[GRASS-SVN] r72275 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Sat Feb 24 13:44:20 PST 2018
Author: mmetz
Date: 2018-02-24 13:44:20 -0800 (Sat, 24 Feb 2018)
New Revision: 72275
grass/trunk/lib/vector/Vlib/build.c
Vlib: change topology building messages to verbose messages
Modified: grass/trunk/lib/vector/Vlib/build.c
--- grass/trunk/lib/vector/Vlib/build.c 2018-02-23 23:44:43 UTC (rev 72274)
+++ grass/trunk/lib/vector/Vlib/build.c 2018-02-24 21:44:20 UTC (rev 72275)
@@ -103,6 +103,7 @@
n_lines = dig_build_area_with_line(plus, iline, side, &lines);
G_debug(3, " n_lines = %d", n_lines);
if (n_lines < 1) {
+ G_debug(3, " unable to build area with line %d", iline);
return 0;
} /* area was not built */
@@ -897,18 +898,18 @@
if (build > GV_BUILD_NONE) {
- G_message(_("Number of nodes: %d"), plus->n_nodes);
- G_message(_("Number of primitives: %d"), plus->n_lines);
- G_message(_("Number of points: %d"), plus->n_plines);
- G_message(_("Number of lines: %d"), plus->n_llines);
- G_message(_("Number of boundaries: %d"), plus->n_blines);
- G_message(_("Number of centroids: %d"), plus->n_clines);
+ G_verbose_message(_("Number of nodes: %d"), plus->n_nodes);
+ G_verbose_message(_("Number of primitives: %d"), plus->n_lines);
+ G_verbose_message(_("Number of points: %d"), plus->n_plines);
+ G_verbose_message(_("Number of lines: %d"), plus->n_llines);
+ G_verbose_message(_("Number of boundaries: %d"), plus->n_blines);
+ G_verbose_message(_("Number of centroids: %d"), plus->n_clines);
if (plus->n_flines > 0)
- G_message(_("Number of faces: %d"), plus->n_flines);
+ G_verbose_message(_("Number of faces: %d"), plus->n_flines);
if (plus->n_klines > 0)
- G_message(_("Number of kernels: %d"), plus->n_klines);
+ G_verbose_message(_("Number of kernels: %d"), plus->n_klines);
if (plus->built >= GV_BUILD_AREAS) {
@@ -954,8 +955,8 @@
err_nocentr++;
- G_message(_("Number of areas: %d"), plus->n_areas);
- G_message(_("Number of isles: %d"), plus->n_isles);
+ G_verbose_message(_("Number of areas: %d"), plus->n_areas);
+ G_verbose_message(_("Number of isles: %d"), plus->n_isles);
#if 0
/* not an error, message disabled to avoid confusion */
@@ -981,8 +982,8 @@
else if (build > GV_BUILD_NONE) {
- G_message(_("Number of areas: -"));
- G_message(_("Number of isles: -"));
+ G_verbose_message(_("Number of areas: -"));
+ G_verbose_message(_("Number of isles: -"));
return 1;
