[GRASS-SVN] r72230 - in grass/trunk: . include
Sun Feb 11 13:39:35 PST 2018
Author: mmetz
Date: 2018-02-11 13:39:35 -0800 (Sun, 11 Feb 2018)
New Revision: 72230
   grass/trunk/configure
   grass/trunk/configure.in
   grass/trunk/include/config.h.in
   grass/trunk/include/gis.h
add 64 bit signed integer
Modified: grass/trunk/configure
--- grass/trunk/configure	2018-02-11 21:32:57 UTC (rev 72229)
+++ grass/trunk/configure	2018-02-11 21:39:35 UTC (rev 72230)
@@ -3670,8 +3670,37 @@
 fi
 rm -f conftest*
+echo $ac_n "checking for int64_t""... $ac_c" 1>&6
+echo "configure:3675: checking for int64_t" >&5
+cat > conftest.$ac_ext <<EOF
+#line 3677 "configure"
+#include "confdefs.h"
+#include <sys/types.h>
+int main() {
+int64_t x;
+; return 0; }
+EOF
+if { (eval echo configure:3684: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+  rm -rf conftest*
+echo "$ac_t""yes" 1>&6
+cat >> confdefs.h <<\EOF
+#define HAVE_INT64_T 1
+EOF
+else
+  echo "configure: failed program was:" >&5
+  cat conftest.$ac_ext >&5
+  rm -rf conftest*
+echo "$ac_t""no" 1>&6
+fi
+rm -f conftest*
 echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:3675: checking for W11" >&5
+echo "configure:3704: checking for W11" >&5
 case "$enable_w11" in
 	yes|no)	echo "$ac_t"""$enable_w11"" 1>&6	;;
 	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
@@ -3699,7 +3728,7 @@
 # Uses ac_ vars as temps to allow command line to override cache and checks.
 # --without-x overrides everything else, but does not touch the cache.
 echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:3703: checking for X" >&5
+echo "configure:3732: checking for X" >&5
 # Check whether --with-x or --without-x was given.
 if test "${with_x+set}" = set; then
@@ -3759,12 +3788,12 @@
   # First, try using that file with no special directory specified.
-#line 3763 "configure"
+#line 3792 "configure"
 #include <$x_direct_test_include>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:3768: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3797: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -3833,14 +3862,14 @@
   ac_save_LIBS="$LIBS"
   LIBS="-l$x_direct_test_library $LIBS"
-#line 3837 "configure"
+#line 3866 "configure"
 int main() {
 ${x_direct_test_function}()
 ; return 0; }
 EOF
-if { (eval echo configure:3844: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3873: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LIBS="$ac_save_LIBS"
 # We can link X programs with no special library path.
@@ -3945,17 +3974,17 @@
     case "`(uname -sr) 2>/dev/null`" in
     "SunOS 5"*)
       echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:3949: checking whether -R must be followed by a space" >&5
+echo "configure:3978: checking whether -R must be followed by a space" >&5
       ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 3952 "configure"
+#line 3981 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:3959: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3988: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_nospace=yes
 else
@@ -3971,14 +4000,14 @@
       else
 	LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 3975 "configure"
+#line 4004 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:3982: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4011: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_space=yes
 else
@@ -4010,13 +4039,13 @@
     # libraries were built with DECnet support.  And karl at cs.umb.edu says
     # the Alpha needs dnet_stub (dnet does not exist).
     echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:4014: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:4043: checking for dnet_ntoa in -ldnet" >&5
 ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet  $LIBS"
-#line 4020 "configure"
+#line 4049 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -4027,7 +4056,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:4031: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4060: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -4048,13 +4077,13 @@
     if test $ac_cv_lib_dnet_dnet_ntoa = no; then
       echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:4052: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:4081: checking for dnet_ntoa in -ldnet_stub" >&5
 ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet_stub  $LIBS"
-#line 4058 "configure"
+#line 4087 "configure"
@@ -4065,7 +4094,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:4069: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4098: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4093,10 +4122,10 @@
     # The nsl library prevents programs from opening the X display
     # on Irix 5.2, according to dickey at clark.net.
     echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:4097: checking for gethostbyname" >&5
+echo "configure:4126: checking for gethostbyname" >&5
-#line 4100 "configure"
+#line 4129 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char gethostbyname(); below.  */
@@ -4119,7 +4148,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4123: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4152: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gethostbyname=yes"
 else
@@ -4139,13 +4168,13 @@
     if test $ac_cv_func_gethostbyname = no; then
       echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:4143: checking for gethostbyname in -lnsl" >&5
+echo "configure:4172: checking for gethostbyname in -lnsl" >&5
 ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 4149 "configure"
+#line 4178 "configure"
@@ -4156,7 +4185,7 @@
 gethostbyname()
 ; return 0; }
 EOF
-if { (eval echo configure:4160: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4189: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4185,10 +4214,10 @@
     # -lsocket must be given before -lnsl if both are needed.
     # We assume that if connect needs -lnsl, so does gethostbyname.
     echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:4189: checking for connect" >&5
+echo "configure:4218: checking for connect" >&5
-#line 4192 "configure"
+#line 4221 "configure"
     which can conflict with char connect(); below.  */
@@ -4211,7 +4240,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4215: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4244: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_connect=yes"
 else
@@ -4231,13 +4260,13 @@
     if test $ac_cv_func_connect = no; then
       echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:4235: checking for connect in -lsocket" >&5
+echo "configure:4264: checking for connect in -lsocket" >&5
 ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
 LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 4241 "configure"
+#line 4270 "configure"
@@ -4248,7 +4277,7 @@
 connect()
 ; return 0; }
 EOF
-if { (eval echo configure:4252: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4281: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4271,10 +4300,10 @@
     # gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
     echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:4275: checking for remove" >&5
+echo "configure:4304: checking for remove" >&5
-#line 4278 "configure"
+#line 4307 "configure"
     which can conflict with char remove(); below.  */
@@ -4297,7 +4326,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4301: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4330: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_remove=yes"
 else
@@ -4317,13 +4346,13 @@
     if test $ac_cv_func_remove = no; then
       echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:4321: checking for remove in -lposix" >&5
+echo "configure:4350: checking for remove in -lposix" >&5
 ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
 LIBS="-lposix  $LIBS"
-#line 4327 "configure"
+#line 4356 "configure"
@@ -4334,7 +4363,7 @@
 remove()
 ; return 0; }
 EOF
-if { (eval echo configure:4338: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4367: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4357,10 +4386,10 @@
     # BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
     echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:4361: checking for shmat" >&5
+echo "configure:4390: checking for shmat" >&5
-#line 4364 "configure"
+#line 4393 "configure"
     which can conflict with char shmat(); below.  */
@@ -4383,7 +4412,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4387: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4416: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_shmat=yes"
 else
@@ -4403,13 +4432,13 @@
     if test $ac_cv_func_shmat = no; then
       echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:4407: checking for shmat in -lipc" >&5
+echo "configure:4436: checking for shmat in -lipc" >&5
 ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
 LIBS="-lipc  $LIBS"
-#line 4413 "configure"
+#line 4442 "configure"
@@ -4420,7 +4449,7 @@
 shmat()
 ; return 0; }
 EOF
-if { (eval echo configure:4424: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4453: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4452,13 +4481,13 @@
