[GRASS-SVN] r73853 - in grass/branches/releasebranch_7_6: display/d.legend display/d.vect doc/vector/v.example general/g.region general/g.rename/testsuite general/g.setproj imagery/i.atcorr imagery/i.evapo.pm imagery/i.his.rgb imagery/i.ortho.photo imagery/i.ortho.photo/lib imagery/i.segment imagery/i.smap include/iostream lib/gis lib/ogsf lib/raster lib/raster3d lib/rst/interp_float mswindows/external/rbatch raster/r.contour raster/r.cost raster/r.distance raster/r.fill.stats raster/r.gwflow raster/r.lake raster/r.li/r.li.daemon raster/r.out.gdal raster/r.proj raster/r.random raster/r.random.cells raster/r.ros raster/r.spread raster/r.stream.extract raster/r.sun raster/r.sunhours raster/r.sunmask raster/r.surf.area raster/r.surf.contour raster/r.terraflow raster/r.to.vect raster/r.viewshed raster/r.walk raster/r.watershed/ram raster/r.watershed/seg raster/r.watershed/shed raster3d/r3.gwflow raster3d/r3.retile raster3d/r3.showdspf raster3d/r3.stats raster3d/r3.to.rast tools vector/v.in. ogr vector/v.label.sa vector/v.profile
svn_grass at osgeo.org
Wed Dec 26 04:09:47 PST 2018
Author: neteler
Date: 2018-12-26 04:09:47 -0800 (Wed, 26 Dec 2018)
New Revision: 73853
grass/branches/releasebranch_7_6/display/d.legend/draw.c
grass/branches/releasebranch_7_6/display/d.vect/shape.c
grass/branches/releasebranch_7_6/doc/vector/v.example/main.c
grass/branches/releasebranch_7_6/general/g.region/printwindow.c
grass/branches/releasebranch_7_6/general/g.rename/testsuite/test_overwrite.py
grass/branches/releasebranch_7_6/general/g.setproj/get_deg.c
grass/branches/releasebranch_7_6/general/g.setproj/get_num.c
grass/branches/releasebranch_7_6/general/g.setproj/main.c
grass/branches/releasebranch_7_6/imagery/i.atcorr/computations.cpp
grass/branches/releasebranch_7_6/imagery/i.atcorr/main.cpp
grass/branches/releasebranch_7_6/imagery/i.evapo.pm/functions.c
grass/branches/releasebranch_7_6/imagery/i.his.rgb/his2rgb.c
grass/branches/releasebranch_7_6/imagery/i.ortho.photo/README
grass/branches/releasebranch_7_6/imagery/i.ortho.photo/alg_photo_rectify.txt
grass/branches/releasebranch_7_6/imagery/i.ortho.photo/lib/orthoref.c
grass/branches/releasebranch_7_6/imagery/i.segment/flag.h
grass/branches/releasebranch_7_6/imagery/i.segment/mean_shift.c
grass/branches/releasebranch_7_6/imagery/i.segment/outline
grass/branches/releasebranch_7_6/imagery/i.smap/decimate.c
grass/branches/releasebranch_7_6/imagery/i.smap/reg_util.c
grass/branches/releasebranch_7_6/include/iostream/empq_impl.h
grass/branches/releasebranch_7_6/include/iostream/mm.h
grass/branches/releasebranch_7_6/lib/gis/adj_cellhd.c
grass/branches/releasebranch_7_6/lib/gis/lz4.c
grass/branches/releasebranch_7_6/lib/ogsf/gk2.c
grass/branches/releasebranch_7_6/lib/ogsf/gs.c
grass/branches/releasebranch_7_6/lib/ogsf/gsd_label.c
grass/branches/releasebranch_7_6/lib/ogsf/gsd_objs.c
grass/branches/releasebranch_7_6/lib/ogsf/gsd_prim.c
grass/branches/releasebranch_7_6/lib/ogsf/gsdrape.c
grass/branches/releasebranch_7_6/lib/ogsf/gsds.c
grass/branches/releasebranch_7_6/lib/ogsf/gvl2.c
grass/branches/releasebranch_7_6/lib/ogsf/gvl_calc.c
grass/branches/releasebranch_7_6/lib/ogsf/gvld.c
grass/branches/releasebranch_7_6/lib/raster/color_org.c
grass/branches/releasebranch_7_6/lib/raster/rasterlib.dox
grass/branches/releasebranch_7_6/lib/raster3d/raster3dlib.dox
grass/branches/releasebranch_7_6/lib/rst/interp_float/segmen2d_parallel.c
grass/branches/releasebranch_7_6/mswindows/external/rbatch/batchfiles.md
grass/branches/releasebranch_7_6/mswindows/external/rbatch/batchfiles.tex
grass/branches/releasebranch_7_6/raster/r.contour/README
grass/branches/releasebranch_7_6/raster/r.cost/flag.h
grass/branches/releasebranch_7_6/raster/r.cost/main.c
grass/branches/releasebranch_7_6/raster/r.distance/distance.c
grass/branches/releasebranch_7_6/raster/r.fill.stats/main.c
grass/branches/releasebranch_7_6/raster/r.gwflow/r.gwflow.html
grass/branches/releasebranch_7_6/raster/r.lake/main.c
grass/branches/releasebranch_7_6/raster/r.li/r.li.daemon/daemon.h
grass/branches/releasebranch_7_6/raster/r.out.gdal/main.c
grass/branches/releasebranch_7_6/raster/r.proj/main.c
grass/branches/releasebranch_7_6/raster/r.random.cells/flag.h
grass/branches/releasebranch_7_6/raster/r.random/local_proto.h
grass/branches/releasebranch_7_6/raster/r.ros/main.c
grass/branches/releasebranch_7_6/raster/r.ros/spot_dist.c
grass/branches/releasebranch_7_6/raster/r.spread/spot.c
grass/branches/releasebranch_7_6/raster/r.stream.extract/flag.h
grass/branches/releasebranch_7_6/raster/r.sun/main.c
grass/branches/releasebranch_7_6/raster/r.sun/rsunglobals.h
grass/branches/releasebranch_7_6/raster/r.sun/rsunlib.c
grass/branches/releasebranch_7_6/raster/r.sun/sunradstruct.h
grass/branches/releasebranch_7_6/raster/r.sunhours/solpos00.c
grass/branches/releasebranch_7_6/raster/r.sunmask/solpos00.c
grass/branches/releasebranch_7_6/raster/r.surf.area/main.c
grass/branches/releasebranch_7_6/raster/r.surf.contour/flag.h
grass/branches/releasebranch_7_6/raster/r.terraflow/main.cpp
grass/branches/releasebranch_7_6/raster/r.terraflow/water.cpp
grass/branches/releasebranch_7_6/raster/r.to.vect/lines.c
grass/branches/releasebranch_7_6/raster/r.viewshed/distribute.cpp
grass/branches/releasebranch_7_6/raster/r.viewshed/eventlist.h
grass/branches/releasebranch_7_6/raster/r.viewshed/grid.cpp
grass/branches/releasebranch_7_6/raster/r.viewshed/grid.h
grass/branches/releasebranch_7_6/raster/r.viewshed/rbbst.cpp
grass/branches/releasebranch_7_6/raster/r.walk/flag.h
grass/branches/releasebranch_7_6/raster/r.walk/main.c
grass/branches/releasebranch_7_6/raster/r.watershed/ram/do_cum.c
grass/branches/releasebranch_7_6/raster/r.watershed/ram/flag.h
grass/branches/releasebranch_7_6/raster/r.watershed/seg/do_cum.c
grass/branches/releasebranch_7_6/raster/r.watershed/seg/flag.h
grass/branches/releasebranch_7_6/raster/r.watershed/shed/print.c
grass/branches/releasebranch_7_6/raster3d/r3.gwflow/r3.gwflow.html
grass/branches/releasebranch_7_6/raster3d/r3.retile/test.r3.retile.sh
grass/branches/releasebranch_7_6/raster3d/r3.showdspf/get_color_ogl.c
grass/branches/releasebranch_7_6/raster3d/r3.showdspf/main_ogl.c
grass/branches/releasebranch_7_6/raster3d/r3.showdspf/new_init_graphics.c
grass/branches/releasebranch_7_6/raster3d/r3.stats/support.c
grass/branches/releasebranch_7_6/raster3d/r3.to.rast/main.c
grass/branches/releasebranch_7_6/tools/module_synopsis.sh
grass/branches/releasebranch_7_6/tools/pylintrc.txt
grass/branches/releasebranch_7_6/vector/v.in.ogr/main.c
grass/branches/releasebranch_7_6/vector/v.label.sa/main.c
grass/branches/releasebranch_7_6/vector/v.profile/main.c
bulk fixing of typos in comments (using tools/fix_typos.sh)
Modified: grass/branches/releasebranch_7_6/display/d.legend/draw.c
--- grass/branches/releasebranch_7_6/display/d.legend/draw.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/display/d.legend/draw.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -1,7 +1,7 @@
/* draw.c:
* Compute position of legend, title, labels and ticks
* Extracted from original d.legend/main.c for background purpose
- * Moving to seperate file: Adam Laza, GSoC 2016
+ * Moving to separate file: Adam Laza, GSoC 2016
* Copyright (C) 2014 by Hamish Bowman, and the GRASS Development Team*
* This program is free software under the GPL (>=v2)
@@ -895,7 +895,7 @@
/* Display sidebar histogram, if requested.
