[GRASS-SVN] r72258 - in grass/trunk: raster/r.external raster/r.in.gdal vector/v.external vector/v.in.ogr
svn_grass at osgeo.org
Wed Feb 21 00:40:03 PST 2018
Author: mmetz
Date: 2018-02-21 00:40:03 -0800 (Wed, 21 Feb 2018)
New Revision: 72258
grass/trunk/raster/r.external/proj.c
grass/trunk/raster/r.in.gdal/proj.c
grass/trunk/vector/v.external/proj.c
grass/trunk/vector/v.in.ogr/proj.c
r.in.gdal/r.external/v.in.ogr/v.external: sync projection check
Modified: grass/trunk/raster/r.external/proj.c
--- grass/trunk/raster/r.external/proj.c 2018-02-20 20:51:54 UTC (rev 72257)
+++ grass/trunk/raster/r.external/proj.c 2018-02-21 08:40:03 UTC (rev 72258)
@@ -254,19 +254,21 @@
proj_units->value[i_value]);
- strcat(error_msg,
- _("\nIn case of no significant differences in the projection definitions,"
- " use the -o flag to ignore them and use"
- " current location definition.\n"));
- strcat(error_msg,
- _("Consider generating a new location from the input dataset using "
- "the 'location' parameter.\n"));
+ if (!check_only) {
+ strcat(error_msg,
+ _("\nIn case of no significant differences in the projection definitions,"
+ " use the -o flag to ignore them and use"
+ " current location definition.\n"));
+ strcat(error_msg,
+ _("Consider generating a new location from the input dataset using "
+ "the 'location' parameter.\n"));
if (check_only)
msg_fn = G_warning;
else
msg_fn = G_fatal_error;
- msg_fn(error_msg);
+ msg_fn("%s", error_msg);
if (check_only) {
GDALClose(hDS);
exit(EXIT_FAILURE);
Modified: grass/trunk/raster/r.in.gdal/proj.c
--- grass/trunk/raster/r.in.gdal/proj.c 2018-02-20 20:51:54 UTC (rev 72257)
+++ grass/trunk/raster/r.in.gdal/proj.c 2018-02-21 08:40:03 UTC (rev 72258)
@@ -268,7 +268,7 @@
msg_fn = G_warning;
else
if (check_only) {
GDALClose(hDS);
exit(EXIT_FAILURE);
Modified: grass/trunk/vector/v.external/proj.c
--- grass/trunk/vector/v.external/proj.c 2018-02-20 20:51:54 UTC (rev 72257)
+++ grass/trunk/vector/v.external/proj.c 2018-02-21 08:40:03 UTC (rev 72258)
@@ -347,19 +347,21 @@
- strcat(error_msg,
- strcat(error_msg,
+ strcat(error_msg,
+ strcat(error_msg,
if (check_only)
msg_fn = G_warning;
else
if (check_only) {
ds_close(hDS);
exit(EXIT_FAILURE);
Modified: grass/trunk/vector/v.in.ogr/proj.c
--- grass/trunk/vector/v.in.ogr/proj.c 2018-02-20 20:51:54 UTC (rev 72257)
+++ grass/trunk/vector/v.in.ogr/proj.c 2018-02-21 08:40:03 UTC (rev 72258)
@@ -462,19 +462,21 @@
- strcat(error_msg,
- strcat(error_msg,
+ strcat(error_msg,
+ strcat(error_msg,
if (check_only)
msg_fn = G_warning;
else
if (check_only) {
ds_close(hDS);
exit(EXIT_FAILURE);
