[GRASS-SVN] [GRASS-dev] r72948 - grass/trunk/misc/m.nviz.image
Huidae Cho grass4u at gmail.com
Wed Jul 4 20:20:39 PDT 2018
Anna,
You're right! Good catch. I switched 0 & 1 for write_img once again. It was
my holiday brain... Sorry about that. Fixed in r72951.
Thanks for catching the mistake.
Huidae
On Wed, Jul 4, 2018 at 8:15 PM, Anna Petrášová <kratochanna at gmail.com>
wrote:
> On Wed, Jul 4, 2018 at 3:11 PM <svn_grass at osgeo.org> wrote:
>> Author: hcho
>> Date: 2018-07-04 12:11:33 -0700 (Wed, 04 Jul 2018)
>> New Revision: 72948
>> Modified:
>>    grass/trunk/misc/m.nviz.image/main.c
>>    grass/trunk/misc/m.nviz.image/write_img.c
>> Log:
>> m.nviz.image: Check return value from GS_write_(ppm|tif)
>> Modified: grass/trunk/misc/m.nviz.image/main.c
>> --- grass/trunk/misc/m.nviz.image/main.c        2018-07-03 19:44:31 UTC
>> (rev 72947)
>> +++ grass/trunk/misc/m.nviz.image/main.c        2018-07-04 19:11:33 UTC
>> (rev 72948)
>> @@ -236,7 +236,9 @@
>>      if (strcmp(params->format->answer, "tif") == 0)
>>         ret = write_img(output_name, FORMAT_TIF);
>> -    if (!ret)
>> +    if (ret == 1)
>> +       G_fatal_error(_("Failed to write image"));
>> +    else if (ret == 2)
>>         G_fatal_error(_("Unsupported output format"));
>>      G_done_msg(_("File <%s> created."), output_name);
>> Modified: grass/trunk/misc/m.nviz.image/write_img.c
>> --- grass/trunk/misc/m.nviz.image/write_img.c   2018-07-03 19:44:31 UTC
>> (rev 72947)
>> +++ grass/trunk/misc/m.nviz.image/write_img.c   2018-07-04 19:11:33 UTC
>> (rev 72948)
>> @@ -23,19 +23,20 @@
>>     \param name filename
>> -   \return 1 on success
>> -   \return 0 on failure (unsupported format)
>> +   \return 0 on success
>> +   \return 1 on failure (failed to write image)
>> +   \return 2 on failure (unsupported format)
>>  int write_img(const char *name, int format)
>>      if (format == FORMAT_PPM)
>> -       GS_write_ppm(name);
>> +       return !GS_write_ppm(name);
>>  #ifdef HAVE_TIFFIO_H
>>      else if (format == FORMAT_TIF)
>> -       GS_write_tif(name);
>> +       return !GS_write_tif(name);
>>  #endif
>>      else
>> -       return 0;
>> +       return 2;
>> -    return 1;
>> +    return 0;
> Shouldn't it be
> return GS_write_ppm(name);
> the return code of GS_write_ppm is 1 when it fails, so there shouldn't be
> the negation?
> Anna
>> grass-commit mailing list
>> grass-commit at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-commit
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
Huidae Cho, Ph.D., PE, M.ASCE, CFM, GISP
Senior Geospatial Engineer, MapAnything
Open Source GIS Developer, GRASS GIS Development Team
URL: <http://lists.osgeo.org/pipermail/grass-commit/attachments/20180704/6fecc7e9/attachment.html>