   # libraries we check for below, so use a different variable.
   #  --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
   echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:4456: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:4485: checking for IceConnectionNumber in -lICE" >&5
 ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
 LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 4462 "configure"
+#line 4491 "configure"
@@ -4469,7 +4498,7 @@
 IceConnectionNumber()
 ; return 0; }
 EOF
-if { (eval echo configure:4473: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4502: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4509,12 +4538,12 @@
 LIBS=""
 echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:4513: checking for library containing cuserid" >&5
+echo "configure:4542: checking for library containing cuserid" >&5
 ac_func_search_save_LIBS="$LIBS"
 ac_cv_search_cuserid="no"
-#line 4518 "configure"
+#line 4547 "configure"
@@ -4525,7 +4554,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:4529: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4558: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="none required"
 else
@@ -4536,7 +4565,7 @@
 test "$ac_cv_search_cuserid" = "no" && for i in compat; do
 LIBS="-l$i  $ac_func_search_save_LIBS"
-#line 4540 "configure"
+#line 4569 "configure"
@@ -4547,7 +4576,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:4551: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4580: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="-l$i"
 break
@@ -4573,10 +4602,10 @@
 for ac_func in asprintf
 do
 echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:4577: checking for $ac_func" >&5
+echo "configure:4606: checking for $ac_func" >&5
-#line 4580 "configure"
+#line 4609 "configure"
     which can conflict with char $ac_func(); below.  */
@@ -4599,7 +4628,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4603: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4632: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_$ac_func=yes"
 else
@@ -4626,10 +4655,10 @@
 # Test if mathlib needs -lm flag or is included with libc
 echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:4630: checking for atan" >&5
+echo "configure:4659: checking for atan" >&5
-#line 4633 "configure"
+#line 4662 "configure"
     which can conflict with char atan(); below.  */
@@ -4652,7 +4681,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4656: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4685: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_atan=yes"
 else
@@ -4670,13 +4699,13 @@
 echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:4674: checking for atan in -lm" >&5
+echo "configure:4703: checking for atan in -lm" >&5
 ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
 LIBS="-lm  $LIBS"
-#line 4680 "configure"
+#line 4709 "configure"
@@ -4687,7 +4716,7 @@
 atan()
 ; return 0; }
 EOF
-if { (eval echo configure:4691: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4720: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4714,10 +4743,10 @@
 echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:4718: checking for dlsym" >&5
+echo "configure:4747: checking for dlsym" >&5
-#line 4721 "configure"
+#line 4750 "configure"
     which can conflict with char dlsym(); below.  */
@@ -4740,7 +4769,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4744: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4773: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dlsym=yes"
 else
@@ -4758,13 +4787,13 @@
 echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:4762: checking for dlsym in -ldl" >&5
+echo "configure:4791: checking for dlsym in -ldl" >&5
 ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
 LIBS="-ldl  $LIBS"
-#line 4768 "configure"
+#line 4797 "configure"
@@ -4775,7 +4804,7 @@
 dlsym()
 ; return 0; }
 EOF
-if { (eval echo configure:4779: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4808: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4802,10 +4831,10 @@
 echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:4806: checking for iconv" >&5
+echo "configure:4835: checking for iconv" >&5
-#line 4809 "configure"
+#line 4838 "configure"
     which can conflict with char iconv(); below.  */
@@ -4828,7 +4857,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4832: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4861: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_iconv=yes"
 else
@@ -4846,13 +4875,13 @@
 echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:4850: checking for iconv in -liconv" >&5
+echo "configure:4879: checking for iconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-liconv  $LIBS"
-#line 4856 "configure"
+#line 4885 "configure"
@@ -4863,7 +4892,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:4867: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4896: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4882,13 +4911,13 @@
 echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4886: checking for iconv in -lgiconv" >&5
+echo "configure:4915: checking for iconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-lgiconv  $LIBS"
-#line 4892 "configure"
+#line 4921 "configure"
@@ -4899,7 +4928,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:4903: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4932: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4918,10 +4947,10 @@
 echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:4922: checking for libiconv" >&5
+echo "configure:4951: checking for libiconv" >&5
-#line 4925 "configure"
+#line 4954 "configure"
     which can conflict with char libiconv(); below.  */
@@ -4944,7 +4973,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4948: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4977: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_libiconv=yes"
 else
@@ -4962,13 +4991,13 @@
 echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:4966: checking for libiconv in -liconv" >&5
+echo "configure:4995: checking for libiconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 4972 "configure"
+#line 5001 "configure"
@@ -4979,7 +5008,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:4983: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5012: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4998,13 +5027,13 @@
 echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:5002: checking for libiconv in -lgiconv" >&5
+echo "configure:5031: checking for libiconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 5008 "configure"
+#line 5037 "configure"
@@ -5015,7 +5044,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:5019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5048: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5052,10 +5081,10 @@
 have_socket=1
 echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:5056: checking for socket" >&5
+echo "configure:5085: checking for socket" >&5
-#line 5059 "configure"
+#line 5088 "configure"
     which can conflict with char socket(); below.  */
@@ -5078,7 +5107,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5082: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5111: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_socket=yes"
 else
@@ -5096,13 +5125,13 @@
 echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:5100: checking for socket in -lsocket" >&5
+echo "configure:5129: checking for socket in -lsocket" >&5
 ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
 LIBS="-lsocket  $LIBS"
-#line 5106 "configure"
+#line 5135 "configure"
@@ -5113,7 +5142,7 @@
 socket()
 ; return 0; }
 EOF
-if { (eval echo configure:5117: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5146: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5161,7 +5190,7 @@
 echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:5165: checking for location of zlib includes" >&5
+echo "configure:5194: checking for location of zlib includes" >&5
 case "$with_zlib_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -5187,15 +5216,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:5191: checking for $ac_hdr" >&5
+echo "configure:5220: checking for $ac_hdr" >&5
-#line 5194 "configure"
+#line 5223 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5199: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5228: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5229,7 +5258,7 @@
 echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:5233: checking for location of zlib library" >&5
+echo "configure:5262: checking for location of zlib library" >&5
 case "$with_zlib_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -5254,13 +5283,13 @@
 echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:5258: checking for deflate in -lz" >&5
+echo "configure:5287: checking for deflate in -lz" >&5
 ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
 LIBS="-lz  $LIBS"
-#line 5264 "configure"
+#line 5293 "configure"
@@ -5271,7 +5300,7 @@
 deflate()
 ; return 0; }
 EOF
-if { (eval echo configure:5275: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5304: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5317,7 +5346,7 @@
 echo $ac_n "checking whether to use bzlib""... $ac_c" 1>&6
-echo "configure:5321: checking whether to use bzlib" >&5
+echo "configure:5350: checking whether to use bzlib" >&5
 echo "$ac_t"""$with_bzlib"" 1>&6
 case "$with_bzlib" in
 	"no")	USE_BZIP2=	;;
@@ -5333,7 +5362,7 @@
 echo $ac_n "checking for location of bzlib includes""... $ac_c" 1>&6
-echo "configure:5337: checking for location of bzlib includes" >&5
+echo "configure:5366: checking for location of bzlib includes" >&5
 case "$with_bzlib_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-bzlib-includes." 1>&2; exit 1; }
@@ -5359,15 +5388,15 @@
 do
-echo "configure:5363: checking for $ac_hdr" >&5
+echo "configure:5392: checking for $ac_hdr" >&5
-#line 5366 "configure"
+#line 5395 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5371: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5400: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5401,7 +5430,7 @@
 echo $ac_n "checking for location of bzlib library""... $ac_c" 1>&6
-echo "configure:5405: checking for location of bzlib library" >&5
+echo "configure:5434: checking for location of bzlib library" >&5
 case "$with_bzlib_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-bzlib-libs." 1>&2; exit 1; }
@@ -5426,13 +5455,13 @@
 echo $ac_n "checking for BZ2_bzBuffToBuffCompress in -lbz2""... $ac_c" 1>&6
-echo "configure:5430: checking for BZ2_bzBuffToBuffCompress in -lbz2" >&5
+echo "configure:5459: checking for BZ2_bzBuffToBuffCompress in -lbz2" >&5
 ac_lib_var=`echo bz2'_'BZ2_bzBuffToBuffCompress | sed 'y%./+-%__p_%'`
 LIBS="-lbz2  $LIBS"
-#line 5436 "configure"
+#line 5465 "configure"
@@ -5443,7 +5472,7 @@
 BZ2_bzBuffToBuffCompress()
 ; return 0; }
 EOF