/ In case of horizontal legend, maximum of histogram - max_hist
- will efect the title position */
+ will affect the title position */
max_hist = 0;
if (histo->answer) {
render_range.min = (DCELL) (fp ? dmin : min_ind);
Modified: grass/branches/releasebranch_7_6/display/d.vect/shape.c
--- grass/branches/releasebranch_7_6/display/d.vect/shape.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/display/d.vect/shape.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -183,7 +183,7 @@
z_style = NULL;
else if (rgb_column) {
- /* this should not happend, zcolor and rgb_columns are mutually exclusive */
+ /* this should not happen, zcolor and rgb_columns are mutually exclusive */
z_style = NULL;
else {
Modified: grass/branches/releasebranch_7_6/doc/vector/v.example/main.c
--- grass/branches/releasebranch_7_6/doc/vector/v.example/main.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/doc/vector/v.example/main.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -6,7 +6,7 @@
* AUTHOR(S): GRASS Development Team, Radim Blazek, Maris Nartiss
* PURPOSE: copies vector data from source map to destination map
- * prints out all point coordinates and atributes
+ * prints out all point coordinates and attributes
* COPYRIGHT: (C) 2002-2009 by the GRASS Development Team
@@ -226,6 +226,6 @@
Vect_close(&Out);
db_close_database_shutdown_driver(driver);
- /* Don't forget to report to caller sucessfull end of data processing :) */
+ /* Don't forget to report to caller successful end of data processing :) */
exit(EXIT_SUCCESS);
Modified: grass/branches/releasebranch_7_6/general/g.region/printwindow.c
--- grass/branches/releasebranch_7_6/general/g.region/printwindow.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/general/g.region/printwindow.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -534,7 +534,7 @@
/* flag.bbox
- Calculate the largest bouding box in lat-lon coordinates
+ Calculate the largest bounding box in lat-lon coordinates
and print it to stdout
if (print_flag & PRINT_MBBOX) {
Modified: grass/branches/releasebranch_7_6/general/g.rename/testsuite/test_overwrite.py
--- grass/branches/releasebranch_7_6/general/g.rename/testsuite/test_overwrite.py 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/general/g.rename/testsuite/test_overwrite.py 2018-12-26 12:09:47 UTC (rev 73853)
@@ -76,7 +76,7 @@
self.fail(msg)
def test_overwrite_existing_raster(self):
- """Test that existing raster is overriden if desired"""
+ """Test that existing raster is overridden if desired"""
runivar_source = SimpleModule('r.univar', flags='g', map='rename_3')
self.runModule(runivar_source, expecting_stdout=True)
original_runivar_source = text_to_keyvalue(runivar_source.outputs.stdout,
Modified: grass/branches/releasebranch_7_6/general/g.setproj/get_deg.c
--- grass/branches/releasebranch_7_6/general/g.setproj/get_deg.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/general/g.setproj/get_deg.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -4,9 +4,9 @@
* Provide a means of collecting user lat/long
* data, in different formats; convert to
* decimal degrees
- * Input arguements : lat or long string and
+ * Input arguments : lat or long string and
* a 1 for latitude or 0 for longitude
- * Output arguements: decimal degrees in string
+ * Output arguments: decimal degrees in string
* Note: All functions are callable directly see
* g.get_stp g.get_fips g.stp_proj geo
Modified: grass/branches/releasebranch_7_6/general/g.setproj/get_num.c
--- grass/branches/releasebranch_7_6/general/g.setproj/get_num.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/general/g.setproj/get_num.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -50,7 +50,7 @@
char answer[200];
char buff[256];
- /* get LONCEN value arguements */
+ /* get LONCEN value arguments */
if (parm->def_exists == 1) {
if (lat == 1) {
G_format_northing(parm->deflt, buff, PROJECTION_LL);
Modified: grass/branches/releasebranch_7_6/general/g.setproj/main.c
--- grass/branches/releasebranch_7_6/general/g.setproj/main.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/general/g.setproj/main.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -23,8 +23,8 @@
* Provides a means of creating a new projection
* information file
- * ------Rev 4.+ arguements --------------------------------------
- * Input arguements:
+ * ------Rev 4.+ arguments --------------------------------------
+ * Input arguments:
* m.setproj set=mapset for output project info file
* proj=projection of the output project info file
Modified: grass/branches/releasebranch_7_6/imagery/i.atcorr/computations.cpp
--- grass/branches/releasebranch_7_6/imagery/i.atcorr/computations.cpp 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/imagery/i.atcorr/computations.cpp 2018-12-26 12:09:47 UTC (rev 73853)
@@ -163,7 +163,7 @@
Decompose the atmosphere in a finite number of layers. For each layer, DISCRE
provides the optical thickness, the proportion of molecules and aerosols assuming an exponential
- distribution for each constituants. Figure 1 illustrate the way molecules and aerosols are mixed in a
+ distribution for each constituents. Figure 1 illustrate the way molecules and aerosols are mixed in a
realistic atmosphere. For molecules, the scale height is 8km. For aerosols it is assumed to be 2km
unless otherwise specified by the user (using aircraft measurements).
@@ -1395,7 +1395,7 @@
/* rayleigh+aerosol=romix,aerosol=roaero reflectance computed
- using sucessive order of scattering method
+ using successive order of scattering method
3 cases: satellite,plane,ground */
if (alt.palt > 0)
Modified: grass/branches/releasebranch_7_6/imagery/i.atcorr/main.cpp
--- grass/branches/releasebranch_7_6/imagery/i.atcorr/main.cpp 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/imagery/i.atcorr/main.cpp 2018-12-26 12:09:47 UTC (rev 73853)
@@ -85,8 +85,8 @@
/* flags */
struct Flag *oint; /* output data as integer */
struct Flag *irad; /* treat input values as reflectance instead of radiance values */
- struct Flag *etmafter; /* treat input data as a satelite image of type etm+ taken after July 1, 2000 */
- struct Flag *etmbefore; /* treat input data as a satelite image of type etm+ taken before July 1, 2000 */
+ struct Flag *etmafter; /* treat input data as a satellite image of type etm+ taken after July 1, 2000 */
+ struct Flag *etmbefore; /* treat input data as a satellite image of type etm+ taken before July 1, 2000 */
struct ScaleRange
@@ -116,7 +116,7 @@
Adjust the region to that of the input raster.
Atmospheric corrections should be done on the whole
- satelite image, not just portions.
+ satellite image, not just portions.
static void adjust_region(const char *name)
Modified: grass/branches/releasebranch_7_6/imagery/i.evapo.pm/functions.c
--- grass/branches/releasebranch_7_6/imagery/i.evapo.pm/functions.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/imagery/i.evapo.pm/functions.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -17,7 +17,7 @@
#define Tko 293.16 /* [K] reference temperature at sea level */
#define eta 0.0065 /* [K/m] constant lapse rate */
#define Ao 0 /* [m] altitude at sea level */
-#define g 9.81 /* [m/s] gravitational accelleration */
+#define g 9.81 /* [m/s] gravitational acceleration */
#define R 287 /* [J/kg*K] specific gas constant */
#define Zw 2 /* [m] height of wind measurements */
#define Zh 2 /* [m] height of humidity measurements */
Modified: grass/branches/releasebranch_7_6/imagery/i.his.rgb/his2rgb.c
--- grass/branches/releasebranch_7_6/imagery/i.his.rgb/his2rgb.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/imagery/i.his.rgb/his2rgb.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -2,7 +2,7 @@
-PURPOSE To proces hue,intensity,saturation bands to red,green,blue.
