[GRASS-SVN] r72023 - grass/branches/releasebranch_7_2/vector/v.info
Tue Jan 2 13:53:34 PST 2018
Author: neteler
Date: 2018-01-02 13:53:34 -0800 (Tue, 02 Jan 2018)
New Revision: 72023
Added:
   grass/branches/releasebranch_7_2/vector/v.info/testsuite/
   grass/branches/releasebranch_7_2/vector/v.info/local_proto.h
   grass/branches/releasebranch_7_2/vector/v.info/main.c
   grass/branches/releasebranch_7_2/vector/v.info/print.c
v.info: Added layer specific database information to extended metadata flag (trunk, r69535)
Modified: grass/branches/releasebranch_7_2/vector/v.info/local_proto.h
--- grass/branches/releasebranch_7_2/vector/v.info/local_proto.h	2018-01-02 21:48:01 UTC (rev 72022)
+++ grass/branches/releasebranch_7_2/vector/v.info/local_proto.h	2018-01-02 21:53:34 UTC (rev 72023)
@@ -10,8 +10,8 @@
 /* parse.c */
 void parse_args(int, char**,
-		char **, char**,
-		int *, int *, int *);
+                char **, char**,
+                int *, int *, int *);
 /* print.c */
 void format_double(double, char *);
@@ -19,4 +19,4 @@
 void print_topo(const struct Map_info *);
 void print_columns(const struct Map_info *, const char *, const char *);
 void print_info(const struct Map_info *);
-void print_shell(const struct Map_info *);
+void print_shell(const struct Map_info *, const char *);
Modified: grass/branches/releasebranch_7_2/vector/v.info/main.c
--- grass/branches/releasebranch_7_2/vector/v.info/main.c	2018-01-02 21:48:01 UTC (rev 72022)
+++ grass/branches/releasebranch_7_2/vector/v.info/main.c	2018-01-02 21:53:34 UTC (rev 72023)
@@ -83,7 +83,7 @@
     if (shell_flag & SHELL_BASIC) {
-	print_shell(&Map);
+	print_shell(&Map, field_opt);
     if (shell_flag & SHELL_REGION) {
 	print_region(&Map);
Modified: grass/branches/releasebranch_7_2/vector/v.info/print.c
--- grass/branches/releasebranch_7_2/vector/v.info/print.c	2018-01-02 21:48:01 UTC (rev 72022)
+++ grass/branches/releasebranch_7_2/vector/v.info/print.c	2018-01-02 21:53:34 UTC (rev 72023)
@@ -165,12 +165,12 @@
     db_shutdown_driver(driver);
-void print_shell(const struct Map_info *Map)
+void print_shell(const struct Map_info *Map, const char *field_opt)
     int map_type;
     int time_ok, first_time_ok, second_time_ok;
     char timebuff[256];
+    struct field_info *fi;
     struct TimeStamp ts;
     time_ok = first_time_ok = second_time_ok = FALSE;
@@ -263,6 +263,18 @@
     if (Vect_level(Map) > 0) {
         fprintf(stdout, "num_dblinks=%d\n",
                 Vect_get_num_dblinks(Map));
+        if (Vect_get_num_dblinks(Map) > 0) {
+            fi = Vect_get_field2(Map, field_opt);
+            if(fi != NULL) {
+                fprintf(stdout, "attribute_layer_number=%i\n",fi->number);
+                fprintf(stdout, "attribute_layer_name=%s\n",fi->name);
+                fprintf(stdout, "attribute_database=%s\n",fi->database);
+                fprintf(stdout, "attribute_database_driver=%s\n",fi->driver);
+                fprintf(stdout, "attribute_table=%s\n",fi->table);
+                fprintf(stdout, "attribute_primary_key=%s\n",fi->key);
     fprintf(stdout, "projection=%s\n",