-if { (eval echo configure:5447: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5476: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5491,7 +5520,7 @@
 echo $ac_n "checking whether to use zstd""... $ac_c" 1>&6
-echo "configure:5495: checking whether to use zstd" >&5
+echo "configure:5524: checking whether to use zstd" >&5
 echo "$ac_t"""$with_zstd"" 1>&6
 case "$with_zstd" in
 	"no")	USE_ZSTD=	;;
@@ -5507,7 +5536,7 @@
 echo $ac_n "checking for location of zstd includes""... $ac_c" 1>&6
-echo "configure:5511: checking for location of zstd includes" >&5
+echo "configure:5540: checking for location of zstd includes" >&5
 case "$with_zstd_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-zstd-includes." 1>&2; exit 1; }
@@ -5532,15 +5561,15 @@
 do
-echo "configure:5536: checking for $ac_hdr" >&5
+echo "configure:5565: checking for $ac_hdr" >&5
-#line 5539 "configure"
+#line 5568 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5544: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5573: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5574,7 +5603,7 @@
 echo $ac_n "checking for location of zstd library""... $ac_c" 1>&6
-echo "configure:5578: checking for location of zstd library" >&5
+echo "configure:5607: checking for location of zstd library" >&5
 case "$with_zstd_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-zstd-libs." 1>&2; exit 1; }
@@ -5599,13 +5628,13 @@
 echo $ac_n "checking for ZSTD_compress in -lzstd""... $ac_c" 1>&6
-echo "configure:5603: checking for ZSTD_compress in -lzstd" >&5
+echo "configure:5632: checking for ZSTD_compress in -lzstd" >&5
 ac_lib_var=`echo zstd'_'ZSTD_compress | sed 'y%./+-%__p_%'`
 LIBS="-lzstd  $LIBS"
-#line 5609 "configure"
+#line 5638 "configure"
@@ -5616,7 +5645,7 @@
 ZSTD_compress()
 ; return 0; }
 EOF
-if { (eval echo configure:5620: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5649: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5666,7 +5695,7 @@
 echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:5670: checking for location of External PROJ.4 includes" >&5
+echo "configure:5699: checking for location of External PROJ.4 includes" >&5
 case "$with_proj_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -5692,15 +5721,15 @@
 do
-echo "configure:5696: checking for $ac_hdr" >&5
+echo "configure:5725: checking for $ac_hdr" >&5
-#line 5699 "configure"
+#line 5728 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5704: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5733: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5737,7 +5766,7 @@
 else
 echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:5741: checking External PROJ.4 version" >&5
+echo "configure:5770: checking External PROJ.4 version" >&5
 ac_save_cppflags="$CPPFLAGS"
 CPPFLAGS="$PROJINC $CPPFLAGS"
 if test "$cross_compiling" = yes; then
@@ -5745,7 +5774,7 @@
         echo "$ac_t""unknown (cross-compiling)" 1>&6
 else
-#line 5749 "configure"
+#line 5778 "configure"
 #include <stdio.h>
@@ -5757,7 +5786,7 @@
 EOF
-if { (eval echo configure:5761: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:5790: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      proj_ver=`cat conftestdata`
         echo "$ac_t""$proj_ver" 1>&6
@@ -5782,7 +5811,7 @@
 echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:5786: checking for location of External PROJ.4 library" >&5
+echo "configure:5815: checking for location of External PROJ.4 library" >&5
 case "$with_proj_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -5807,13 +5836,13 @@
 echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:5811: checking for pj_get_def in -lproj" >&5
+echo "configure:5840: checking for pj_get_def in -lproj" >&5
 ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
 LIBS="-lproj  $LIBS"
-#line 5817 "configure"
+#line 5846 "configure"
@@ -5824,7 +5853,7 @@
 pj_get_def()
 ; return 0; }
 EOF
-if { (eval echo configure:5828: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5857: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5858,7 +5887,7 @@
 echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:5862: checking for location of External PROJ.4 data files" >&5
+echo "configure:5891: checking for location of External PROJ.4 data files" >&5
 case "$with_proj_share" in
         { echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -5882,14 +5911,14 @@
 # LOC_CHECK_SHARE does not work when cross compiling
 if test "$cross_compiling" = "yes" ; then
     echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:5886: checking for epsg" >&5
+echo "configure:5915: checking for epsg" >&5
 else
 ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:5893: checking for $PROJSHARE/epsg" >&5
+echo "configure:5922: checking for $PROJSHARE/epsg" >&5
     { echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -5921,7 +5950,7 @@
 # Extract the first word of "nad2bin", so it can be a program name with args.
 set dummy nad2bin; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:5925: checking for $ac_word" >&5
+echo "configure:5954: checking for $ac_word" >&5
 case "$NAD2BIN" in
@@ -5961,7 +5990,7 @@
 echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:5965: checking whether to use regex" >&5
+echo "configure:5994: checking whether to use regex" >&5
 echo "$ac_t"""$with_regex"" 1>&6
 case "$with_regex" in
 	"no")	USE_REGEX=	;;
@@ -5981,7 +6010,7 @@
 echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:5985: checking for location of regex includes" >&5
+echo "configure:6014: checking for location of regex includes" >&5
 case "$with_regex_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -6007,15 +6036,15 @@
 do
-echo "configure:6011: checking for $ac_hdr" >&5
+echo "configure:6040: checking for $ac_hdr" >&5
-#line 6014 "configure"
+#line 6043 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6019: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6048: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6049,7 +6078,7 @@
 echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:6053: checking for location of regex library" >&5
+echo "configure:6082: checking for location of regex library" >&5
 case "$with_regex_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -6074,10 +6103,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:6078: checking for regcomp" >&5
+echo "configure:6107: checking for regcomp" >&5
-#line 6081 "configure"
+#line 6110 "configure"
     which can conflict with char regcomp(); below.  */
@@ -6100,7 +6129,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6104: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6133: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_regcomp=yes"
 else
@@ -6127,13 +6156,13 @@
 echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:6131: checking for regcomp in -lregex" >&5
+echo "configure:6160: checking for regcomp in -lregex" >&5
 ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
 LIBS="-lregex  $LIBS"
-#line 6137 "configure"
+#line 6166 "configure"
@@ -6144,7 +6173,7 @@
 regcomp()
 ; return 0; }
 EOF
-if { (eval echo configure:6148: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6177: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6194,7 +6223,7 @@
 echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:6198: checking whether to use Readline" >&5
+echo "configure:6227: checking whether to use Readline" >&5
 echo "$ac_t"""$with_readline"" 1>&6
 case "$with_readline" in
 	"no")	USE_READLINE=	;;
@@ -6215,7 +6244,7 @@
 echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:6219: checking for location of Readline includes" >&5
+echo "configure:6248: checking for location of Readline includes" >&5
 case "$with_readline_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -6241,15 +6270,15 @@
 do
-echo "configure:6245: checking for $ac_hdr" >&5
+echo "configure:6274: checking for $ac_hdr" >&5
-#line 6248 "configure"
+#line 6277 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6253: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6282: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6285,15 +6314,15 @@
 do
-echo "configure:6289: checking for $ac_hdr" >&5
+echo "configure:6318: checking for $ac_hdr" >&5
-#line 6292 "configure"
+#line 6321 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6297: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6326: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6327,7 +6356,7 @@
 echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:6331: checking for location of Readline library" >&5
+echo "configure:6360: checking for location of Readline library" >&5
 case "$with_readline_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -6352,13 +6381,13 @@
 echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:6356: checking for readline in -lreadline" >&5
+echo "configure:6385: checking for readline in -lreadline" >&5
 ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
 LIBS="-lreadline  $LIBS"
-#line 6362 "configure"
+#line 6391 "configure"
@@ -6369,7 +6398,7 @@
 readline()
 ; return 0; }
 EOF
-if { (eval echo configure:6373: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6402: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6404,13 +6433,13 @@
 echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:6408: checking for add_history in -lhistory" >&5
+echo "configure:6437: checking for add_history in -lhistory" >&5
 ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
 LIBS="-lhistory  $LIBS"
-#line 6414 "configure"
+#line 6443 "configure"
@@ -6421,7 +6450,7 @@
 add_history()
 ; return 0; }
 EOF
-if { (eval echo configure:6425: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6454: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6463,7 +6492,7 @@
 # GDAL option
 echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:6467: checking whether to use GDAL" >&5
+echo "configure:6496: checking whether to use GDAL" >&5
 GDAL_LIBS=
 GDAL_CFLAGS=
@@ -6481,7 +6510,7 @@
   # Extract the first word of "gdal-config", so it can be a program name with args.
 set dummy gdal-config; ac_word=$2
-echo "configure:6485: checking for $ac_word" >&5
+echo "configure:6514: checking for $ac_word" >&5
 case "$GDAL_CONFIG" in
@@ -6536,14 +6565,14 @@
   LIBS="$LIBS $GDAL_LIBS"
   CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 6540 "configure"
+#line 6569 "configure"
 #include <gdal.h>
 int main() {
 GDALOpen("foo", GA_ReadOnly);
 ; return 0; }
 EOF
-if { (eval echo configure:6547: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6576: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
@@ -6552,14 +6581,14 @@
   LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 6556 "configure"
+#line 6585 "configure"
 #include <gdal.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:6563: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6592: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