+PURPOSE To process hue,intensity,saturation bands to red,green,blue.
ALGORITHM:
Get hue, intensity, saturation from input buffer
Modified: grass/branches/releasebranch_7_6/imagery/i.ortho.photo/README
--- grass/branches/releasebranch_7_6/imagery/i.ortho.photo/README 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/imagery/i.ortho.photo/README 2018-12-26 12:09:47 UTC (rev 73853)
@@ -1,7 +1,7 @@
STATUS:
The i.ortho.photo suite of modules has been temporarily disabled
from GRASS 7 as they are heavily dependent on the text-based
- Vask libary and interactive XDRIVER monitors, both of which
+ Vask library and interactive XDRIVER monitors, both of which
have been removed. As the modules are rewritten to run in non-
interactive mode or with a wxPython frontend, they will be
added back into GRASS 7. This work will be undertaken in the
Modified: grass/branches/releasebranch_7_6/imagery/i.ortho.photo/alg_photo_rectify.txt
--- grass/branches/releasebranch_7_6/imagery/i.ortho.photo/alg_photo_rectify.txt 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/imagery/i.ortho.photo/alg_photo_rectify.txt 2018-12-26 12:09:47 UTC (rev 73853)
@@ -148,7 +148,7 @@
ref equ: case good
E21 = -943.487394 -0.990568 0.540622
N21 = -1672.101767 -0.719668 -0.167699
- got psuedo pts: row 0 col 0
+ got pseudo pts: row 0 col 0
compute geo matrix
perform georef
write matrix
@@ -187,7 +187,7 @@
ref equ: case good
E21 = -1388.336416 -0.227609 0.176021
N21 = -765.007897 0.036045 0.516496
- got psuedo pts: row 21 col 27
+ got pseudo pts: row 21 col 27
compute geo matrix
perform georef
write matrix
@@ -225,7 +225,7 @@
ref equ: case good
E21 = -1382.560261 -0.243551 0.194739
N21 = -748.402304 0.027409 0.505204
- got psuedo pts: row 22 col 27
+ got pseudo pts: row 22 col 27
compute geo matrix
perform georef
write matrix
Modified: grass/branches/releasebranch_7_6/imagery/i.ortho.photo/lib/orthoref.c
--- grass/branches/releasebranch_7_6/imagery/i.ortho.photo/lib/orthoref.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/imagery/i.ortho.photo/lib/orthoref.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -189,7 +189,7 @@
double dist_grnd, dist_photo;
double meanx, meany, meanX, meanY, meanZ;
- /* set intial XC and YC from mean values of control points */
+ /* set initial XC and YC from mean values of control points */
meanx = meany = meanX = meanY = meanZ = 0;
x = y = X = Y = 0;
n = 0;
@@ -283,7 +283,7 @@
epsilon.x[5][0] = *Kappa;
/************************** Start Iterations *****************************/
- /* itererate untill convergence */
+ /* itererate until convergence */
for (iter = 0; iter <= MAX_ITERS; iter++) {
/* break if converged */
Modified: grass/branches/releasebranch_7_6/imagery/i.segment/flag.h
--- grass/branches/releasebranch_7_6/imagery/i.segment/flag.h 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/imagery/i.segment/flag.h 2018-12-26 12:09:47 UTC (rev 73853)
@@ -10,7 +10,7 @@
** int nrows, ncols;
** opens the structure flag.
** The flag structure will be a two dimensional array of bits the
- ** size of nrows by ncols. Will initalize flags to zero (unset).
+ ** size of nrows by ncols. Will initialize flags to zero (unset).
** flag_destroy(flags)
** FLAG *flags;
Modified: grass/branches/releasebranch_7_6/imagery/i.segment/mean_shift.c
--- grass/branches/releasebranch_7_6/imagery/i.segment/mean_shift.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/imagery/i.segment/mean_shift.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -15,7 +15,7 @@
int remove_small_clumps(struct globals *globals);
-/* standard gauss funtion:
+/* standard gauss function:
* a * exp(-(x - m)^2 / (2 * stddev^2)
* a is not needed because the sum of weights is calculated for each
* sampling window
Modified: grass/branches/releasebranch_7_6/imagery/i.segment/outline
--- grass/branches/releasebranch_7_6/imagery/i.segment/outline 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/imagery/i.segment/outline 2018-12-26 12:09:47 UTC (rev 73853)
@@ -3,7 +3,7 @@
For anyone interested in background discussion, Rev 51907 includes original comments and discussion between EM, MM, and ML. All comments were combined (and new threads started!) after that revision.
-TODO: Memory managment, allow user to imput how much RAM can be used. Compare i.watershed and i.cost for two current options, initial recommendations are to follow i.watershed.
+TODO: Memory management, allow user to imput how much RAM can be used. Compare i.watershed and i.cost for two current options, initial recommendations are to follow i.watershed.
TODO: Are any parts here potentially useful as library functions? Are any of these tasks already done by existing library functions?
@@ -107,7 +107,7 @@
I think this will apply to vector lines only, initially it was framed as being for polygons or lines.
-/*ML: vector to raster conversion is probably necesary. Pixels crosses by a line (polygon boundary or not) have to become part of a segment boundary.*/
+/*ML: vector to raster conversion is probably necessary. Pixels crosses by a line (polygon boundary or not) have to become part of a segment boundary.*/
/*EM: hmm, OK, something else for discussion: These pixels that are on a vector line, should they eventually be included in one of the adjacent segments? Is "segment boundary" just the edge pixels of the segment, or are the not included in any segment?*/
/*ML: Here is where a difference comes into play between lines that are boundary polgons and lines as linear features. In my eyes pixels that are on boundarylines of polygons should be part of the segments that are internal to that boundary. Linear features would have to be treated differently. During discussions with colleagues we did have some difficulties finding actual use cases for linear features. Maybe we can start with only polygon features and if the use case of a linear features comes up try to integrate that then ?*/
/*EM: But for polygons covering the entire map, there is a segment on either side of the polygon line. If the line crosses the pixel, what should be done... It looks like this will not be a problem for multi-scalar segmentation, the polygons generated in a high level segmentation will be exactly between pixels. This will only be an issue for polygons generated elsewhere, smoothed, at different resolution, etc.*/
@@ -260,7 +260,7 @@
looks at the 4 or 8 adjacent neighbors. (can use this as basis for Find Pixel Neighbors function)
r.buffer
-My current understanding: needs to know the min/max row and column that the feature is found in, it then scans that entire square, if the pixel is part of the feature, then checks distances around it. Seems looking for min/max for every segment number will be time consuming. Would need data structure to accomodate remembering what pixels are in each segment to use this.
+My current understanding: needs to know the min/max row and column that the feature is found in, it then scans that entire square, if the pixel is part of the feature, then checks distances around it. Seems looking for min/max for every segment number will be time consuming. Would need data structure to accommodate remembering what pixels are in each segment to use this.
@@ -305,7 +305,7 @@
-Statistics for the segmentation calculated in a seperate module
+Statistics for the segmentation calculated in a separate module
Segmentation output = raster
statistics module input and output = vector. The user will have to run r.to.vect between the two.
