* | 7300* | 3300* | delta* | motorola* | sun[234]* \
+ | unicom* | ibm* | next | hp | isi* | apollo | altos* \
+ | convergent* | ncr* | news | 32* | 3600* | 3100* \
+ | hitachi* | c[123]* | convex* | sun | crds | omron* | dg \
+ | ultra | tti* | harris | dolphin | highlevel | gould \
+ | cbm | ns | masscomp | apple | axis | knuth | cray \
+ | microblaze* | sim | cisco \
+ | oki | wec | wrs | winbond)
+ os=
+ os=$field2
+ esac
+ esac
- -scout)
+ # Convert single-component short-hands not valid as part of
+ # multi-component configurations.
+ case $field1 in
+ 386bsd)
+ basic_machine=i386-pc
+ os=bsd
+ a29khif)
+ basic_machine=a29k-amd
+ os=udi
+ adobe68k)
+ basic_machine=m68010-adobe
+ os=scout
+ alliant)
+ basic_machine=fx80-alliant
+ os=
+ altos | altos3068)
+ basic_machine=m68k-altos
+ os=
+ am29k)
+ basic_machine=a29k-none
+ os=bsd
+ amdahl)
+ basic_machine=580-amdahl
+ os=sysv
+ amiga)
+ basic_machine=m68k-unknown
+ os=
+ amigaos | amigados)
+ os=amigaos
+ amigaunix | amix)
+ os=sysv4
+ apollo68)
+ basic_machine=m68k-apollo
+ os=sysv
+ apollo68bsd)
+ os=bsd
+ aros)
+ os=aros
+ aux)
+ basic_machine=m68k-apple
+ os=aux
+ balance)
+ basic_machine=ns32k-sequent
+ os=dynix
+ blackfin)
+ basic_machine=bfin-unknown
+ os=linux
+ cegcc)
+ basic_machine=arm-unknown
+ os=cegcc
+ convex-c1)
+ basic_machine=c1-convex
+ os=bsd
+ convex-c2)
+ basic_machine=c2-convex
+ os=bsd
+ convex-c32)
+ basic_machine=c32-convex
+ os=bsd
+ convex-c34)
+ basic_machine=c34-convex
+ os=bsd
+ convex-c38)
+ basic_machine=c38-convex
+ os=bsd
+ cray)
+ basic_machine=j90-cray
+ os=unicos
+ crds | unos)
+ basic_machine=m68k-crds
+ os=
+ da30)
+ basic_machine=m68k-da30
+ os=
+ decstation | pmax | pmin | dec3100 | decstatn)
+ os=
+ delta88)
+ basic_machine=m88k-motorola
+ os=sysv3
+ dicos)
+ basic_machine=i686-pc
+ os=dicos
+ djgpp)
+ basic_machine=i586-pc
+ os=msdosdjgpp
+ ebmon29k)
+ os=ebmon
+ es1800 | OSE68k | ose68k | ose | OSE)
+ basic_machine=m68k-ericsson
+ os=ose
+ gmicro)
+ basic_machine=tron-gmicro
+ os=sysv
+ go32)
+ os=go32
+ h8300hms)
+ basic_machine=h8300-hitachi
+ os=hms
+ h8300xray)
+ os=xray
+ h8500hms)
+ basic_machine=h8500-hitachi
+ os=hms
+ harris)
+ basic_machine=m88k-harris
+ os=sysv3
+ hp300)
+ basic_machine=m68k-hp
+ hp300bsd)
+ os=bsd
+ hp300hpux)
+ os=hpux
+ hppaosf)
+ basic_machine=hppa1.1-hp
+ os=osf
+ hppro)
+ os=proelf
+ i386mach)
+ basic_machine=i386-mach
+ os=mach
+ vsta)
+ os=vsta
+ isi68 | isi)
+ basic_machine=m68k-isi
+ os=sysv
+ m68knommu)
+ os=linux
+ magnum | m3230)
+ basic_machine=mips-mips
+ os=sysv
+ merlin)
+ basic_machine=ns32k-utek
+ os=sysv
+ mingw64)
+ basic_machine=x86_64-pc
+ os=mingw64
+ mingw32)
+ os=mingw32
+ mingw32ce)
+ os=mingw32ce
+ monitor)
+ basic_machine=m68k-rom68k
+ os=coff
+ morphos)
+ basic_machine=powerpc-unknown
+ os=morphos
+ moxiebox)
+ basic_machine=moxie-unknown
+ os=moxiebox
+ msdos)
+ os=msdos
+ msys)
+ os=msys
+ mvs)
+ basic_machine=i370-ibm
+ os=mvs
+ nacl)
+ basic_machine=le32-unknown
+ os=nacl
+ ncr3000)
+ basic_machine=i486-ncr
+ os=sysv4
+ netbsd386)
+ os=netbsd
+ netwinder)
+ basic_machine=armv4l-rebel
+ os=linux
+ news | news700 | news800 | news900)
+ basic_machine=m68k-sony
+ os=newsos
+ news1000)
+ basic_machine=m68030-sony
+ os=newsos
+ necv70)
+ basic_machine=v70-nec
+ os=sysv
+ nh3000)
+ basic_machine=m68k-harris
+ os=cxux
+ nh[45]000)
+ os=cxux
+ nindy960)
+ basic_machine=i960-intel
+ os=nindy
+ mon960)
+ os=mon960
+ nonstopux)
+ basic_machine=mips-compaq
+ os=nonstopux
+ os400)
+ basic_machine=powerpc-ibm
+ os=os400
+ OSE68000 | ose68000)
+ basic_machine=m68000-ericsson
+ os=ose
+ os68k)
+ basic_machine=m68k-none
+ os=os68k
+ paragon)
+ basic_machine=i860-intel
+ os=osf
+ parisc)
+ basic_machine=hppa-unknown
+ os=linux
+ pw32)
+ basic_machine=i586-unknown
+ os=pw32
+ rdos | rdos64)
+ os=rdos
+ rdos32)
+ os=rdos
+ rom68k)
+ os=coff
+ sa29200)
+ os=udi
+ sei)
+ basic_machine=mips-sei
+ os=seiux
+ sequent)
+ basic_machine=i386-sequent
+ os=
+ sps7)
+ basic_machine=m68k-bull
+ os=sysv2
+ st2000)
+ basic_machine=m68k-tandem
+ os=
+ stratus)
+ basic_machine=i860-stratus
+ os=sysv4
+ sun2)
+ basic_machine=m68000-sun
+ os=
+ sun2os3)
+ os=sunos3
+ sun2os4)
+ os=sunos4
+ sun3)
+ basic_machine=m68k-sun
+ os=
+ sun3os3)
+ os=sunos3
+ sun3os4)
+ os=sunos4
+ sun4)
+ basic_machine=sparc-sun
+ os=
+ sun4os3)
+ os=sunos3
+ sun4os4)
+ os=sunos4
+ sun4sol2)
+ os=solaris2
+ sun386 | sun386i | roadrunner)
+ basic_machine=i386-sun
+ os=
+ sv1)
+ basic_machine=sv1-cray
+ os=unicos
+ symmetry)
+ os=dynix
+ t3e)
+ basic_machine=alphaev5-cray
+ os=unicos
+ t90)
+ basic_machine=t90-cray
+ os=unicos
+ toad1)
+ basic_machine=pdp10-xkl
+ os=tops20
+ tpf)
+ basic_machine=s390x-ibm
+ os=tpf
+ udi29k)
+ os=udi
+ ultra3)
+ basic_machine=a29k-nyu
+ os=sym1
+ v810 | necv810)
+ basic_machine=v810-nec
+ os=none
+ vaxv)
+ basic_machine=vax-dec
+ os=sysv
+ vms)
+ os=vms
+ vxworks960)
+ basic_machine=i960-wrs
+ os=vxworks
+ vxworks68)
+ basic_machine=m68k-wrs
+ os=vxworks
+ vxworks29k)
+ basic_machine=a29k-wrs
+ os=vxworks
+ xbox)
+ os=mingw32
+ ymp)
+ basic_machine=ymp-cray
+ os=unicos
+ basic_machine=$1
+ os=
+ esac
- -wrs)
- os=-vxworks
- basic_machine=$1
- -chorusos*)
- os=-chorusos
- basic_machine=$1
- -chorusrdb)
- os=-chorusrdb
- basic_machine=$1
- -hiux*)
- os=-hiuxwe2
- -sco6)
- os=-sco5v6
- basic_machine=`echo "$1" | sed -e 's/86-.*/86-pc/'`
- -sco5)
- os=-sco3.2v5
- -sco4)
- os=-sco3.2v4
- -sco3.2.[4-9]*)
- os=`echo $os | sed -e 's/sco3.2./sco3.2v/'`
- -sco3.2v[4-9]*)
- # Don't forget version if it is 3.2v4 or newer.