 else
@@ -6591,7 +6620,7 @@
 # libLAS option
 echo $ac_n "checking whether to use libLAS""... $ac_c" 1>&6
-echo "configure:6595: checking whether to use libLAS" >&5
+echo "configure:6624: checking whether to use libLAS" >&5
 LIBLAS_LIBS=
 LIBLAS_CFLAGS=
@@ -6608,7 +6637,7 @@
   # Extract the first word of "liblas-config", so it can be a program name with args.
 set dummy liblas-config; ac_word=$2
-echo "configure:6612: checking for $ac_word" >&5
+echo "configure:6641: checking for $ac_word" >&5
 case "$LIBLAS_CONFIG" in
@@ -6661,15 +6690,15 @@
 do
-echo "configure:6665: checking for $ac_hdr" >&5
+echo "configure:6694: checking for $ac_hdr" >&5
-#line 6668 "configure"
+#line 6697 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6673: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6702: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6695,14 +6724,14 @@
 done
-#line 6699 "configure"
+#line 6728 "configure"
 #include <liblas/capi/liblas.h>
 int main() {
 LASReader_Create("foo");
 ; return 0; }
 EOF
-if { (eval echo configure:6706: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6735: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
@@ -6710,14 +6739,14 @@
   rm -rf conftest*
-#line 6714 "configure"
+#line 6743 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:6721: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6750: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LAS_LIBS="$LAS_LIBS"
 else
@@ -6750,7 +6779,7 @@
 # PDAL option
 echo $ac_n "checking whether to use PDAL""... $ac_c" 1>&6
-echo "configure:6754: checking whether to use PDAL" >&5
+echo "configure:6783: checking whether to use PDAL" >&5
 # new and currently used way to switch language to C++
 # AC_LANG_PUSH(C++)
@@ -6778,7 +6807,7 @@
   # Extract the first word of "pdal-config", so it can be a program name with args.
 set dummy pdal-config; ac_word=$2
-echo "configure:6782: checking for $ac_word" >&5
+echo "configure:6811: checking for $ac_word" >&5
 case "$PDAL_CONFIG" in
@@ -6828,14 +6857,14 @@
   CFLAGS="$CFLAGS $PDAL_CFLAGS"
   CPPFLAGS="$CPPFLAGS $PDAL_CPPFLAGS $PDAL_INC"
-#line 6832 "configure"
+#line 6861 "configure"
 #include <pdal/PointTable.hpp>
 int main() {
 pdal::PointTable table;
 ; return 0; }
 EOF
-if { (eval echo configure:6839: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6868: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
@@ -6843,14 +6872,14 @@
   rm -rf conftest*
-#line 6847 "configure"
+#line 6876 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:6854: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6883: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   PDAL_LIBS="$PDAL_LIBS"
 else
@@ -6900,7 +6929,7 @@
 # NetCDF option
 echo $ac_n "checking whether to use NetCDF""... $ac_c" 1>&6
-echo "configure:6904: checking whether to use NetCDF" >&5
+echo "configure:6933: checking whether to use NetCDF" >&5
 NETCDF_LIBS=
 NETCDF_CFLAGS=
@@ -6917,7 +6946,7 @@
   # Extract the first word of "nc-config", so it can be a program name with args.
 set dummy nc-config; ac_word=$2
-echo "configure:6921: checking for $ac_word" >&5
+echo "configure:6950: checking for $ac_word" >&5
 case "$NETCDF_CONFIG" in
@@ -6964,14 +6993,14 @@
   LIBS="$LIBS $NETCDF_LIBS"
   CFLAGS="$CFLAGS $NETCDF_CFLAGS"
-#line 6968 "configure"
+#line 6997 "configure"
 #include <netcdf.h>
 int main() {
 nc_create("foo", NC_CLOBBER, NULL);
 ; return 0; }
 EOF
-if { (eval echo configure:6975: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7004: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
@@ -6979,14 +7008,14 @@
   rm -rf conftest*
-#line 6983 "configure"
+#line 7012 "configure"
 #include <netcdf.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:6990: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   NETCDF_LIBS="$NETCDF_LIBS"
 else
@@ -7017,7 +7046,7 @@
 # GEOS option
 echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:7021: checking whether to use GEOS" >&5
+echo "configure:7050: checking whether to use GEOS" >&5
 GEOS_LIBS=
 GEOS_CFLAGS=
@@ -7035,7 +7064,7 @@
   # Extract the first word of "geos-config", so it can be a program name with args.
 set dummy geos-config; ac_word=$2
-echo "configure:7039: checking for $ac_word" >&5
+echo "configure:7068: checking for $ac_word" >&5
 case "$GEOS_CONFIG" in
@@ -7083,15 +7112,15 @@
 do
-echo "configure:7087: checking for $ac_hdr" >&5
+echo "configure:7116: checking for $ac_hdr" >&5
-#line 7090 "configure"
+#line 7119 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7095: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7124: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7130,13 +7159,13 @@
 echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:7134: checking for initGEOS in -lgeos_c" >&5
+echo "configure:7163: checking for initGEOS in -lgeos_c" >&5
 ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
 LIBS="-lgeos_c  $LIBS"
-#line 7140 "configure"
+#line 7169 "configure"
@@ -7147,7 +7176,7 @@
 initGEOS()
 ; return 0; }
 EOF
-if { (eval echo configure:7151: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7180: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7191,7 +7220,7 @@
 echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:7195: checking whether to use TIFF" >&5
+echo "configure:7224: checking whether to use TIFF" >&5
 echo "$ac_t"""$with_tiff"" 1>&6
 case "$with_tiff" in
 	"no")	USE_TIFF=	;;
@@ -7211,7 +7240,7 @@
 echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:7215: checking for location of TIFF includes" >&5
+echo "configure:7244: checking for location of TIFF includes" >&5
 case "$with_tiff_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -7237,15 +7266,15 @@
 do
-echo "configure:7241: checking for $ac_hdr" >&5
+echo "configure:7270: checking for $ac_hdr" >&5
-#line 7244 "configure"
+#line 7273 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7249: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7278: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7279,7 +7308,7 @@
 echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:7283: checking for location of TIFF library" >&5
+echo "configure:7312: checking for location of TIFF library" >&5
 case "$with_tiff_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -7310,13 +7339,13 @@
 echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:7314: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7343: checking for TIFFOpen in -ltiff" >&5
 ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
 LIBS="-ltiff  $LIBS"
-#line 7320 "configure"
+#line 7349 "configure"
@@ -7327,7 +7356,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7331: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7360: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7346,13 +7375,13 @@
-echo "configure:7350: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7379: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $MATHLIB $LIBS"
-#line 7356 "configure"
+#line 7385 "configure"
@@ -7363,7 +7392,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7367: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7396: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7382,13 +7411,13 @@
-echo "configure:7386: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7415: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $LIBS"
-#line 7392 "configure"
+#line 7421 "configure"
@@ -7399,7 +7428,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7403: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7432: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7418,13 +7447,13 @@
-echo "configure:7422: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7451: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 7428 "configure"
+#line 7457 "configure"
@@ -7435,7 +7464,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7439: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7468: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7454,13 +7483,13 @@
-echo "configure:7458: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7487: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $LIBS"
-#line 7464 "configure"
+#line 7493 "configure"
@@ -7471,7 +7500,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7475: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7504: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7490,13 +7519,13 @@
-echo "configure:7494: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7523: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $MATHLIB $LIBS"
-#line 7500 "configure"
+#line 7529 "configure"
@@ -7507,7 +7536,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7511: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7540: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7526,13 +7555,13 @@
-echo "configure:7530: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7559: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $ZLIB $LIBS"
-#line 7536 "configure"
+#line 7565 "configure"
@@ -7543,7 +7572,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7547: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7576: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7562,13 +7591,13 @@
-echo "configure:7566: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7595: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $ZLIB $MATHLIB $LIBS"
-#line 7572 "configure"
+#line 7601 "configure"
@@ -7579,7 +7608,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7583: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7612: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7677,7 +7706,7 @@
 echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:7681: checking whether to use PNG" >&5
+echo "configure:7710: checking whether to use PNG" >&5
 echo "$ac_t"""$with_png"" 1>&6
 case "$with_png" in
 	"no")	USE_PNG=	;;
@@ -7696,7 +7725,7 @@
 echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:7700: checking for location of PNG includes" >&5
+echo "configure:7729: checking for location of PNG includes" >&5
 case "$with_png_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -7722,15 +7751,15 @@
 do
-echo "configure:7726: checking for $ac_hdr" >&5
+echo "configure:7755: checking for $ac_hdr" >&5
-#line 7729 "configure"
+#line 7758 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7734: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7763: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7764,7 +7793,7 @@
 echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:7768: checking for location of PNG library" >&5
+echo "configure:7797: checking for location of PNG library" >&5
 case "$with_png_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -7789,13 +7818,13 @@
 echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:7793: checking for png_read_image in -lpng" >&5
+echo "configure:7822: checking for png_read_image in -lpng" >&5
 ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
 LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 7799 "configure"
+#line 7828 "configure"
@@ -7806,7 +7835,7 @@
 png_read_image()
 ; return 0; }
 EOF
-if { (eval echo configure:7810: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7839: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7848,7 +7877,7 @@
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:7852: checking whether to use PostgreSQL" >&5
+echo "configure:7881: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -7875,7 +7904,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:7879: checking for location of PostgreSQL includes" >&5
+echo "configure:7908: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -7901,15 +7930,15 @@
 do
-echo "configure:7905: checking for $ac_hdr" >&5
+echo "configure:7934: checking for $ac_hdr" >&5
-#line 7908 "configure"
+#line 7937 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7913: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7942: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7947,7 +7976,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:7951: checking for location of PostgreSQL library" >&5
+echo "configure:7980: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -7976,13 +8005,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:7980: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8009: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 7986 "configure"
+#line 8015 "configure"
@@ -7993,7 +8022,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7997: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8026: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8012,13 +8041,13 @@
-echo "configure:8016: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8045: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 8022 "configure"
+#line 8051 "configure"
@@ -8029,7 +8058,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:8033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8062: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8048,13 +8077,13 @@
-echo "configure:8052: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8081: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
