[GRASS-SVN] r73875 - grass-addons/grass7/raster/r.in.srtm.region
svn_grass at osgeo.org
Thu Dec 27 13:36:30 PST 2018
Author: veroandreo
Date: 2018-12-27 13:36:30 -0800 (Thu, 27 Dec 2018)
New Revision: 73875
grass-addons/grass7/raster/r.in.srtm.region/r.in.srtm.region.py
revert r73872 because of unintentional extra mess when attempting to fix tab/space indentation mess
Modified: grass-addons/grass7/raster/r.in.srtm.region/r.in.srtm.region.py
--- grass-addons/grass7/raster/r.in.srtm.region/r.in.srtm.region.py 2018-12-27 21:20:04 UTC (rev 73874)
+++ grass-addons/grass7/raster/r.in.srtm.region/r.in.srtm.region.py 2018-12-27 21:36:30 UTC (rev 73875)
@@ -102,33 +102,33 @@
def import_local_tile(tile, local, pid, srtmv3, one):
output = tile + '.r.in.srtm.tmp.' + str(pid)
if srtmv3:
- if one:
- local_tile = str(tile) + '.SRTMGL1.hgt.zip'
+ if one:
+ local_tile = str(tile) + '.SRTMGL1.hgt.zip'
+ else:
+ local_tile = str(tile) + '.SRTMGL3.hgt.zip'
else:
- local_tile = str(tile) + '.SRTMGL3.hgt.zip'
- else:
local_tile = str(tile) + '.hgt.zip'
path = os.path.join(local, local_tile)
if os.path.exists(path):
- path = os.path.join(local, local_tile)
- if one:
- grass.run_command('r.in.srtm', input = path, output = output, flags = '1', quiet = True)
- else:
- grass.run_command('r.in.srtm', input = path, output = output, quiet = True)
- return 1
+ path = os.path.join(local, local_tile)
+ if one:
+ grass.run_command('r.in.srtm', input = path, output = output, flags = '1', quiet = True)
+ else:
+ grass.run_command('r.in.srtm', input = path, output = output, quiet = True)
+ return 1
# SRTM subdirs: Africa, Australia, Eurasia, Islands, North_America, South_America
for srtmdir in ('Africa', 'Australia', 'Eurasia', 'Islands', 'North_America', 'South_America'):
- path = os.path.join(local, srtmdir, local_tile)
+ path = os.path.join(local, srtmdir, local_tile)
- if os.path.exists(path):
- if one:
- else:
- return 1
+ if os.path.exists(path):
+ if one:
+ else:
+ return 1
return 0
@@ -135,64 +135,64 @@
def download_tile(tile, url, pid, srtmv3, one, username, password):
if srtmv3:
- if one:
+ if one:
+ else:
else:
- else:
urllib.urlcleanup()
if srtmv3:
- remote_tile = str(url) + local_tile
- goturl = 1
+ remote_tile = str(url) + local_tile
+ goturl = 1
- try:
- password_manager = urllib2.HTTPPasswordMgrWithDefaultRealm()
- password_manager.add_password(None, "https://urs.earthdata.nasa.gov", username, password)
+ try:
+ password_manager = urllib2.HTTPPasswordMgrWithDefaultRealm()
+ password_manager.add_password(None, "https://urs.earthdata.nasa.gov", username, password)
- cookie_jar = CookieJar()
+ cookie_jar = CookieJar()
- opener = urllib2.build_opener(
- urllib2.HTTPBasicAuthHandler(password_manager),
- #urllib2.HTTPHandler(debuglevel=1), # Uncomment these two lines to see
- #urllib2.HTTPSHandler(debuglevel=1), # details of the requests/responses
- urllib2.HTTPCookieProcessor(cookie_jar))
- urllib2.install_opener(opener)
+ opener = urllib2.build_opener(
+ urllib2.HTTPBasicAuthHandler(password_manager),
+ #urllib2.HTTPHandler(debuglevel=1), # Uncomment these two lines to see
+ #urllib2.HTTPSHandler(debuglevel=1), # details of the requests/responses
+ urllib2.HTTPCookieProcessor(cookie_jar))
+ urllib2.install_opener(opener)
- request = urllib2.Request(remote_tile)
- response = urllib2.urlopen(request)
+ request = urllib2.Request(remote_tile)
+ response = urllib2.urlopen(request)
- fo = open(local_tile, 'w+b')
- fo.write(response.read())
- fo.close
- time.sleep(0.5)
- except:
- goturl = 0
- pass
- return goturl
+ fo = open(local_tile, 'w+b')
+ fo.write(response.read())
+ fo.close
+ time.sleep(0.5)
