[GRASS-SVN] r72181 - grass/branches/releasebranch_7_2/raster/r.random.surface
svn_grass at osgeo.org
Sun Jan 28 07:37:11 PST 2018
Author: neteler
Date: 2018-01-28 07:37:11 -0800 (Sun, 28 Jan 2018)
New Revision: 72181
grass/branches/releasebranch_7_2/raster/r.random.surface/calcsurf.c
grass/branches/releasebranch_7_2/raster/r.random.surface/init.c
grass/branches/releasebranch_7_2/raster/r.random.surface/main.c
grass/branches/releasebranch_7_2/raster/r.random.surface/ransurf.h
grass/branches/releasebranch_7_2/raster/r.random.surface/save.c
grass/branches/releasebranch_7_2/raster/r.random.surface/zero.c
r.random.surface: rename variable Surface to RSurface to avoid variable clash with GDAL on EPEL7 (trunk, r72179)
Modified: grass/branches/releasebranch_7_2/raster/r.random.surface/calcsurf.c
--- grass/branches/releasebranch_7_2/raster/r.random.surface/calcsurf.c 2018-01-28 15:33:50 UTC (rev 72180)
+++ grass/branches/releasebranch_7_2/raster/r.random.surface/calcsurf.c 2018-01-28 15:37:11 UTC (rev 72181)
@@ -93,14 +93,14 @@
if (ODD(Row)) {
for (Col = Cs - 1; Col >= 0; Col--) {
G_percent(Count++, MapCount, 1);
- Surface[Row][Col] =
+ RSurface[Row][Col] =
MakePP(Row, Col, OutRows, OutCols, Randoms, BigF);
else {
for (Col = 0; Col < Cs; Col++) {
@@ -113,10 +113,10 @@
if (ODD(Row)) {
if (CellBuffer[Col] == 0)
- Surface[Row][Col] = 0.0;
+ RSurface[Row][Col] = 0.0;
else {
@@ -124,10 +124,10 @@
else {
else {
Modified: grass/branches/releasebranch_7_2/raster/r.random.surface/init.c
--- grass/branches/releasebranch_7_2/raster/r.random.surface/init.c 2018-01-28 15:33:50 UTC (rev 72180)
+++ grass/branches/releasebranch_7_2/raster/r.random.surface/init.c 2018-01-28 15:37:11 UTC (rev 72181)
@@ -24,9 +24,9 @@
Rs = Rast_window_rows();
Cs = Rast_window_cols();
- Surface = (double **)G_malloc(Rs * sizeof(double *));
+ RSurface = (double **)G_malloc(Rs * sizeof(double *));
for (row = 0; row < Rs; row++)
- Surface[row] = (double *)G_malloc(Cs * sizeof(double));
+ RSurface[row] = (double *)G_malloc(Cs * sizeof(double));
G_get_set_window(&Region);
EW = Region.ew_res;
Modified: grass/branches/releasebranch_7_2/raster/r.random.surface/main.c
--- grass/branches/releasebranch_7_2/raster/r.random.surface/main.c 2018-01-28 15:33:50 UTC (rev 72180)
+++ grass/branches/releasebranch_7_2/raster/r.random.surface/main.c 2018-01-28 15:37:11 UTC (rev 72181)
@@ -31,7 +31,7 @@
#include "local_proto.h"
BIGF BigF;
-double **Surface, NS, EW, FilterSD, AllMaxDist, *Norm;
+double **RSurface, NS, EW, FilterSD, AllMaxDist, *Norm;
int MapCount, FDM, Rs, Cs, Theory;
CELL *CellBuffer;
FILTER *AllFilters, Filter;
Modified: grass/branches/releasebranch_7_2/raster/r.random.surface/ransurf.h
--- grass/branches/releasebranch_7_2/raster/r.random.surface/ransurf.h 2018-01-28 15:33:50 UTC (rev 72180)
+++ grass/branches/releasebranch_7_2/raster/r.random.surface/ransurf.h 2018-01-28 15:37:11 UTC (rev 72181)
@@ -38,7 +38,7 @@
extern BIGF BigF;
-extern double **Surface, NS, EW, FilterSD, AllMaxDist, *Norm;
+extern double **RSurface, NS, EW, FilterSD, AllMaxDist, *Norm;
extern int MapCount, FDM, Rs, Cs, Theory;
extern CELL *CellBuffer;
extern FILTER *AllFilters, Filter;
Modified: grass/branches/releasebranch_7_2/raster/r.random.surface/save.c
--- grass/branches/releasebranch_7_2/raster/r.random.surface/save.c 2018-01-28 15:33:50 UTC (rev 72180)
+++ grass/branches/releasebranch_7_2/raster/r.random.surface/save.c 2018-01-28 15:37:11 UTC (rev 72181)
@@ -26,7 +26,7 @@
if (FDM == -1) {
for (Row = 0; Row < Rs; Row++) {
- Value = Surface[Row][Col];
+ Value = RSurface[Row][Col];
MeanMod += Value;
@@ -37,13 +37,13 @@
DownInterval = UpInterval = Value;
Value = (Value - MeanMod) / FilterSD
+ MeanMod / FilterSD;
Value /= FilterSD;
- Surface[Row][Col] = Value;
+ RSurface[Row][Col] = Value;
if (UpInterval < Value)
UpInterval = Value;
@@ -58,7 +58,7 @@
Rast_get_c_row_nomask(FDM, CellBuffer, Row);
if (CellBuffer[Col] != 0) {
MeanMod += Value;
@@ -77,13 +77,13 @@
Value /= FilterSD;
UpInterval = Value;
@@ -111,7 +111,7 @@
/* normal distribution */
if (Value > UpInterval) {
Value = UpInterval;
@@ -132,7 +132,7 @@
if (Value < CatInfo.Min[Index])
CatInfo.Min[Index] = Value;
- Surface[Row][Col] = 1 + Index;
+ RSurface[Row][Col] = 1 + Index;
@@ -140,7 +140,7 @@
/* mapping to cumulative normal distribution function */
Ratio = (double)(Value - MIN_INTERVAL) /
(MAX_INTERVAL - MIN_INTERVAL);
Index = (int)(Ratio * (SIZE_OF_DISTRIBUTION - 1));
@@ -157,7 +157,7 @@
CatInfo.Min[NormIndex] = Value;
/* NormIndex in range of [0 .. (CatInfo.NumCat-1)] */
- Surface[Row][Col] = 1 + NormIndex;
+ RSurface[Row][Col] = 1 + NormIndex;
@@ -165,7 +165,7 @@
G_percent(Row, Rs, 2);
- CellBuffer[Col] = (CELL) Surface[Row][Col];
+ CellBuffer[Col] = (CELL) RSurface[Row][Col];
Rast_put_row(OutFD, CellBuffer, CELL_TYPE);
Modified: grass/branches/releasebranch_7_2/raster/r.random.surface/zero.c
--- grass/branches/releasebranch_7_2/raster/r.random.surface/zero.c 2018-01-28 15:33:50 UTC (rev 72180)
+++ grass/branches/releasebranch_7_2/raster/r.random.surface/zero.c 2018-01-28 15:37:11 UTC (rev 72181)
@@ -14,6 +14,6 @@