- -sco5v6*)
- -sco*)
- os=-sco3.2v2
- -udk*)
- -isc)
- os=-isc2.2
- -clix*)
- basic_machine=clipper-intergraph
- -isc*)
- -lynx*178)
- os=-lynxos178
- -lynx*5)
- os=-lynxos5
- -lynx*)
- os=-lynxos
- -ptx*)
- basic_machine=`echo "$1" | sed -e 's/86-.*/86-sequent/'`
- -psos*)
- os=-psos
- -mint | -mint[0-9]*)
- basic_machine=m68k-atari
- os=-mint
esac
-# Decode aliases for certain CPU-COMPANY combinations.
+# Decode 1-component or ad-hoc basic machines
case $basic_machine in
- # Recognize the basic CPU types without company name.
- # Some are omitted here because they have special meanings below.
- 1750a | 580 \
- | a29k \
- | aarch64 | aarch64_be \
- | alpha | alphaev[4-8] | alphaev56 | alphaev6[78] | alphapca5[67] \
- | alpha64 | alpha64ev[4-8] | alpha64ev56 | alpha64ev6[78] | alpha64pca5[67] \
- | am33_2.0 \
- | arc | arceb \
- | arm | arm[bl]e | arme[lb] | armv[2-8] | armv[3-8][lb] | armv6m | armv[78][arm] \
- | avr | avr32 \
- | ba \
- | be32 | be64 \
- | bfin \
- | c4x | c8051 | clipper | csky \
- | d10v | d30v | dlx | dsp16xx \
- | e2k | epiphany \
- | fido | fr30 | frv | ft32 \
- | h8300 | h8500 | hppa | hppa1.[01] | hppa2.0 | hppa2.0[nw] | hppa64 \
- | hexagon \
- | i370 | i860 | i960 | ia16 | ia64 \
- | ip2k | iq2000 \
- | k1om \
- | le32 | le64 \
- | lm32 \
- | m32c | m32r | m32rle | m68000 | m68k | m88k \
- | maxq | mb | microblaze | microblazeel | mcore | mep | metag \
- | mips | mipsbe | mipseb | mipsel | mipsle \
- | mips16 \
- | mips64 | mips64el \
- | mips64octeon | mips64octeonel \
- | mips64orion | mips64orionel \
- | mips64r5900 | mips64r5900el \
- | mips64vr | mips64vrel \
- | mips64vr4100 | mips64vr4100el \
- | mips64vr4300 | mips64vr4300el \
- | mips64vr5000 | mips64vr5000el \
- | mips64vr5900 | mips64vr5900el \
- | mipsisa32 | mipsisa32el \
- | mipsisa32r2 | mipsisa32r2el \
- | mipsisa32r6 | mipsisa32r6el \
- | mipsisa64 | mipsisa64el \
- | mipsisa64r2 | mipsisa64r2el \
- | mipsisa64r6 | mipsisa64r6el \
- | mipsisa64sb1 | mipsisa64sb1el \
- | mipsisa64sr71k | mipsisa64sr71kel \
- | mipsr5900 | mipsr5900el \
- | mipstx39 | mipstx39el \
- | mn10200 | mn10300 \
- | moxie \
- | mt \
- | msp430 \
- | nds32 | nds32le | nds32be \
- | nfp \
- | nios | nios2 | nios2eb | nios2el \
- | ns16k | ns32k \
- | open8 | or1k | or1knd | or32 \
- | pdp10 | pj | pjl \
- | powerpc | powerpc64 | powerpc64le | powerpcle \
- | pru \
- | pyramid \
- | riscv32 | riscv64 \
- | rl78 | rx \
- | score \
- | sh | sh[1234] | sh[24]a | sh[24]aeb | sh[23]e | sh[234]eb | sheb | shbe | shle | sh[1234]le | sh3ele \
- | sh64 | sh64le \
- | sparc | sparc64 | sparc64b | sparc64v | sparc86x | sparclet | sparclite \
- | sparcv8 | sparcv9 | sparcv9b | sparcv9v \
- | spu \
- | tahoe | tic4x | tic54x | tic55x | tic6x | tic80 | tron \
- | ubicom32 \
- | v850 | v850e | v850e1 | v850e2 | v850es | v850e2v3 \
- | visium \
- | wasm32 \
- | x86 | xc16x | xstormy16 | xtensa \
- | z8k | z80)
- basic_machine=$basic_machine-unknown
+ # Here we handle the default manufacturer of certain CPU types. It is in
+ # some cases the only manufacturer, in others, it is the most popular.
+ w89k)
+ cpu=hppa1.1
+ vendor=winbond
- c54x)
- basic_machine=tic54x-unknown
+ op50n)
+ cpu=hppa1.1
+ vendor=oki
- c55x)
- basic_machine=tic55x-unknown
+ op60c)
+ cpu=hppa1.1
+ vendor=oki
- c6x)
- basic_machine=tic6x-unknown
+ ibm*)
+ cpu=i370
+ vendor=ibm
- leon|leon[3-9])
- basic_machine=sparc-$basic_machine
+ orion105)
+ cpu=clipper
+ vendor=highlevel
- m6811 | m68hc11 | m6812 | m68hc12 | m68hcs12x | nvptx | picochip)
- os=-none
+ mac | mpw | mac-mpw)
+ cpu=m68k
+ vendor=apple
- m88110 | m680[12346]0 | m683?2 | m68360 | m5200 | v70 | w65)
+ pmac | pmac-mpw)
+ cpu=powerpc
+ vendor=apple
- m9s12z | m68hcs12z | hcs12z | s12z)
- basic_machine=s12z-unknown
- os=-none
- ms1)
- basic_machine=mt-unknown
- strongarm | thumb | xscale)
- basic_machine=arm-unknown
- xgate)
- os=-none
- xscaleeb)
- basic_machine=armeb-unknown
- xscaleel)
- basic_machine=armel-unknown
- # We use `pc' rather than `unknown'
- # because (1) that's what they normally are, and
- # (2) the word "unknown" tends to confuse beginning users.
- i*86 | x86_64)
- basic_machine=$basic_machine-pc
- # Object if more than one company name word.
- echo Invalid configuration \`"$1"\': machine \`"$basic_machine"\' not recognized 1>&2
- exit 1
- # Recognize the basic CPU types with company name.