+ except:
+ goturl = 0
+ pass
+ return goturl
- remote_tile = str(url) + str(srtmdir) + '/' + local_tile
- goturl = 1
+ remote_tile = str(url) + str(srtmdir) + '/' + local_tile
+ goturl = 1
- try:
- fo.close
- time.sleep(0.5)
- # does not work:
- #urllib.urlretrieve(remote_tile, local_tile, data = None)
- except:
- goturl = 0
- pass
- if goturl == 1:
- return 1
+ try:
+ fo.close
+ time.sleep(0.5)
+ # does not work:
+ #urllib.urlretrieve(remote_tile, local_tile, data = None)
+ except:
+ goturl = 0
+ pass
+ if goturl == 1:
+ return 1
return 0
@@ -199,7 +199,7 @@
def cleanup():
if not in_temp:
- return
+ return
os.chdir(currdir)
grass.run_command('g.region', region = tmpregionname)
grass.run_command('g.remove', type = 'region', name = tmpregionname, flags = 'f', quiet = True)
@@ -226,33 +226,33 @@
res = '00:00:03'
if srtmv3:
fillnulls = 0
- if one:
- res = '00:00:01'
+ if one:
+ res = '00:00:01'
else:
- one = None
+ one = None
if len(local) == 0:
- if len(url) == 0:
- if srtmv3:
- if one:
+ if len(url) == 0:
+ if srtmv3:
+ if one:
url = 'https://e4ftl01.cr.usgs.gov/MEASURES/SRTMGL1.003/2000.02.11/'
- else:
- url = 'https://e4ftl01.cr.usgs.gov/MEASURES/SRTMGL3.003/2000.02.11/'
- else:
- url = 'http://dds.cr.usgs.gov/srtm/version2_1/SRTM3/'
+ else:
+ url = 'https://e4ftl01.cr.usgs.gov/MEASURES/SRTMGL3.003/2000.02.11/'
+ else:
+ url = 'http://dds.cr.usgs.gov/srtm/version2_1/SRTM3/'
if len(local) == 0:
- local = None
+ local = None
# are we in LatLong location?
s = grass.read_command("g.proj", flags='j')
kv = grass.parse_key_val(s)
if kv['+proj'] != 'longlat':
- grass.fatal(_("This module only operates in LatLong locations"))
+ grass.fatal(_("This module only operates in LatLong locations"))
if fillnulls == 1 and memory <= 0:
- grass.warning(_("Amount of memory to use for interpolation must be positive, setting to 300 MB"))
- memory = '300'
+ grass.warning(_("Amount of memory to use for interpolation must be positive, setting to 300 MB"))
+ memory = '300'
# make a temporary directory
tmpdir = grass.tempfile()
@@ -265,7 +265,7 @@
os.chdir(tmpdir)
in_temp = True
if local is None:
- local = tmpdir
+ local = tmpdir
# get extents
reg = grass.region()
@@ -272,46 +272,46 @@
tmpregionname = 'r_in_srtm_tmp_region'
grass.run_command('g.region', save = tmpregionname, overwrite=overwrite)
if options['region'] is None or options['region'] == '':
- north = reg['n']
- south = reg['s']
- east = reg['e']
- west = reg['w']
+ north = reg['n']
+ south = reg['s']
+ east = reg['e']
+ west = reg['w']
else:
- west, south, east, north = options['region'].split(',')
- west = float(west)
- south = float(south)
- east = float(east)
- north = float(north)
+ west, south, east, north = options['region'].split(',')
+ west = float(west)
+ south = float(south)
+ east = float(east)
+ north = float(north)
# adjust extents to cover SRTM tiles: 1 degree bounds
tmpint = int(north)
if tmpint < north:
- north = tmpint + 1
+ north = tmpint + 1
else:
- north = tmpint
+ north = tmpint
tmpint = int(south)
if tmpint > south:
- south = tmpint - 1
+ south = tmpint - 1
else:
- south = tmpint
+ south = tmpint
tmpint = int(east)
if tmpint < east:
- east = tmpint + 1
+ east = tmpint + 1
else:
- east = tmpint
+ east = tmpint
tmpint = int(west)
if tmpint > west:
- west = tmpint - 1
+ west = tmpint - 1
else:
- west = tmpint
+ west = tmpint
if north == south:
- north += 1
+ north += 1
if east == west:
- east += 1
+ east += 1
rows = abs(north - south)
cols = abs(east - west)
@@ -322,97 +322,97 @@
srtmtiles = ''
valid_tiles = 0
for ndeg in range(south, north):
- for edeg in range(west, east):
- grass.percent(counter, ntiles, 1)