Modified: grass/branches/releasebranch_7_6/imagery/i.smap/decimate.c
--- grass/branches/releasebranch_7_6/imagery/i.smap/decimate.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/imagery/i.smap/decimate.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -18,7 +18,7 @@
int wd, ht;
struct Region region_buff;
- /* save region stucture */
+ /* save region structure */
copy_reg(region, ®ion_buff);
D = 0;
Modified: grass/branches/releasebranch_7_6/imagery/i.smap/reg_util.c
--- grass/branches/releasebranch_7_6/imagery/i.smap/reg_util.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/imagery/i.smap/reg_util.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -7,7 +7,7 @@
int wd, ht;
D = 0;
Modified: grass/branches/releasebranch_7_6/include/iostream/empq_impl.h
--- grass/branches/releasebranch_7_6/include/iostream/empq_impl.h 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/include/iostream/empq_impl.h 2018-12-26 12:09:47 UTC (rev 73853)
@@ -293,7 +293,7 @@
//assign M/2 to AMI_STREAMS and compute arity
/* arity is mainly constrained by the size of an AMI_STREAM; the
- rest of the memory must accomodate for arity * max_nbuf
+ rest of the memory must accommodate for arity * max_nbuf
*sizeof(AMI_STREAM); there are some temporary stuff like arity *
sizeof(long) (the deleted array), arity * sizeof(T) (the array of
keys for merging) and so on, but the main factor is the
@@ -338,11 +338,11 @@
buff[i] = NULL;
- //max nb of items the structure can accomodate (constrained by max_nbuf)
+ //max nb of items the structure can accommodate (constrained by max_nbuf)
cout << "EM_PQUEUE: maximum length is " << maxlen() << "\n";
cout.flush();
- //check that structure can accomodate N elements
+ //check that structure can accommodate N elements
// assert(N < buf_arity * (buf_arity + 1) * bufsize);
//assert(N < maxlen());
mm_avail = getAvailableMemory();
Modified: grass/branches/releasebranch_7_6/include/iostream/mm.h
--- grass/branches/releasebranch_7_6/include/iostream/mm.h 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/include/iostream/mm.h 2018-12-26 12:09:47 UTC (rev 73853)
@@ -86,7 +86,7 @@
-// Declarations of a very simple memory manager desgined to work with
+// Declarations of a very simple memory manager designed to work with
// BTEs that rely on the underlying OS to manage physical memory.
class MM_register {
private:
Modified: grass/branches/releasebranch_7_6/lib/gis/adj_cellhd.c
--- grass/branches/releasebranch_7_6/lib/gis/adj_cellhd.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/lib/gis/adj_cellhd.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -516,7 +516,7 @@
char buf[100], buf2[100];
double diff;
double old, new;
- struct Cell_head cellhds; /* everyting in seconds, not degrees */
+ struct Cell_head cellhds; /* everything in seconds, not degrees */
/* lat/lon checks */
if (cellhd->proj != PROJECTION_LL)
Modified: grass/branches/releasebranch_7_6/lib/gis/lz4.c
--- grass/branches/releasebranch_7_6/lib/gis/lz4.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/lib/gis/lz4.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -824,7 +824,7 @@
_next_match:
/* at this stage, the following variables must be correctly set :
* - ip : at start of LZ operation
- * - match : at start of previous pattern occurence; can be within current prefix, or within extDict
+ * - match : at start of previous pattern occurrence; can be within current prefix, or within extDict
* - offset : if maybe_ext_memSegment==1 (constant)
* - lowLimit : must be == dictionary to mean "match is within extDict"; must be == source otherwise
* - token and *token : position to write 4-bits for match length; higher 4-bits for literal length supposed already written
Modified: grass/branches/releasebranch_7_6/lib/ogsf/gk2.c
--- grass/branches/releasebranch_7_6/lib/ogsf/gk2.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/lib/ogsf/gk2.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -418,7 +418,7 @@
pre-existing keyframe. e.g., if anykey.pos - newkey.pos <= precis,
GK_add_key() will fail unless force_replace is TRUE.
- \param pos postion
+ \param pos position
\param fmaks
\param force_replace
\param precis precision value
Modified: grass/branches/releasebranch_7_6/lib/ogsf/gs.c
--- grass/branches/releasebranch_7_6/lib/ogsf/gs.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/lib/ogsf/gs.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -964,7 +964,7 @@
\param coloratt color attribute
\param offset offset value
- \return packed color for catagory at offset
+ \return packed color for category at offset
int gs_mapcolor(typbuff * cobuff, gsurf_att * coloratt, int offset)
Modified: grass/branches/releasebranch_7_6/lib/ogsf/gsd_label.c
--- grass/branches/releasebranch_7_6/lib/ogsf/gsd_label.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/lib/ogsf/gsd_label.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -31,7 +31,7 @@
\brief Put label
- \todo Allocate label dynamicaly
+ \todo Allocate label dynamically
\param fontbase fontbase settings
\param size font size
Modified: grass/branches/releasebranch_7_6/lib/ogsf/gsd_objs.c
--- grass/branches/releasebranch_7_6/lib/ogsf/gsd_objs.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/lib/ogsf/gsd_objs.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -29,7 +29,7 @@
static void init_stuff(void);
- \brief vertices for octohedron
+ \brief vertices for octahedron
float Octo[6][3] = {
{1.0, 0.0, 0.0},
@@ -43,7 +43,7 @@
#define ONORM .57445626
- \brief normals for flat-shaded octohedron
+ \brief normals for flat-shaded octahedron
float OctoN[8][3] = {
{ONORM, ONORM, ONORM},
Modified: grass/branches/releasebranch_7_6/lib/ogsf/gsd_prim.c
--- grass/branches/releasebranch_7_6/lib/ogsf/gsd_prim.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/lib/ogsf/gsd_prim.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -76,7 +76,7 @@
static float ogl_mat_shin;
- \brief Mostly for flushing drawing commands accross a network
+ \brief Mostly for flushing drawing commands across a network
glFlush doesn't block, so if blocking is desired use glFinish.
@@ -372,7 +372,7 @@
/* OGLXXX
* special cases for polygons:
- * independant quads: use GL_QUADS
+ * independent quads: use GL_QUADS
* independent triangles: use GL_TRIANGLES
glBegin(GL_POLYGON);
Modified: grass/branches/releasebranch_7_6/lib/ogsf/gsdrape.c
--- grass/branches/releasebranch_7_6/lib/ogsf/gsdrape.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/lib/ogsf/gsdrape.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -9,7 +9,7 @@
specific triangle edge is intersected, but on a broader sense with
the horizontal, vertical, and diagonal seams in the grid, then
the intersections are ordered. If quadstrips are used for drawing
- rather than tmesh, triangulation is not consistant; for diagonal
+ rather than tmesh, triangulation is not consistent; for diagonal
intersections, the proper diagonal to intersect would need to be
determined according to the algorithm used by qstrip (look at nearby
normals). It may be faster to go ahead and find the intersections
@@ -1328,7 +1328,7 @@
\brief Define plane
\param p1,p2,p3 three point on plane
- \param[out] plane plane defintion
+ \param[out] plane plane definition
\return 1
Modified: grass/branches/releasebranch_7_6/lib/ogsf/gsds.c
--- grass/branches/releasebranch_7_6/lib/ogsf/gsds.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/lib/ogsf/gsds.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -5,7 +5,7 @@
GRASS OpenGL gsurf OGSF Library
- The idea here is to treat datasets as seperate objects, which SHOULD:
+ The idea here is to treat datasets as separate objects, which SHOULD:
- allow easier reuse of data for different attributes.
- allow a mechanism for changing data and have changes reflected
in each attribute using that data.
Modified: grass/branches/releasebranch_7_6/lib/ogsf/gvl2.c
--- grass/branches/releasebranch_7_6/lib/ogsf/gvl2.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/lib/ogsf/gvl2.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -30,7 +30,7 @@
static double Region[6];
- \brief Library intialization for volumes
+ \brief Library initialization for volumes
Set region extent (N,S,W,E,T,B)
Modified: grass/branches/releasebranch_7_6/lib/ogsf/gvl_calc.c
--- grass/branches/releasebranch_7_6/lib/ogsf/gvl_calc.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/lib/ogsf/gvl_calc.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -930,7 +930,7 @@
f_rows = distz / modz;
rows = f_rows > (int)f_rows ? (int)f_rows + 1 : (int)f_rows;
- /* set x,y intially to first slice point */
+ /* set x,y initially to first slice point */
x = slice->x1;
y = slice->y1;
Modified: grass/branches/releasebranch_7_6/lib/ogsf/gvld.c
--- grass/branches/releasebranch_7_6/lib/ogsf/gvld.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/lib/ogsf/gvld.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -23,7 +23,7 @@
#include "mc33_table.h"
-/* usefull macros */
+/* useful macros */
#define READ() gvl_read_char(pos[i]++, gvl->isosurf[i]->data)
@@ -563,7 +563,7 @@
stepy = (slice->y2 - slice->y1) / f_cols;
stepz = (slice->z2 - slice->z1) / f_rows;
- /* set x,y intially to first slice pt */
+ /* set x,y initially to first slice pt */
x = (slice->x1);
y = (slice->y1);
Modified: grass/branches/releasebranch_7_6/lib/raster/color_org.c
--- grass/branches/releasebranch_7_6/lib/raster/color_org.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/lib/raster/color_org.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -75,7 +75,7 @@
qsort((char *)cp->fp_lookup.vals, cp->fp_lookup.nalloc,
sizeof(DCELL), &double_comp);
- /* now find the rule to apply inbetween each 2 values in a list */
+ /* now find the rule to apply between each 2 values in a list */
for (i = 0; i < cp->fp_lookup.nalloc - 1; i++) {
val = (cp->fp_lookup.vals[i] + cp->fp_lookup.vals[i + 1]) / 2.;
/* fprintf (stderr, "%lf %lf ", cp->fp_lookup.vals[i], cp->fp_lookup.vals[i+1]); */
Modified: grass/branches/releasebranch_7_6/lib/raster/rasterlib.dox
--- grass/branches/releasebranch_7_6/lib/raster/rasterlib.dox 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/lib/raster/rasterlib.dox 2018-12-26 12:09:47 UTC (rev 73853)
@@ -1408,7 +1408,7 @@
used)
- fp_lookup - a lookup table for floating point numbers is added. It
orders the end points of fp intervals into array with a pointer to a
-color rule for each inteval, and the binary search is then used when
+color rule for each interval, and the binary search is then used when
looking up colors instead of linearly searching through all color
rules.