- 580-* \
- | a29k-* \
- | aarch64-* | aarch64_be-* \
- | alpha-* | alphaev[4-8]-* | alphaev56-* | alphaev6[78]-* \
- | alpha64-* | alpha64ev[4-8]-* | alpha64ev56-* | alpha64ev6[78]-* \
- | alphapca5[67]-* | alpha64pca5[67]-* | arc-* | arceb-* \
- | arm-* | armbe-* | armle-* | armeb-* | armv*-* \
- | avr-* | avr32-* \
- | ba-* \
- | be32-* | be64-* \
- | bfin-* | bs2000-* \
- | c[123]* | c30-* | [cjt]90-* | c4x-* \
- | c8051-* | clipper-* | craynv-* | csky-* | cydra-* \
- | d10v-* | d30v-* | dlx-* \
- | e2k-* | elxsi-* \
- | f30[01]-* | f700-* | fido-* | fr30-* | frv-* | fx80-* \
- | h8300-* | h8500-* \
- | hppa-* | hppa1.[01]-* | hppa2.0-* | hppa2.0[nw]-* | hppa64-* \
- | hexagon-* \
- | i*86-* | i860-* | i960-* | ia16-* | ia64-* \
- | ip2k-* | iq2000-* \
- | k1om-* \
- | le32-* | le64-* \
- | lm32-* \
- | m32c-* | m32r-* | m32rle-* \
- | m68000-* | m680[012346]0-* | m68360-* | m683?2-* | m68k-* \
- | m88110-* | m88k-* | maxq-* | mcore-* | metag-* \
- | microblaze-* | microblazeel-* \
- | mips-* | mipsbe-* | mipseb-* | mipsel-* | mipsle-* \
- | mips16-* \
- | mips64-* | mips64el-* \
- | mips64octeon-* | mips64octeonel-* \
- | mips64orion-* | mips64orionel-* \
- | mips64r5900-* | mips64r5900el-* \
- | mips64vr-* | mips64vrel-* \
- | mips64vr4100-* | mips64vr4100el-* \
- | mips64vr4300-* | mips64vr4300el-* \
- | mips64vr5000-* | mips64vr5000el-* \
- | mips64vr5900-* | mips64vr5900el-* \
- | mipsisa32-* | mipsisa32el-* \
- | mipsisa32r2-* | mipsisa32r2el-* \
- | mipsisa32r6-* | mipsisa32r6el-* \
- | mipsisa64-* | mipsisa64el-* \
- | mipsisa64r2-* | mipsisa64r2el-* \
- | mipsisa64r6-* | mipsisa64r6el-* \
- | mipsisa64sb1-* | mipsisa64sb1el-* \
- | mipsisa64sr71k-* | mipsisa64sr71kel-* \
- | mipsr5900-* | mipsr5900el-* \
- | mipstx39-* | mipstx39el-* \
- | mmix-* \
- | mt-* \
- | msp430-* \
- | nds32-* | nds32le-* | nds32be-* \
- | nfp-* \
- | nios-* | nios2-* | nios2eb-* | nios2el-* \
- | none-* | np1-* | ns16k-* | ns32k-* \
- | open8-* \
- | or1k*-* \
- | orion-* \
- | pdp10-* | pdp11-* | pj-* | pjl-* | pn-* | power-* \
- | powerpc-* | powerpc64-* | powerpc64le-* | powerpcle-* \
- | pru-* \
- | pyramid-* \
- | riscv32-* | riscv64-* \
- | rl78-* | romp-* | rs6000-* | rx-* \
- | sh-* | sh[1234]-* | sh[24]a-* | sh[24]aeb-* | sh[23]e-* | sh[34]eb-* | sheb-* | shbe-* \
- | shle-* | sh[1234]le-* | sh3ele-* | sh64-* | sh64le-* \
- | sparc-* | sparc64-* | sparc64b-* | sparc64v-* | sparc86x-* | sparclet-* \
- | sparclite-* \
- | sparcv8-* | sparcv9-* | sparcv9b-* | sparcv9v-* | sv1-* | sx*-* \
- | tahoe-* \
- | tic30-* | tic4x-* | tic54x-* | tic55x-* | tic6x-* | tic80-* \
- | tile*-* \
- | tron-* \
- | ubicom32-* \
- | v850-* | v850e-* | v850e1-* | v850es-* | v850e2-* | v850e2v3-* \
- | vax-* \
- | visium-* \
- | wasm32-* \
- | we32k-* \
- | x86-* | x86_64-* | xc16x-* | xps100-* \
- | xstormy16-* | xtensa*-* \
- | ymp-* \
- | z8k-* | z80-*)
- # Recognize the basic CPU types without company name, with glob match.
- xtensa*)
# Recognize the various machine names and aliases which stand
# for a CPU type and a company and sometimes even an OS.
- 386bsd)
- basic_machine=i386-pc
- os=-bsd
3b1 | 7300 | 7300-att | att-7300 | pc7300 | safari | unixpc)
- basic_machine=m68000-att
+ cpu=m68000
+ vendor=att
3b*)
- basic_machine=we32k-att
+ cpu=we32k
+ vendor=att
- a29khif)
- basic_machine=a29k-amd
- os=-udi
- abacus)
- basic_machine=abacus-unknown
- adobe68k)
- basic_machine=m68010-adobe
- os=-scout
- alliant | fx80)
- basic_machine=fx80-alliant
- altos | altos3068)
- basic_machine=m68k-altos
- am29k)
- basic_machine=a29k-none
- os=-bsd
- amd64)
- basic_machine=x86_64-pc
- amd64-*)
- basic_machine=x86_64-`echo "$basic_machine" | sed 's/^[^-]*-//'`
- amdahl)
- basic_machine=580-amdahl
- os=-sysv
- amiga | amiga-*)
- basic_machine=m68k-unknown
- amigaos | amigados)
- os=-amigaos
- amigaunix | amix)
- os=-sysv4
- apollo68)
- basic_machine=m68k-apollo
- os=-sysv
- apollo68bsd)
- os=-bsd
- aros)
- os=-aros
- asmjs)
- basic_machine=asmjs-unknown
- aux)
- basic_machine=m68k-apple
- os=-aux
- balance)
- basic_machine=ns32k-sequent
- os=-dynix
- blackfin)
- basic_machine=bfin-unknown
- os=-linux
- blackfin-*)
- basic_machine=bfin-`echo "$basic_machine" | sed 's/^[^-]*-//'`
- os=-linux
bluegene*)
- basic_machine=powerpc-ibm
- os=-cnk
+ cpu=powerpc
+ vendor=ibm
+ os=cnk
- c54x-*)
- basic_machine=tic54x-`echo "$basic_machine" | sed 's/^[^-]*-//'`
- c55x-*)
- basic_machine=tic55x-`echo "$basic_machine" | sed 's/^[^-]*-//'`
- c6x-*)
- basic_machine=tic6x-`echo "$basic_machine" | sed 's/^[^-]*-//'`
- c90)
- basic_machine=c90-cray
- os=-unicos
- cegcc)
- os=-cegcc
- convex-c1)
- basic_machine=c1-convex
- os=-bsd
- convex-c2)
- basic_machine=c2-convex
- os=-bsd
- convex-c32)
- basic_machine=c32-convex
- os=-bsd
- convex-c34)
- basic_machine=c34-convex
- os=-bsd
- convex-c38)
- basic_machine=c38-convex
- os=-bsd
- cray | j90)
- basic_machine=j90-cray
- os=-unicos
- craynv)
- basic_machine=craynv-cray
- os=-unicosmp
- cr16 | cr16-*)
- basic_machine=cr16-unknown
- os=-elf
- crds | unos)
- basic_machine=m68k-crds
- crisv32 | crisv32-* | etraxfs*)
- basic_machine=crisv32-axis
- cris | cris-* | etrax*)
- basic_machine=cris-axis
- crx)
- basic_machine=crx-unknown
- os=-elf
- da30 | da30-*)
- basic_machine=m68k-da30
- decstation | decstation-3100 | pmax | pmax-* | pmin | dec3100 | decstatn)
- basic_machine=mips-dec
decsystem10* | dec10*)
- basic_machine=pdp10-dec
- os=-tops10
+ cpu=pdp10
+ vendor=dec
+ os=tops10
decsystem20* | dec20*)
- os=-tops20
+ cpu=pdp10
+ vendor=dec
+ os=tops20
delta | 3300 | motorola-3300 | motorola-delta \
| 3300-motorola | delta-motorola)
- basic_machine=m68k-motorola
+ cpu=m68k
+ vendor=motorola
- delta88)
- basic_machine=m88k-motorola
- os=-sysv3
- dicos)
- basic_machine=i686-pc
- os=-dicos
- djgpp)
- basic_machine=i586-pc
- os=-msdosdjgpp
- dpx20 | dpx20-*)
- basic_machine=rs6000-bull
- os=-bosx
dpx2*)
- basic_machine=m68k-bull
- os=-sysv3
+ cpu=m68k
+ vendor=bull
+ os=sysv3
- e500v[12])
- basic_machine=powerpc-unknown
- os=$os"spe"
+ encore | umax | mmax)
