[GRASS-SVN] r72979 - in grass/trunk/vector: v.external v.in.ogr
svn_grass at osgeo.org
Thu Jul 12 05:39:37 PDT 2018
Author: mmetz
Date: 2018-07-12 05:39:37 -0700 (Thu, 12 Jul 2018)
New Revision: 72979
grass/trunk/vector/v.external/dsn.c
grass/trunk/vector/v.external/main.c
grass/trunk/vector/v.in.ogr/main.c
v.in.ogr/v.external: OGR dsn and GRASS db connections are independent of each other
Modified: grass/trunk/vector/v.external/dsn.c
--- grass/trunk/vector/v.external/dsn.c 2018-07-11 08:49:23 UTC (rev 72978)
+++ grass/trunk/vector/v.external/dsn.c 2018-07-12 12:39:37 UTC (rev 72979)
@@ -8,6 +8,12 @@
char *dsn;
+ dsn = G_store(opt_dsn);
+ return dsn;
+ /* OGR dsn and GRASS db connections are independent of each other */
if (G_strncasecmp(opt_dsn, "PG:", 3) == 0) {
/* PostgreSQL/PostGIS */
size_t i;
Modified: grass/trunk/vector/v.external/main.c
--- grass/trunk/vector/v.external/main.c 2018-07-11 08:49:23 UTC (rev 72978)
+++ grass/trunk/vector/v.external/main.c 2018-07-12 12:39:37 UTC (rev 72979)
@@ -102,7 +102,7 @@
dsn = NULL;
if (options.dsn->answer)
- dsn = get_datasource_name(options.dsn->answer, use_ogr);
+ dsn = G_store(options.dsn->answer);
if (flags.list->answer || flags.tlist->answer) {
/* list layers */
Modified: grass/trunk/vector/v.in.ogr/main.c
--- grass/trunk/vector/v.in.ogr/main.c 2018-07-11 08:49:23 UTC (rev 72978)
+++ grass/trunk/vector/v.in.ogr/main.c 2018-07-12 12:39:37 UTC (rev 72979)
@@ -456,7 +456,7 @@
dsn = NULL;
if (param.dsn->answer)
- dsn = get_datasource_name(param.dsn->answer, TRUE);
+ dsn = G_store(param.dsn->answer);
min_area = atof(param.min_area->answer);
snap = atof(param.snap->answer);
