[GRASS-SVN] r72993 - grass/trunk/db/db.execute
svn_grass at osgeo.org
Tue Jul 17 09:26:41 PDT 2018
Author: mmetz
Date: 2018-07-17 09:26:40 -0700 (Tue, 17 Jul 2018)
New Revision: 72993
grass/trunk/db/db.execute/main.c
db.execute: check return code of db_execute_immediate() also for sql option
Modified: grass/trunk/db/db.execute/main.c
--- grass/trunk/db/db.execute/main.c 2018-07-16 12:57:48 UTC (rev 72992)
+++ grass/trunk/db/db.execute/main.c 2018-07-17 16:26:40 UTC (rev 72993)
@@ -80,6 +80,18 @@
/* parms.sql */
db_set_string(&stmt, parms.sql);
ret = db_execute_immediate(driver, &stmt);
+ if (ret != DB_OK) {
+ if (parms.i) { /* ignore SQL errors */
+ G_warning(_("Error while executing: '%s'"),
+ db_get_string(&stmt));
+ error++;
+ else {
+ G_fatal_error(_("Error while executing: '%s'"),
else { /* parms.input */
while (get_stmt(fd, &stmt)) {