+ cpu=ns32k
+ vendor=encore
- e500v[12]-*)
- basic_machine=powerpc-`echo "$basic_machine" | sed 's/^[^-]*-//'`
- os=$os"spe"
- ebmon29k)
- os=-ebmon
elxsi)
- basic_machine=elxsi-elxsi
- os=-bsd
+ cpu=elxsi
+ vendor=elxsi
+ os=${os:-bsd}
- encore | umax | mmax)
- basic_machine=ns32k-encore
- es1800 | OSE68k | ose68k | ose | OSE)
- basic_machine=m68k-ericsson
- os=-ose
fx2800)
- basic_machine=i860-alliant
+ cpu=i860
+ vendor=alliant
genix)
- basic_machine=ns32k-ns
+ cpu=ns32k
+ vendor=ns
- gmicro)
- basic_machine=tron-gmicro
- os=-sysv
- go32)
- os=-go32
h3050r* | hiux*)
- basic_machine=hppa1.1-hitachi
- os=-hiuxwe2
+ cpu=hppa1.1
+ vendor=hitachi
+ os=hiuxwe2
- h8300hms)
- basic_machine=h8300-hitachi
- os=-hms
- h8300xray)
- os=-xray
- h8500hms)
- basic_machine=h8500-hitachi
- os=-hms
- harris)
- basic_machine=m88k-harris
- os=-sysv3
- hp300-*)
- basic_machine=m68k-hp
- hp300bsd)
- os=-bsd
- hp300hpux)
- os=-hpux
hp3k9[0-9][0-9] | hp9[0-9][0-9])
- basic_machine=hppa1.0-hp
+ cpu=hppa1.0
+ vendor=hp
hp9k2[0-9][0-9] | hp9k31[0-9])
- basic_machine=m68000-hp
+ cpu=m68000
+ vendor=hp
hp9k3[2-9][0-9])
+ cpu=m68k
+ vendor=hp
hp9k6[0-9][0-9] | hp6[0-9][0-9])
+ cpu=hppa1.0
+ vendor=hp
hp9k7[0-79][0-9] | hp7[0-79][0-9])
- basic_machine=hppa1.1-hp
+ cpu=hppa1.1
+ vendor=hp
hp9k78[0-9] | hp78[0-9])
# FIXME: really hppa2.0-hp
+ cpu=hppa1.1
+ vendor=hp
hp9k8[67]1 | hp8[67]1 | hp9k80[24] | hp80[24] | hp9k8[78]9 | hp8[78]9 | hp9k893 | hp893)
+ cpu=hppa1.1
+ vendor=hp
hp9k8[0-9][13679] | hp8[0-9][13679])
+ cpu=hppa1.1
+ vendor=hp
hp9k8[0-9][0-9] | hp8[0-9][0-9])
+ cpu=hppa1.0
+ vendor=hp
- hppaosf)
- os=-osf
- hppro)
- os=-proelf
- i370-ibm* | ibm*)
- basic_machine=i370-ibm
i*86v32)
- basic_machine=`echo "$1" | sed -e 's/86.*/86-pc/'`
- os=-sysv32
+ cpu=`echo "$1" | sed -e 's/86.*/86/'`
+ vendor=pc
+ os=sysv32
i*86v4*)
- os=-sysv4
+ vendor=pc
+ os=sysv4
i*86v)
- os=-sysv
+ vendor=pc
+ os=sysv
i*86sol2)
- os=-solaris2
+ vendor=pc
+ os=solaris2
- i386mach)
- basic_machine=i386-mach
- os=-mach
+ j90 | j90-cray)
+ cpu=j90
+ vendor=cray
+ os=${os:-unicos}
- vsta)
- basic_machine=i386-unknown
- os=-vsta
iris | iris4d)
- basic_machine=mips-sgi
+ cpu=mips
+ vendor=sgi
case $os in
- -irix*)
+ irix*)
- os=-irix4
+ os=irix4
esac
- isi68 | isi)
- basic_machine=m68k-isi
- os=-sysv
- leon-*|leon[3-9]-*)
- basic_machine=sparc-`echo "$basic_machine" | sed 's/-.*//'`
- m68knommu)
- os=-linux
- m68knommu-*)
- basic_machine=m68k-`echo "$basic_machine" | sed 's/^[^-]*-//'`
- os=-linux
- magnum | m3230)
- basic_machine=mips-mips
- os=-sysv
- merlin)
- basic_machine=ns32k-utek
- os=-sysv
- microblaze*)
- basic_machine=microblaze-xilinx
- mingw64)
- os=-mingw64
- mingw32)
- os=-mingw32
- mingw32ce)
- os=-mingw32ce
miniframe)
- basic_machine=m68000-convergent
+ cpu=m68000
+ vendor=convergent
- *mint | -mint[0-9]* | *MiNT | *MiNT[0-9]*)
- os=-mint
+ *mint | mint[0-9]* | *MiNT | *MiNT[0-9]*)
+ cpu=m68k
+ vendor=atari
+ os=mint
- mips3*-*)
- basic_machine=`echo "$basic_machine" | sed -e 's/mips3/mips64/'`
- mips3*)
- basic_machine=`echo "$basic_machine" | sed -e 's/mips3/mips64/'`-unknown
- monitor)
- basic_machine=m68k-rom68k
- os=-coff
- morphos)
- os=-morphos
- moxiebox)
- basic_machine=moxie-unknown
- os=-moxiebox
- msdos)
- os=-msdos
- ms1-*)
- basic_machine=`echo "$basic_machine" | sed -e 's/ms1-/mt-/'`
- msys)
- os=-msys
- mvs)
- os=-mvs
- nacl)
- basic_machine=le32-unknown
- os=-nacl
- ncr3000)
- basic_machine=i486-ncr
- os=-sysv4
- netbsd386)
- os=-netbsd
- netwinder)
- basic_machine=armv4l-rebel
- os=-linux
- news | news700 | news800 | news900)
- basic_machine=m68k-sony
- os=-newsos
- news1000)
- basic_machine=m68030-sony
- os=-newsos
news-3600 | risc-news)
- basic_machine=mips-sony
- os=-newsos
+ cpu=mips
+ vendor=sony
+ os=newsos
- necv70)
- basic_machine=v70-nec
- os=-sysv
next | m*-next)
- basic_machine=m68k-next
+ cpu=m68k
+ vendor=next
case $os in
- -nextstep* )
+ nextstep* )
- -ns2*)
- os=-nextstep2
+ ns2*)
+ os=nextstep2
- os=-nextstep3
+ os=nextstep3
esac
- nh3000)
- basic_machine=m68k-harris
- os=-cxux
- nh[45]000)
- os=-cxux
- nindy960)
- basic_machine=i960-intel
- os=-nindy
- mon960)
- os=-mon960
- nonstopux)
- basic_machine=mips-compaq
- os=-nonstopux
np1)
- basic_machine=np1-gould
+ cpu=np1
+ vendor=gould
- neo-tandem)
- basic_machine=neo-tandem
- nse-tandem)
- basic_machine=nse-tandem
- nsr-tandem)
- basic_machine=nsr-tandem
- nsv-tandem)
- basic_machine=nsv-tandem
- nsx-tandem)
- basic_machine=nsx-tandem
op50n-* | op60c-*)
- basic_machine=hppa1.1-oki
- os=-proelf
+ cpu=hppa1.1
+ vendor=oki
+ os=proelf
- openrisc | openrisc-*)
- basic_machine=or32-unknown
- os400)
- os=-os400
- OSE68000 | ose68000)
- basic_machine=m68000-ericsson
- os=-ose
- os68k)
- basic_machine=m68k-none
- os=-os68k
pa-hitachi)
- os=-hiuxwe2
+ cpu=hppa1.1
+ vendor=hitachi
+ os=hiuxwe2
- paragon)
- basic_machine=i860-intel
- os=-osf
- parisc)
- basic_machine=hppa-unknown
- os=-linux
- parisc-*)
- basic_machine=hppa-`echo "$basic_machine" | sed 's/^[^-]*-//'`
- os=-linux
pbd)
- basic_machine=sparc-tti
+ cpu=sparc
+ vendor=tti
pbb)
- basic_machine=m68k-tti
+ cpu=m68k
+ vendor=tti
- pc532 | pc532-*)
- basic_machine=ns32k-pc532
+ pc532)
+ cpu=ns32k
+ vendor=pc532
- pc98)
- pc98-*)
- basic_machine=i386-`echo "$basic_machine" | sed 's/^[^-]*-//'`
- pentium | p5 | k5 | k6 | nexgen | viac3)
- pentiumpro | p6 | 6x86 | athlon | athlon_*)
- pentiumii | pentium2 | pentiumiii | pentium3)
- pentium4)
- basic_machine=i786-pc
- pentium-* | p5-* | k5-* | k6-* | nexgen-* | viac3-*)
- basic_machine=i586-`echo "$basic_machine" | sed 's/^[^-]*-//'`
- pentiumpro-* | p6-* | 6x86-* | athlon-*)
- basic_machine=i686-`echo "$basic_machine" | sed 's/^[^-]*-//'`
- pentiumii-* | pentium2-* | pentiumiii-* | pentium3-*)
- pentium4-*)
- basic_machine=i786-`echo "$basic_machine" | sed 's/^[^-]*-//'`
pn)
- basic_machine=pn-gould
+ cpu=pn
+ vendor=gould
- power) basic_machine=power-ibm
+ power)
+ cpu=power
+ vendor=ibm
- ppc | ppcbe) basic_machine=powerpc-unknown
+ ps2)
+ cpu=i386
+ vendor=ibm
- ppc-* | ppcbe-*)
+ rm[46]00)
