[GRASS-SVN] r72207 - grass-addons/grass7/raster/r.futures/r.futures.pga
svn_grass at osgeo.org
Sat Feb 3 16:28:40 PST 2018
Author: annakrat
Date: 2018-02-03 16:28:40 -0800 (Sat, 03 Feb 2018)
New Revision: 72207
grass-addons/grass7/raster/r.futures/r.futures.pga/main.c
r.futures.pga: force developing every available cell to speed up computation when there are extremely low probability values; initialize variable
Modified: grass-addons/grass7/raster/r.futures/r.futures.pga/main.c
--- grass-addons/grass7/raster/r.futures/r.futures.pga/main.c 2018-02-03 14:40:59 UTC (rev 72206)
+++ grass-addons/grass7/raster/r.futures/r.futures.pga/main.c 2018-02-04 00:28:40 UTC (rev 72207)
@@ -1319,6 +1319,7 @@
G_debug(1, "After accounting for extra cells, attempt %d cells", nToConvert);
/* if have cells to convert this step */
+ bool forceConvertEverything = false;
if (nToConvert > 0) {
/* if not enough cells to convert then alter number required */
if (nToConvert > pLandscape->num_undevSites[regionID]) {
@@ -1326,6 +1327,7 @@
" available: %d). Converting all available.",
nToConvert, pLandscape->num_undevSites[regionID]);
nToConvert = pLandscape->num_undevSites[regionID];
+ forceConvertEverything = true;
/* update in stochastic fashion */
nDone = 0;
@@ -1364,7 +1366,7 @@
/* Doug's "back to front" logit */
// dProb = 1.0/(1.0 + exp(pLandscape->asUndev[i].logitVal));
dProb = pLandscape->asUndevs[regionID][i].logitVal;
- if (uniformRandom() < dProb) {
+ if (forceConvertEverything || (uniformRandom() < dProb)) {
nDone +=
convertCells(pLandscape, pParams,
@@ -1904,7 +1906,6 @@
if (p >= pLandscape->asUndevs[regionID][last].cumulProb)
return last;
while (first <= last) {
- // TODO: these might not me initialized (says also valgrind)
if (pLandscape->asUndevs[regionID][middle].cumulProb < p)
first = middle + 1;
else if (pLandscape->asUndevs[regionID][middle - 1].cumulProb < p &&
@@ -2007,9 +2008,8 @@
int j;
for (j = 0; j < pParams->num_Regions; j++) {
- // TODO: value of pLandscape->asUndevs[j][0].cumulProb is what?
double sum = pLandscape->asUndevs[j][0].logitVal;
+ pLandscape->asUndevs[j][0].cumulProb = pLandscape->asUndevs[j][0].logitVal;
for (i = 1; i < pLandscape->num_undevSites[j]; i++) {
pLandscape->asUndevs[j][i].cumulProb =
pLandscape->asUndevs[j][i - 1].cumulProb +