Modified: grass/branches/releasebranch_7_6/lib/raster3d/raster3dlib.dox
--- grass/branches/releasebranch_7_6/lib/raster3d/raster3dlib.dox 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/lib/raster3d/raster3dlib.dox 2018-12-26 12:09:47 UTC (rev 73853)
@@ -664,7 +664,7 @@
<P>
void Rast3d_fatalError(char (*msg)(char *)) This function prints the
error message <EM>msg</EM> to <EM>stderr</EM>, flushes <EM>stdout</EM>
- and <EM>stderr</EM>, and terminates the program with a segementation fault.
+ and <EM>stderr</EM>, and terminates the program with a segmentation fault.
<P>
Modified: grass/branches/releasebranch_7_6/lib/rst/interp_float/segmen2d_parallel.c
--- grass/branches/releasebranch_7_6/lib/rst/interp_float/segmen2d_parallel.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/lib/rst/interp_float/segmen2d_parallel.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -163,8 +163,8 @@
ymx = ((struct quaddata *)(all_leafs[i_cnt]->data))->ymax;
i = 0;
MAXENC = 0;
- /* data is a window with zero points; some fields don't make sence in this case
- so they are zero (like resolution,dimentions */
+ /* data is a window with zero points; some fields don't make sense in this case
+ so they are zero (like resolution,dimensions */
/* CHANGE */
/* Calcutaing kmin for surrent segment (depends on the size) */
Modified: grass/branches/releasebranch_7_6/mswindows/external/rbatch/batchfiles.md
--- grass/branches/releasebranch_7_6/mswindows/external/rbatch/batchfiles.md 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/mswindows/external/rbatch/batchfiles.md 2018-12-26 12:09:47 UTC (rev 73853)
@@ -377,7 +377,7 @@
## el.js ##
-`el.js` runs its arguments elevated (i.e. with Adminstrator privileges). For example,
+`el.js` runs its arguments elevated (i.e. with Administrator privileges). For example,
el R touch
Modified: grass/branches/releasebranch_7_6/mswindows/external/rbatch/batchfiles.tex
--- grass/branches/releasebranch_7_6/mswindows/external/rbatch/batchfiles.tex 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/mswindows/external/rbatch/batchfiles.tex 2018-12-26 12:09:47 UTC (rev 73853)
@@ -306,7 +306,7 @@
\subsection{el.js}
-\texttt{el.js} runs its arguments elevated (i.e.~with Adminstrator
+\texttt{el.js} runs its arguments elevated (i.e.~with Administrator
privileges).
\subsection{clip2r.js}
Modified: grass/branches/releasebranch_7_6/raster/r.contour/README
--- grass/branches/releasebranch_7_6/raster/r.contour/README 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster/r.contour/README 2018-12-26 12:09:47 UTC (rev 73853)
@@ -86,13 +86,13 @@
problems may be due to the floating point and NULL (which would
change the handling of special cases and which probably wasn't taken
care of.)
-I don't remeber who ported r.contour to FP - it might have been Olga
+I don't remember who ported r.contour to FP - it might have been Olga
Waupotitsch (she did most of the FP port). Bill is right, I don't believe
that Terry (she is a woman, BTW) could help too much here. I use r.contour
occasionally and I don't remember any problems, although I usually run it
without mask, so NULLs may be the most problematic issue (Terry left before
those were introduced.) I hope that Bill's description of the algorithm will
-be helpfull,
+be helpful,
Helena
Modified: grass/branches/releasebranch_7_6/raster/r.cost/flag.h
--- grass/branches/releasebranch_7_6/raster/r.cost/flag.h 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster/r.cost/flag.h 2018-12-26 12:09:47 UTC (rev 73853)
@@ -10,7 +10,7 @@
** FLAG *flags;
Modified: grass/branches/releasebranch_7_6/raster/r.cost/main.c
--- grass/branches/releasebranch_7_6/raster/r.cost/main.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster/r.cost/main.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -418,7 +418,7 @@
G_debug(1, " %d rows, %d cols", nrows, ncols);
/* this is most probably the limitation of r.cost for large datasets
- * segment size needs to be reduced to avoid unecessary disk IO
+ * segment size needs to be reduced to avoid unnecessary disk IO
* but it doesn't make sense to go down to 1
* so use 64 segment rows and cols for <= 200 million cells
* for larger regions, 32 segment rows and cols
Modified: grass/branches/releasebranch_7_6/raster/r.distance/distance.c
--- grass/branches/releasebranch_7_6/raster/r.distance/distance.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster/r.distance/distance.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -88,7 +88,7 @@
int nrows, ncols, row, col;
void *cell1, *cell2;
- /* NOTE: no need to controll, if the map exists. it should be checked in edge.c */
+ /* NOTE: no need to control, if the map exists. it should be checked in edge.c */
mapset = G_find_raster2(name1, "");
maptype1 = Rast_map_type(name1, mapset);
mapd1 = Rast_open_old(name1, mapset);
Modified: grass/branches/releasebranch_7_6/raster/r.fill.stats/main.c
--- grass/branches/releasebranch_7_6/raster/r.fill.stats/main.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster/r.fill.stats/main.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -309,7 +309,7 @@
- * Simple double comparision function for use by qsort().
+ * Simple double comparison function for use by qsort().
* This is needed for calculating median statistics.
int compare_dbl(const void *val1, const void *val2)
Modified: grass/branches/releasebranch_7_6/raster/r.gwflow/r.gwflow.html
--- grass/branches/releasebranch_7_6/raster/r.gwflow/r.gwflow.html 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster/r.gwflow/r.gwflow.html 2018-12-26 12:09:47 UTC (rev 73853)
@@ -35,7 +35,7 @@
<h2>NOTES</h2>
The groundwater flow calculation is based on Darcy's law and a numerical implicit
-finite volume discretization. The discretization results in a symmetric and positive definit
+finite volume discretization. The discretization results in a symmetric and positive definite
linear equation system in form of <i>Ax = b</i>, which must be solved. The groundwater flow partial
differential equation is of the following form:
Modified: grass/branches/releasebranch_7_6/raster/r.lake/main.c
--- grass/branches/releasebranch_7_6/raster/r.lake/main.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster/r.lake/main.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -70,7 +70,7 @@
*volume += cellsize * out[row][col];
- /* Get min/max depth. Can be usefull ;) */
+ /* Get min/max depth. Can be useful ;) */
if (out[row][col] > *max_depth)
*max_depth = out[row][col];
if (out[row][col] < *min_depth)
Modified: grass/branches/releasebranch_7_6/raster/r.li/r.li.daemon/daemon.h
--- grass/branches/releasebranch_7_6/raster/r.li/r.li.daemon/daemon.h 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster/r.li/r.li.daemon/daemon.h 2018-12-26 12:09:47 UTC (rev 73853)
@@ -241,7 +241,7 @@
* \brief calculates a simple index for code debugging
* \param fd file descriptor of raster
- * \param par the parameters of index not included in funtion
+ * \param par the parameters of index not included in function
* declaration
* \param result where to return result
* \return 0 on error, 1 otherwise
Modified: grass/branches/releasebranch_7_6/raster/r.out.gdal/main.c
--- grass/branches/releasebranch_7_6/raster/r.out.gdal/main.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster/r.out.gdal/main.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -15,7 +15,7 @@
-/* Undefine this if you do not want any extra funtion calls before G_parse() */
+/* Undefine this if you do not want any extra function calls before G_parse() */
#define __ALLOW_DYNAMIC_OPTIONS__
#include <stdlib.h>
@@ -680,7 +680,7 @@
- /* Finaly create user requested raster format from memory raster
+ /* Finally create user requested raster format from memory raster
* if in-memory driver was used */
if (hMEMDS) {
hDstDS =
Modified: grass/branches/releasebranch_7_6/raster/r.proj/main.c
--- grass/branches/releasebranch_7_6/raster/r.proj/main.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster/r.proj/main.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -42,7 +42,7 @@
* needed amount of memory will be allocated for the projection
* Bugfixes 20050328: added floor() before (int) typecasts to in avoid
-* assymetrical rounding errors. Added missing offset outcellhd.ew_res/2
+* asymmetrical rounding errors. Added missing offset outcellhd.ew_res/2
* to initial xcoord for each row in main projection loop (we want to project
* center of cell, not border).