+ cpu=mips
+ vendor=siemens
- ppcle | powerpclittle)
- basic_machine=powerpcle-unknown
+ rtpc | rtpc-*)
+ cpu=romp
+ vendor=ibm
- ppcle-* | powerpclittle-*)
- basic_machine=powerpcle-`echo "$basic_machine" | sed 's/^[^-]*-//'`
+ sde)
+ cpu=mipsisa32
+ vendor=sde
+ os=${os:-elf}
- ppc64) basic_machine=powerpc64-unknown
+ simso-wrs)
+ cpu=sparclite
+ vendor=wrs
+ os=vxworks
- ppc64-*) basic_machine=powerpc64-`echo "$basic_machine" | sed 's/^[^-]*-//'`
+ tower | tower-32)
+ cpu=m68k
+ vendor=ncr
- ppc64le | powerpc64little)
- basic_machine=powerpc64le-unknown
+ vpp*|vx|vx-*)
+ cpu=f301
+ vendor=fujitsu
- ppc64le-* | powerpc64little-*)
- basic_machine=powerpc64le-`echo "$basic_machine" | sed 's/^[^-]*-//'`
+ w65)
+ cpu=w65
+ vendor=wdc
- ps2)
- basic_machine=i386-ibm
+ w89k-*)
+ cpu=hppa1.1
+ vendor=winbond
+ os=proelf
- pw32)
- basic_machine=i586-unknown
- os=-pw32
+ none)
+ cpu=none
+ vendor=none
- rdos | rdos64)
- os=-rdos
+ leon|leon[3-9])
+ cpu=sparc
+ vendor=$basic_machine
- rdos32)
- os=-rdos
+ leon-*|leon[3-9]-*)
+ cpu=sparc
+ vendor=`echo "$basic_machine" | sed 's/-.*//'`
- rom68k)
- os=-coff
+ IFS="-" read cpu vendor <<EOF
+$basic_machine
+EOF
- rm[46]00)
- basic_machine=mips-siemens
+ # We use `pc' rather than `unknown'
+ # because (1) that's what they normally are, and
+ # (2) the word "unknown" tends to confuse beginning users.
+ i*86 | x86_64)
+ cpu=$basic_machine
+ vendor=pc
- rtpc | rtpc-*)
- basic_machine=romp-ibm
+ # These rules are duplicated from below for sake of the special case above;
+ # i.e. things that normalized to x86 arches should also default to "pc"
+ pc98)
+ cpu=i386
+ vendor=pc
- s390 | s390-*)
- basic_machine=s390-ibm
+ x64 | amd64)
+ cpu=x86_64
+ vendor=pc
- s390x | s390x-*)
- basic_machine=s390x-ibm
+ # Recognize the basic CPU types without company name.
+ vendor=unknown
- sa29200)
- os=-udi
+esac
+unset -v basic_machine
+# Decode basic machines in the full and proper CPU-Company form.
+case $cpu-$vendor in
+ # Here we handle the default manufacturer of certain CPU types in canonical form. It is in
+ craynv-unknown)
+ vendor=cray
+ os=${os:-unicosmp}
- sb1)
- basic_machine=mipsisa64sb1-unknown
+ c90-unknown | c90-cray)
+ vendor=cray
+ os=${os:-unicos}
- sb1el)
- basic_machine=mipsisa64sb1el-unknown
+ fx80-unknown)
+ vendor=alliant
- sde)
- basic_machine=mipsisa32-sde
- os=-elf
+ romp-unknown)
+ vendor=ibm
- sei)
- basic_machine=mips-sei
- os=-seiux
+ mmix-unknown)
+ vendor=knuth
- sequent)
- basic_machine=i386-sequent
+ microblaze-unknown | microblazeel-unknown)
+ vendor=xilinx
- sh5el)
- basic_machine=sh5le-unknown
+ rs6000-unknown)
+ vendor=ibm
- simso-wrs)
- basic_machine=sparclite-wrs
- os=-vxworks
+ vax-unknown)
+ vendor=dec
- sps7)
- os=-sysv2
+ pdp11-unknown)
+ vendor=dec
- spur)
- basic_machine=spur-unknown
+ we32k-unknown)
+ vendor=att
- st2000)
- basic_machine=m68k-tandem
+ cydra-unknown)
+ vendor=cydrome
- stratus)
- basic_machine=i860-stratus
- os=-sysv4
+ i370-ibm*)
+ vendor=ibm
- strongarm-* | thumb-*)
- basic_machine=arm-`echo "$basic_machine" | sed 's/^[^-]*-//'`
+ orion-unknown)
+ vendor=highlevel
- sun2)
- basic_machine=m68000-sun
+ xps-unknown | xps100-unknown)
+ cpu=xps100
+ vendor=honeywell
- sun2os3)
- os=-sunos3
+ # Here we normalize CPU types with a missing or matching vendor
+ dpx20-unknown | dpx20-bull)
+ cpu=rs6000
+ vendor=bull
+ os=${os:-bosx}
- sun2os4)
- os=-sunos4
+ # Here we normalize CPU types irrespective of the vendor
+ amd64-*)
+ cpu=x86_64
- sun3os3)
- basic_machine=m68k-sun
- os=-sunos3
+ blackfin-*)
+ cpu=bfin
+ os=linux
- sun3os4)
- os=-sunos4
+ c54x-*)
+ cpu=tic54x
- sun4os3)
- basic_machine=sparc-sun
- os=-sunos3
+ c55x-*)
+ cpu=tic55x
- sun4os4)
- os=-sunos4
+ c6x-*)
+ cpu=tic6x
- sun4sol2)
- os=-solaris2
+ e500v[12]-*)
+ cpu=powerpc
+ os=$os"spe"
- sun3 | sun3-*)
+ mips3*-*)
+ cpu=mips64
- sun4)
+ ms1-*)
+ cpu=mt
- sun386 | sun386i | roadrunner)
- basic_machine=i386-sun
+ m68knommu-*)
+ cpu=m68k
+ os=linux
- sv1)
- basic_machine=sv1-cray
- os=-unicos
+ m9s12z-* | m68hcs12z-* | hcs12z-* | s12z-*)
+ cpu=s12z
- symmetry)
- os=-dynix
+ openrisc-*)
+ cpu=or32
- t3e)
- basic_machine=alphaev5-cray
- os=-unicos
+ parisc-*)
+ cpu=hppa
+ os=linux
- t90)
- basic_machine=t90-cray
- os=-unicos
+ pentium-* | p5-* | k5-* | k6-* | nexgen-* | viac3-*)
+ cpu=i586
- tile*)
- os=-linux-gnu
+ pentiumpro-* | p6-* | 6x86-* | athlon-* | athalon_*-*)
+ cpu=i686
- tx39)
- basic_machine=mipstx39-unknown
+ pentiumii-* | pentium2-* | pentiumiii-* | pentium3-*)
+ cpu=i686
- tx39el)
- basic_machine=mipstx39el-unknown
+ pentium4-*)
+ cpu=i786
- toad1)
- basic_machine=pdp10-xkl
- os=-tops20
+ pc98-*)
+ cpu=i386
- tower | tower-32)
- basic_machine=m68k-ncr
+ ppc-* | ppcbe-*)
+ cpu=powerpc
- tpf)
- os=-tpf
+ ppcle-* | powerpclittle-*)
+ cpu=powerpcle
- udi29k)
- os=-udi
+ ppc64-*)
+ cpu=powerpc64
- ultra3)
- basic_machine=a29k-nyu
- os=-sym1
+ ppc64le-* | powerpc64little-*)
+ cpu=powerpc64le
- v810 | necv810)
- basic_machine=v810-nec
- os=-none
+ sb1-*)
+ cpu=mipsisa64sb1
- vaxv)
- basic_machine=vax-dec
- os=-sysv
+ sb1el-*)
+ cpu=mipsisa64sb1el
- vms)
- os=-vms
+ sh5e[lb]-*)
+ cpu=`echo "$cpu" | sed 's/^\(sh.\)e\(.\)$/\1\2e/'`
- vpp*|vx|vx-*)
- basic_machine=f301-fujitsu
+ spur-*)
+ cpu=spur
- vxworks960)
- basic_machine=i960-wrs
- os=-vxworks
+ strongarm-* | thumb-*)
+ cpu=arm
- vxworks68)
- basic_machine=m68k-wrs
- os=-vxworks
+ tx39-*)
+ cpu=mipstx39
- vxworks29k)
- basic_machine=a29k-wrs
- os=-vxworks
+ tx39el-*)
+ cpu=mipstx39el
- w65*)
- basic_machine=w65-wdc
- os=-none
+ x64-*)
+ cpu=x86_64
- w89k-*)
- basic_machine=hppa1.1-winbond
- os=-proelf
- x64)
- xbox)
- os=-mingw32
- xps | xps100)
- basic_machine=xps100-honeywell
xscale-* | xscalee[bl]-*)
- basic_machine=`echo "$basic_machine" | sed 's/^xscale/arm/'`
+ cpu=`echo "$cpu" | sed 's/^xscale/arm/'`
- ymp)
- basic_machine=ymp-cray
- os=-unicos
- none)
- basic_machine=none-none
- os=-none
-# Here we handle the default manufacturer of certain CPU types. It is in
-# some cases the only manufacturer, in others, it is the most popular.
