[GRASS-SVN] r72942 - grass/trunk/db/db.connect
svn_grass at osgeo.org
Mon Jul 2 09:41:14 PDT 2018
Author: mmetz
Date: 2018-07-02 09:41:14 -0700 (Mon, 02 Jul 2018)
New Revision: 72942
grass/trunk/db/db.connect/main.c
db.connect: use GRASS default, not current parameters as default answer, fix setting from default and from user options (see #3601)
Modified: grass/trunk/db/db.connect/main.c
--- grass/trunk/db/db.connect/main.c 2018-07-02 16:40:02 UTC (rev 72941)
+++ grass/trunk/db/db.connect/main.c 2018-07-02 16:41:14 UTC (rev 72942)
@@ -69,17 +69,18 @@
def->description = _("Overwrite current settings if already initialized");
def->guisection = _("Set");
+ /* the default answers below for driver, database, schema, and group
+ * are current settings, not GRASS default settings */
driver = G_define_standard_option(G_OPT_DB_DRIVER);
driver->options = db_list_drivers();
- driver->answer = (char *) db_get_default_driver_name();
+ driver->answer = "sqlite";
driver->guisection = _("Set");
database = G_define_standard_option(G_OPT_DB_DATABASE);
- database->answer = (char *) db_get_default_database_name();
+ database->answer = "$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db";
database->guisection = _("Set");
schema = G_define_standard_option(G_OPT_DB_SCHEMA);
- schema->answer = (char *) db_get_default_schema_name();
schema->guisection = _("Set");
group = G_define_option();
@@ -87,7 +88,6 @@
group->type = TYPE_STRING;
group->required = NO;
group->multiple = NO;
- group->answer = (char*) db_get_default_group_name();
group->description = _("Default group of database users to which "
"select privilege is granted");
group->guisection = _("Set");
@@ -179,7 +179,6 @@
exit(EXIT_SUCCESS);
if (def->answer) {
db_set_default_connection();
db_get_connection(&conn);
@@ -191,8 +190,8 @@
exit(EXIT_SUCCESS);
- /* set connection */
- db_get_connection(&conn); /* read current */
+ /* do not read current, set new connection from options */
+ G_zero(&conn, sizeof(dbConnection));
if (driver->answer)
conn.driverName = driver->answer;
@@ -207,7 +206,12 @@
conn.group = group->answer;
db_set_connection(&conn);
+ /* check */
+ if (db_get_connection(&conn) != DB_OK) {
+ G_fatal_error(_("Unable to set default database connection"));
+ exit(EXIT_FAILURE);
exit(EXIT_SUCCESS);