Modified: grass/branches/releasebranch_7_6/raster/r.random/local_proto.h
--- grass/branches/releasebranch_7_6/raster/r.random/local_proto.h 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster/r.random/local_proto.h 2018-12-26 12:09:47 UTC (rev 73853)
@@ -28,7 +28,7 @@
typedef unsigned long gcell_count;
#endif
-/* Put all the state infomation into a struct */
+/* Put all the state information into a struct */
struct rr_state
char *inraster, *inrcover, *outraster, *outvector;
Modified: grass/branches/releasebranch_7_6/raster/r.random.cells/flag.h
--- grass/branches/releasebranch_7_6/raster/r.random.cells/flag.h 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster/r.random.cells/flag.h 2018-12-26 12:09:47 UTC (rev 73853)
@@ -29,7 +29,7 @@
/** opens the structure flag.
-** size of nrows by ncols. Will initalize flags to zero (unset).
+** size of nrows by ncols. Will initialize flags to zero (unset).
void FlagDestroy(FLAG * flags);
Modified: grass/branches/releasebranch_7_6/raster/r.ros/main.c
--- grass/branches/releasebranch_7_6/raster/r.ros/main.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster/r.ros/main.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -18,7 +18,7 @@
* cell is based on the Fortran code by Pat Andrews (1983)
* of the Northern Forest Fire Laboratory, USDA Forest
* Service. These three raster map layers are expected to
- * be the inputs for a seperate GRASS raster module
+ * be the inputs for a separate GRASS raster module
* 'r.spread'.
* 'r.ros' can be run in two standard GRASS modes:
@@ -637,7 +637,7 @@
aspect[col] = (630 - aspect[col]) % 360;
/* assign some dead fuel moisture if not completely
- * given based on emperical relationship*/
+ * given based on empirical relationship*/
if (!(parm.mois_10h->answer || parm.mois_100h->answer)) {
moisture[1] = moisture[0] + 0.01;
moisture[2] = moisture[0] + 0.02;
Modified: grass/branches/releasebranch_7_6/raster/r.ros/spot_dist.c
--- grass/branches/releasebranch_7_6/raster/r.ros/spot_dist.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster/r.ros/spot_dist.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -67,7 +67,7 @@
* and in Chase (1984) equation for source z
* @param maxros maximal ROS used in Byram's equation
* @param speed wind speed used to compute mean windspeed at 6 meter
- * accoring to Chase (1984) influencing the target z
+ * according to Chase (1984) influencing the target z
* @param angle direction of maximal ROS, i.e. the direction of spotting
* (if you think that only direction of wind influences the spotting
* then this should be the wind direction)
Modified: grass/branches/releasebranch_7_6/raster/r.spread/spot.c
--- grass/branches/releasebranch_7_6/raster/r.spread/spot.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster/r.spread/spot.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -31,7 +31,7 @@
* 3) the landing firebrand may ignite spread based on fine fuel
* moisture dictated probability simplified from Rothermel (1983);
* 4) spotting travel time is proportional to but slower than windspeed;
- * 5) there is an elapsed time to reach equilibium rate of spread (ROS).
+ * 5) there is an elapsed time to reach equilibrium rate of spread (ROS).
* This elapsed time is proportional to the ROS.
* Refs:
* Chase, C. H., 1984, Spotting distance from wind-driven surface fires --
Modified: grass/branches/releasebranch_7_6/raster/r.stream.extract/flag.h
--- grass/branches/releasebranch_7_6/raster/r.stream.extract/flag.h 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster/r.stream.extract/flag.h 2018-12-26 12:09:47 UTC (rev 73853)
@@ -11,7 +11,7 @@
* sets the flag at position bitno to zero.
* int flag_get(flag, bitno)
- * checks if the flag is set at postion bitno.
+ * checks if the flag is set at position bitno.
* Examples:
* set flag at position 0: FLAG_SET(flag, 0)
Modified: grass/branches/releasebranch_7_6/raster/r.sun/main.c
--- grass/branches/releasebranch_7_6/raster/r.sun/main.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster/r.sun/main.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -1,6 +1,6 @@
-r.sun: This program was writen by Jaro Hofierka in Summer 1993 and re-engineered
+r.sun: This program was written by Jaro Hofierka in Summer 1993 and re-engineered
in 1996-1999. In cooperation with Marcel Suri and Thomas Huld from JRC in Ispra
a new version of r.sun was prepared using ESRA solar radiation formulas.
See manual pages for details.
Modified: grass/branches/releasebranch_7_6/raster/r.sun/rsunglobals.h
--- grass/branches/releasebranch_7_6/raster/r.sun/rsunglobals.h 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster/r.sun/rsunglobals.h 2018-12-26 12:09:47 UTC (rev 73853)
@@ -1,6 +1,6 @@
-r.sun: rsunglobals.h. This program was writen by Jaro Hofierka in Summer 1993 and re-engineered
+r.sun: rsunglobals.h. This program was written by Jaro Hofierka in Summer 1993 and re-engineered
Modified: grass/branches/releasebranch_7_6/raster/r.sun/rsunlib.c
--- grass/branches/releasebranch_7_6/raster/r.sun/rsunlib.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster/r.sun/rsunlib.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -1,5 +1,5 @@
- r.sun: rsunlib.c. This program was writen by Jaro Hofierka in Summer 1993
+ r.sun: rsunlib.c. This program was written by Jaro Hofierka in Summer 1993
and re-engineered in 1996-1999. In cooperation with Marcel Suri and
Thomas Huld from JRC in Ispra a new version of r.sun was prepared using
ESRA solar radiation formulas. See the manual page for details.
Modified: grass/branches/releasebranch_7_6/raster/r.sun/sunradstruct.h
--- grass/branches/releasebranch_7_6/raster/r.sun/sunradstruct.h 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster/r.sun/sunradstruct.h 2018-12-26 12:09:47 UTC (rev 73853)
@@ -1,6 +1,6 @@
-r.sun: sunradstruct.h. This program was writen by Jaro Hofierka in Summer 1993 and re-engineered
+r.sun: sunradstruct.h. This program was written by Jaro Hofierka in Summer 1993 and re-engineered
Modified: grass/branches/releasebranch_7_6/raster/r.sunhours/solpos00.c
--- grass/branches/releasebranch_7_6/raster/r.sunhours/solpos00.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster/r.sunhours/solpos00.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -305,7 +305,7 @@
/* No absurd dates, please. */
if (pdat->function & L_GEOM) {
- if ((pdat->year < 1950) || (pdat->year > 2050)) /* limits of algoritm */
+ if ((pdat->year < 1950) || (pdat->year > 2050)) /* limits of algorithm */
retval |= (1L << S_YEAR_ERROR);
if (!(pdat->function & S_DOY) &&
((pdat->month < 1) || (pdat->month > 12)))
Modified: grass/branches/releasebranch_7_6/raster/r.sunmask/solpos00.c
--- grass/branches/releasebranch_7_6/raster/r.sunmask/solpos00.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster/r.sunmask/solpos00.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -305,7 +305,7 @@
Modified: grass/branches/releasebranch_7_6/raster/r.surf.area/main.c
--- grass/branches/releasebranch_7_6/raster/r.surf.area/main.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster/r.surf.area/main.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -44,8 +44,8 @@
/* Modified by Eric G. Miller to work with FP rasters and to handle
* NULL value cells. I'm not too sure how bad the surface area
- * calculation will get if there are alot of NULL cells mixed around.
