[GRASS-SVN] r72204 - in grass-addons/grass7/temporal: . t.rast.null
svn_grass at osgeo.org
Fri Feb 2 06:20:09 PST 2018
Author: lucadelu
Date: 2018-02-02 06:20:09 -0800 (Fri, 02 Feb 2018)
New Revision: 72204
Added:
grass-addons/grass7/temporal/t.rast.null/
grass-addons/grass7/temporal/t.rast.null/Makefile
grass-addons/grass7/temporal/t.rast.null/t.rast.null.html
grass-addons/grass7/temporal/t.rast.null/t.rast.null.py
t.rast.null: added new temporal modules to manage null values
Added: grass-addons/grass7/temporal/t.rast.null/Makefile
--- grass-addons/grass7/temporal/t.rast.null/Makefile (rev 0)
+++ grass-addons/grass7/temporal/t.rast.null/Makefile 2018-02-02 14:20:09 UTC (rev 72204)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = t.rast.null
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/grass7/temporal/t.rast.null/Makefile
___________________________________________________________________
Added: svn:mime-type
+ text/x-makefile
Added: svn:eol-style
+ native
Added: grass-addons/grass7/temporal/t.rast.null/t.rast.null.html
--- grass-addons/grass7/temporal/t.rast.null/t.rast.null.html (rev 0)
+++ grass-addons/grass7/temporal/t.rast.null/t.rast.null.html 2018-02-02 14:20:09 UTC (rev 72204)
@@ -0,0 +1,29 @@
+<h2>DESCRIPTION</h2>
+<em><b>t.rast.null</b></em> manages NULL-values of the input space time raster
+dataset.
+<p>
+The setnull parameter is used to specify values in the ranges to be set to NULL.
+A range is either a single value (e.g., 5.3), or a pair of values (e.g., 4.76-34.56).
+Existing NULL-values are left NULL, unless the null argument is requested.
+<p>
+The null parameter eliminates the NULL value and replaces it with value.
+This argument is applied only to existing NULL values, and not to the NULLs created by the setnull argument.
+<h2>EXAMPLES</h2>
+Set specific values (0,-1 and -2) of a space time raster dataset to NULL:
+<div class="code"><pre>
+ t.rast.null input=MY_INPUT_DATASET setnull=0,-1,-2
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.null.html">r.null</a>,
+</em>
+<h2>AUTHOR</h2>
+Luca Delucchi, Fondazione Edmund Mach
+<p>
+<i>Last changed: $Date$</i>
Property changes on: grass-addons/grass7/temporal/t.rast.null/t.rast.null.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
Added: grass-addons/grass7/temporal/t.rast.null/t.rast.null.py
--- grass-addons/grass7/temporal/t.rast.null/t.rast.null.py (rev 0)
+++ grass-addons/grass7/temporal/t.rast.null/t.rast.null.py 2018-02-02 14:20:09 UTC (rev 72204)
@@ -0,0 +1,109 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE: t.rast.null
+# AUTHOR(S): Luca Delucchi
+# PURPOSE: t.rast.null set null values in a space time raster dataset
+# COPYRIGHT: (C) 2018 by Luca Delucchi
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Calculate kappa parameter in a space time raster dataset
+#% keyword: temporal
+#% keyword: raster
+#% keyword: null data
+#%end
+#%option G_OPT_STRDS_INPUT
+#% key: strds
+#%end
+#%option
+#% key: setnull
+#% type: string
+#% label: List of cell values to be set to NULL
+#% multiple: yes
+#% required: no
+#%end
+#%option
+#% key: null
+#% type: double
+#% label: The value to replace the null value by
+#% multiple: no
+#% required: no
+#%end
+#%option G_OPT_T_WHERE
+#%end
+#%option
+#% key: nprocs
+#% type: integer
+#% description: Number of r.to.vect processes to run in parallel, more than 1 process works only in conjunction with flag -t
+#% required: no
+#% multiple: no
+#% answer: 1
+#%end
+import copy
+import sys
+import grass.temporal as tgis
+import grass.script as gscript
+import grass.pygrass.modules as pymod
+def main():
+ strds = options["strds"]
+ where = options["where"]
+ nprocs = int(options["nprocs"])
+ nullmod = pymod.Module('r.null')
+ nullmod.flags.quiet = True
+ if options["null"]:
+ nullmod.inputs.null = options["null"]
+ elif options["setnull"]:
+ nullmod.inputs.setnull = options["setnull"]
+ else:
+ gscript.fatal(_("Please set 'null' or 'setnull' option"))
+ tgis.init()
+ # We need a database interface
+ dbif = tgis.SQLDatabaseInterfaceConnection()
+ dbif.connect()
+ sp = tgis.open_old_stds(strds, "strds", dbif)
+ maps = sp.get_registered_maps_as_objects(where, "start_time", None)
+ if maps is None:
+ gscript.fatal(_("Space time raster dataset {st} seems to be "
+ "empty".format(st=strds)))
+ return 1
+ # module queue for parallel execution
+ process_queue = pymod.ParallelModuleQueue(int(nprocs))
+ count = 0
+ num_maps = len(maps)
+ for mapp in maps:
+ count += 1
+ mod = copy.deepcopy(nullmod)
+ mod.inputs.map = mapp.get_id()
+ process_queue.put(mod)
+ if count%10 == 0:
+ gscript.percent(count, num_maps, 1)
+ # Wait for unfinished processes
+ process_queue.wait()
+if __name__ == "__main__":
+ options, flags = gscript.parser()
+ sys.exit(main())
Property changes on: grass-addons/grass7/temporal/t.rast.null/t.rast.null.py
+ text/x-python
+ native
