[GRASS-SVN] r72031 - grass/trunk/lib/gis
svn_grass at osgeo.org
Fri Jan 5 12:35:40 PST 2018
Author: mmetz
Date: 2018-01-05 12:35:40 -0800 (Fri, 05 Jan 2018)
New Revision: 72031
grass/trunk/lib/gis/cmprbzip.c
grass/trunk/lib/gis/cmprlz4.c
grass/trunk/lib/gis/cmprzlib.c
grass/trunk/lib/gis/cmprzstd.c
grass/trunk/lib/gis/compress.c
libgis: more informative messages when (de)compression fails
Modified: grass/trunk/lib/gis/cmprbzip.c
--- grass/trunk/lib/gis/cmprbzip.c 2018-01-05 20:33:55 UTC (rev 72030)
+++ grass/trunk/lib/gis/cmprbzip.c 2018-01-05 20:35:40 UTC (rev 72031)
@@ -99,12 +99,23 @@
#else
/* Catch errors early */
- if (src == NULL || dst == NULL)
+ if (src == NULL || dst == NULL) {
+ if (src == NULL)
+ G_warning(_("No source buffer"));
+ if (dst == NULL)
+ G_warning(_("No destination buffer"));
return -1;
- /* Don't do anything if src is empty */
- if (src_sz <= 0)
+ /* Don't do anything if either of these are true */
+ if (src_sz <= 0 || dst_sz <= 0) {
+ if (src_sz <= 0)
+ G_warning(_("Invalid source buffer size %d"), src_sz);
+ if (dst_sz <= 0)
+ G_warning(_("Invalid destination buffer size %d"), dst_sz);
return 0;
/* Output buffer has to be 1% + 600 bytes bigger for single pass compression */
buf = dst;
@@ -127,6 +138,8 @@
100); /* workFactor */
if (err != BZ_OK) {
+ G_warning(_("BZIP2 version %s compression error %d"),
+ BZ2_bzlibVersion(), err);
if (buf != dst)
G_free(buf);
return -1;
@@ -165,12 +178,23 @@
#else
/* Catch error condition */
+ if (src == NULL)
+ if (dst == NULL)
return -2;
- if (src_sz <= 0 || dst_sz <= 0)
+ if (src_sz <= 0)
+ if (dst_sz <= 0)
return 0;
/* Do single pass decompression */
@@ -181,6 +205,8 @@
0); /* verbosity */
if (err != BZ_OK) {
+ G_warning(_("BZIP2 version %s decompression error %d"),
return -1;
@@ -189,6 +215,8 @@
if (nbytes != dst_sz) {
+ /* TODO: it is not an error if destination is larger than needed */
+ G_warning(_("Got uncompressed size %d, expected %d"), (int)nbytes, dst_sz);
return -1;
Modified: grass/trunk/lib/gis/cmprlz4.c
--- grass/trunk/lib/gis/cmprlz4.c 2018-01-05 20:33:55 UTC (rev 72030)
+++ grass/trunk/lib/gis/cmprlz4.c 2018-01-05 20:35:40 UTC (rev 72031)
@@ -7,7 +7,7 @@
* AUTHOR(S): Eric G. Miller <egm2 at jps.net>
* Markus Metz
* PURPOSE: To provide an interface to lz4 for compressing and
- * decompressing data using LZ$. It's primary use is in
+ * decompressing data using LZ4. It's primary use is in
* the storage and reading of GRASS floating point rasters.
* ALGORITHM: https://code.google.com/p/lz4/
@@ -84,12 +84,23 @@
unsigned char *buf;
+ if (src == NULL)
+ if (dst == NULL)
return -1;
+ if (src_sz <= 0)
+ if (dst_sz <= 0)
return 0;
/* Output buffer should be large enough for single pass compression */
buf = dst;
@@ -107,6 +118,7 @@
err = LZ4_compress_default((char *)src, (char *)buf, src_sz, buf_sz);
if (err <= 0) {
+ G_warning(_("LZ4 compression error"));
if (buf != dst)
G_free(buf);
return -1;
@@ -139,21 +151,39 @@
int err, nbytes;
+ if (src == NULL)
+ if (dst == NULL)
return -2;
+ if (src_sz <= 0)
+ if (dst_sz <= 0)
return 0;
/* Do single pass decompress */
err = LZ4_decompress_safe((char *)src, (char *)dst, src_sz, dst_sz);
/* err = LZ4_decompress_fast(src, dst, src_sz); */
+ if (err <= 0) {
+ G_warning(_("LZ4 decompression error"));
+ return -1;
/* Number of bytes inflated to output stream is return value */
nbytes = err;
return -1;
Modified: grass/trunk/lib/gis/cmprzlib.c
--- grass/trunk/lib/gis/cmprzlib.c 2018-01-05 20:33:55 UTC (rev 72030)
+++ grass/trunk/lib/gis/cmprzlib.c 2018-01-05 20:35:40 UTC (rev 72031)
@@ -95,12 +95,23 @@
unsigned char *buf;
+ if (src == NULL)
+ if (dst == NULL)
return -1;
+ if (src_sz <= 0)
+ if (dst_sz <= 0)
return 0;
/* Output buffer has to be 1% + 12 bytes bigger for single pass deflate */
/* buf_sz = (int)((double)dst_sz * 1.01 + (double)12); */
@@ -128,6 +139,8 @@
G__.compression_level); /* level */
if (err != Z_OK) {
+ G_warning(_("ZLIB compression error %d: %s"),
+ (int)err, zError(err));
if (buf != dst)
G_free(buf);
return -1;