- * Added function prototypes and removed a couple unneccessary typedefs
+ * calculation will get if there are a lot of NULL cells mixed around.
+ * Added function prototypes and removed a couple unnecessary typedefs
* Added the add_null_area() function.
* 2000-10-17
Modified: grass/branches/releasebranch_7_6/raster/r.surf.contour/flag.h
--- grass/branches/releasebranch_7_6/raster/r.surf.contour/flag.h 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster/r.surf.contour/flag.h 2018-12-26 12:09:47 UTC (rev 73853)
@@ -6,7 +6,7 @@
** FLAG *flags;
Modified: grass/branches/releasebranch_7_6/raster/r.terraflow/main.cpp
--- grass/branches/releasebranch_7_6/raster/r.terraflow/main.cpp 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster/r.terraflow/main.cpp 2018-12-26 12:09:47 UTC (rev 73853)
@@ -408,7 +408,7 @@
-/* print the largest interm file that will be generated during
+/* print the largest interim file that will be generated during
r.terraflow */
void
printMaxSortSize(long nodata_count) {
@@ -548,7 +548,7 @@
long nodata_count;
elstr = cell2stream<elevation_type>(opt->elev_grid, elevation_type_max,
&nodata_count);
- /* print the largest interm file that will be generated */
+ /* print the largest interim file that will be generated */
printMaxSortSize(nodata_count);
Modified: grass/branches/releasebranch_7_6/raster/r.terraflow/water.cpp
--- grass/branches/releasebranch_7_6/raster/r.terraflow/water.cpp 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster/r.terraflow/water.cpp 2018-12-26 12:09:47 UTC (rev 73853)
@@ -349,7 +349,7 @@
winp->getDepth(k),
winp->i + i, winp->j + j);
#ifndef NDEBUG
- /* dont insert if preceeds us */
+ /* dont insert if precedes us */
if(winp->getPriority() < prio) {
fillPLabel plabel(prio, label);
pq->insert(plabel);
Modified: grass/branches/releasebranch_7_6/raster/r.to.vect/lines.c
--- grass/branches/releasebranch_7_6/raster/r.to.vect/lines.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster/r.to.vect/lines.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -18,7 +18,7 @@
* USA CERL on nov, 1993
* because the previous implementation was incosistent
* stopped in the middle of map, because it tried to continue
- * a line wich was presumed to have been started earlier
+ * a line which was presumed to have been started earlier
* but in fact was not started.
* also the write_line() complained that the lines end unexpectedly
@@ -333,13 +333,13 @@
v_list[col - 1].right = new_ptr1;
else { /* lower-left */
- /* if the non-zero neigbours are adjacent */
+ /* if the non-zero neighbors are adjacent */
if (mr && br)
h_ptr = start_line(1);
else if ((br && bc) || (bl && bc))
v_list[col].center = start_line(1);
else
- /* the non-zero neigbours are not adjacent */
+ /* the non-zero neighbors are not adjacent */
{ /* starting in middle of line */
new_ptr1 = get_ptr();
new_ptr2 = get_ptr();
Modified: grass/branches/releasebranch_7_6/raster/r.viewshed/distribute.cpp
--- grass/branches/releasebranch_7_6/raster/r.viewshed/distribute.cpp 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster/r.viewshed/distribute.cpp 2018-12-26 12:09:47 UTC (rev 73853)
@@ -1015,7 +1015,7 @@
//technically, if there is not enough memory to hold two
//blocks, the function should enter solve_in_memory; so there
//is not enough memory to solve in memory nor to
- //distribute...this shoudl happen only under tests with very
+ //distribute...this should happen only under tests with very
//very little memory. just set nsect=2 and hope that it
//works */
Modified: grass/branches/releasebranch_7_6/raster/r.viewshed/eventlist.h
--- grass/branches/releasebranch_7_6/raster/r.viewshed/eventlist.h 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster/r.viewshed/eventlist.h 2018-12-26 12:09:47 UTC (rev 73853)
@@ -96,7 +96,7 @@
/*computes the distance from the event to the viewpoint. Note: all 3
//events associate to a cell are considered at the same distance, from
- //the center of teh cell to the viewpoint */
+ //the center of the cell to the viewpoint */
double get_square_distance_from_viewpoint(const AEvent & a,
const Viewpoint & vp);
Modified: grass/branches/releasebranch_7_6/raster/r.viewshed/grid.cpp
--- grass/branches/releasebranch_7_6/raster/r.viewshed/grid.cpp 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster/r.viewshed/grid.cpp 2018-12-26 12:09:47 UTC (rev 73853)
@@ -116,7 +116,7 @@
-/* allocate memroy for grid_data; grid must have a header that gives
+/* allocate memory for grid_data; grid must have a header that gives
the dimensions */
void alloc_grid_data(Grid * pgrid)
Modified: grass/branches/releasebranch_7_6/raster/r.viewshed/grid.h
--- grass/branches/releasebranch_7_6/raster/r.viewshed/grid.h 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster/r.viewshed/grid.h 2018-12-26 12:09:47 UTC (rev 73853)
@@ -56,7 +56,7 @@
typedef float surface_type;
typedef FCELL G_SURFACE_T;
-/* this should accomodate grid sizes up to 2^16-1=65,535
+/* this should accommodate grid sizes up to 2^16-1=65,535
If this is not enough, change type and recompile */
typedef unsigned short int dimensionType;
static const dimensionType maxDimension = USHRT_MAX - 1;
Modified: grass/branches/releasebranch_7_6/raster/r.viewshed/rbbst.cpp
--- grass/branches/releasebranch_7_6/raster/r.viewshed/rbbst.cpp 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster/r.viewshed/rbbst.cpp 2018-12-26 12:09:47 UTC (rev 73853)
@@ -632,7 +632,7 @@
return SMALLEST_GRADIENT;
assert(root);
/*assert(root->value.maxGradient != SMALLEST_GRADIENT);
- //LT: this shoudl be fixed
+ //LT: this should be fixed
//if (root->value.maxGradient != SMALLEST_GRADIENT) */
return root->value.maxGradient;
Modified: grass/branches/releasebranch_7_6/raster/r.walk/flag.h
--- grass/branches/releasebranch_7_6/raster/r.walk/flag.h 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster/r.walk/flag.h 2018-12-26 12:09:47 UTC (rev 73853)
@@ -10,7 +10,7 @@
** FLAG *flags;
Modified: grass/branches/releasebranch_7_6/raster/r.walk/main.c
--- grass/branches/releasebranch_7_6/raster/r.walk/main.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster/r.walk/main.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -531,7 +531,7 @@
G_debug(1, " NS resolution %s (%g)", buf, window.ns_res);
/* this is most probably the limitation of r.walk for large datasets
Modified: grass/branches/releasebranch_7_6/raster/r.watershed/ram/do_cum.c
--- grass/branches/releasebranch_7_6/raster/r.watershed/ram/do_cum.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster/r.watershed/ram/do_cum.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -239,8 +239,8 @@
* implemented here:
* Holmgren (1994) with modifications to honour A * path in order to get
- * out of depressions and across obstacles with gracefull flow convergence
- * before depressions/obstacles and gracefull flow divergence after
+ * out of depressions and across obstacles with graceful flow convergence
+ * before depressions/obstacles and graceful flow divergence after
* depressions/obstacles
* Topographic Convergence Index (TCI)
Modified: grass/branches/releasebranch_7_6/raster/r.watershed/ram/flag.h
--- grass/branches/releasebranch_7_6/raster/r.watershed/ram/flag.h 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster/r.watershed/ram/flag.h 2018-12-26 12:09:47 UTC (rev 73853)
@@ -10,7 +10,7 @@
** FLAG *flags;
Modified: grass/branches/releasebranch_7_6/raster/r.watershed/seg/do_cum.c
--- grass/branches/releasebranch_7_6/raster/r.watershed/seg/do_cum.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster/r.watershed/seg/do_cum.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -252,8 +252,8 @@
* implemented here:
Modified: grass/branches/releasebranch_7_6/raster/r.watershed/seg/flag.h
--- grass/branches/releasebranch_7_6/raster/r.watershed/seg/flag.h 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster/r.watershed/seg/flag.h 2018-12-26 12:09:47 UTC (rev 73853)
@@ -11,7 +11,7 @@
* Examples:
Modified: grass/branches/releasebranch_7_6/raster/r.watershed/shed/print.c
--- grass/branches/releasebranch_7_6/raster/r.watershed/shed/print.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster/r.watershed/shed/print.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -60,7 +60,7 @@
fprintf(output->out_file, " Area Percent Basin\n");
for (b = 0; b < output->num_maps; b++) {
- "<< %20s >> map layer, average catagory value: %.2f\n",
+ "<< %20s >> map layer, average category value: %.2f\n",
output->maps[b].name,
((double)output->maps[b].basins[c].sum_values) /
output->basin_facts[c].num_cells);
Modified: grass/branches/releasebranch_7_6/raster3d/r3.gwflow/r3.gwflow.html
--- grass/branches/releasebranch_7_6/raster3d/r3.gwflow/r3.gwflow.html 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster3d/r3.gwflow/r3.gwflow.html 2018-12-26 12:09:47 UTC (rev 73853)
@@ -21,7 +21,7 @@
implicit finite volume discretization. The discretization results in a
-symmetric and positive definit linear equation system in form of
+symmetric and positive definite linear equation system in form of
Modified: grass/branches/releasebranch_7_6/raster3d/r3.retile/test.r3.retile.sh
--- grass/branches/releasebranch_7_6/raster3d/r3.retile/test.r3.retile.sh 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster3d/r3.retile/test.r3.retile.sh 2018-12-26 12:09:47 UTC (rev 73853)
@@ -1,4 +1,4 @@
-# The module r3.retile is the object of ths test case
+# The module r3.retile is the object of the test case
# We need to set a specific region in the
Modified: grass/branches/releasebranch_7_6/raster3d/r3.showdspf/get_color_ogl.c
--- grass/branches/releasebranch_7_6/raster3d/r3.showdspf/get_color_ogl.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster3d/r3.showdspf/get_color_ogl.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -167,7 +167,7 @@
which is the original (per threshold) color table
(i.e. gets out of per cube color mode).
