[GRASS-SVN] r72170 -	grass-addons/grass7/raster/r.sentinel/r.sentinel.import
    svn_grass at osgeo.org
    Sun Jan 28 06:47:02 PST 2018
Author: martinl
Date: 2018-01-28 06:47:02 -0800 (Sun, 28 Jan 2018)
New Revision: 72170
   grass-addons/grass7/raster/r.sentinel/r.sentinel.import/r.sentinel.import.py
r.sentinel.import: add -o for reprojecting data
Modified: grass-addons/grass7/raster/r.sentinel/r.sentinel.import/r.sentinel.import.py
--- grass-addons/grass7/raster/r.sentinel/r.sentinel.import/r.sentinel.import.py	2018-01-28 10:47:25 UTC (rev 72169)
+++ grass-addons/grass7/raster/r.sentinel/r.sentinel.import/r.sentinel.import.py	2018-01-28 14:47:02 UTC (rev 72170)
@@ -31,6 +31,10 @@
 #% description: File name pattern to import
 #%end
 #%flag
+#% key: o
+#% description: Reproject raster data using r.import if needed
+#%end
+#%flag
 #% key: l
 #% description: Link raster data instead of importing
 #%end
@@ -38,7 +42,9 @@
 #% key: c
 #% description: Import cloud masks as vector maps
 #%end
+#%rules
+#% exclusive: -l,-o
+#%end
 import os
 import sys
 import re
@@ -76,17 +82,21 @@
         return files
-    def import_products(self, link=False):
+    def import_products(self, reproject=False, link=False):
+        if link:
+            module = 'r.external'
+        else:
+            if reproject:
+                module = 'r.import'
+            else:
+                module = 'r.in.gdal'
         for f in self.files:
-            self._import_file(f, link)
+            self._import_file(f, module)
-    def _import_file(self, filename, link=False):
-        module = 'r.external' if link else 'r.import'
+    def _import_file(self, filename, module):
         mapname = os.path.splitext(os.path.basename(filename))[0]
-        if link:
-            gs.message('Linking <{}>...'.format(mapname))
-        else:
-            gs.message('Importing <{}>...'.format(mapname))
+        gs.message('Processing <{}>...'.format(mapname))
         try:
             gs.run_command(module, input=filename, output=mapname)
         except CalledModuleError as e:
@@ -113,7 +123,7 @@
     importer.filter(options['pattern'])
-    importer.import_products(flags['l'])
+    importer.import_products(flags['o'], flags['l'])
     if flags['c']:
         importer.import_cloud_masks()
