[GRASS-SVN] r72064 - in grass/trunk/imagery/i.vi: . testsuite
svn_grass at osgeo.org
Tue Jan 9 23:20:04 PST 2018
Author: lucadelu
Date: 2018-01-09 23:20:04 -0800 (Tue, 09 Jan 2018)
New Revision: 72064
Added:
grass/trunk/imagery/i.vi/testsuite/
grass/trunk/imagery/i.vi/testsuite/test_vi.py
i.vi: added tests, thanks to Sunveer Singh during Google Code-in 2017
Added: grass/trunk/imagery/i.vi/testsuite/test_vi.py
--- grass/trunk/imagery/i.vi/testsuite/test_vi.py (rev 0)
+++ grass/trunk/imagery/i.vi/testsuite/test_vi.py 2018-01-10 07:20:04 UTC (rev 72064)
@@ -0,0 +1,89 @@
+Name: i.vi test
+Purpose: Tests i.vi and its flags/options.
+Author: Sunveer Singh, Google Code-in 2017
+Copyright: (C) 2017 by Sunveer Singh and the GRASS Development Team
+Licence: This program is free software under the GNU General Public
+ License (>=v2). Read the file COPYING that comes with GRASS
+ for details.
+from grass.gunittest.case import TestCase
+class TestReport(TestCase):
+ blue='lsat5_1987_10'
+ green='lsat5_1987_20'
+ red='lsat5_1987_30'
+ nir= 'lsat5_1987_40'
+ @classmethod
+ def setUpClass(cls):
+ """Use temporary region settings"""
+ cls.runModule("g.region", raster='lsat5_1987_30')
+ cls.use_temp_region()
+ @classmethod
+ def tearDownClass(cls):
+ cls.runModule("g.remove", flags='f', type="raster", name="ipvi")
+ cls.runModule("g.remove", flags='f', type="raster", name="dvi")
+ cls.runModule("g.remove", flags='f', type="raster", name="sr")
+ cls.runModule("g.remove", flags='f', type="raster", name="evi")
+ cls.runModule("g.remove", flags='f', type="raster", name="evi2")
+ cls.runModule("g.remove", flags='f', type="raster", name="gari")
+ cls.runModule("g.remove", flags='f', type="raster", name="gemi")
+ cls.del_temp_region()
+ def test_vinameipvi(self):
+ """Testing viname ipvi"""
+ map_output = 'ipvi'
+ self.assertModule('i.vi', red=self.red, nir=self.nir, output=map_output, viname='ipvi')
+ self.assertRasterMinMax(map=map_output, refmin=0.0454545454545, refmax=0.906666666667,
+ msg="ipvi in degrees must be between 0.0454545454545 and 0.906666666667")
+ def test_vinamedvi(self):
+ """Testing viname dvi"""
+ map_output = 'dvi'
+ self.assertModule('i.vi', red=self.red, nir=self.nir, viname='dvi', output=map_output)
+ self.assertRasterMinMax(map=map_output, refmin=-0.33, refmax=0.56,
+ msg="dvi in percent must be between -0.32 and 0.52")
+ def test_vinamesr(self):
+ """Testing viname sr"""
+ map_output = 'sr'
+ self.assertModule('i.vi', red=self.red, nir=self.nir, blue=self.blue, output=map_output, viname='sr')
+ self.assertRasterMinMax(map=map_output, refmin=0.04, refmax=9.73,
+ msg="sr in percent must be between 0.04 and 9.72")
+ def test_vinameevi(self):
+ """Testing viname evi"""
+ map_output = 'evi'
+ self.assertModule('i.vi', red=self.red, nir=self.nir, blue=self.blue, output=map_output, viname='evi')
+ self.assertRasterMinMax(map=map_output, refmin=-8.12414050428e+16, refmax=4.45061610234e+17,
+ msg="evi in degrees must be between -8.12 and 4.45061610234e+17")
+ def test_vinameevi2(self):
+ """Testing viname evi2"""
+ map_output = 'evi2'
+ self.assertModule('i.vi', red=self.red, nir=self.nir, output=map_output, viname='evi2')
+ self.assertRasterMinMax(map=map_output, refmin=-0.33, refmax=0.74,
+ msg="evi2 in degrees must be between -0.33 and 0.74")
+ def test_vinamegari(self):
+ """Testing viname gari"""
+ map_output = 'gari'
+ self.assertModule('i.vi', red=self.red, nir=self.nir, blue=self.blue, green=self.green, output=map_output, viname='gari')
+ self.assertRasterMinMax(map=map_output, refmin=-1.58244128083e+17, refmax='inf',
+ msg="gari in degrees must be between -1.58")
+ def test_vinamegemi(self):
+ """Testing viname gemi"""
+ map_output = 'gemi'
+ self.assertModule('i.vi', red=self.red, nir=self.nir, output=map_output, viname='gemi')
+ self.assertRasterMinMax(map=map_output, refmin=-221.69, refmax=0.97,
+ msg="gemi in degrees must be between -221.69 and 0.97")
+if __name__ == '__main__':
+ from grass.gunittest.main import test
+ test()
Property changes on: grass/trunk/imagery/i.vi/testsuite/test_vi.py
___________________________________________________________________
Added: svn:mime-type
+ text/x-python
Added: svn:eol-style
+ native
