[GRASS-SVN] r72076 - grass-addons/grass7/raster/r.hazard.flood
svn_grass at osgeo.org
Mon Jan 15 01:41:07 PST 2018
Author: neteler
Date: 2018-01-15 01:41:07 -0800 (Mon, 15 Jan 2018)
New Revision: 72076
grass-addons/grass7/raster/r.hazard.flood/r.hazard.flood.html
grass-addons/grass7/raster/r.hazard.flood/r.hazard.flood.py
r.hazard.flood addon: MTI acronym explained; msg cosmetics
Modified: grass-addons/grass7/raster/r.hazard.flood/r.hazard.flood.html
--- grass-addons/grass7/raster/r.hazard.flood/r.hazard.flood.html 2018-01-13 08:11:05 UTC (rev 72075)
+++ grass-addons/grass7/raster/r.hazard.flood/r.hazard.flood.html 2018-01-15 09:41:07 UTC (rev 72076)
@@ -1,5 +1,9 @@
<h2>DESCRIPTION</h2>
-<em>r.hazard.flood</em> Implementation of a fast procedure to detect flood prone areas
+<em>r.hazard.flood</em> is an implementation of a fast procedure to detect
+flood prone areas. It is based on a simple procedure that exploits the
+correlation between flood exposure and a Modified Topographic Index (MTI),
+calculated on the basis of the DTM and strongly influenced by the resolution
+of this latter.
<h3>Important:</h3>
Before running the program, the region should be aligned perfectly with the
@@ -8,7 +12,7 @@
nonsense.
<h2>NOTES</h2>
-<p>The availability of new technologies for the measurement of surface
+The availability of new technologies for the measurement of surface
elevation has addressed the lack of high resolution elevation data, and
this has led to an increase in the attraction of DEM-based automated
procedures for hydrological applications including the delineation of
@@ -50,23 +54,25 @@
<h3>Dependencies</h3>
<em>
-<a href="r.area.html">r.area</a>,
+<a href="r.area.html">r.area</a>
</em>
<h2>CITE AS</h2>
-<p><em>Di Leo M., Manfreda S., Fiorentino M., An automated procedure for
+<em>Di Leo M., Manfreda S., Fiorentino M., An automated procedure for
the detection of flood prone areas: r.hazard.flood, Geomatics Workbooks
n.10, 2011.
-(<a href="http://geomatica.como.polimi.it/workbooks/n10/GW10-FOSS4Git_2011.pdf">PDF</a>)</em>
+(<a href="http://geomatica.como.polimi.it/workbooks/n10/GW10-FOSS4Git_2011.pdf">PDF</a>)
+</em>
<h2>REFERENCES</h2>
-<p><em>Manfreda S., Di Leo M., Sole A., Detection of Flood Prone Areas using
+<em>Manfreda S., Di Leo M., Sole A., Detection of Flood Prone Areas using
Digital Elevation Models, Journal of Hydrologic Engineering,
(10.1061/(ASCE)HE.1943-5584.0000367), 2011.</em>
<h2>AUTHOR</h2>
-<p>Margherita Di Leo (dileomargherita AT gmail DOT com)
+Margherita Di Leo (dileomargherita AT gmail DOT com)
<p>
<i>Last changed: $Date$</i>
Modified: grass-addons/grass7/raster/r.hazard.flood/r.hazard.flood.py
--- grass-addons/grass7/raster/r.hazard.flood/r.hazard.flood.py 2018-01-13 08:11:05 UTC (rev 72075)
+++ grass-addons/grass7/raster/r.hazard.flood/r.hazard.flood.py 2018-01-15 09:41:07 UTC (rev 72076)
@@ -42,7 +42,8 @@
#% type: string
#% gisprompt: new,raster,raster
#% key_desc: MTI
-#% description: Name of output MTI raster map
+#% label: Name of output MTI raster map
+#% description: Name of the output Modified Topographic Index (MTI) raster map
#% required: yes
#%END
@@ -137,11 +138,11 @@
# Cleaning up
grass.message("Cleaning up.. ")
- grass.run_command('g.remove', flags='f', type='raster', name='r_clump')
- grass.run_command('g.remove', flags='f', type='raster', name='r_flood_th')
- grass.run_command('g.remove', flags='f', type='raster', name='r_flood')
+ grass.run_command('g.remove', flags='f', type='raster', name='r_clump', quiet=True)
+ grass.run_command('g.remove', flags='f', type='raster', name='r_flood_th', quiet=True)
+ grass.run_command('g.remove', flags='f', type='raster', name='r_flood', quiet=True)
- grass.message(_('Done.'))
+ grass.message(_('Raster maps <%s> and <%s> calculated') % (r_mti, r_flood_map) )
if __name__ == "__main__":
options, flags = grass.parser()