- counter += 1
- if ndeg < 0:
- tile = 'S'
- else:
- tile = 'N'
- tile = tile + '%02d' % abs(ndeg)
- if edeg < 0:
- tile = tile + 'W'
- else:
- tile = tile + 'E'
- tile = tile + '%03d' % abs(edeg)
- grass.debug("Tile: %s" % tile, debug = 1)
- if local != tmpdir:
- gotit = import_local_tile(tile, local, pid, srtmv3, one)
- else:
- gotit = download_tile(tile, url, pid, srtmv3, one, username, password)
- if gotit == 1:
- gotit = import_local_tile(tile, tmpdir, pid, srtmv3, one)
- if gotit == 1:
- grass.verbose(_("Tile %s successfully imported") % tile)
- valid_tiles += 1
- elif dozerotile:
- # create tile with zeros
- if one:
- # north
- if ndeg < -1:
- tmpn = '%02d:59:59.5S' % (abs(ndeg) - 2)
- else:
- tmpn = '%02d:00:00.5N' % (ndeg + 1)
- # south
- if ndeg < 1:
- tmps = '%02d:00:00.5S' % abs(ndeg)
- else:
- tmps = '%02d:59:59.5N' % (ndeg - 1)
- # east
- if edeg < -1:
- tmpe = '%03d:59:59.5W' % (abs(edeg) - 2)
- else:
- tmpe = '%03d:00:00.5E' % (edeg + 1)
- # west
- if edeg < 1:
- tmpw = '%03d:00:00.5W' % abs(edeg)
- else:
- tmpw = '%03d:59:59.5E' % (edeg - 1)
- else:
- # north
- if ndeg < -1:
- tmpn = '%02d:59:58.5S' % (abs(ndeg) - 2)
- else:
- tmpn = '%02d:00:01.5N' % (ndeg + 1)
- # south
- if ndeg < 1:
- tmps = '%02d:00:01.5S' % abs(ndeg)
- else:
- tmps = '%02d:59:58.5N' % (ndeg - 1)
- # east
- if edeg < -1:
- tmpe = '%03d:59:58.5W' % (abs(edeg) - 2)
- else:
- tmpe = '%03d:00:01.5E' % (edeg + 1)
- # west
- if edeg < 1:
- tmpw = '%03d:00:01.5W' % abs(edeg)
- else:
- tmpw = '%03d:59:58.5E' % (edeg - 1)
+ for edeg in range(west, east):
+ grass.percent(counter, ntiles, 1)
+ counter += 1
+ if ndeg < 0:
+ tile = 'S'
+ else:
+ tile = 'N'
+ tile = tile + '%02d' % abs(ndeg)
+ if edeg < 0:
+ tile = tile + 'W'
+ else:
+ tile = tile + 'E'
+ tile = tile + '%03d' % abs(edeg)
+ grass.debug("Tile: %s" % tile, debug = 1)
+ if local != tmpdir:
+ gotit = import_local_tile(tile, local, pid, srtmv3, one)
+ else:
+ gotit = download_tile(tile, url, pid, srtmv3, one, username, password)
+ if gotit == 1:
+ gotit = import_local_tile(tile, tmpdir, pid, srtmv3, one)
+ if gotit == 1:
+ grass.verbose(_("Tile %s successfully imported") % tile)
+ valid_tiles += 1
+ elif dozerotile:
+ # create tile with zeros
+ if one:
+ # north
+ if ndeg < -1:
+ tmpn = '%02d:59:59.5S' % (abs(ndeg) - 2)
+ else:
+ tmpn = '%02d:00:00.5N' % (ndeg + 1)
+ # south
+ if ndeg < 1:
+ tmps = '%02d:00:00.5S' % abs(ndeg)
+ else:
+ tmps = '%02d:59:59.5N' % (ndeg - 1)
+ # east
+ if edeg < -1:
+ tmpe = '%03d:59:59.5W' % (abs(edeg) - 2)
+ else:
+ tmpe = '%03d:00:00.5E' % (edeg + 1)
+ # west
+ if edeg < 1:
+ tmpw = '%03d:00:00.5W' % abs(edeg)
+ else:
+ tmpw = '%03d:59:59.5E' % (edeg - 1)
+ else:
+ # north
+ if ndeg < -1:
+ tmpn = '%02d:59:58.5S' % (abs(ndeg) - 2)
+ else:
+ tmpn = '%02d:00:01.5N' % (ndeg + 1)
+ # south
+ if ndeg < 1:
+ tmps = '%02d:00:01.5S' % abs(ndeg)
+ else:
+ tmps = '%02d:59:58.5N' % (ndeg - 1)
+ # east
+ if edeg < -1:
+ tmpe = '%03d:59:58.5W' % (abs(edeg) - 2)
+ else:
+ tmpe = '%03d:00:01.5E' % (edeg + 1)
+ # west
+ if edeg < 1:
+ tmpw = '%03d:00:01.5W' % abs(edeg)
+ else:
+ tmpw = '%03d:59:58.5E' % (edeg - 1)
- grass.run_command('g.region', n = tmpn, s = tmps, e = tmpe, w = tmpw, res = res)
- grass.run_command('r.mapcalc', expression = "%s = 0" % (tile + '.r.in.srtm.tmp.' + str(pid)), quiet = True)
- grass.run_command('g.region', region = tmpregionname)
+ grass.run_command('g.region', n = tmpn, s = tmps, e = tmpe, w = tmpw, res = res)
+ grass.run_command('r.mapcalc', expression = "%s = 0" % (tile + '.r.in.srtm.tmp.' + str(pid)), quiet = True)
+ grass.run_command('g.region', region = tmpregionname)