@@ -161,12 +174,23 @@
uLong ss, nbytes;
+ if (src == NULL)
+ if (dst == NULL)
return -2;
+ if (src_sz <= 0)
+ if (dst_sz <= 0)
return 0;
ss = src_sz;
@@ -176,14 +200,19 @@
(const Bytef *)src, ss); /* source */
/* If not Z_OK return error -1 */
- if (err != Z_OK)
+ if (err != Z_OK) {
+ G_warning(_("ZLIB decompression error %d: %s"),
+ err, zError(err));
return -1;
* updated buffer size
return -1;
Modified: grass/trunk/lib/gis/cmprzstd.c
--- grass/trunk/lib/gis/cmprzstd.c 2018-01-05 20:33:55 UTC (rev 72030)
+++ grass/trunk/lib/gis/cmprzstd.c 2018-01-05 20:35:40 UTC (rev 72031)
@@ -3,16 +3,16 @@
* -- GRASS Development Team --
* MODULE: GRASS gis library
- * FILENAME: cmprlz4.c
+ * FILENAME: cmprzstd.c
* Markus Metz
- * PURPOSE: To provide an interface to lz4 for compressing and
+ * PURPOSE: To provide an interface to ZSTD for compressing and
+ * decompressing data using ZSTD. It's primary use is in
- * ALGORITHM: https://code.google.com/p/lz4/
- * DATE CREATED: Dec 18 2015
- * COPYRIGHT: (C) 2015 by the GRASS Development Team
+ * ALGORITHM: http://www.zstd.net
+ * DATE CREATED: Dec 18 2017
+ * COPYRIGHT: (C) 2017 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (version 2 or greater). Read the file COPYING that
@@ -97,12 +97,23 @@
#else
+ if (src == NULL)
+ if (dst == NULL)
return -1;
+ if (src_sz <= 0)
+ if (dst_sz <= 0)
return 0;
/* Output buffer has to be larger for single pass compression */
buf = dst;
@@ -120,6 +131,8 @@
err = ZSTD_compress((char *)buf, buf_sz, (char *)src, src_sz, 3);
if (err <= 0 || ZSTD_isError(err)) {
+ G_warning(_("ZSTD compression error %d: %s"),
+ err, ZSTD_getErrorName(err));
if (buf != dst)
G_free(buf);
return -1;
@@ -158,21 +171,39 @@
#else
+ if (src == NULL)
+ if (dst == NULL)
return -2;
+ if (src_sz <= 0)
+ if (dst_sz <= 0)
return 0;
err = ZSTD_decompress((char *)dst, dst_sz, (char *)src, src_sz);
- /* err = LZ4_decompress_fast(src, dst, src_sz); */
+ if (err <= 0 || ZSTD_isError(err)) {
+ return -1;
nbytes = err;
return -1;
Modified: grass/trunk/lib/gis/compress.c
--- grass/trunk/lib/gis/compress.c 2018-01-05 20:33:55 UTC (rev 72030)
+++ grass/trunk/lib/gis/compress.c 2018-01-05 20:35:40 UTC (rev 72031)
@@ -84,6 +84,7 @@
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
+#include <errno.h>
#include <unistd.h>
#include <grass/gis.h>
#include <grass/glocale.h>
@@ -217,9 +218,8 @@
* -1: error
* -2: dst too small
-int
-G_compress(unsigned char *src, int src_sz, unsigned char *dst,
- int dst_sz, int number)
+int G_compress(unsigned char *src, int src_sz, unsigned char *dst,
+ int dst_sz, int number)
if (number < 0 || number >= n_compressors) {
G_fatal_error(_("Request for unsupported compressor"));
@@ -233,9 +233,8 @@
* > 0: number of bytes in dst
* -1: error
-int
-G_expand(unsigned char *src, int src_sz, unsigned char *dst,
+int G_expand(unsigned char *src, int src_sz, unsigned char *dst,
@@ -251,9 +250,19 @@
int bsize, nread, err;
unsigned char *b;
- if (dst == NULL || nbytes < 0)
+ if (dst == NULL || nbytes <= 0) {
+ if (dst == NULL)
+ G_warning(_("No destination buffer allocated"));
+ if (nbytes <= 0)
+ G_warning(_("Invalid destination buffer size %d"), nbytes);
return -2;
+ if (rbytes <= 0) {
+ G_warning(_("Invalid read size %d"), nbytes);
+ return -2;
bsize = rbytes;
/* Our temporary input buffer for read */
@@ -269,9 +278,18 @@
nread += err;
} while (err > 0 && nread < bsize);
+ if (err <= 0) {
+ if (err == 0)
+ G_warning(_("Unable to read %d bytes: end of file"), rbytes);
+ else
+ G_warning(_("Unable to read %d bytes: %s"), rbytes, strerror(errno));
+ return -1;
/* If the bsize if less than rbytes and we didn't get an error.. */
- if (nread < rbytes && err > 0) {
+ if (nread < rbytes) {
G_free(b);
+ G_warning("Unable to read %d bytes, got %d bytes", rbytes, nread);
return -1;
@@ -287,6 +305,7 @@
else if (b[0] != G_COMPRESSED_YES) {
/* We're not at the start of a row */
G_free(b);
+ G_warning("Read error: We're not at the start of a row");
return -1;
/* Okay it's a compressed row */
