[GRASS-SVN] r72190 - grass/trunk/rpm
svn_grass at osgeo.org
Sun Jan 28 12:56:20 PST 2018
Author: neteler
Date: 2018-01-28 12:56:20 -0800 (Sun, 28 Jan 2018)
New Revision: 72190
grass/trunk/rpm/grass.spec
rpm/grass.spec: SPEC cleanup as per external review in https://bugzilla.redhat.com/show_bug.cgi?id=1539116
Modified: grass/trunk/rpm/grass.spec
--- grass/trunk/rpm/grass.spec 2018-01-28 20:54:23 UTC (rev 72189)
+++ grass/trunk/rpm/grass.spec 2018-01-28 20:56:20 UTC (rev 72190)
@@ -6,7 +6,9 @@
Release: 1%{?dist}
Summary: GRASS GIS - Geographic Resources Analysis Support System
+%if 0%{?rhel}
Group: Applications/Engineering
+%endif
License: GPLv2+
URL: https://grass.osgeo.org
Source0: https://grass.osgeo.org/%{name}%{shortver}/source/%{name}-%{version}.tar.gz
@@ -89,7 +91,7 @@
%global cpuarch 64
%endif
-Requires: %{name}%{?isa}-libs = %{version}-%{release}
+Requires: %{name}-libs%{?_isa} = %{version}-%{release}
%description
GRASS (Geographic Resources Analysis Support System) is a Geographic
@@ -109,7 +111,6 @@
%package gui
Summary: GRASS GIS GUI
Requires: %{name}%{?isa} = %{version}-%{release}
%description gui
@@ -118,7 +119,7 @@
%package devel
Summary: GRASS GIS development headers
%description devel
@@ -244,36 +245,41 @@
# append shortver to destination ? man pages are unversioned
ln -s %{_libdir}/%{name}-%{version}/docs %{buildroot}%{_docdir}/%{name}%{shortver}
-for file in infrastructure.txt ; do
- iconv -f ISO-8859-1 -t UTF-8 $file > ${file}.tmp && mv -f ${file}.tmp $file
-done
# Make desktop, appdata and icon files available on the system
mv %{buildroot}%{_libdir}/%{name}-%{version}/share/* %{buildroot}%{_datadir}
desktop-file-validate %{buildroot}/%{_datadir}/applications/*.desktop
# EPEL7 fails on url tag, so we ignore failure:
-appstream-util validate-relax --nonet %{buildroot}/%{_datadir}/appdata/*.appdata.xml || echo "Ignoring appstream-util failure"
+appstream-util validate-relax --nonet %{buildroot}/%{_datadir}/appdata/%{name}*.appdata.xml || echo "Ignoring appstream-util failure"
+# as per https://fedoraproject.org/wiki/Packaging:AppData
+mkdir -p %{buildroot}%{_datadir}/metainfo/
+cp %{buildroot}/%{_datadir}/appdata/%{name}*.appdata.xml %{buildroot}%{_datadir}/metainfo/
# Cleanup: nothing to do
#rm -rf %%{buildroot}%%{_prefix}/%%{name}-%%{version}
-# rpm macro for version checking
+# rpm macro for version checking (not from buildroot!)
mkdir -p ${RPM_BUILD_ROOT}%{macrosdir}
cat > ${RPM_BUILD_ROOT}%{macrosdir}/macros.%{name} <<EOF
%%%{name}_version %{version}
EOF
%post
+%if 0%{?rhel}
/bin/touch --no-create %{_datadir}/icons/hicolor &>/dev/null || :
+%endif
%postun
+%if 0%{?rhel}
if [ $1 -eq 0 ] ; then
/usr/bin/gtk-update-icon-cache %{_datadir}/icons/hicolor &>/dev/null || :
fi
+%endif
%posttrans
+%if 0%{?rhel}
+%endif
%post libs -p /sbin/ldconfig
@@ -289,6 +295,7 @@
%{_datadir}/icons/hicolor/*/apps/*
+%{_datadir}/metainfo/
%{_mandir}/man1/*
@@ -312,6 +319,9 @@
%{_libdir}/%{name}-%{version}/include
%changelog
+* Sun Jan 28 2018 Markus Neteler <neteler at mundialis.de> - 7.4.0-2
+- SPEC cleanup as per review in https://bugzilla.redhat.com/show_bug.cgi?id=1539116
* Mon Jan 15 2018 Markus Metz <metz at mundialis.de> - 7.4.0-1
- New upstream version 7.4.0
- Fix grass-devel which needs include/grass and include/Make dirs