If unable to open cfile (colortable file), prints error message
-andd uses default color table.
+and uses default color table.
void no_color_file(D_spec, cfile)
struct dspec *D_spec;
Modified: grass/branches/releasebranch_7_6/raster3d/r3.showdspf/main_ogl.c
--- grass/branches/releasebranch_7_6/raster3d/r3.showdspf/main_ogl.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster3d/r3.showdspf/main_ogl.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -220,7 +220,7 @@
Headfax.g3mapin = g3map;
/* currently seems rather redundant, but may have future use to
- keep them seperate. */
+ keep them separate. */
copy_head(&G3header, &Headfax);
/* INIT */
@@ -804,7 +804,7 @@
do__draw_solid(Headp, G3p, D_spec, Cap);
else if (type & DRAW_CAP)
draw_cap_side(D_spec, Headp, G3p, Cap, (type >> 16) & 0x3f);
- /* bring over arguement to DRAW_CAP in high 16 bits to low 16 */
+ /* bring over argument to DRAW_CAP in high 16 bits to low 16 */
/* and AND with 00111111 for sides 1-6 */
@@ -933,7 +933,7 @@
Modified: grass/branches/releasebranch_7_6/raster3d/r3.showdspf/new_init_graphics.c
--- grass/branches/releasebranch_7_6/raster3d/r3.showdspf/new_init_graphics.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster3d/r3.showdspf/new_init_graphics.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -152,7 +152,7 @@
initializeFonts()
This function initializes the OpenGL display lists required for drawing
2D text in a 3D window. FontBase will end up pointing to a sequence
- of display lists in which each individual display charactor in a font.
+ of display lists in which each individual display character in a font.
The font chosen in a Courier Bold font chosen to match the font used
by the IRISGL charstr() function.
Modified: grass/branches/releasebranch_7_6/raster3d/r3.stats/support.c
--- grass/branches/releasebranch_7_6/raster3d/r3.stats/support.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster3d/r3.stats/support.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -353,7 +353,7 @@
* [[7,8]] [[8,9]]
- * Searching the value 5.5 will result in the follwoing steps:
+ * Searching the value 5.5 will result in the following steps:
* value 5.5 in range of
* 1.) left array index = 0 - right array index = 8 -> range [0 - 9]
Modified: grass/branches/releasebranch_7_6/raster3d/r3.to.rast/main.c
--- grass/branches/releasebranch_7_6/raster3d/r3.to.rast/main.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/raster3d/r3.to.rast/main.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -135,7 +135,7 @@
-/* Write the slices to seperate raster maps ******************************** */
+/* Write the slices to separate raster maps ******************************** */
/* coefficients are used only when needed, otherwise the original values
Modified: grass/branches/releasebranch_7_6/tools/module_synopsis.sh
--- grass/branches/releasebranch_7_6/tools/module_synopsis.sh 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/tools/module_synopsis.sh 2018-12-26 12:09:47 UTC (rev 73853)
@@ -2,7 +2,7 @@
# TOOL: module_synopsis.sh
-# AUTHOR: M. Hamish Bowman, Dept. Marine Science, Otago Univeristy,
+# AUTHOR: M. Hamish Bowman, Dept. Marine Science, Otago University,
# New Zealand
# PURPOSE: Runs through GRASS modules and creates a synopsis list of
# module names and descriptions.
@@ -240,7 +240,7 @@
<li> db.* - <a href="#db">database</a> commands
<li> g.* - <a href="#g">general</a> commands
<li> i.* - <a href="#i">imagery</a> commands
- <li> m.* - <a href="#m">miscellanous</a> commands
+ <li> m.* - <a href="#m">miscellaneous</a> commands
<li> ps.* - <a href="#ps">PostScript</a> commands
<li> r.* - <a href="#r">raster</a> commands
<li> r3.* - <a href="#r3">raster3D</a> commands
@@ -380,7 +380,7 @@
\item [db.{*}]database commands
\item [g.{*}]general commands
\item [i.{*}]imagery commands
-\item [m.{*}]miscellanous commands
+\item [m.{*}]miscellaneous commands
\item [ps.{*}]postscript commands
\item [r.{*}]raster commands
\item [r3.{*}]raster3D commands
Modified: grass/branches/releasebranch_7_6/tools/pylintrc.txt
--- grass/branches/releasebranch_7_6/tools/pylintrc.txt 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/tools/pylintrc.txt 2018-12-26 12:09:47 UTC (rev 73853)
@@ -13,7 +13,7 @@
# pylint --rcfile=../../tools/pylintrc.txt -f parseable -r n -i y lmgr/
# A lot of errors need to be ignored now to avoid a large number of messages.
-# Files need to be fixed one by one (partialy without this configuration).
+# Files need to be fixed one by one (partially without this configuration).
# Save this file ~/.pylintrc on Linux
Modified: grass/branches/releasebranch_7_6/vector/v.in.ogr/main.c
--- grass/branches/releasebranch_7_6/vector/v.in.ogr/main.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/vector/v.in.ogr/main.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -1486,7 +1486,7 @@
/* It is not to clean to snap centroids, but I have seen data with 2 duplicate polygons
* (as far as decimal places were printed) and centroids were not identical */
/* Disabled, because the mechanism has changed:
- * at this stage, there are no centroids yet, centroids are caluclated
+ * at this stage, there are no centroids yet, centroids are calculated
* later for output areas, not fo input polygons */
fprintf ( stderr, separator );
Modified: grass/branches/releasebranch_7_6/vector/v.label.sa/main.c
--- grass/branches/releasebranch_7_6/vector/v.label.sa/main.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/vector/v.label.sa/main.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -5,7 +5,7 @@
* PURPOSE: Create paint labels, but use a Simulated Annealing
* algorithm to avoid overlapping labels.
* This file contains the command line parsing and main function.
- * The paint label file writing funtion (print_label()) is also
+ * The paint label file writing function (print_label()) is also
* part of this file.
* COPYRIGHT: (C) 2007 by the GRASS Development Team
Modified: grass/branches/releasebranch_7_6/vector/v.profile/main.c
--- grass/branches/releasebranch_7_6/vector/v.profile/main.c 2018-12-26 12:09:39 UTC (rev 73852)
+++ grass/branches/releasebranch_7_6/vector/v.profile/main.c 2018-12-26 12:09:47 UTC (rev 73853)
@@ -742,7 +742,7 @@
if (ascii != NULL)
fclose(ascii);
exit(EXIT_SUCCESS);