# g.list with sep = comma does not work ???
pattern = '*.r.in.srtm.tmp.%d' % pid
srtmtiles = grass.read_command('g.list', type = 'raster',
- pattern = pattern,
- sep = 'newline',
- quiet = True)
+ pattern = pattern,
+ sep = 'newline',
+ quiet = True)
srtmtiles = srtmtiles.splitlines()
srtmtiles = ','.join(srtmtiles)
if valid_tiles == 0:
- grass.run_command('g.remove', type = 'raster', name = str(srtmtiles), flags = 'f', quiet = True)
- grass.warning(_("No tiles imported"))
- grass.fatal(_("Please check if local folder <%s> is correct.") % local)
- else:
- grass.fatal(_("Please check internet connection, credentials, and if url <%s> is correct.") % url)
+ grass.run_command('g.remove', type = 'raster', name = str(srtmtiles), flags = 'f', quiet = True)
+ grass.warning(_("No tiles imported"))
+ grass.fatal(_("Please check if local folder <%s> is correct.") % local)
+ else:
+ grass.fatal(_("Please check internet connection, credentials, and if url <%s> is correct.") % url)
grass.run_command('g.region', raster = str(srtmtiles));
@@ -424,30 +424,30 @@
grass.run_command('g.rename', raster = '%s,%s' % (srtmtiles, output ), quiet = True)
else:
ncells = grass.region()['cells']
- if long(ncells) > 1000000000:
- grass.message(_("%s cells to interpolate, this will take some time") % str(ncells), flag = 'i')
- grass.run_command('r.patch', input = srtmtiles, output = output + '.holes')
- mapstats = grass.parse_command('r.univar', map = output + '.holes', flags = 'g', quiet = True)
- if mapstats['null_cells'] == '0':
- grass.run_command('g.rename', raster = '%s,%s' % (output + '.holes', output), quiet = True)
- else:
- grass.run_command('r.resamp.bspline',
- input = output + '.holes',
- output = output + '.interp',
- se = '0.0025', sn = '0.0025',
- method = 'linear',
- memory = memory,
- flags = 'n')
- input = '%s,%s' % (output + '.holes',
- output + '.interp'),
- output = output + '.float',
- flags = 'z')
- grass.run_command('r.mapcalc', expression = '%s = round(%s)' % (output, output + '.float'))
- name = '%s,%s,%s' % (output + '.holes', output + '.interp', output + '.float'),
+ if long(ncells) > 1000000000:
+ grass.message(_("%s cells to interpolate, this will take some time") % str(ncells), flag = 'i')
+ grass.run_command('r.patch', input = srtmtiles, output = output + '.holes')
+ mapstats = grass.parse_command('r.univar', map = output + '.holes', flags = 'g', quiet = True)
+ if mapstats['null_cells'] == '0':
+ grass.run_command('g.rename', raster = '%s,%s' % (output + '.holes', output), quiet = True)
+ else:
+ grass.run_command('r.resamp.bspline',
+ input = output + '.holes',
+ output = output + '.interp',
+ se = '0.0025', sn = '0.0025',
+ method = 'linear',
+ memory = memory,
+ flags = 'n')
+ input = '%s,%s' % (output + '.holes',
+ output + '.interp'),
+ output = output + '.float',
+ flags = 'z')
+ grass.run_command('r.mapcalc', expression = '%s = round(%s)' % (output, output + '.float'))
+ name = '%s,%s,%s' % (output + '.holes', output + '.interp', output + '.float'),
flags = 'f',
- quiet = True)
+ quiet = True)
grass.run_command('g.remove', type = 'raster', pattern = pattern, flags = 'f', quiet = True)
@@ -464,10 +464,10 @@
else:
source1 = 'SRTM V2.1'
grass.run_command('r.support', map = output,
- loadhistory = tmphist,
- description = 'generated by r.in.srtm.region',
- source1 = source1,
- source2 = (local if local != tmpdir else url))
+ loadhistory = tmphist,
+ description = 'generated by r.in.srtm.region',
+ source1 = source1,
+ source2 = (local if local != tmpdir else url))
grass.try_remove(tmphist)
grass.message(_("Done: generated map <%s>") % output)
