[GRASS-SVN] r73018 - grass/branches/releasebranch_7_4/rpm
svn_grass at osgeo.org
Mon Jul 30 00:15:59 PDT 2018
Author: neteler
Date: 2018-07-30 00:15:59 -0700 (Mon, 30 Jul 2018)
New Revision: 73018
grass/branches/releasebranch_7_4/rpm/grass.spec
Fedora RPM SPEC: fix wxGTK-devel and cairo-devel dependencies; Python macro; explicitely add gcc-c++ BuildRequires (sync to Fedora koji system)
Modified: grass/branches/releasebranch_7_4/rpm/grass.spec
--- grass/branches/releasebranch_7_4/rpm/grass.spec 2018-07-30 07:15:31 UTC (rev 73017)
+++ grass/branches/releasebranch_7_4/rpm/grass.spec 2018-07-30 07:15:59 UTC (rev 73018)
@@ -3,7 +3,7 @@
Version: 7.4.1
-Release: 2%{?dist}
+Release: 6%{?dist}
Summary: GRASS GIS - Geographic Resources Analysis Support System
%if 0%{?rhel}
@@ -16,6 +16,8 @@
BuildRequires: bison
BuildRequires: blas-devel
+BuildRequires: cairo-devel
+BuildRequires: gcc-c++
BuildRequires: desktop-file-utils
BuildRequires: fftw-devel
BuildRequires: flex
@@ -45,6 +47,7 @@
%if (0%{?rhel} > 6 || 0%{?fedora})
BuildRequires: netcdf-devel
%endif
+BuildRequires: python < 3.0
BuildRequires: python2-numpy
BuildRequires: postgresql-devel
@@ -80,12 +83,12 @@
BuildRequires: sqlite-devel
BuildRequires: subversion
BuildRequires: unixODBC-devel
-BuildRequires: wxGTK-devel
BuildRequires: zlib-devel
Requires: geos
Requires: proj-epsg
Requires: proj-nad
+Requires: python2
%if 0%{?rhel}
Requires: wxPython
@@ -140,7 +143,9 @@
sed -i -e 's/--libmysqld-libs/--libs/g' configure
# Fixup shebangs
-find -type f | xargs sed -i -e 's,#!/usr/bin/env python,#!%{__python},'
+# in future python3 will be supported
+find -type f | xargs sed -i -e 's,#!/usr/bin/env python,#!%{__python2},'
+sed -i -e 's,python,%{__python2},g' include/Make/Platform.make.in
find -name \*.pl | xargs sed -i -e 's,#!/usr/bin/env perl,#!%{__perl},'
%build
@@ -147,6 +152,8 @@
# Package is not ready for -Werror=format-security or the C++11 standard
CFLAGS="$(echo ${RPM_OPT_FLAGS} | sed -e 's/ -Werror=format-security//')"
CXXFLAGS="-std=c++98 ${CFLAGS}"
+# enforce python2 during build process
+export GRASS_PYTHON="/usr/bin/python2"
%configure \
--with-cxx \
--with-tiff \
@@ -333,6 +340,18 @@
%{_libdir}/%{name}%{shortver}/include
%changelog
+* Sun Jul 29 2018 Markus Neteler <neteler at mundialis.de> - 7.4.1-6
+- added BuildRequires gcc-c++ to address RHBZ #1604262 due to RHBZ #1551327 (removing gcc and gcc-c++ from default buildroot)
+* Fri Jul 13 2018 Fedora Release Engineering <releng at fedoraproject.org> - 7.4.1-5
+- Rebuilt for https://fedoraproject.org/wiki/Fedora_29_Mass_Rebuild
+* Sun Jul 08 2018 Markus Neteler <neteler at mundialis.de> - 7.4.1-4
+- fix Python macro to explicitely use Python 2 interpreter
+* Sat Jul 07 2018 Scott Talbert <swt at techie.net> - 7.4.1-3
+- Update BRs: remove wxGTK-devel and add cairo-devel
* Sat Jun 23 2018 Markus Neteler <neteler at mundialis.de> - 7.4.1-2
- fix wxPython package dependency name for CentOS7
