[GRASS-SVN] r72970 - in grass/trunk: include/defs lib/nviz lib/ogsf misc/m.nviz.image
svn_grass at osgeo.org
Tue Jul 10 09:39:55 PDT 2018
Author: hcho
Date: 2018-07-10 09:39:54 -0700 (Tue, 10 Jul 2018)
New Revision: 72970
grass/trunk/include/defs/ogsf.h
grass/trunk/lib/nviz/render.c
grass/trunk/lib/ogsf/gs2.c
grass/trunk/lib/ogsf/gsd_prim.c
grass/trunk/lib/ogsf/gsx.c
grass/trunk/lib/ogsf/ogsflib.dox
grass/trunk/misc/m.nviz.image/main.c
nviz: Fix double buffering & swapping; Remove GS_set_swap_func (shouldn't be user-settable; ever need to replace the default swapping?)
Modified: grass/trunk/include/defs/ogsf.h
--- grass/trunk/include/defs/ogsf.h 2018-07-10 08:44:19 UTC (rev 72969)
+++ grass/trunk/include/defs/ogsf.h 2018-07-10 16:39:54 UTC (rev 72970)
@@ -185,7 +185,6 @@
int GS_check_cancel(void);
void GS_set_cancel(int);
void GS_set_cxl_func(void (*)(void));
-void GS_set_swap_func(void (*)(void));
/* GS_util.c */
double GS_geodistance(double *, double *, const char *);
Modified: grass/trunk/lib/nviz/render.c
--- grass/trunk/lib/nviz/render.c 2018-07-10 08:44:19 UTC (rev 72969)
+++ grass/trunk/lib/nviz/render.c 2018-07-10 16:39:54 UTC (rev 72970)
@@ -100,7 +100,7 @@
#if defined(OPENGL_X11)
int attributeList[] = { GLX_RGBA, GLX_RED_SIZE, 1,
GLX_GREEN_SIZE, 1, GLX_BLUE_SIZE, 1,
- GLX_DEPTH_SIZE, 1, None
+ GLX_DEPTH_SIZE, 1, GLX_DOUBLEBUFFER, None
XVisualInfo *v;
@@ -135,7 +135,7 @@
#elif defined(OPENGL_AQUA)
int attributeList[] = { AGL_RGBA, AGL_RED_SIZE, 1,
AGL_GREEN_SIZE, 1, AGL_BLUE_SIZE, 1,
- AGL_DEPTH_SIZE, 1, AGL_NONE
+ AGL_DEPTH_SIZE, 1, AGL_DOUBLEBUFFER, AGL_NONE
/* TODO: open mac display */
Modified: grass/trunk/lib/ogsf/gs2.c
--- grass/trunk/lib/ogsf/gs2.c 2018-07-10 08:44:19 UTC (rev 72969)
+++ grass/trunk/lib/ogsf/gs2.c 2018-07-10 16:39:54 UTC (rev 72970)
@@ -119,7 +119,6 @@
Region[0], Region[1], Region[2], Region[3], Gv.scale, first);
Cxl_func = void_func;
- Swap_func = void_func;
if (first) {
Modified: grass/trunk/lib/ogsf/gsd_prim.c
--- grass/trunk/lib/ogsf/gsd_prim.c 2018-07-10 08:44:19 UTC (rev 72969)
+++ grass/trunk/lib/ogsf/gsd_prim.c 2018-07-10 16:39:54 UTC (rev 72970)
@@ -21,12 +21,18 @@
#include <grass/config.h>
-#if defined(OPENGL_X11) || defined(OPENGL_WINDOWS)
+#if defined(OPENGL_X11)
#include <GL/gl.h>
#include <GL/glu.h>
+#include <GL/glx.h>
#include <OpenGL/gl.h>
#include <OpenGL/glu.h>
+#include <AGL/agl.h>
+#elif defined(OPENGL_WINDOWS)
+#include <GL/gl.h>
+#include <GL/glu.h>
+#include <wingdi.h>
#endif
#include <grass/gis.h>
@@ -476,9 +482,14 @@
/* OGLXXX swapbuffers:
glXSwapBuffers(*display, window);
replace display and window */
+ glXSwapBuffers(glXGetCurrentDisplay(), glXGetCurrentDrawable());
+#elif defined(OPENGL_AQUA)
+ aglSwapBuffers(aglGetCurrentContext());
+ SwapBuffers(wglGetCurrentDC());
+#endif
- Swap_func();
return;
Modified: grass/trunk/lib/ogsf/gsx.c
--- grass/trunk/lib/ogsf/gsx.c 2018-07-10 08:44:19 UTC (rev 72969)
+++ grass/trunk/lib/ogsf/gsx.c 2018-07-10 16:39:54 UTC (rev 72970)
@@ -19,7 +19,6 @@
#include <grass/ogsf.h>
void (*Cxl_func) ();
-void (*Swap_func) ();
static int Cxl = 0;
@@ -56,15 +55,3 @@
return;
- \brief Set swap function
- \param pointer to function
-void GS_set_swap_func(void (*f) (void))
- Swap_func = f;
- return;
Modified: grass/trunk/lib/ogsf/ogsflib.dox
--- grass/trunk/lib/ogsf/ogsflib.dox 2018-07-10 08:44:19 UTC (rev 72969)
+++ grass/trunk/lib/ogsf/ogsflib.dox 2018-07-10 16:39:54 UTC (rev 72970)
@@ -311,8 +311,6 @@
- GS_set_SDsurf()
-- GS_set_swap_func()
- GS_set_trans()
- GS_set_twist()
Modified: grass/trunk/misc/m.nviz.image/main.c
--- grass/trunk/misc/m.nviz.image/main.c 2018-07-10 08:44:19 UTC (rev 72969)
+++ grass/trunk/misc/m.nviz.image/main.c 2018-07-10 16:39:54 UTC (rev 72970)
@@ -26,8 +26,6 @@
#include "local_proto.h"
-static void swap_gl();
int main(int argc, char *argv[])
struct GModule *module;
@@ -74,8 +72,6 @@
GS_libinit();
GVL_libinit();
- GS_set_swap_func(swap_gl);
/* define render window */
offscreen = Nviz_new_render_window();
Nviz_init_render_window(offscreen);
@@ -251,8 +247,3 @@
exit(EXIT_SUCCESS);
-void swap_gl()
- return;