- w89k)
+ # Recognize the canonical CPU Types that limit and/or modify the
+ # company names they are paired with.
+ cr16-*)
+ os=${os:-elf}
- op50n)
+ crisv32-* | etraxfs*-*)
+ cpu=crisv32
+ vendor=axis
- op60c)
+ cris-* | etrax*-*)
+ cpu=cris
+ vendor=axis
- romp)
+ crx-*)
+ os=${os:-elf}
- mmix)
- basic_machine=mmix-knuth
+ neo-tandem)
+ cpu=neo
+ vendor=tandem
- rs6000)
- basic_machine=rs6000-ibm
+ nse-tandem)
+ cpu=nse
+ vendor=tandem
- vax)
+ nsr-tandem)
+ cpu=nsr
+ vendor=tandem
- pdp11)
- basic_machine=pdp11-dec
+ nsv-tandem)
+ cpu=nsv
+ vendor=tandem
- we32k)
+ nsx-tandem)
+ cpu=nsx
+ vendor=tandem
- sh[1234] | sh[24]a | sh[24]aeb | sh[34]eb | sh[1234]le | sh[23]ele)
- basic_machine=sh-unknown
+ s390-*)
+ cpu=s390
+ vendor=ibm
- cydra)
- basic_machine=cydra-cydrome
+ s390x-*)
+ cpu=s390x
+ vendor=ibm
- orion)
- basic_machine=orion-highlevel
+ tile*-*)
+ os=${os:-linux-gnu}
- orion105)
- basic_machine=clipper-highlevel
- mac | mpw | mac-mpw)
- pmac | pmac-mpw)
- basic_machine=powerpc-apple
- *-unknown)
- # Make sure to match an already-canonicalized machine name.
- exit 1
+ # Recognize the canonical CPU types that are allowed with any
+ # company name.
+ case $cpu in
+ 1750a | 580 \
+ | a29k \
+ | aarch64 | aarch64_be \
+ | abacus \
+ | alpha | alphaev[4-8] | alphaev56 | alphaev6[78] \
+ | alpha64 | alpha64ev[4-8] | alpha64ev56 | alpha64ev6[78] \
+ | alphapca5[67] | alpha64pca5[67] \
+ | am33_2.0 \
+ | amdgcn \
+ | arc | arceb \
+ | arm | arm[lb]e | arme[lb] | armv* \
+ | avr | avr32 \
+ | asmjs \
+ | ba \
+ | be32 | be64 \
+ | bfin | bs2000 \
+ | c[123]* | c30 | [cjt]90 | c4x \
+ | c8051 | clipper | craynv | csky | cydra \
+ | d10v | d30v | dlx | dsp16xx \
+ | e2k | elxsi | epiphany \
+ | f30[01] | f700 | fido | fr30 | frv | ft32 | fx80 \
+ | h8300 | h8500 \
+ | hppa | hppa1.[01] | hppa2.0 | hppa2.0[nw] | hppa64 \
+ | hexagon \
+ | i370 | i*86 | i860 | i960 | ia16 | ia64 \
+ | ip2k | iq2000 \
+ | k1om \
+ | le32 | le64 \
+ | lm32 \
+ | m32c | m32r | m32rle \
+ | m5200 | m68000 | m680[012346]0 | m68360 | m683?2 | m68k | v70 | w65 \
+ | m6811 | m68hc11 | m6812 | m68hc12 | m68hcs12x | nvptx | picochip \
+ | m88110 | m88k | maxq | mb | mcore | mep | metag \
+ | microblaze | microblazeel \
+ | mips | mipsbe | mipseb | mipsel | mipsle \
+ | mips16 \
+ | mips64 | mips64el \
+ | mips64octeon | mips64octeonel \
+ | mips64orion | mips64orionel \
+ | mips64r5900 | mips64r5900el \
+ | mips64vr | mips64vrel \
+ | mips64vr4100 | mips64vr4100el \
+ | mips64vr4300 | mips64vr4300el \
+ | mips64vr5000 | mips64vr5000el \
+ | mips64vr5900 | mips64vr5900el \
+ | mipsisa32 | mipsisa32el \
+ | mipsisa32r2 | mipsisa32r2el \
+ | mipsisa32r6 | mipsisa32r6el \
+ | mipsisa64 | mipsisa64el \
+ | mipsisa64r2 | mipsisa64r2el \
+ | mipsisa64r6 | mipsisa64r6el \
+ | mipsisa64sb1 | mipsisa64sb1el \
+ | mipsisa64sr71k | mipsisa64sr71kel \
+ | mipsr5900 | mipsr5900el \
+ | mipstx39 | mipstx39el \
+ | mmix \
+ | mn10200 | mn10300 \
+ | moxie \
+ | mt \
+ | msp430 \
+ | nds32 | nds32le | nds32be \
+ | nfp \
+ | nios | nios2 | nios2eb | nios2el \
+ | none | np1 | ns16k | ns32k \
+ | open8 \
+ | or1k* \
+ | or32 \
+ | orion \
+ | pdp10 | pdp11 | pj | pjl | pn | power \
+ | powerpc | powerpc64 | powerpc64le | powerpcle | powerpcspe \
+ | pru \
+ | pyramid \
+ | riscv | riscv32 | riscv64 \
+ | rl78 | romp | rs6000 | rx \
+ | score \
+ | sh | sh[1234] | sh[24]a | sh[24]ae[lb] | sh[23]e | she[lb] | sh[lb]e \
+ | sh[1234]e[lb] | sh[12345][lb]e | sh[23]ele | sh64 | sh64le \
+ | sparc | sparc64 | sparc64b | sparc64v | sparc86x | sparclet \
+ | sparclite \
+ | sparcv8 | sparcv9 | sparcv9b | sparcv9v | sv1 | sx* \
+ | spu \
+ | tahoe \
+ | tic30 | tic4x | tic54x | tic55x | tic6x | tic80 \
+ | tron \
+ | ubicom32 \
+ | v850 | v850e | v850e1 | v850es | v850e2 | v850e2v3 \
+ | vax \
+ | visium \
+ | wasm32 \
+ | we32k \
+ | x86 | x86_64 | xc16x | xgate | xps100 \
+ | xstormy16 | xtensa* \
+ | ymp \
+ | z8k | z80)
+ echo Invalid configuration \`"$1"\': machine \`"$cpu-$vendor"\' not recognized 1>&2
+ exit 1
+ esac
esac
# Here we canonicalize certain aliases for manufacturers.
-case $basic_machine in
- *-digital*)
- basic_machine=`echo "$basic_machine" | sed 's/digital.*/dec/'`
+case $vendor in
+ digital*)
+ vendor=dec
- *-commodore*)
- basic_machine=`echo "$basic_machine" | sed 's/commodore.*/cbm/'`
+ commodore*)
+ vendor=cbm
@@ -1345,199 +1271,245 @@
# Decode manufacturer-specific aliases for certain operating systems.
-if [ x"$os" != x"" ]
+if [ x$os != x ]
then
case $os in
# First match some system type aliases that might get confused
# with valid system types.
- # -solaris* is a basic system type, with this one exception.
