[GRASS-SVN] r72060 - in grass/trunk/raster/r.in.ascii: . testsuite testsuite/data
svn_grass at osgeo.org
Tue Jan 9 05:09:18 PST 2018
Author: lucadelu
Date: 2018-01-09 05:09:18 -0800 (Tue, 09 Jan 2018)
New Revision: 72060
Added:
grass/trunk/raster/r.in.ascii/testsuite/
grass/trunk/raster/r.in.ascii/testsuite/data/
grass/trunk/raster/r.in.ascii/testsuite/data/input_ascii.txt
grass/trunk/raster/r.in.ascii/testsuite/test_r_in_ascii.py
r.in.ascii: added tests, thanks to Sunveer Singh during Google Code-in 2017
Added: grass/trunk/raster/r.in.ascii/testsuite/data/input_ascii.txt
--- grass/trunk/raster/r.in.ascii/testsuite/data/input_ascii.txt (rev 0)
+++ grass/trunk/raster/r.in.ascii/testsuite/data/input_ascii.txt 2018-01-09 13:09:18 UTC (rev 72060)
@@ -0,0 +1,13 @@
+north: 220542
+south: 220528
+east: 638492
+west: 638478
+rows: 7
+cols: 7
+3 2 5 3 5 3 4
+1 4 5 5 5 * 4
+2 1 * 3 5 5 2
+4 2 4 4 4 5 4
+4 4 2 * 5 2 4
+1 2 1 1 2 2 2
+5 4 1 2 3 4 2
Property changes on: grass/trunk/raster/r.in.ascii/testsuite/data/input_ascii.txt
___________________________________________________________________
Added: svn:mime-type
+ text/plain
Added: svn:keywords
+ Author Date Id
Added: svn:eol-style
+ native
Added: grass/trunk/raster/r.in.ascii/testsuite/test_r_in_ascii.py
--- grass/trunk/raster/r.in.ascii/testsuite/test_r_in_ascii.py (rev 0)
+++ grass/trunk/raster/r.in.ascii/testsuite/test_r_in_ascii.py 2018-01-09 13:09:18 UTC (rev 72060)
@@ -0,0 +1,118 @@
+Name: r.in.ascii test
+Purpose: Tests r.in.ascii and its flags/options.
+Author: Sunveer Singh, Google Code-in 2017
+Copyright: (C) 2017 by Sunveer Singh and the GRASS Development Team
+Licence: This program is free software under the GNU General Public
+ License (>=v2). Read the file COPYING that comes with GRASS
+ for details.
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+from grass.script.core import read_command
+INPUT_NOQUOTES="""north: 4299000.00
+south: 4247000.00
+east: 528000.00
+west: 500000.00
+rows: 10
+cols: 15
+null: -9999
+1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
+1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 """
+INPUT_TSV="""north: 4299000.00
+south: 4247000.00
+east: 528000.00
+west: 500000.00
+rows: 10
+cols: 15
+null: -9999
+1\ 2\ 3\ 4\ 5\ 6\ 7\ 8\ 9\ 10\ 11\ 12\ 13\ 14\ 15
+1\ 2\ 3\ 4\ 5\ 6\ 7\ 8\ 9\ 10\ 11\ 12\ 13\ 14\ 15 """
+INPUT_UNCOMMON="""north: 4299000.00
+south: 4247000.00
+east: 528000.00
+west: 500000.00
+rows: 10
+cols: 15
+null: -9999
+1@ 2@ 3@ 4@ 5@ 6@ 7@ 8@ 9@ 10@ 11@ 12@ 13@ 14@ 15
+1@ 2@ 3@ 4@ 5@ 6@ 7@ 8@ 9@ 10@ 11@ 12@ 13@ 14@ 15 """
+class SimpleCsvTestCase(TestCase):
+ ascii_test = 'ascii'
+ @classmethod
+ def setUpClass(cls):
+ """Use temporary region settings"""
+ cls.use_temp_region()
+ cls.runModule('g.region', n=4299000.00, s=4247000.00, e=528000.00, w=500000.00)
+ @classmethod
+ def tearDownClass(cls):
+ cls.del_temp_region()
+ def tearDown(self):
+ """Remove the raster map after each test method"""
+ self.runModule('g.remove', flags='f', type='raster', pattern=self.ascii_test)
+ def test_no_text_delimeter(self):
+ """Test loading no quotes"""
+ self.assertModule('r.in.ascii', input='-', output=self.ascii_test,
+ type='CELL', stdin_=INPUT_NOQUOTES)
+ self.assertRasterMinMax(map=self.ascii_test, refmin=1, refmax=15,
+ msg="ascii_test in degrees must be between 1 and 15")
+ def test_text_delimeter(self):
+ """Testing with external file"""
+ self.assertModule('r.in.ascii', input='input_ascii.txt', output=self.ascii_test,
+ type='CELL')
+ self.assertRasterMinMax(map=self.ascii_test, refmin=1, refmax=5,
+ msg="ascii_test in degrees must be between 1 and 5")
+ def test_tsv(self):
+ """Test loading TSV"""
+ type='CELL', stdin_=INPUT_TSV)
+ def test_uncommon_delims(self):
+ """Test loading with uncommon delimiters"""
+ type='CELL', stdin_=INPUT_UNCOMMON)
+if __name__ == '__main__':
+ test()
Property changes on: grass/trunk/raster/r.in.ascii/testsuite/test_r_in_ascii.py
+ text/x-python
+ native
