[GRASS-SVN] r72175 - grass/trunk/doc/vector/v.example
svn_grass at osgeo.org
Sun Jan 28 07:16:19 PST 2018
Author: martinl
Date: 2018-01-28 07:16:19 -0800 (Sun, 28 Jan 2018)
New Revision: 72175
grass/trunk/doc/vector/v.example/main.c
v.example: use std vector and db error handlers
Modified: grass/trunk/doc/vector/v.example/main.c
--- grass/trunk/doc/vector/v.example/main.c 2018-01-28 15:10:14 UTC (rev 72174)
+++ grass/trunk/doc/vector/v.example/main.c 2018-01-28 15:16:19 UTC (rev 72175)
@@ -92,16 +92,20 @@
else
open3d = WITHOUT_Z;
+ /* Set error handler for input vector map */
+ Vect_set_error_handler_io(&In, NULL);
/* Open new vector for reading/writing */
if (0 > Vect_open_new(&Out, new->answer, open3d)) {
- Vect_close(&In);
G_fatal_error(_("Unable to create vector map <%s>"), new->answer);
+ /* Set error handler for output vector map */
+ Vect_set_error_handler_io(NULL, &Out);
/* Let's get vector layers db connections information */
Fi = Vect_get_field(&In, 1);
if (!Fi) {
- Vect_close(&In);
G_fatal_error(_("Database connection not defined for layer %d"), 1);
@@ -122,18 +126,19 @@
/* Prepare database for use */
driver = db_start_driver(Fi->driver);
if (driver == NULL) {
- Vect_close(&In);
G_fatal_error(_("Unable to start driver <%s>"), Fi->driver);
+ /* Set error handler for DB driver */
+ db_set_error_handler_driver(driver);
db_set_handle(&handle, Fi->database, NULL);
if (db_open_database(driver, &handle) != DB_OK) {
- Vect_close(&In);
G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
Fi->database, Fi->driver);
db_set_string(&table_name, Fi->table);
if (db_describe_table(driver, &table_name, &table) != DB_OK) {
- Vect_close(&In);
G_fatal_error(_("Unable to describe table <%s>"), Fi->table);
ncols = db_get_table_number_of_columns(table);