-#line 8058 "configure"
+#line 8087 "configure"
@@ -8065,7 +8094,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:8069: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8098: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8084,13 +8113,13 @@
-echo "configure:8088: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8117: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 8094 "configure"
+#line 8123 "configure"
@@ -8101,7 +8130,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:8105: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8134: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8158,13 +8187,13 @@
 ac_save_ldflags="$LDFLAGS"
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:8162: checking for PQcmdTuples in -lpq" >&5
+echo "configure:8191: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 8168 "configure"
+#line 8197 "configure"
@@ -8175,7 +8204,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:8179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8208: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8197,13 +8226,13 @@
-echo "configure:8201: checking for PQcmdTuples in -lpq" >&5
+echo "configure:8230: checking for PQcmdTuples in -lpq" >&5
-#line 8207 "configure"
+#line 8236 "configure"
@@ -8214,7 +8243,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:8218: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8247: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8257,7 +8286,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:8261: checking whether to use MySQL" >&5
+echo "configure:8290: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -8277,7 +8306,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:8281: checking for location of MySQL includes" >&5
+echo "configure:8310: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -8303,15 +8332,15 @@
 do
-echo "configure:8307: checking for $ac_hdr" >&5
+echo "configure:8336: checking for $ac_hdr" >&5
-#line 8310 "configure"
+#line 8339 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8315: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8344: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8348,7 +8377,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:8352: checking for location of MySQL library" >&5
+echo "configure:8381: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -8379,13 +8408,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:8383: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8412: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 8389 "configure"
+#line 8418 "configure"
@@ -8396,7 +8425,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8400: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8429: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8415,13 +8444,13 @@
-echo "configure:8419: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8448: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 8425 "configure"
+#line 8454 "configure"
@@ -8432,7 +8461,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8436: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8465: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8451,13 +8480,13 @@
-echo "configure:8455: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8484: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 8461 "configure"
+#line 8490 "configure"
@@ -8468,7 +8497,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8472: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8501: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8487,13 +8516,13 @@
-echo "configure:8491: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8520: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 8497 "configure"
+#line 8526 "configure"
@@ -8504,7 +8533,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8508: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8537: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8523,13 +8552,13 @@
-echo "configure:8527: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8556: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 8533 "configure"
+#line 8562 "configure"
@@ -8540,7 +8569,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8544: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8573: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8559,13 +8588,13 @@
-echo "configure:8563: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8592: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 8569 "configure"
+#line 8598 "configure"
@@ -8576,7 +8605,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8580: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8609: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8595,13 +8624,13 @@
-echo "configure:8599: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8628: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
 cat > conftest.$ac_ext <<EOF
-#line 8605 "configure"
+#line 8634 "configure"
 #include "confdefs.h"
@@ -8612,7 +8641,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8616: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8645: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8631,13 +8660,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:8635: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8664: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 8641 "configure"
+#line 8670 "configure"
@@ -8648,7 +8677,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8652: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8681: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8738,7 +8767,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
-echo "configure:8742: checking for $ac_word" >&5
+echo "configure:8771: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -8787,10 +8816,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:8791: checking for mysql_server_init" >&5
+echo "configure:8820: checking for mysql_server_init" >&5
-#line 8794 "configure"
+#line 8823 "configure"
     which can conflict with char mysql_server_init(); below.  */
@@ -8816,7 +8845,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:8820: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8849: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -8868,7 +8897,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:8872: checking whether to use SQLite" >&5
+echo "configure:8901: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -8888,7 +8917,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:8892: checking for location of SQLite includes" >&5
+echo "configure:8921: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -8914,15 +8943,15 @@
 do
-echo "configure:8918: checking for $ac_hdr" >&5
+echo "configure:8947: checking for $ac_hdr" >&5
-#line 8921 "configure"
+#line 8950 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:8926: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8955: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -8965,7 +8994,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:8969: checking for location of SQLite library" >&5
+echo "configure:8998: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -8994,13 +9023,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:8998: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9027: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lsqlite3  $LIBS"
-#line 9004 "configure"
+#line 9033 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -9011,7 +9040,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:9015: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9044: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -9030,13 +9059,13 @@
-echo "configure:9034: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9063: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 9040 "configure"
+#line 9069 "configure"
@@ -9047,7 +9076,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:9051: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9080: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9066,13 +9095,13 @@
-echo "configure:9070: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9099: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 9076 "configure"
+#line 9105 "configure"
@@ -9083,7 +9112,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:9087: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9116: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9102,13 +9131,13 @@
-echo "configure:9106: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9135: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 9112 "configure"
+#line 9141 "configure"
@@ -9119,7 +9148,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:9123: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9152: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9194,7 +9223,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:9198: checking whether to use OpenGL" >&5
+echo "configure:9227: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -9228,7 +9257,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:9232: checking for location of OpenGL includes" >&5
+echo "configure:9261: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -9254,15 +9283,15 @@
 do
-echo "configure:9258: checking for $ac_hdr" >&5
+echo "configure:9287: checking for $ac_hdr" >&5
-#line 9261 "configure"
+#line 9290 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9266: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9295: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9296,7 +9325,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:9300: checking for location of OpenGL library" >&5
+echo "configure:9329: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -9325,13 +9354,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:9329: checking for glBegin in -lGL" >&5
+echo "configure:9358: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 9335 "configure"
+#line 9364 "configure"
@@ -9342,7 +9371,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9346: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9375: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9361,13 +9390,13 @@
-echo "configure:9365: checking for glBegin in -lGL" >&5
+echo "configure:9394: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 9371 "configure"
+#line 9400 "configure"
@@ -9378,7 +9407,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9382: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9411: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9397,13 +9426,13 @@
-echo "configure:9401: checking for glBegin in -lGL" >&5
+echo "configure:9430: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 9407 "configure"
+#line 9436 "configure"
@@ -9414,7 +9443,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9418: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9447: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9433,13 +9462,13 @@
-echo "configure:9437: checking for glBegin in -lGL" >&5
+echo "configure:9466: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 9443 "configure"
+#line 9472 "configure"
@@ -9450,7 +9479,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9454: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9483: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9512,13 +9541,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:9516: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9545: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 9522 "configure"
+#line 9551 "configure"
@@ -9529,7 +9558,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:9533: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9562: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9548,13 +9577,13 @@
-echo "configure:9552: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9581: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 9558 "configure"
+#line 9587 "configure"
@@ -9565,7 +9594,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:9569: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9598: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9612,10 +9641,10 @@
 LIBS=" $OPENGLLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:9616: checking for glXCreatePbuffer" >&5
+echo "configure:9645: checking for glXCreatePbuffer" >&5
-#line 9619 "configure"
+#line 9648 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -9638,7 +9667,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9642: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9671: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -9675,10 +9704,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:9679: checking for glXCreateGLXPixmap" >&5
+echo "configure:9708: checking for glXCreateGLXPixmap" >&5
-#line 9682 "configure"
+#line 9711 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -9701,7 +9730,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9705: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9734: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -9744,7 +9773,7 @@
 echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:9748: checking for location of OpenGL framework" >&5
