[GRASS-SVN] r72092 - in grass/branches/releasebranch_7_2/raster: r.series r.series.accumulate
Tue Jan 16 11:15:46 PST 2018
Author: veroandreo
Date: 2018-01-16 11:15:46 -0800 (Tue, 16 Jan 2018)
New Revision: 72092
   grass/branches/releasebranch_7_2/raster/r.series.accumulate/r.series.accumulate.html
   grass/branches/releasebranch_7_2/raster/r.series/r.series.html
r.series & r.series.accumulate manual: fix -z and file option description (trunk 72090)
Modified: grass/branches/releasebranch_7_2/raster/r.series/r.series.html
--- grass/branches/releasebranch_7_2/raster/r.series/r.series.html	2018-01-16 19:08:59 UTC (rev 72091)
+++ grass/branches/releasebranch_7_2/raster/r.series/r.series.html	2018-01-16 19:15:46 UTC (rev 72092)
@@ -88,44 +88,51 @@
 <em>r.series</em> can calculate arbitrary quantiles.
 <h3>Memory consumption</h3>
 Memory usage is not an issue, as <em>r.series</em> only needs to hold
 one row from each map at a time.
 <h3>Management of open file limits</h3>
-Number of raster maps to be processed is given by the limit of the
-operating system. For example, both the hard and soft limits are
-typically 1024. The soft limit can be changed with e.g. <tt>ulimit -n 1500</tt>
-(UNIX-based operating systems) but not higher than the hard
-limit. If it is too low, you can as superuser add an entry in
+The maximum number of raster maps that can be processed is given by the
+user-specific limit of the operating system. For example, the soft limits
+for users are typically 1024 files. The soft limit can be changed with e.g.
+<tt>ulimit -n 4096</tt> (UNIX-based operating systems) but it cannot be
+higher than the hard limit. If the latter is too low, you can as superuser
+add an entry in:
 <div class="code"><pre>
 /etc/security/limits.conf
 # <domain>      <type>  <item>         <value>
-your_username  hard    nofile          1500
+your_username  hard    nofile          4096
 </pre></div>
-This would raise the hard limit to 1500 file. Be warned that more
-files open need more RAM. See also the Wiki page
-<a href="http://grasswiki.osgeo.org/wiki/Large_raster_data_processing">Hints for large raster data processing</a>.
+This will raise the hard limit to 4096 files. Also have a look at the
+overall limit of the operating system
+<div class="code"><pre>
+cat /proc/sys/fs/file-max
+</pre></div>
+which on modern Linux systems is several 100,000 files.
 <p>
 For each map a weighting factor can be specified using the
 <em>weights</em> option. Using weights can be meaningful when computing
-sum or average of maps with different temporal extent. The default
-weight is 1.0. The number of weights must be identical with the number
+the sum or average of maps with different temporal extent. The default
+weight is 1.0. The number of weights must be identical to the number
 of input maps and must have the same order. Weights can also be
 specified in the input file.
 <p>
-Use the <em>file</em> option to analyze large amount of raster maps
-without hitting open files limit and the size limit of command line
-arguments. The computation is slower than the <em>input</em> option
-method. For every sinlge row in the output map(s) all input maps are
-opened and closed. The amount of RAM will rise linear with the number
-of specified input maps. The input and file options are mutually
-exclusive. Input is a text file with a new line separated list of
-raster map names and optional weights. As separator between the map
-name and the weight the character "|" must be used.
+Use the <b>-z</b> flag to analyze large amounts of raster maps without
+hitting open files limit and the <em>file</em> option to avoid hitting
+the size limit of command line arguments.
+Note that the computation using the <em>file</em> option is slower
+than with the <em>input</em> option.
+For every single row in the output map(s) all input maps are
+opened and closed. The amount of RAM will rise linearly with the number
+of specified input maps. The <em>input</em> and <em>file</em> options are
+mutually exclusive: the former is a comma separated list of raster map
+names and the latter is a text file with a new line separated list of
+raster map names and optional weights. As separator between the map name
+and the weight the character "|" must be used.
 <h2>EXAMPLES</h2>
Modified: grass/branches/releasebranch_7_2/raster/r.series.accumulate/r.series.accumulate.html
--- grass/branches/releasebranch_7_2/raster/r.series.accumulate/r.series.accumulate.html	2018-01-16 19:08:59 UTC (rev 72091)
+++ grass/branches/releasebranch_7_2/raster/r.series.accumulate/r.series.accumulate.html	2018-01-16 19:15:46 UTC (rev 72092)
@@ -88,32 +88,38 @@
 <em>range=0,inf</em> to ignore negative values, or
 <em>range=-inf,-200.4</em> to ignore values above -200.4).
 <p>
-The number of input raster maps to be processed is given by the limit of the
-<tt>ulimit -n 1500</tt> (UNIX-based operating systems) but not higher
-than the hard limit. If it is too low, you can as superuser add an
-entry in
+add an entry in:
 </pre></div>
+</pre></div>
 <p>
-number of specified input maps. The input and file options are
-mutually exclusive. Input is a text file with a new line separated
-list of raster map names and optional weights. As separator between
-the map name and the weight the character "|" must be used.
+raster map names.
 <h2>EXAMPLES</h2>
