[GRASS-SVN] r72196 - grass-addons/grass7/raster/r.sentinel/r.sentinel.import
svn_grass at osgeo.org
Mon Jan 29 07:49:52 PST 2018
Author: martinl
Date: 2018-01-29 07:49:52 -0800 (Mon, 29 Jan 2018)
New Revision: 72196
grass-addons/grass7/raster/r.sentinel/r.sentinel.import/r.sentinel.import.py
r.sentinel.import: check projection, improve explanation, rename -o flag to -r
Modified: grass-addons/grass7/raster/r.sentinel/r.sentinel.import/r.sentinel.import.py
--- grass-addons/grass7/raster/r.sentinel/r.sentinel.import/r.sentinel.import.py 2018-01-29 11:19:20 UTC (rev 72195)
+++ grass-addons/grass7/raster/r.sentinel/r.sentinel.import/r.sentinel.import.py 2018-01-29 15:49:52 UTC (rev 72196)
@@ -31,7 +31,7 @@
#% description: File name pattern to import
#%end
#%flag
-#% key: o
+#% key: r
#% description: Reproject raster data using r.import if needed
#%end
#%flag
@@ -43,7 +43,7 @@
#% description: Import cloud masks as vector maps
#%end
#%rules
-#% exclusive: -l,-o
+#% exclusive: -l,-r
#%end
import os
import sys
@@ -92,8 +92,27 @@
module = 'r.in.gdal'
for f in self.files:
+ if link or (not link and not reproject):
+ if not self._check_projection(f):
+ gs.fatal('Projection of dataset does not appear to match current location. '
+ 'Force reprojecting dataset by -r flag.')
self._import_file(f, module)
+ def _check_projection(self, filename):
+ try:
+ # module is not so script friedly, so we discard all
+ # warning and errors
+ nuldev = open(os.devnull, 'w+')
+ gs.run_command('r.in.gdal', flags='j',
+ input=filename, quiet=True,
+ stderr = nuldev)
+ nuldev.close()
+ except CalledModuleError as e:
+ return False
+ return True
def _import_file(self, filename, module):
mapname = os.path.splitext(os.path.basename(filename))[0]
gs.message('Processing <{}>...'.format(mapname))
@@ -123,7 +142,7 @@
importer.filter(options['pattern'])
- importer.import_products(flags['o'], flags['l'])
+ importer.import_products(flags['r'], flags['l'])
if flags['c']:
importer.import_cloud_masks()