- -auroraux)
- os=-auroraux
+ # solaris* is a basic system type, with this one exception.
+ auroraux)
+ os=auroraux
- -solaris1 | -solaris1.*)
+ bluegene*)
+ os=cnk
+ solaris1 | solaris1.*)
os=`echo $os | sed -e 's|solaris1|sunos4|'`
- -solaris)
- os=-solaris2
+ solaris)
+ os=solaris2
- -unixware*)
- os=-sysv4.2uw
+ unixware*)
+ os=sysv4.2uw
- -gnu/linux*)
+ gnu/linux*)
os=`echo $os | sed -e 's|gnu/linux|linux-gnu|'`
# es1800 is here to avoid being matched by es* (a different OS)
- -es1800*)
- os=-ose
+ es1800*)
+ os=ose
+ # Some version numbers need modification
+ chorusos*)
+ os=chorusos
+ isc)
+ os=isc2.2
+ sco6)
+ os=sco5v6
+ sco5)
+ os=sco3.2v5
+ sco4)
+ os=sco3.2v4
+ sco3.2.[4-9]*)
+ os=`echo $os | sed -e 's/sco3.2./sco3.2v/'`
+ sco3.2v[4-9]* | sco5v6*)
+ # Don't forget version if it is 3.2v4 or newer.
+ scout)
+ # Don't match below
+ sco*)
+ os=sco3.2v2
+ psos*)
+ os=psos
# Now accept the basic system types.
# The portable systems comes first.
# Each alternative MUST end in a * to match a version number.
- # -sysv* is not here because it comes later, after sysvr4.
- -gnu* | -bsd* | -mach* | -minix* | -genix* | -ultrix* | -irix* \
- | -*vms* | -sco* | -esix* | -isc* | -aix* | -cnk* | -sunos | -sunos[34]*\
- | -hpux* | -unos* | -osf* | -luna* | -dgux* | -auroraux* | -solaris* \
- | -sym* | -kopensolaris* | -plan9* \
- | -amigaos* | -amigados* | -msdos* | -newsos* | -unicos* | -aof* \
- | -aos* | -aros* | -cloudabi* | -sortix* \
- | -nindy* | -vxsim* | -vxworks* | -ebmon* | -hms* | -mvs* \
- | -clix* | -riscos* | -uniplus* | -iris* | -rtu* | -xenix* \
- | -hiux* | -knetbsd* | -mirbsd* | -netbsd* \
- | -bitrig* | -openbsd* | -solidbsd* | -libertybsd* \
- | -ekkobsd* | -kfreebsd* | -freebsd* | -riscix* | -lynxos* \
- | -bosx* | -nextstep* | -cxux* | -aout* | -elf* | -oabi* \
- | -ptx* | -coff* | -ecoff* | -winnt* | -domain* | -vsta* \
- | -udi* | -eabi* | -lites* | -ieee* | -go32* | -aux* | -hcos* \
- | -chorusos* | -chorusrdb* | -cegcc* | -glidix* \
- | -cygwin* | -msys* | -pe* | -psos* | -moss* | -proelf* | -rtems* \
- | -midipix* | -mingw32* | -mingw64* | -linux-gnu* | -linux-android* \
- | -linux-newlib* | -linux-musl* | -linux-uclibc* \
- | -uxpv* | -beos* | -mpeix* | -udk* | -moxiebox* \
- | -interix* | -uwin* | -mks* | -rhapsody* | -darwin* \
- | -openstep* | -oskit* | -conix* | -pw32* | -nonstopux* \
- | -storm-chaos* | -tops10* | -tenex* | -tops20* | -its* \
- | -os2* | -vos* | -palmos* | -uclinux* | -nucleus* \
- | -morphos* | -superux* | -rtmk* | -windiss* \
- | -powermax* | -dnix* | -nx6 | -nx7 | -sei* | -dragonfly* \
- | -skyos* | -haiku* | -rdos* | -toppers* | -drops* | -es* \
- | -onefs* | -tirtos* | -phoenix* | -fuchsia* | -redox* | -bme* \
- | -midnightbsd*)
+ # sysv* is not here because it comes later, after sysvr4.
+ gnu* | bsd* | mach* | minix* | genix* | ultrix* | irix* \
+ | *vms* | esix* | aix* | cnk* | sunos | sunos[34]*\
+ | hpux* | unos* | osf* | luna* | dgux* | auroraux* | solaris* \
+ | sym* | kopensolaris* | plan9* \
+ | amigaos* | amigados* | msdos* | newsos* | unicos* | aof* \
+ | aos* | aros* | cloudabi* | sortix* \
+ | nindy* | vxsim* | vxworks* | ebmon* | hms* | mvs* \
+ | clix* | riscos* | uniplus* | iris* | isc* | rtu* | xenix* \
+ | knetbsd* | mirbsd* | netbsd* \
+ | bitrig* | openbsd* | solidbsd* | libertybsd* \
+ | ekkobsd* | kfreebsd* | freebsd* | riscix* | lynxos* \
+ | bosx* | nextstep* | cxux* | aout* | elf* | oabi* \
+ | ptx* | coff* | ecoff* | winnt* | domain* | vsta* \
+ | udi* | eabi* | lites* | ieee* | go32* | aux* | hcos* \
+ | chorusrdb* | cegcc* | glidix* \
+ | cygwin* | msys* | pe* | moss* | proelf* | rtems* \
+ | midipix* | mingw32* | mingw64* | linux-gnu* | linux-android* \
+ | linux-newlib* | linux-musl* | linux-uclibc* \
+ | uxpv* | beos* | mpeix* | udk* | moxiebox* \
+ | interix* | uwin* | mks* | rhapsody* | darwin* \
+ | openstep* | oskit* | conix* | pw32* | nonstopux* \
+ | storm-chaos* | tops10* | tenex* | tops20* | its* \
+ | os2* | vos* | palmos* | uclinux* | nucleus* \
+ | morphos* | superux* | rtmk* | windiss* \
+ | powermax* | dnix* | nx6 | nx7 | sei* | dragonfly* \
+ | skyos* | haiku* | rdos* | toppers* | drops* | es* \
+ | onefs* | tirtos* | phoenix* | fuchsia* | redox* | bme* \
+ | midnightbsd* | amdhsa* | unleashed*)
# Remember, each alternative MUST END IN *, to match a version number.
- -qnx*)
- case $basic_machine in
- x86-* | i*86-*)
+ qnx*)
+ case $cpu in
+ x86 | i*86)
- os=-nto$os
+ os=nto-$os
esac
- -nto-qnx*)
+ hiux*)
+ os=hiuxwe2
- -nto*)
+ nto-qnx*)
+ nto*)
os=`echo $os | sed -e 's|nto|nto-qnx|'`
- -sim | -xray | -os68k* | -v88r* \
- | -windows* | -osx | -abug | -netware* | -os9* \
- | -macos* | -mpw* | -magic* | -mmixware* | -mon960* | -lnews*)
+ sim | xray | os68k* | v88r* \
+ | windows* | osx | abug | netware* | os9* \
+ | macos* | mpw* | magic* | mmixware* | mon960* | lnews*)
- -mac*)
+ linux-dietlibc)
+ os=linux-dietlibc
+ linux*)
+ os=`echo $os | sed -e 's|linux|linux-gnu|'`
+ lynx*178)
+ os=lynxos178
+ lynx*5)
+ os=lynxos5
+ lynx*)
+ os=lynxos
+ mac*)
os=`echo "$os" | sed -e 's|mac|macos|'`
- -linux-dietlibc)
- os=-linux-dietlibc
+ opened*)
+ os=openedition
- -linux*)
- os=`echo $os | sed -e 's|linux|linux-gnu|'`
+ os400*)
+ os=os400
- -sunos5*)
+ sunos5*)
os=`echo "$os" | sed -e 's|sunos5|solaris2|'`
- -sunos6*)
+ sunos6*)
os=`echo "$os" | sed -e 's|sunos6|solaris3|'`
- -opened*)
- os=-openedition
+ wince*)
+ os=wince
- -os400*)
- os=-os400
+ utek*)
+ os=bsd
- -wince*)
- os=-wince
+ dynix*)
+ os=bsd
- -utek*)
- os=-bsd
+ acis*)
+ os=aos
- -dynix*)
- os=-bsd
+ atheos*)
+ os=atheos
- -acis*)
- os=-aos
+ syllable*)
+ os=syllable
- -atheos*)
- os=-atheos
+ 386bsd)
+ os=bsd
- -syllable*)
- os=-syllable
+ ctix* | uts*)
+ os=sysv
- -386bsd)
- os=-bsd
+ nova*)
+ os=rtmk-nova
- -ctix* | -uts*)
- os=-sysv
+ ns2)
+ os=nextstep2
- -nova*)
- os=-rtmk-nova
+ nsk*)
+ os=nsk
- -ns2)
- os=-nextstep2
- -nsk*)