+echo "configure:9777: checking for location of OpenGL framework" >&5
 case "$with_opengl_framework" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -9768,15 +9797,15 @@
 do
-echo "configure:9772: checking for $ac_hdr" >&5
+echo "configure:9801: checking for $ac_hdr" >&5
-#line 9775 "configure"
+#line 9804 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9780: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9809: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9812,10 +9841,10 @@
 LIBS="-framework OpenGL -framework AGL -framework ApplicationServices  $LIBS"
 LDFLAGS="$OPENGLPATH $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:9816: checking for glBegin" >&5
+echo "configure:9845: checking for glBegin" >&5
-#line 9819 "configure"
+#line 9848 "configure"
     which can conflict with char glBegin(); below.  */
@@ -9838,7 +9867,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9842: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9871: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -9875,10 +9904,10 @@
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:9879: checking for gluBeginCurve" >&5
+echo "configure:9908: checking for gluBeginCurve" >&5
-#line 9882 "configure"
+#line 9911 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -9901,7 +9930,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9905: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9934: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -9949,7 +9978,7 @@
-echo "configure:9953: checking for location of OpenGL includes" >&5
+echo "configure:9982: checking for location of OpenGL includes" >&5
@@ -9975,15 +10004,15 @@
 do
-echo "configure:9979: checking for $ac_hdr" >&5
+echo "configure:10008: checking for $ac_hdr" >&5
-#line 9982 "configure"
+#line 10011 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9987: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10016: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10017,7 +10046,7 @@
-echo "configure:10021: checking for location of OpenGL library" >&5
+echo "configure:10050: checking for location of OpenGL library" >&5
@@ -10042,18 +10071,18 @@
 ac_save_libs="$LIBS"
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:10046: checking for OpenGL library" >&5
+echo "configure:10075: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 10050 "configure"
+#line 10079 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:10057: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10086: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -10077,18 +10106,18 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:10081: checking for GLU library" >&5
+echo "configure:10110: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
-#line 10085 "configure"
+#line 10114 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:10092: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10121: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -10137,7 +10166,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:10141: checking whether to use ODBC" >&5
+echo "configure:10170: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -10156,7 +10185,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:10160: checking for location of ODBC includes" >&5
+echo "configure:10189: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -10182,15 +10211,15 @@
 do
-echo "configure:10186: checking for $ac_hdr" >&5
+echo "configure:10215: checking for $ac_hdr" >&5
-#line 10189 "configure"
+#line 10218 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10194: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10223: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10224,7 +10253,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:10228: checking for location of ODBC library" >&5
+echo "configure:10257: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -10249,13 +10278,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:10253: checking for SQLConnect in -lodbc" >&5
+echo "configure:10282: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 10259 "configure"
+#line 10288 "configure"
@@ -10266,7 +10295,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:10270: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10299: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10291,13 +10320,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:10295: checking for SQLConnect in -liodbc" >&5
+echo "configure:10324: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 10301 "configure"
+#line 10330 "configure"
@@ -10308,7 +10337,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:10312: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10341: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10333,11 +10362,11 @@
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:10337: checking for ODBC library" >&5
+echo "configure:10366: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 10341 "configure"
+#line 10370 "configure"
 #include <windows.h>
 #include <sql.h>
@@ -10345,7 +10374,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:10349: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10378: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -10394,7 +10423,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:10398: checking whether to use FFTW" >&5
+echo "configure:10427: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -10413,7 +10442,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:10417: checking for location of FFTW includes" >&5
+echo "configure:10446: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -10439,15 +10468,15 @@
 do
-echo "configure:10443: checking for $ac_hdr" >&5
+echo "configure:10472: checking for $ac_hdr" >&5
-#line 10446 "configure"
+#line 10475 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10451: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10480: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10475,15 +10504,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:10479: checking for $ac_hdr" >&5
+echo "configure:10508: checking for $ac_hdr" >&5
-#line 10482 "configure"
+#line 10511 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10487: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10516: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10511,15 +10540,15 @@
 do
-echo "configure:10515: checking for $ac_hdr" >&5
+echo "configure:10544: checking for $ac_hdr" >&5
-#line 10518 "configure"
+#line 10547 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10523: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10552: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10565,7 +10594,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:10569: checking for location of FFTW library" >&5
+echo "configure:10598: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -10590,13 +10619,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:10594: checking for fftw_execute in -lfftw3" >&5
+echo "configure:10623: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 10600 "configure"
+#line 10629 "configure"
@@ -10607,7 +10636,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:10611: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10640: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10632,13 +10661,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:10636: checking for fftwnd_one in -lfftw" >&5
+echo "configure:10665: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 10642 "configure"
+#line 10671 "configure"
@@ -10649,7 +10678,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:10653: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10682: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10674,13 +10703,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:10678: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:10707: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 10684 "configure"
+#line 10713 "configure"
@@ -10691,7 +10720,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:10695: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10724: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10748,7 +10777,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:10752: checking whether to use BLAS" >&5
+echo "configure:10781: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -10769,7 +10798,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:10773: checking for location of BLAS includes" >&5
+echo "configure:10802: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -10789,7 +10818,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:10793: checking for location of BLAS library" >&5
+echo "configure:10822: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -10815,15 +10844,15 @@
 do
-echo "configure:10819: checking for $ac_hdr" >&5
+echo "configure:10848: checking for $ac_hdr" >&5
-#line 10822 "configure"
+#line 10851 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10827: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10856: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10858,13 +10887,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:10862: checking for dnrm2_ in -lblas" >&5
+echo "configure:10891: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 10868 "configure"
+#line 10897 "configure"
@@ -10875,7 +10904,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:10879: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10908: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10894,13 +10923,13 @@
-echo "configure:10898: checking for dnrm2_ in -lblas" >&5
+echo "configure:10927: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 10904 "configure"
+#line 10933 "configure"
@@ -10911,7 +10940,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:10915: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10944: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10955,13 +10984,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:10959: checking for ATL_xerbla in -latlas" >&5
+echo "configure:10988: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 10965 "configure"
+#line 10994 "configure"
@@ -10972,7 +11001,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:10976: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11005: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10987,13 +11016,13 @@
 if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
   echo "$ac_t""yes" 1>&6
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:10991: checking for sgemm_ in -lf77blas" >&5
+echo "configure:11020: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 10997 "configure"
+#line 11026 "configure"
@@ -11004,7 +11033,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:11008: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11037: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11019,13 +11048,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:11023: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:11052: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 11029 "configure"
+#line 11058 "configure"
@@ -11036,7 +11065,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:11040: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11069: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11082,16 +11111,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:11086: checking for sgemm in $vlib_flags" >&5
+echo "configure:11115: checking for sgemm in $vlib_flags" >&5
-#line 11088 "configure"
+#line 11117 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:11095: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11124: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -11109,13 +11138,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:11113: checking for sgemm_ in -lblas" >&5
+echo "configure:11142: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas  $LIBS"
-#line 11119 "configure"
+#line 11148 "configure"
@@ -11126,7 +11155,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:11130: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11159: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11141,13 +11170,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:11145: checking for dgemm_ in -ldgemm" >&5
+echo "configure:11174: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 11151 "configure"
+#line 11180 "configure"
@@ -11158,7 +11187,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:11162: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11191: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11173,13 +11202,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:11177: checking for sgemm_ in -lsgemm" >&5
+echo "configure:11206: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 11183 "configure"
+#line 11212 "configure"
@@ -11190,7 +11219,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:11194: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11223: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11224,13 +11253,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:11228: checking for acosp in -lsunmath" >&5
+echo "configure:11257: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 11234 "configure"
+#line 11263 "configure"
@@ -11241,7 +11270,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:11245: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11274: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11256,13 +11285,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:11260: checking for sgemm_ in -lsunperf" >&5
+echo "configure:11289: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 11266 "configure"
+#line 11295 "configure"
@@ -11273,7 +11302,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:11277: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11306: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11303,13 +11332,13 @@
 # Generic BLAS library
-echo "configure:11307: checking for sgemm_ in -lblas" >&5
+echo "configure:11336: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 11313 "configure"
+#line 11342 "configure"
@@ -11320,7 +11349,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:11324: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11353: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11359,7 +11388,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:11363: checking whether to use LAPACK" >&5
+echo "configure:11392: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -11384,7 +11413,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:11388: checking for location of LAPACK includes" >&5
+echo "configure:11417: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -11404,7 +11433,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:11408: checking for location of LAPACK library" >&5
+echo "configure:11437: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -11430,15 +11459,15 @@
 do
-echo "configure:11434: checking for $ac_hdr" >&5
+echo "configure:11463: checking for $ac_hdr" >&5
-#line 11437 "configure"
+#line 11466 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11442: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11471: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11470,10 +11499,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:11474: checking for dsegv_" >&5
+echo "configure:11503: checking for dsegv_" >&5
-#line 11477 "configure"
+#line 11506 "configure"
     which can conflict with char dsegv_(); below.  */
@@ -11496,7 +11525,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11500: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11529: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -11523,13 +11552,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:11527: checking for desgv_ in -llapack" >&5
+echo "configure:11556: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 11533 "configure"
+#line 11562 "configure"
@@ -11540,7 +11569,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:11544: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11573: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11572,13 +11601,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:11576: checking for dgesv_ in -llapack" >&5
+echo "configure:11605: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 11582 "configure"
+#line 11611 "configure"
@@ -11589,7 +11618,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:11593: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11622: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11608,13 +11637,13 @@
-echo "configure:11612: checking for dgesv_ in -llapack" >&5
+echo "configure:11641: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 11618 "configure"
+#line 11647 "configure"
@@ -11625,7 +11654,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:11629: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11658: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11681,7 +11710,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:11685: checking whether to use Cairo" >&5
+echo "configure:11714: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -11713,7 +11742,7 @@
 echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:11717: checking for location of cairo includes" >&5
+echo "configure:11746: checking for location of cairo includes" >&5
 case "$with_cairo_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -11739,15 +11768,15 @@
 do
-echo "configure:11743: checking for $ac_hdr" >&5
+echo "configure:11772: checking for $ac_hdr" >&5
-#line 11746 "configure"
+#line 11775 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11751: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11780: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11783,7 +11812,7 @@
 echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:11787: checking for location of cairo library" >&5
+echo "configure:11816: checking for location of cairo library" >&5
 case "$with_cairo_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -11803,7 +11832,7 @@
 echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:11807: checking for cairo linking flags" >&5
+echo "configure:11836: checking for cairo linking flags" >&5
 case "$with_cairo_ldflags" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -11819,10 +11848,10 @@
 LIBS=" $CAIROLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:11823: checking for cairo_create" >&5
+echo "configure:11852: checking for cairo_create" >&5
-#line 11826 "configure"
+#line 11855 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -11845,7 +11874,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11849: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11878: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -11879,10 +11908,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:11883: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:11912: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 11886 "configure"
+#line 11915 "configure"
     which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below.  */
@@ -11905,7 +11934,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11909: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11938: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
 else
@@ -11938,10 +11967,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:11942: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:11971: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 11945 "configure"
+#line 11974 "configure"
     which can conflict with char cairo_xlib_surface_get_xrender_format(); below.  */
@@ -11964,7 +11993,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11968: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11997: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
 else
@@ -12006,7 +12035,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:12010: checking whether to use FreeType" >&5
+echo "configure:12039: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -12025,7 +12054,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:12029: checking for location of FreeType includes" >&5
+echo "configure:12058: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -12051,15 +12080,15 @@
 do
-echo "configure:12055: checking for $ac_hdr" >&5
+echo "configure:12084: checking for $ac_hdr" >&5
-#line 12058 "configure"
+#line 12087 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12063: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12092: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12093,7 +12122,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:12097: checking for location of FreeType library" >&5
+echo "configure:12126: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -12118,13 +12147,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:12122: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:12151: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 12128 "configure"
+#line 12157 "configure"
@@ -12135,7 +12164,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:12139: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12168: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12176,7 +12205,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:12180: checking whether to use NLS" >&5
+echo "configure:12209: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -12196,10 +12225,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:12200: checking for gettext" >&5
+echo "configure:12229: checking for gettext" >&5
-#line 12203 "configure"
+#line 12232 "configure"
     which can conflict with char gettext(); below.  */
@@ -12222,7 +12251,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12226: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12255: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -12240,13 +12269,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:12244: checking for gettext in -lintl" >&5
+echo "configure:12273: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 12250 "configure"
+#line 12279 "configure"
@@ -12257,7 +12286,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:12261: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12290: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12292,7 +12321,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:12296: checking whether to use C++" >&5
+echo "configure:12325: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -12308,7 +12337,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:12312: checking for $ac_word" >&5
+echo "configure:12341: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -12337,7 +12366,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:12341: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:12370: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -12348,12 +12377,12 @@
 cat > conftest.$ac_ext << EOF
-#line 12352 "configure"
+#line 12381 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:12357: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12386: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -12379,19 +12408,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:12383: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:12412: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:12388: checking whether we are using GNU C++" >&5
+echo "configure:12417: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:12395: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:12424: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -12409,7 +12438,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:12413: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:12442: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -12447,7 +12476,7 @@
    'void exit (int);'
 do
-#line 12451 "configure"
+#line 12480 "configure"
 #include <stdlib.h>
 $ac_declaration
@@ -12455,7 +12484,7 @@
 exit (42);
 ; return 0; }
 EOF
-if { (eval echo configure:12459: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12488: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   echo "configure: failed program was:" >&5
@@ -12465,14 +12494,14 @@
 fi
 rm -f conftest*
-#line 12469 "configure"
+#line 12498 "configure"
 $ac_declaration
 int main() {
 exit (42);
 ; return 0; }
 EOF
-if { (eval echo configure:12476: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12505: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   break
 else
@@ -12501,7 +12530,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:12505: checking whether to use openDWG" >&5
+echo "configure:12534: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -12521,7 +12550,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:12525: checking for location of openDGW includes" >&5
+echo "configure:12554: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -12547,15 +12576,15 @@
 do
-echo "configure:12551: checking for $ac_hdr" >&5
+echo "configure:12580: checking for $ac_hdr" >&5
-#line 12554 "configure"
+#line 12583 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12559: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12588: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12589,7 +12618,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:12593: checking for location of openDWG library" >&5
+echo "configure:12622: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -12630,7 +12659,7 @@
 echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:12634: checking whether to use POSIX threads" >&5
+echo "configure:12663: checking whether to use POSIX threads" >&5
 echo "$ac_t"""$with_pthread"" 1>&6
 case "$with_pthread" in
 	"no")	USE_PTHREAD=	;;
@@ -12650,7 +12679,7 @@
 echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:12654: checking for location of POSIX threads includes" >&5
+echo "configure:12683: checking for location of POSIX threads includes" >&5
 case "$with_pthread_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -12676,15 +12705,15 @@
 do
-echo "configure:12680: checking for $ac_hdr" >&5
+echo "configure:12709: checking for $ac_hdr" >&5
-#line 12683 "configure"
+#line 12712 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12688: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12717: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12718,7 +12747,7 @@
 echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:12722: checking for location of POSIX threads library" >&5
+echo "configure:12751: checking for location of POSIX threads library" >&5
 case "$with_pthread_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -12743,10 +12772,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:12747: checking for pthread_create" >&5
+echo "configure:12776: checking for pthread_create" >&5
-#line 12750 "configure"
+#line 12779 "configure"
     which can conflict with char pthread_create(); below.  */
@@ -12769,7 +12798,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12773: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12802: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_pthread_create=yes"
 else
@@ -12796,13 +12825,13 @@
 echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:12800: checking for pthread_create in -lpthread" >&5
+echo "configure:12829: checking for pthread_create in -lpthread" >&5
 ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
 LIBS="-lpthread  $LIBS"
-#line 12806 "configure"
+#line 12835 "configure"
@@ -12813,7 +12842,7 @@
 pthread_create()
 ; return 0; }
 EOF
-if { (eval echo configure:12817: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12846: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12863,7 +12892,7 @@
 echo $ac_n "checking whether to use OpenMP""... $ac_c" 1>&6
-echo "configure:12867: checking whether to use OpenMP" >&5
+echo "configure:12896: checking whether to use OpenMP" >&5
 echo "$ac_t"""$with_openmp"" 1>&6
 case "$with_openmp" in
 	"no")	USE_OPENMP=	;;
@@ -12884,7 +12913,7 @@
 echo $ac_n "checking for location of OpenMP includes""... $ac_c" 1>&6
-echo "configure:12888: checking for location of OpenMP includes" >&5
+echo "configure:12917: checking for location of OpenMP includes" >&5
 case "$with_openmp_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-openmp-includes." 1>&2; exit 1; }
@@ -12910,15 +12939,15 @@
 do
-echo "configure:12914: checking for $ac_hdr" >&5
+echo "configure:12943: checking for $ac_hdr" >&5
-#line 12917 "configure"
+#line 12946 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12922: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12951: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12956,7 +12985,7 @@
 echo $ac_n "checking for location of OpenMP library""... $ac_c" 1>&6
-echo "configure:12960: checking for location of OpenMP library" >&5
+echo "configure:12989: checking for location of OpenMP library" >&5
 case "$with_openmp_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-openmp-libs." 1>&2; exit 1; }
@@ -12981,10 +13010,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for GOMP_parallel_start""... $ac_c" 1>&6
-echo "configure:12985: checking for GOMP_parallel_start" >&5
+echo "configure:13014: checking for GOMP_parallel_start" >&5
-#line 12988 "configure"
+#line 13017 "configure"
     which can conflict with char GOMP_parallel_start(); below.  */
@@ -13007,7 +13036,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13011: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13040: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_GOMP_parallel_start=yes"
 else
@@ -13034,13 +13063,13 @@
 echo $ac_n "checking for GOMP_parallel_start in -lgomp""... $ac_c" 1>&6
-echo "configure:13038: checking for GOMP_parallel_start in -lgomp" >&5
+echo "configure:13067: checking for GOMP_parallel_start in -lgomp" >&5
 ac_lib_var=`echo gomp'_'GOMP_parallel_start | sed 'y%./+-%__p_%'`
 LIBS="-lgomp  $LIBS"
-#line 13044 "configure"
+#line 13073 "configure"
@@ -13051,7 +13080,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13055: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13084: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13124,7 +13153,7 @@
 echo $ac_n "checking whether to use OpenCL""... $ac_c" 1>&6
-echo "configure:13128: checking whether to use OpenCL" >&5
+echo "configure:13157: checking whether to use OpenCL" >&5
 echo "$ac_t"""$with_opencl"" 1>&6
 case "$with_opencl" in
 	"no")	USE_OPENCL=	;;
@@ -13144,7 +13173,7 @@
 echo $ac_n "checking for location of OpenCL includes""... $ac_c" 1>&6
-echo "configure:13148: checking for location of OpenCL includes" >&5
+echo "configure:13177: checking for location of OpenCL includes" >&5
 case "$with_opencl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opencl-includes." 1>&2; exit 1; }
@@ -13171,15 +13200,15 @@
 do
-echo "configure:13175: checking for $ac_hdr" >&5
+echo "configure:13204: checking for $ac_hdr" >&5
-#line 13178 "configure"
+#line 13207 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13183: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13212: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13219,10 +13248,10 @@
 LIBS="-framework OpenCL  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for clGetPlatformInfo""... $ac_c" 1>&6
-echo "configure:13223: checking for clGetPlatformInfo" >&5
+echo "configure:13252: checking for clGetPlatformInfo" >&5
-#line 13226 "configure"
+#line 13255 "configure"
     which can conflict with char clGetPlatformInfo(); below.  */
@@ -13245,7 +13274,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13249: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13278: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_clGetPlatformInfo=yes"
 else
@@ -13284,15 +13313,15 @@
 do
-echo "configure:13288: checking for $ac_hdr" >&5
+echo "configure:13317: checking for $ac_hdr" >&5
-#line 13291 "configure"
+#line 13320 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13296: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13325: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13325,7 +13354,7 @@
     # With OpenCL library directory
 echo $ac_n "checking for location of OpenCL library""... $ac_c" 1>&6
-echo "configure:13329: checking for location of OpenCL library" >&5
+echo "configure:13358: checking for location of OpenCL library" >&5
 case "$with_opencl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opencl-libs." 1>&2; exit 1; }
@@ -13349,13 +13378,13 @@
 echo $ac_n "checking for clGetPlatformInfo in -lOpenCL""... $ac_c" 1>&6
-echo "configure:13353: checking for clGetPlatformInfo in -lOpenCL" >&5
+echo "configure:13382: checking for clGetPlatformInfo in -lOpenCL" >&5
 ac_lib_var=`echo OpenCL'_'clGetPlatformInfo | sed 'y%./+-%__p_%'`
 LIBS="-lOpenCL  $LIBS"
-#line 13359 "configure"
+#line 13388 "configure"
@@ -13366,7 +13395,7 @@
 clGetPlatformInfo()
 ; return 0; }
 EOF
-if { (eval echo configure:13370: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13399: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13426,7 +13455,7 @@
      fi
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:13430: checking for special C compiler options needed for large files" >&5
+echo "configure:13459: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -13434,7 +13463,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 13438 "configure"
+#line 13467 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -13450,7 +13479,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13454: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13483: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
@@ -13459,7 +13488,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 13463 "configure"
+#line 13492 "configure"
@@ -13475,7 +13504,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13479: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13508: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -13502,11 +13531,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:13506: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:13535: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
       cat > conftest.$ac_ext <<EOF
-#line 13510 "configure"
+#line 13539 "configure"
 #include "confdefs.h"
@@ -13522,14 +13551,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13526: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13555: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   cat conftest.$ac_ext >&5
   rm -rf conftest*
-#line 13533 "configure"
+#line 13562 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -13547,7 +13576,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13551: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13580: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -13573,11 +13602,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:13577: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:13606: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 13581 "configure"
+#line 13610 "configure"
@@ -13593,14 +13622,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13597: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13626: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13604 "configure"
+#line 13633 "configure"
 #define _LARGE_FILES 1
@@ -13618,7 +13647,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13622: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13651: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -13644,25 +13673,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:13648: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13677: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 13652 "configure"
+#line 13681 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13659: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13688: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13666 "configure"
+#line 13695 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -13671,7 +13700,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13675: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13704: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -13703,25 +13732,25 @@
 ac_save_cflags=${CFLAGS}
 CFLAGS="$LFS_CFLAGS ${ac_save_cflags}"
-echo "configure:13707: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13736: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 13711 "configure"
+#line 13740 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13718: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13747: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13725 "configure"
+#line 13754 "configure"
 #include <stdio.h>
@@ -13730,7 +13759,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13734: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13763: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
 else
@@ -13760,18 +13789,18 @@
    # If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
    echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:13764: checking for fseeko" >&5
+echo "configure:13793: checking for fseeko" >&5
 ac_cv_func_fseeko=no
-#line 13768 "configure"
+#line 13797 "configure"
 #include <stdio.h>
 int main() {
 return fseeko && fseeko (stdin, 0, 0);
 ; return 0; }
 EOF
-if { (eval echo configure:13775: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13804: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_func_fseeko=yes
 else
@@ -13788,10 +13817,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:13792: checking if system supports Large Files at all" >&5
+echo "configure:13821: checking if system supports Large Files at all" >&5
-#line 13795 "configure"
+#line 13824 "configure"
 #include <stdio.h>
@@ -13823,7 +13852,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:13827: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13856: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in	2018-02-11 21:32:57 UTC (rev 72229)
+++ grass/trunk/configure.in	2018-02-11 21:39:35 UTC (rev 72230)
@@ -489,6 +489,14 @@
 AC_MSG_RESULT(no)
+AC_MSG_CHECKING(for int64_t)
+AC_TRY_COMPILE([#include <sys/types.h>],[int64_t x;],[
+AC_MSG_RESULT(yes)
+AC_DEFINE(HAVE_INT64_T)
+AC_MSG_RESULT(no)
 AC_MSG_CHECKING(for W11)
 case "$enable_w11" in
 	yes|no)	AC_MSG_RESULT("$enable_w11")	;;
Modified: grass/trunk/include/config.h.in
--- grass/trunk/include/config.h.in	2018-02-11 21:32:57 UTC (rev 72229)
+++ grass/trunk/include/config.h.in	2018-02-11 21:39:35 UTC (rev 72230)
@@ -89,9 +89,12 @@
 /* define uid_t type */
 #undef uid_t
-/* define if "long long" is available */
+/* define if "long long int" is available */
 #undef HAVE_LONG_LONG_INT
+/* define if "int64_t" is available */
+#undef HAVE_INT64_T
 /* Define the return type of signal handlers */
 #define RETSIGTYPE int
Modified: grass/trunk/include/gis.h
--- grass/trunk/include/gis.h	2018-02-11 21:32:57 UTC (rev 72229)
+++ grass/trunk/include/gis.h	2018-02-11 21:39:35 UTC (rev 72230)
@@ -581,6 +581,23 @@
 typedef double DCELL;
 typedef float FCELL;
+/* 64 bit signed integer */
+#ifdef __MINGW32__
+typedef __int64 grass_int64;
+#elif HAVE_INT64_T
+#include <sys/types.h>
+typedef int64_t grass_int64;
+#elif HAVE_LONG_LONG_INT
+typedef long long int grass_int64;
+#elif HAVE_LARGEFILES
+typedef off_t grass_int64;
+#else
+#error "no 64 bit integer available"
+#endif
+/* LCELL = large CELL, proposed new raster data type */
+typedef grass_int64 LCELL;
 struct _Color_Value_
     DCELL value;
