[GRASS-SVN] r72255 - grass/trunk/raster/r.in.gdal
svn_grass at osgeo.org
Mon Feb 19 11:54:10 PST 2018
Author: martinl
Date: 2018-02-19 11:54:10 -0800 (Mon, 19 Feb 2018)
New Revision: 72255
grass/trunk/raster/r.in.gdal/proj.c
r.in.gdal: print only proj comparision when -j flag is given (r.in.gdal -j is mostly used in scripts)
Modified: grass/trunk/raster/r.in.gdal/proj.c
--- grass/trunk/raster/r.in.gdal/proj.c 2018-02-18 18:59:08 UTC (rev 72254)
+++ grass/trunk/raster/r.in.gdal/proj.c 2018-02-19 19:54:10 UTC (rev 72255)
@@ -254,14 +254,16 @@
proj_units->value[i_value]);
- strcat(error_msg,
- _("\nIn case of no significant differences in the projection definitions,"
- " use the -o flag to ignore them and use"
- " current location definition.\n"));
- strcat(error_msg,
- _("Consider generating a new location from the input dataset using "
- "the 'location' parameter.\n"));
+ if (!check_only) {
+ strcat(error_msg,
+ _("\nIn case of no significant differences in the projection definitions,"
+ " use the -o flag to ignore them and use"
+ " current location definition.\n"));
+ strcat(error_msg,
+ _("Consider generating a new location from the input dataset using "
+ "the 'location' parameter.\n"));
if (check_only)
msg_fn = G_warning;
else