- os=-nsk
# Preserve the version number of sinix5.
- -sinix5.*)
+ sinix5.*)
os=`echo $os | sed -e 's|sinix|sysv|'`
- -sinix*)
- os=-sysv4
+ sinix*)
+ os=sysv4
- -tpf*)
- os=-tpf
+ tpf*)
+ os=tpf
- -triton*)
- os=-sysv3
+ triton*)
+ os=sysv3
- -oss*)
- os=-sysv3
+ oss*)
+ os=sysv3
- -svr4*)
- os=-sysv4
+ svr4*)
+ os=sysv4
- -svr3)
- os=-sysv3
+ svr3)
+ os=sysv3
- -sysvr4)
- os=-sysv4
+ sysvr4)
+ os=sysv4
- # This must come after -sysvr4.
- -sysv*)
+ # This must come after sysvr4.
+ sysv*)
- -ose*)
- os=-ose
+ ose*)
+ os=ose
- -*mint | -mint[0-9]* | -*MiNT | -MiNT[0-9]*)
- os=-mint
+ *mint | mint[0-9]* | *MiNT | MiNT[0-9]*)
+ os=mint
- -zvmoe)
- os=-zvmoe
+ zvmoe)
+ os=zvmoe
- -dicos*)
- os=-dicos
+ dicos*)
+ os=dicos
- -pikeos*)
+ pikeos*)
# Until real need of OS specific support for
# particular features comes up, bare metal
# configurations are quite functional.
+ case $cpu in
arm*)
- os=-eabi
+ os=eabi
- os=-elf
+ os=elf
esac
- -nacl*)
+ nacl*)
- -ios)
+ ios)
- -none)
+ none)
+ *-eabi)
- # Get rid of the `-' at the beginning of $os.
- os=`echo $os | sed 's/[^-]*-//'`
echo Invalid configuration \`"$1"\': system \`"$os"\' not recognized 1>&2
exit 1
@@ -1554,175 +1526,181 @@
# will signal an error saying that MANUFACTURER isn't an operating
# system, and we'll never get to this point.
score-*)
- os=-elf
+ os=elf
spu-*)
- os=-elf
+ os=elf
*-acorn)
- os=-riscix1.2
+ os=riscix1.2
arm*-rebel)
- os=-linux
+ os=linux
arm*-semi)
- os=-aout
+ os=aout
c4x-* | tic4x-*)
- os=-coff
+ os=coff
c8051-*)
- os=-elf
+ os=elf
+ clipper-intergraph)
+ os=clix
hexagon-*)
- os=-elf
+ os=elf
tic54x-*)
- os=-coff
+ os=coff
tic55x-*)
- os=-coff
+ os=coff
tic6x-*)
- os=-coff
+ os=coff
# This must come before the *-dec entry.
pdp10-*)
- os=-tops20
+ os=tops20
pdp11-*)
- os=-none
+ os=none
*-dec | vax-*)
- os=-ultrix4.2
+ os=ultrix4.2
m68*-apollo)
- os=-domain
+ os=domain
i386-sun)
- os=-sunos4.0.2
+ os=sunos4.0.2
m68000-sun)
- os=-sunos3
+ os=sunos3
m68*-cisco)
- os=-aout
+ os=aout
mep-*)
- os=-elf
+ os=elf
mips*-cisco)
- os=-elf
+ os=elf
mips*-*)
- os=-elf
+ os=elf
or32-*)
- os=-coff
+ os=coff
*-tti) # must be before sparc entry or we get the wrong os.
- os=-sysv3
+ os=sysv3
sparc-* | *-sun)
- os=-sunos4.1.1
+ os=sunos4.1.1
pru-*)
- os=-elf
+ os=elf
*-be)
- os=-beos
+ os=beos
*-ibm)
- os=-aix
+ os=aix
*-knuth)
- os=-mmixware
+ os=mmixware
*-wec)
- os=-proelf
+ os=proelf
*-winbond)
- os=-proelf
+ os=proelf
*-oki)
- os=-proelf
+ os=proelf
*-hp)
- os=-hpux
+ os=hpux
*-hitachi)
- os=-hiux
+ os=hiux
i860-* | *-att | *-ncr | *-altos | *-motorola | *-convergent)
- os=-sysv
+ os=sysv
*-cbm)
- os=-amigaos
+ os=amigaos
*-dg)
- os=-dgux
+ os=dgux
*-dolphin)
- os=-sysv3
+ os=sysv3
m68k-ccur)
- os=-rtu
+ os=rtu
m88k-omron*)
- os=-luna
+ os=luna
*-next)
- os=-nextstep
+ os=nextstep
*-sequent)
- os=-ptx
+ os=ptx
*-crds)
- os=-unos
+ os=unos
*-ns)
- os=-genix
+ os=genix
i370-*)
- os=-mvs
+ os=mvs
*-gould)
- os=-sysv
+ os=sysv
*-highlevel)
- os=-bsd
+ os=bsd
*-encore)
- os=-bsd
+ os=bsd
*-sgi)
- os=-irix
+ os=irix
*-siemens)
- os=-sysv4
+ os=sysv4
*-masscomp)
- os=-rtu
+ os=rtu
f30[01]-fujitsu | f700-fujitsu)
- os=-uxpv
+ os=uxpv
*-rom68k)
- os=-coff
+ os=coff
*-*bug)
- os=-coff
+ os=coff
*-apple)
- os=-macos
+ os=macos
*-atari*)
- os=-mint
+ os=mint
+ *-wrs)
+ os=vxworks
- os=-none
+ os=none
esac
fi
@@ -1729,79 +1707,80 @@
# Here we handle the case where we know the os, and the CPU type, but not the
# manufacturer. We pick the logical manufacturer.
-vendor=unknown
- *-unknown)
+case $vendor in
+ unknown)
case $os in
- -riscix*)
+ riscix*)
vendor=acorn
- -sunos*)
+ sunos*)
vendor=sun
- -cnk*|-aix*)
+ cnk*|-aix*)
vendor=ibm
- -beos*)
+ beos*)
vendor=be
- -hpux*)
+ hpux*)
vendor=hp
- -mpeix*)
+ mpeix*)
vendor=hp
- -hiux*)
+ hiux*)
vendor=hitachi
- -unos*)
+ unos*)
vendor=crds
- -dgux*)
+ dgux*)
vendor=dg
- -luna*)
+ luna*)
vendor=omron
- -genix*)
+ genix*)
vendor=ns
- -mvs* | -opened*)
+ clix*)
+ vendor=intergraph
+ mvs* | opened*)
vendor=ibm
- -os400*)
+ os400*)
vendor=ibm
- -ptx*)
+ ptx*)
vendor=sequent
- -tpf*)
+ tpf*)
vendor=ibm
- -vxsim* | -vxworks* | -windiss*)
+ vxsim* | vxworks* | windiss*)
vendor=wrs
- -aux*)
+ aux*)
vendor=apple
- -hms*)
+ hms*)
vendor=hitachi
- -mpw* | -macos*)
+ mpw* | macos*)
vendor=apple
vendor=atari
- -vos*)
+ vos*)
vendor=stratus
esac
- basic_machine=`echo "$basic_machine" | sed "s/unknown/$vendor/"`
esac
-echo "$basic_machine$os"
+echo "$cpu-$vendor-$os"
exit
# Local variables:
